Jamo Concert Series Returns: Concert Legacy and Concert Element Speakers Premiere at High End Vienna 2026
Priced from $1,099 to $7,999 per pair, Jamo Concert Legacy and Element Series Loudspeakers preview August 2026 launch.
2026 Jamo Concert Legacy 11 Loudspeakers Heritage Finish Lifestyle
Jamo’s 2026 comeback now has real products attached to the promise. Following its relaunch under Cinemaster and Rayleigh Lab, the Danish loudspeaker brand is introducing two new speaker families, Concert Legacy and Concert Element, both scheduled to arrive in August 2026 and both set to make their public premiere at High End Vienna 2026, running June 4 through June 7.
That matters because Jamo’s return was never going to survive on heritage alone. The brand still carries weight with listeners who remember when Scandinavian hi-fi meant clean design, practical engineering, and speakers that didn’t require a home equity conversation. But the market in 2026 is crowded, especially with DALI, KEF, Q Acoustics, Wharfedale, and others already fighting for the same living rooms. Concert Legacy and Concert Element are Jamo’s first real test: can the brand turn a familiar name into something relevant again, or is this just another comeback wearing nice Danish shoes?
Who Is Jamo Today? Danish Roots, New Global Muscle
Before we get to Concert Legacy and Concert Element, it is worth remembering that Jamo in 2026 is not simply being dragged out of the attic, dusted off, and told to look Scandinavian for the cameras. The revived brand is now being shaped by a team that combines Danish design heritage, European creative direction, and serious engineering and production resources from Asia.
Xiaodong Yang, CEO of Cinemaster, is central to the relaunch and brings prior experience with Jamo, which matters. This comeback needs someone who understands why the name still means something, not just someone hunting for an old badge with resale value. On the engineering and production side, Rayleigh Lab founder and CEO Thomas Li brings Shenzhen based development and manufacturing expertise, while the creative and design effort includes Kim Michel, Simon Matthews, Jamie Cobb, and Danish design agency HarritSorensen, founded by Thomas Harrit and Nicolai Sørensen.
That is the new Jamo equation: Danish DNA, global execution, and a brand trying to prove it can be relevant again without turning into another nostalgia act with nicer veneer. Heritage gets people to look. The speakers have to make them stay.
Jamo Concert Legacy Series
Concert Legacy is Jamo’s premium passive loudspeaker range for 2026, and the name is not accidental. This is the line designed to reconnect the revived Danish brand with one of its most respected chapters, the original Concert 8 and Concert 11 loudspeakers introduced in 1996.
The guiding idea is straightforward: what would the original Concert Series look and sound like today if Jamo had kept developing it for the past 30 years? That is a much better starting point than the usual “let’s slap an old badge on a new box and hope nobody asks questions” routine. Concert Legacy is not being pitched as a retro copy. It is Jamo trying to move the original concept forward with modern parts, updated acoustic engineering, and a stronger Scandinavian supply chain.
That Scandinavian angle matters here. Concert Legacy is made in Denmark, with drivers developed in partnership with ScanSpeak in Denmark and SEAS in Norway. Jamo also says the woofer materials use Finnish wood fibre, giving the range a genuinely Nordic engineering story rather than just a pale cabinet finish and some moody lifestyle photography.
The range also introduces some meaningful acoustic choices. Jamo DualCore architecture physically separates the midrange and bass chambers, which is designed to preserve midrange clarity as low frequency output increases. The speakers also use down firing bass loading, allowing for more flexible placement while keeping the cabinet design clean. In normal English: Jamo is trying to deliver bass that does not hijack the midrange and turn your living room into a badly supervised nightclub.
At the top of the range is the Jamo Concert Legacy 11, the flagship floorstanding model for listeners who want the most complete expression of the new series. The Concert Legacy 9 offers a more compact floorstanding option, while the Concert Legacy 8 brings the same design language and acoustic goals to a standmount format.
Pricing is per pair for all three Concert Legacy models. The Jamo Concert Legacy 11 will be available in Onyx, Heritage, and Northern Frost finishes for $7,999 per pair in the U.S. and €8,999 including tax in Europe. The Concert Legacy 9 is priced at $5,299 per pair and €5,499 including tax, while the Concert Legacy 8 comes in at $2,999 per pair and €3,299 including tax. All of the models are available in the aforementioned finishes.
