Best Budget Bluetooth Speakers Under $150: Editors’ Choice 2026
We tested dozens of budget Bluetooth speakers to find the best. Our top picks deliver big sound, waterproof durability, long battery life, and real value from JBL, Sony, Beats, Tribit, and more.
Bluetooth speakers have improved at a breakneck pace in recent years, with features like rugged weatherproofing, stereo pairing, longer battery life, and high-resolution wireless audio moving from premium luxuries to standard expectations. The best part? You no longer need to spend big to get them. Today’s best budget Bluetooth speakers deliver many of the same practical upgrades found in the best Bluetooth speakers you can buy, making great sound, durability, and everyday convenience far more affordable than they used to be.
That doesn’t mean all speakers are created equal, of course. As usual, sound quality is the great divider. What’s the point of saving big on a feature-packed speaker if you never want to listen to it? That’s why I tested every model for our Best Budget Bluetooth speakers list so vigorously, including long-term listening across dozens of models, to ensure the right pick for any scenario or environment. Wherever you go and whatever you’re into, you’ll find the right speaker at the right price below, without sacrificing features or performance.
Best Budget Portable Bluetooth Speakers of 2026
Best Overall: JBL Flip 7 ($150)
jbl-flip-7-portable-bluetooth-speaker
JBL’s Flip speaker series has long offered one of the best blends of sound quality, features, value, and sheer indestructibility you can buy, and the Flip 7 is another upgrade to the formula. At just over seven inches wide, it’s supremely portable, yet its 3-inch by 1.75-inch racetrack driver and 0.6-inch tweeter combine with efficient passive radiators on the sides for clear, punchy, and well-balanced sound across the frequency range. JBL has made subtle but effective refinements with each generation, resulting in better instrumental detail and improved clarity on the attack, with minimal distortion, especially with rock and pop.
The Flip 7 doesn’t mess around when it comes to features, offering stereo pairing with a second Flip 7, a companion app for EQ and other settings, up to 14 hours of battery life, or 16 hours with its bass-reducing Playtime Boost, and a drop-resistant design that I’ve thoroughly tested both on purpose and by accident. Upgraded IP67 weatherproofing keeps out dust and water, allowing for a quick dunk with no ill effects, while a quick-release strap and included carabiner provide versatile playback options.
Also new for the Flip 7 is Auracast, which allows it to sync with other Auracast devices and as many of JBL’s latest speakers, like the Charge 6 and Clip 5, as you can handle, though it no longer supports JBL’s Party Mode for connecting with older models. That point aside, the Flip 7’s slick mix of performance, usability, and a price that often falls to $100 or less makes it an easy choice as my favorite budget speaker around.
$149.95 $99.99 at Amazon | Best Buy | Crutchfield
Best Bang for Your Buck: Tribit Stormbox 2 ($80)
tribit-stormbox-2-black
Tribit’s Stormbox 2 is the best-sounding portable speaker I’ve tested for the money. The budget brand, which seemed to come out of nowhere, has shown a knack for punching above its weight with multiple models, and the second coming of its baseline Stormbox stands tall with top tubular contenders like the JBL Flip, Ultimate Ears Boom, and others. You’ll find clean treble and impressive midrange gravitas from its multidirectional soundstage, and tapping the bass key ups the ante for a weighty yet controlled lower register. Apart from its tendency to distort more quickly at peak volume than pricier models, there are few reasons to pay more.
The Stormbox 2’s design borrows from the best, including a familiar tubular frame capped by dual passive radiators, grippy acoustic wrapping, and oversized playback keys for simplified control. The Tribit app provides convenient EQ and other controls, while battery life of up to 24 hours bests most speakers in its class. The speaker’s IPX7 weatherproof rating means it has no stated dust protection, so it’s not the best option for the beach, and its build quality feels a little cheap. Otherwise, it’s hard to find much to complain about in a speaker that sounds this good for $80 or less.
$79.99 at Amazon | Tribit
Best Micro Speaker: Sony SRS-XB100 ($65)
sony-srs-xb100-black-outside
Sony’s mighty mini SRS-XB100 is among the most affordable and compact speakers in my Bluetooth arsenal, and I couldn’t imagine living without it. Smaller than a soda can and weighing just over half a pound, the XB100 sounds much bigger than its size suggests. The secret is in Sony’s efficient design, which includes a wide-dispersion driver up top that delivers balanced midrange and treble to fill out small rooms, along with a base-mounted passive radiator to help distribute decent upper bass from surfaces like tables and countertops.
