Jamo HYG Bluetooth Speakers Debut Ahead of High End Vienna 2026 With Scandinavian Comfort at the Core
Jamo’s HYG Bluetooth speakers bring Scandinavian design, Auracast, LC3 support, and pricing from $129, but no Wi-Fi or app control.
Jamo HYG portable Bluetooth Speakers
Jamo isn’t easing back into the market. It’s making noise on multiple fronts ahead of High-End Vienna 2026. After being dropped by Voxx International in 2024 and re-emerging under Cinemaster and Rayleigh Lab, the Danish brand has already returned with the Concert Legacy and Concert Element speaker lines for mid to high-end two-channel and home theater buyers. Now it is moving into a far more crowded Bluetooth speaker category with the new HYG series.
Positioned as a premium lifestyle range built around the Danish concept of hygge, which focuses on comfort, warmth, and connection, the HYG lineup includes three models: Flex, Reflect, and Flow. Each is designed for a different use case, including indoor listening, outdoor spaces, and portable playback. Jamo is not just trying to revive its legacy. It is trying to prove it still belongs in the conversation.
HYG Flex
jamo-hyg-flex-white-black
The HYG Flex sits at the top of Jamo’s new Bluetooth speaker lineup. It is aimed at listeners who want bigger sound from a portable speaker that still looks like it belongs in a living room, terrace, or outdoor space instead of a dorm-room crime scene.
The cylindrical cabinet is wrapped in soft fabric and designed for easy placement around the home. Inside, dual angled tweeters and a dedicated 5-inch woofer are intended to deliver wider dispersion, stronger bass, and greater scale than the smaller HYG models. Auracast support allows compatible Jamo speakers to connect for multi-speaker playback or stereo pairing, while the built-in ambient base light adds a softer visual touch for evening listening.
HYG Reflect
jamo-hyg-reflect-speaker
The HYG Reflect is Jamo’s bedside-focused Bluetooth speaker, designed for listeners who want music, light, and utility in one compact package. The built-in clock makes its intended location rather obvious, and the design leans into calm rather than flashing lights and “party mode” nonsense.
Reflect combines warm ambient lighting, wireless charging, and room-aware audio tuning that adjusts playback based on where the speaker is placed relative to the listener. It is the most lifestyle-focused model in the HYG lineup, built for bedrooms, nightstands, and smaller spaces where a speaker needs to sound good without looking like it escaped from a gaming desk.
The HYG Reflect also includes built-in ambient soundscapes inspired by Scandinavian nature, giving it a relaxation angle beyond basic Bluetooth playback. That makes sense for a bedside speaker, where blasting Slayer at 6:45 a.m. is technically possible but probably not the brand promise.
Two passive radiators and multi-stage tuning are designed to give the Reflect stronger low-frequency output than its compact size might suggest, while the integrated alarm and sleep timer keep the setup simple. The HYG Reflect is not a typical clock radio. It is Jamo’s attempt to make the bedside speaker feel more useful, calmer, and a lot less disposable.
HYG Flow
HYG Flow is designed primarily for outdoor spaces and road trips. Compact, portable, and IPX7 waterproof-rated, the HYG Flow combines Scandinavian-inspired aesthetics with durable materials and extended battery life. The HYG Flow is designed around portability and simplicity, with a braided handle and nano-coated water-resistant fabric.
Inside, the HYG Flow uses dual full-range drivers and two passive radiators to deliver balanced stereo sound from a compact portable design. Jamo has tuned it for vocal clarity and longer listening sessions, making it a strong fit for audiobooks, podcasts, radio, and background music that does not punish your ears after 30 minutes.
With up to 27 hours of battery life, Bluetooth 6.0, and Auracast support, the Flow is the most portable member of the HYG lineup and one of the more feature-complete options in Jamo’s new lifestyle range.