2026 Jamo Concert Legacy 11 Loudspeakers Onyx Finish No Grille
The Concert Legacy 11 is the flagship floorstanding model in the new Concert Legacy range and the most technically ambitious speaker in the family. It uses a 3-way bass reflex design with three 165 mm Scan Speak woofers, a 165 mm SEAS aluminium and magnesium midrange driver, and a 25 mm Scan Speak soft dome tweeter. Jamo’s DualCore cabinet construction isolates the midrange and tweeter section from bass pressure using a sealed upper chamber and a 75 Shore A rubber decoupling layer. With 94 dB sensitivity, a 4 ohm impedance, and a rated frequency response of 32 Hz to 21 kHz, this is the model aimed at listeners who want the full scale version of Jamo’s new Danish built Concert Legacy platform.
Specifications:
  • Type: Floorstanding passive loudspeaker, 3-way bass reflex
  • Made in: Denmark
  • Drivers: 3 x 165 mm Scan Speak woofers, 1 x 165 mm SEAS midrange, 1 x 25 mm Scan Speak tweeter
  • Woofer material: Wood fibre cone material from Finland
  • Midrange material: Aluminium and magnesium cone with copper accented phase plug
  • Frequency response: 32 Hz to 21 kHz
  • Low frequency cut off: 26 Hz
  • Crossover points: 250 Hz and 3 kHz
  • Sensitivity: 94 dB
  • Impedance: 4 ohms
  • Recommended amplifier power: 50 to 250 W
  • Inputs: Bi-wiring terminals
  • Dimensions: 47.5 x 12.1 x 18.9 inches
  • Weight: 88.2 lbs per speaker
  • Included accessories: Magnetic grilles, adjustable rubber feet, terminal jumpers
  • Finishes: Heritage, Northern Frost, Onyx
Jamo Concert Legacy 9
jamo-concert-legacy-9-black
The Concert Legacy 9 is the smaller floorstanding option and keeps much of the same design language and engineering approach as the Legacy 11. It uses a 3-way bass reflex configuration with two 165 mm Scan Speak woofers, a 165 mm SEAS aluminium and magnesium midrange driver, and a 25 mm Scan Speak soft dome tweeter. It also includes the DualCore enclosure, down firing port with aluminium plinth, bi-wiring terminals, and the same Heritage, Northern Frost, and Onyx finish options. Its 92 dB sensitivity and 33 Hz to 21 kHz frequency response make it the more room friendly floorstander without turning it into the “we made it smaller and hoped nobody would notice” version.
Specifications:
  • Made in: Denmark
  • Drivers: 2 x 165 mm Scan Speak woofers, 1 x 165 mm SEAS midrange, 1 x 25 mm Scan Speak tweeter
  • Frequency response: 33 Hz to 21 kHz
  • Low frequency cut off: 27 Hz
  • Sensitivity: 92 dB
  • Impedance: 4 ohms
  • Recommended amplifier power: 40 to 200 W
  • Dimensions: 39.6 x 12.1 x 18.9 inches
  • Weight: 79.4 lbs per speaker
Jamo Concert Legacy 8
jamo-concert-legacy-8-nothern-light
The Concert Legacy 8 brings the Concert Legacy concept into a standmount speaker. It is a 2-way bass reflex design using a 165 mm SEAS aluminium and magnesium midwoofer and a 25 mm Scan Speak soft dome tweeter. The cabinet features real oak veneer, a 40 mm front baffle, bead blasted aluminium trim, bi-wiring terminals, and a down firing port in the plinth to reduce rear wall placement sensitivity. It is the smallest and most affordable model in the Legacy lineup, but it still uses Danish assembly and Scandinavian driver sourcing.
Specifications:
  • Type: Bookshelf passive loudspeaker, 2-way bass reflex
  • Made in: Denmark
  • Drivers: 1 x 165 mm SEAS midwoofer, 1 x 25 mm Scan Speak tweeter
  • Midwoofer material: Aluminium and magnesium cone with copper accented phase plug
  • Frequency response: 34 Hz to 21 kHz
  • Low frequency cut off: 28 Hz
  • Crossover point: 3 kHz
  • Sensitivity: 87 dB
  • Impedance: 4 ohms
  • Dimensions: 14.4 x 9.9 x 14.6 inches
  • Weight: 26.5 lbs per speaker
  • Included accessories: Magnetic grilles, terminal jumpers
Jamo Concert Element Series
Concert Element is the more design driven half of Jamo’s 2026 Concert Series, developed with Copenhagen based HarritSørensen and built around the range’s “circle over rectangle” visual language. The circular driver module extends beyond the shallow cabinet, making the driver both the acoustic focus and the main design element. It is a cleaner, more domestic approach than the Concert Legacy range, but still uses passive loudspeaker architecture, bespoke drivers, and down firing ports across the speaker models.