The XB100 has a handy spread of features, including a built-in microphone for calls, IP67 dust and water resistance, one-touch Android connection, and stereo pairing with a second model. But the main reason I keep coming back to this speaker is its packability-to-performance ratio. From Honolulu to the Oregon Caves, I’ve taken this speaker everywhere, even using it on a recent family trip to San Diego as both our hotel soundtrack and the baby’s white noise machine. If you’re after a satisfying mini speaker that goes wherever you do, the XB100 delivers.
$64.99 $43 at Amazon | Best Buy
Best Super Cheap Speaker: JLab Go Party ($50)
jlab-go-party-lights-on
JLab’s Go Party doesn’t sound amazing. Its topside light show reminds me of a rainbow version of Kmart’s blue light specials, and its ribbon-like handle feels decidedly budget. So why is this speaker on our list? Because its list price of less than a large pizza at my favorite takeout place makes it an insane deal for everything you’re getting.
While the audio can be inconsistent and fuzzy, choosing EQ3 in the JLab app provides solid balance and punch that’s particularly suited for pop and rock. The app makes it easy to shut down the lights, which extends battery life for up to 16 hours of playtime. Features like audio syncing with other JLab speakers and solid IP56 dust and water resistance help make up for the fact that there’s no charger in the box, and the handy volume dial up top is easier to use than any other speaker on our list. This is a budget model in every sense, but at $35 or less, it’s hardly a dent in your weekly budget.
$49.99 $34.34 at Amazon | Best Buy
Best Clip-on Speaker: JBL Clip 5 ($80)
jbl-clip-5-black
I used to think most shower speakers were essentially the same, but the Clip 5 bests every budget hanger I’ve tried, including previous Clip models. With uncommonly full bass matched by a warm and detailed upper register, this speaker rises above bathtime fun to provide a solid soundtrack for hotel rooms, camping outings, and other adventures. Its treble could use more sparkle, but you’re still getting plenty of instrumental detail and depth, and when you lay it flat, a diffused rubber backside offers enhanced bass response without table rumble. Its slim design, at less than two inches thick, makes it easy to pack, while intuitive rubberized keys on the front and sides make it simple to control on the fly.
The Clip 5’s carabiner clip is sturdier than those on other models I’ve tested, providing a secure way to attach it in multiple scenarios, from your shower caddy to tree branches and backpacks. An IP67 dust and water resistance rating means it’s equally secure in wet or rugged environments, and you’ll get a decent, but not amazing, 12 hours of playback time at midrange volume. JBL’s app offers EQ and other settings, and Auracast connection lets you sync with an infinite number of newer JBL models, like the Flip 7. You can certainly find cheaper clip-ons, but if you want great sound for your hang, literally, this is the top option around.
$79.95 at Amazon | Best Buy | Crutchfield
Best for Bass: Soundcore Boom 2 ($130)
soundcore-boom-2
Soundcore’s Boom 2 mini boombox doesn’t offer the most articulate or cohesive sound for your money, but what it lacks in finesse, it makes up for with sheer gravitas. With up to 80 watts of power pushing a center woofer flanked by dual tweeters, this foot-long speaker gets loud enough to fill a midsize room or ramp up larger outdoor get-togethers. It also pulls more bass from your catalog than any other speaker on our list, especially with its “BassUp 2.0” button engaged, where the sound is at its best. Bass aside, you’ll get solid clarity up top, with surprisingly zippy transient response for rapid-fire percussion and a forward, if sometimes slightly hard-edged, push to midrange instruments like guitar, vocals, and piano.
There are some distinctive design traits here, including an easy-grip handle, a buoyant bottom that keeps the speaker afloat on water, and trendy LED grids on each side, customizable in the app with a rainbow of colors. Like the Tribit Stormbox 2, the Boom 2 offers solid IPX7 water resistance but no stated sand protection. Other features include adjustable EQ, phone charging via its protected USB-C port, an onboard mic for calls, and battery life of up to 24 hours per charge, though that takes a hit when you engage the bass boost and/or light show. This is a fun little budget boombox that isn’t designed for critical listening but provides plenty of power at a nice price, especially on sale.