JAMO HYG Comparison
HYG FlexHYG ReflectHYG Flow
Product Type Premium Bluetooth speaker Bluetooth Clock speaker Portable Waterproof Bluetooth speaker
Price$279$149$129
Configuation2-way vented boxNot IndicatedNot Indicated
Drivers2 x 1’’ (25 mm) Tweeter
1 x 5″ (127 mm) Woofer
2 x 2’’ (51 mm) Full-range driver
2 x Passive radiator
2 x 1.5’’ (38 mm) Full-range driver
Frequency Response (-6 dB) 46 Hz – 20 kHz 82 Hz – 20 kHz 66 Hz – 20 kHz
Crossover Frequency 2.5 kHz N/AN/A
Max SPL 96 dB SPL @ 1m Not Indicated90 dB SPL @ 1m
Amplification Power (AC Mode) Total 56 W RMS
Tweeter 2 x 8 W RMS
Woofer 1 x 40 W RMS
2 x 10W RMS
2 x 20W Peak
2 x 5W RMS
2 x 10W Peak
Amplification Power (Battery Mode) Total 28 W RMS
Tweeter 2 x 4 W RMS
Woofer 1 x 20 W RMS
2 x 10W RMS
2 x 20W Peak
2 x 5W RMS
2 x 10W Peak
Inputs Bluetooth, AUX-in Bluetooth, AUX-In 3.5 mm jack Bluetooth
Wireless Streaming Feature Bluetooth 6.0 Bluetooth 6.0 Bluetooth 6.0
Bluetooth Codec SBC, AAC, LC3 SBC, AAC SBC, AAC, LC3
Auracast YesNot IndicatedYes
Ambient Soundscapes TracksNot IndicatedAmbient soundscapes tracks (x3)
Golden Hour
Daybreak
Moonlight Echo
Not Indicated
Power Supply 100-240V AC 100-240V AC adapter Not Indicated
Maximum Music Playtime (Battery) 15 hours Not Indicated27 hours
Charging Time (AC port)3 hours Not Indicated3 hours
Battery 7.4V 2600 mAh Not Indicated7.4V 2600 mAh
Battery TypeNot IndicatedBackup battery for clock (RTC Battery) Not Indicated
Charging Output (USB-C) 10 W maximum (5 V / 2 A) Wireless charging pad: maximum 15W
USB-C charging port: maximum 5V 2A
USB-C
Clock FeatureNoAlarm – sleep timer – snooze feature – 12/24h mode No
Ambient Light Selectable brightness levels Selectable brightness levels Not Indicated
IP Rating IPX2 Not ApplicableIPX7
Security Not IndicatedBluetooth naming setting (local rename)
Safety lock
Not Indicated
Product Dimensions (HWD)249.1 x 250.2 x 193 mm
9.8″ x 9.9″ x 7.6″(excluding handle)
76 x 199 x 105 mm
3’’ x 7.8’’ x 4.1’’
141.5 x 182.9 x 41.8 mm
5.57” x 7.20” x 1.65” (including handle)
Net Product Weight 3.3 kg / 7.28 lbs 0.78 kg / 1.72 lbs 0.6 kg / 1.32 lbs
Weight (Packaging Included) 4.1 kg / 9.04 lbs 1.4 kg / 3.09 lbs 0.9 kg / 1.98 lbs
Available Colors Dark Grey
Light Grey
Dark Grey
Light Grey
Dark Grey
Light Grey
Sand Dune
Summer Bloom
Red Oxide
Sage Green
Jamo HYG Flow portable Bluetooth Speaker Dark Grey Outdoors
Jamo HYG Flow
The Bottom Line
Jamo’s HYG line is less about one Bluetooth speaker in three sizes and more about three lifestyle products with different jobs. Flex is the larger portable option for room-filling sound, Reflect is the bedside model with a clock, ambient lighting, wireless charging, alarm, sleep timer, and relaxation soundscapes, while Flow is the grab-and-go speaker with up to 27 hours of playback. That gives the lineup a clearer identity than the usual “small, medium, large” Bluetooth speaker playbook.
The missing pieces matter. There is no Wi-Fi, no app control, and no listed support for LDAC or aptX Lossless, which limits flexibility versus Sonos, JBL, Bose, and other established players. But with pricing from $129 to $279, the HYG series is aimed at listeners who want simple Bluetooth speakers with Scandinavian design, Auracast on select models, and easy placement around the home, garden, bedroom, or bag. Sonos does not need to panic. But Jamo has at least found a sensible way back into the conversation.
Price & Availability
The Jamo HYG Series Bluetooth Speakers will be available globally starting July 2026 through Authorized Dealers at the following prices:
Pro Tip: The Jamo HYG series will be previewed at High End Vienna from June 4 – 7, 2026
2026 CMF Speaker S and M by Nothing
CMF’s first Bluetooth speakers combine Nothing-style design with Auracast, USB-C audio, IP68 protection and prices starting at just $59.
2026 Horizon 30 Pro Lifestyle Projector in living room 2026 Horizon 30 Pro Lifestyle Projector in living room
XGIMI’s new HORIZON 30 projectors combine brighter RGB triple-laser light engines, improved contrast and 4K/120Hz gaming in a flexible lifestyle design.
2026 Fosi Audio DAP Neo in pocket 2026 Fosi Audio DAP Neo in pocket
DAPs
The $80 Fosi Audio DAP Neo delivers iPod nostalgia, lossless playback, Bluetooth and expandable storage. Can it win over the streaming generation?
2026 JMGO Iris Ultra Projectors 2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
WiiM Bar debuts at High End Vienna 2026 with Dolby Atmos, DTS:X, RoomFit, HDMI eARC, and expandable 3.0.2 surround from $479.
Hisense takes on JBL, Sony, Marshall, LG and TCL with four new Bluetooth and party speakers led by the $399.99 Party Thunder Pro.
Klipsch Odyssey Limited Edition Bluetooth Speaker pairs premium portable audio with a sword-inspired design for Christopher Nolan’s The Odyssey. Limited to 2,500 pieces.
We give Dynaudio's new Opus One all-in-1 soundbar solution a look (and a listen) at its debut at High End 2026.
Trinnov, dCS, and Perlisten delivered a massive 15.8.8 immersive audio demo at HIGH END Vienna 2026, showcasing the music of Justin Gray, who was...
The 11 High End Vienna 2026 products we most want to review, from Ruark and Cambridge to Meze, Eversolo, Questyle, and Klipsch.
Clearaudio N2 MM cartridge uses a carbon fibre PETG body, 8.5g weight and $290 price to challenge Audio-Technica, Grado, Ortofon and Sumiko.