The Element speakers were developed with SB Acoustics and use drivers tuned to their specific cabinet volumes. The range includes the Concert Element 50 bookshelf speaker, Concert Element 70 compact floorstander, Concert Element 90 larger floorstander, and the matching Concert Element SW10 subwoofer. Finishes are Onyx and Northern Frost, with magnetic grilles included in dark grey and light grey.
Jamo Concert Element 90
jamo-concert-element-90-70
Jamo Concert Element 90 (left) and 70 (right)
The Concert Element 90 is the largest passive speaker in the Element range and uses a 3-way bass reflex design. It combines a 250 mm woofer, a 165 mm midrange driver, and a 25 mm soft dome tweeter. Both the woofer and midrange use Scandinavian nettle fibre cones, and the midrange includes a Jamo phase plug. The cabinet uses a dual chamber layout, with a ported woofer section and sealed midrange chamber, which is intended to keep bass output from affecting the midrange. The down firing port is designed to make placement less dependent on rear wall distance.
Specifications:
  • Type: floorstanding passive speaker, 3-way bass reflex
  • Drivers: 1 x 250 mm woofer, 1 x 165 mm midrange, 1 x 25 mm tweeter
  • Woofer material: Scandinavian nettle fibre cone with 4 layer voice coil
  • Midrange material: Scandinavian nettle fibre cone with Jamo phase plug
  • Tweeter: 25 mm soft positive dome
  • Bandwidth: 35 Hz to 22 kHz, plus or minus 3 dB
  • Low frequency cut off: 30 Hz at minus 6 dB
  • Impedance: 4 ohms
  • Recommended amplifier power: 60 to 250 W
  • Dimensions: 43.8 x 12.6 x 14 inches
  • Weight: 73.2 lbs per speaker
  • Included accessories: Magnetic grilles in dark grey and light grey, adjustable rubber feet, terminal jumpers
  • Finishes: Onyx, Northern Frost
Jamo Concert Element 70
The Concert Element 70 is the smaller floorstanding speaker in the range. It uses a 3-way bass reflex design with a 200 mm woofer, 130 mm midrange driver, and 25 mm soft dome tweeter. Like the larger Element 90, the woofer and midrange use Scandinavian nettle fibre cones, while the midrange also includes a Jamo phase plug. The shallow cabinet keeps the footprint relatively compact, while the down firing port is intended to support more flexible placement in typical rooms.
Specifications:
  • Type: Compact floorstanding passive speaker, 3-way bass reflex
  • Drivers: 1 x 200 mm woofer, 1 x 130 mm midrange, 1 x 25 mm tweeter
  • Bandwidth: 40 Hz to 22 kHz, plus or minus 3 dB
  • Low frequency cut off: 35 Hz at minus 6 dB
  • Impedance: 4 ohms
  • Recommended amplifier power: 50 to 200 W
  • Inputs: Bi wiring terminals
  • Dimensions: 40 x 10.8 x 12 inches
  • Weight: 41.4 lbs per speaker
Jamo Concert Element 50
jamo-concert-element-50
The Concert Element 50 is the bookshelf model and the most compact passive speaker in the Element family. Jamo describes it as a true bookshelf speaker rather than a standmount speaker, with a shallow cabinet designed to fit on actual shelves. It uses a 2-way bass reflex design with a 165 mm woofer and a 25 mm soft dome tweeter. The woofer uses a Scandinavian nettle fibre cone, 4 layer voice coil, and Jamo phase plug. The down firing port is intended to reduce placement issues when the speaker is used closer to walls or furniture.