$129.99 $99.99 at Amazon | Best Buy
Best for iPhone: Beats Pill ($150)
beats-pill-champagne-outdoors
The original Beats Pill never won me over with its muddy, bass-forward sound signature, but following Apple’s acquisition in 2014, the Beats sound has undergone a major transformation while still keeping the hallmarks that made it a hit. That’s utterly evident in the Pill’s second coming, which keeps the brand’s signature brash and vivacious “smile” curve of accentuated treble and bass while providing clear-cut detail and rich instrumental textures for a fun sonic ride. This speaker gets loud, with a low register that rumbles through floors, picnic tables, and other surfaces to spawn mobile dance parties wherever you take it.
While the metallic front screen isn’t as drop-friendly as armored rivals like the Flip 7, as evidenced by the dents I gave it during a ride down the stairs, you’ll get stout IP67 dust and water resistance, features like a built-in speakerphone, high-resolution audio support and device charging over USB-C, and even Find My support with iPhones. Up to 24 hours of battery life keeps you grooving off the grid, and Class 1 Bluetooth provides around 130 feet of range, counted with careful footsteps on my front walk. Without EQ, thanks, Apple, the forward treble is a little overexposed on some tracks, but the Pill’s elegant looks, big sound, and long list of features make it a great buy, especially now that it’s often available for around $100.
$149.95 $99.95 at Amazon | Best Buy
Editiors' Choice Best Budget Portable Bluetooth Speakers of 2026
The Bottom Line
Bluetooth speakers have gotten incredibly good at increasingly lower prices. You no longer need to choose between value, quality, and durability; you can get it all in one model. But you’ll still want to choose from well-reviewed options from established brands that put sound and features first.
Other models we tested and considered for this list include the Sony ULT Field 1, Tribit Stormbox Flow, JBL Flip 6 (and the older Flip 5), Ultimate Ears Boom 4 (and older Boom 3), JLab Pop Party, JBL Go 4, Skullcandy Kilo, and Soundcore 3. We also tested our top picks against pricier options like the UE Megaboom 4, JBL Charge 6, and Bose SoundLink Plus.
If you’re only going to pick one speaker, I always point folks to my favorite all-rounder, the JBL Flip 7, first, but there are plenty of reasons to grab something else on our list. At these prices, it’s even worth considering at least one backup, like the micro-sized Sony SRS-XB100, the shower-friendly Clip 5, or a super-cheap model like the JLab Go Party, to throw in your trunk for adventures. The budget Bluetooth category has never been better, so it’s a great time to save big on sound without sacrificing convenience.
2 Comments
2 Comments
  1. Richard Moss
    August 27, 2026 at 9:42 pm
    Best portable bluetooth speaker in this price category by far, for sound quality, portability and ease of use is hands down the Wonderboom 4, which you should have covered just for the name alone, but the fact that you did not even mention it says all it has to about the value of this review.
    • Ian White
      August 28, 2026 at 1:19 am
      Richard,
      Glad you like the product. Manufacturers were given the opportunity to submit their products for the round-up.
      They did not send.
      Our readership would beg to differ with your assessment of the article as it was one of the most popular articles over the past few months with 30,000+ reads.
      Enjoy your summer.
      IW
Hisense takes on JBL, Sony, Marshall, LG and TCL with four new Bluetooth and party speakers led by the $399.99 Party Thunder Pro.
Gaming Headsets
Sony’s new PlayStation Pulse and Pulse Edge headsets add larger planar magnetic drivers, PlayStation Link, Bluetooth and ANC.
The 2026 CEDIA Expo was held last week in Denver and eCoustics was there in force to check out the latest in home theater...
Are Apple AirPods 5 a better value at $129 and $149? Apple cuts the price of its wireless-charging model by $30 for 2026.
Can open-back headphones work as everyday wireless cans? Audio-Technica’s ATH-AL5NC add LDAC, ANC, wired playback and up to 75 hours of battery life.
Sony just did a major refresh to the top models in their ULT Tower party speaker lineup, blurring the line between "pro" and "party."
Can JBL Cove challenge Sonos, HEOS and Bluesound with Whole Home audio, Dolby Atmos and automatic room tuning?