Specifications:
  • Type: bookshelf passive speaker, 2-way bass reflex
  • Drivers: 1 x 165 mm woofer, 1 x 25 mm tweeter
  • Woofer material: Scandinavian nettle fibre cone with 4 layer voice coil and Jamo phase plug
  • Bandwidth: 45 Hz to 22 kHz, plus or minus 3 dB
  • Low frequency cut off: 40 Hz at minus 6 dB
  • Sensitivity: 89.5 dB
  • Impedance: 4 ohms
  • Recommended amplifier power: 40 to 150 W
  • Inputs: Single wiring terminals
  • Dimensions: 14.9 x 12.5 x 10.6 inches
  • Weight: 18.3 lbs per speaker
  • Included accessories: Magnetic grilles in dark grey and light grey, rubber pads
Jamo Concert Element SW10
jamo-concert-element-sw10
The Concert Element SW10 is the matching subwoofer for the Element range. It uses a sealed enclosure, a 250 mm long throw woofer, and Class D amplification rated at 150 W RMS and 300 W maximum. It includes a variable low pass filter from 40 Hz to 140 Hz, continuously adjustable phase from 0 to 180 degrees, and a fixed EQ boost option at 55 Hz. Inputs include dual RCA and LFE line in, with Auto and On operating modes. One important note: the product sheet lists the SW10 as an active bass reflex subwoofer in the technical specifications, while the feature section describes it as a sealed enclosure. That needs clarification from Jamo.
Specifications:
  • Type: subwoofer, active bass reflex
  • Driver: 1 x 250 mm long throw woofer
  • Voice coil: 4 layer voice coil
  • Bandwidth: 30 Hz to 250 Hz, plus or minus 3 dB
  • Low frequency cut off: 20 Hz at minus 6 dB
  • Adjustable low pass: 40 Hz to 140 Hz
  • Adjustable phase: Progressive 0 to 180 degrees
  • Adjustable EQ: 0 to plus 6 dB fixed at 55 Hz
  • Inputs: Dual RCA and LFE line in
  • Mode: Auto or On
  • Amplifier power: 150 W rated, 300 W maximum, Class D
  • Power supply: AC 100 to 120 V at 60 Hz, 220 to 240 V at 50 Hz
  • Standby power consumption: Less than 0.5 W
  • Dimensions: 14.2 x 14.4 x 11.6 inches
  • Weight: 26 lbs
  • Included accessories: Magnetic grilles in dark grey and light grey, power cord, rubber pads
The Bottom Line
Jamo’s revived Concert Series looks like a real two lane comeback. Concert Legacy is the more traditional hi-fi play, with Danish assembly, Scan Speak and SEAS drivers, premium passive designs, and pricing aimed at listeners who still care about two-channel performance first. Concert Element is the more design-forward range, with HarritSørensen styling, shallow cabinets, SB Acoustics drivers, and pricing that should make Jamo visible again in real living rooms.
What is missing? No center channel speaker, no dedicated surround channels, and no subwoofer for the Concert Legacy lineup. The Element range does get the SW10 subwoofer, but Jamo still needs to clarify its enclosure description. On paper, this is a smarter return than another badge revival with nice veneer and better lighting. Legacy is for traditional hi-fi buyers. Element is for modern homes, apartments, and music fans who want proper speakers that do not visually mug the furniture.
Pricing & Availability
The new Jamo speaker line-up is expected to start shipping in August 2026.
SeriesModelColorU.S. MSRP
Concert LegacyJamo Concert Legacy 11Onyx, Heritage, Northern Frost$7,999/pair
Jamo Concert Legacy 9Onyx, Heritage, Northern Frost$5,299/pair
Jamo Concert Legacy 8Onyx, Heritage, Northern Frost$2,999/pair
Concert ElementJamo Concert Element 90Onyx, Northern Frost$2,499/pair
Jamo Concert Element 70Onyx, Northern Frost$1,899/pair
Jamo Concert Element 50Onyx, Northern Frost$1,099/pair
Jamo Concert Element SW10Onyx, Northern Frost$699 each
2026 Steinway & Sons Model O Loudspeaker near wall lifestyle
Magico rebuilds the A3 with M9-derived engineering, new drivers and a new cabinet. The other upgrade? Entry-level Magico now costs $25,000.
WiiM Bar debuts at High End Vienna 2026 with Dolby Atmos, DTS:X, RoomFit, HDMI eARC, and expandable 3.0.2 surround from $479.
Can the Atlantis Lab AT-23 Pro deliver deep bass and room-filling dynamics without a subwoofer? Our review explains why it deserves attention.
Focal’s $50,000 Scala Utopia Evo M loudspeakers add a PRISM tweeter, M-profile midrange, and redesigned bass system to its iconic French floorstander.
We give Dynaudio's new Opus One all-in-1 soundbar solution a look (and a listen) at its debut at High End 2026.
Trinnov, dCS, and Perlisten delivered a massive 15.8.8 immersive audio demo at HIGH END Vienna 2026, showcasing the music of Justin Gray, who was...
The 11 High End Vienna 2026 products we most want to review, from Ruark and Cambridge to Meze, Eversolo, Questyle, and Klipsch.
