Canvas L Audiophile Soundbar Heads to High End Vienna 2026 With BACCH 3D+, GaN Power, and 65 to 115 Inch TV Support
CANVAS L brings BACCH 3D+, GaN power, new drivers, and 1,500 watts of peak power to larger 65 to 115 inch TV systems.
CANVAS L Group Grille Color Options
Danish audio brand Canvas HiFi is bringing a larger and more ambitious version of its award-winning all-in-one wireless speaker and soundbar to High End Vienna 2026 next week. The new CANVAS L builds on the original Canvas, which earned multiple eCoustics Editors’ Choice and Best in Show honors, with more power, additional speaker drivers, expanded connectivity, an improved BACCH 3D+ algorithm, and TV support from 65 inches up to 115 inches.
The original Canvas was one of the strongest all-in-one speaker bar systems we heard in 2025 because it behaved less like a lifestyle soundbar and more like a serious hi-fi system that happened to live under a television. CANVAS L appears to push that concept further: bigger cabinet, bigger screen compatibility, GaN power supply, and a more ambitious acoustic platform. Bigger does not automatically mean better, but Canvas HiFi has already proven that one box can do more damage than most people expect.
CANVAS L cut-away
Bigger Cabinet, More Power, and BACCH 3D+ for Larger TVs
CANVAS HiFi is calling CANVAS L the world’s first audiophile soundbar, although the original Canvas already made a strong case for that description.
The new model uses a cabinet that is 8.4 inches wider, giving CANVAS HiFi room for a revised driver array. That includes a custom-made 3-inch Scan-Speak midrange driver, 8-inch woofers, an SB Acoustics tweeter module, and an additional pair of 8-inch passive radiators.
CANVAS L is more than a larger version of the original model. The drivers have been reworked, and the amplification is new as well: 2 x 300 watts for the woofers, 2 x 200 watts for the midrange drivers, and 2 x 50 watts for the tweeters. Total peak power is rated at 1,500 watts, supported by a highly efficient GaN power supply with substantial power reserves.
canvas-l-features
Ultimately, CANVAS L is not just a larger version of the original Canvas. It is an entirely new speaker system with a slightly revised TV mount and grille design that supports TVs from 65 to 115 inches. The original Canvas supported TVs from 55 to 85 inches, and if you happen to be upgrading, the grilles are not interchangeable.
The TV mount and grille system is designed to create a flush, integrated look with a wide range of TVs. Removable wood or fabric grilles help match the width and finish of the installation, while the optional THE HiFi FRAME L provides a fully enclosed appearance for installations using Samsung The Frame TVs.
With CANVAS L, our ambition was to create far more than a conventional TV audio product. We wanted to deliver a true audiophile experience with the emotional engagement, scale and precision of high-end hi-fi — integrated seamlessly into contemporary interior design,” says Laust Nielsen, CEO of CANVAS HiFi.
canvas-l-testing
CANVAS L
New features in CANVAS L
  • Improved BACCH 3D+ algorithm
  • Coaxial digital input
  • Ethernet/LAN port
  • 2-channel RCA input
  • Control 4 support
  • On/off switch in front
  • Lighter, more versatile TV and Hybrid brackets
  • Fits 65”, 75”, 77”, 83”, and 85” TVs, with optional custom sizes from 98” to 115”
canvas-original
CANVAS (original)
Comparison
CanvasCanvas L
MSRP€3,699
$4,499
€5,999
TBD
AvailabilityNowQ4 2026
TV Compatibility55, 65, 75, 77, 83, 85”65, 75, 77, 83, 85, 98 to 115”
Front Panel (Grilles)13 finish options13 finish options
EnclosureMDF with BridgeBrace TechnologyHighly rigid Compact Density Fiberboard with BridgeBrace+ Technology
Woofer6.5″8″
Passive Radiator5 x 8”8″
Midrange3″
Tweeter29mm29mm
Ampliifers250 wattts1500 watts
Frequency Response28 Hz to 24 kHz25 Hz to 40 kHz
DSPBACCH 3D FilterBACCH 3D+ Filter
Room CorrectionCanvas AppCanvas App
ConnectivityHDMI-ARC/eARC
3.5mm (Analog)
Toslink
HDMI-ARC/eARC
RCA (Analog)
Toslink
Digital Coax
Ethernet
Home AutomationControl 4 (October 2026)Control 4
Dimensions373 x 1226 198 mm373 x 1440 x 198 mm
14.7 x 48.3 x 7.8 inches14.7 x 56.7 x 7.8 inches
Weight26.5 kg (58.4 lbs)24 kg (52.9 lbs)
canvas-exploded
CANVAS (original)
canvas-l-exploded
CANVAS L
The Bottom Line
CANVAS L is not just the original Canvas stretched for larger TVs. The wider cabinet, new driver array, more powerful amplification, GaN power supply, expanded TV support from 65 to 115 inches, and improved BACCH 3D+ processing make this a more ambitious all-in-one speaker system.
What remains unique is the way Canvas uses BACCH 3D technology to create a much larger soundstage from a speaker placed directly under the TV. We heard that effect work convincingly with the original Canvas, and CANVAS L appears designed to push the same concept further with more scale, output, and installation flexibility.
What is missing? We still need to hear it. Power ratings, driver changes, and psychoacoustic processing only matter if the final tuning holds together in a real room. Pricing will also decide whether CANVAS L feels like a serious alternative to a high-end soundbar, a compact hi-fi system, or both.
CANVAS L is for listeners who want a cleaner living room setup without giving up on real stereo scale, serious output, and premium industrial design. It is also for buyers with larger TVs who want something more convincing than a conventional soundbar, but do not want loudspeakers, stands, cables, and the domestic negotiations that usually follow.
canvas-l-frame-front
The HiFi FRAME L with pedestal stand and oak grille.
Pricing & Availability
CANVAS L will have its world premiere on June 4th at High End in Vienna and is expected to be available through authorized CANVAS HiFi retailers in Q4 2026.
Base pricing is expected to be €5,999, which includes front panel, hybrid floor/wall bracket, and universal TV bracket. However, we don’t have final U.S. pricing, which seems like it could be over $10K with customizations. Specific grille covers in fabric or wood finishes can add $500 to $3,000 to the final price, and potentially more for larger widths.
Original CANVAS Introduction
For more information: canvashifi.com
2026 TRIBIT FlyBuds C3 Wireless Earbuds Woman Lifestyle
TRIBIT's $39.99 wireless earbuds come feature packed with noise cancellation, Bluetooth 6.0, multipoint and 5-hour battery life per earbud.
SOUNDBOKS Rider Party Speaker on Bike SOUNDBOKS Rider Party Speaker on Bike
The $599 SOUNDBOKS Rider delivers 118dB, a swappable battery and IP66 protection without requiring a hand truck to move it.
2026 Cayin HA-1A MK3 Tube Headphone Amplifier 2026 Cayin HA-1A MK3 Tube Headphone Amplifier
Cayin's HA-1A MK3 features pure Class A tube amplification with 2.7W output, impedance matching and preamp functionality for $999.
2026 FiiO M25 Veritas and M25-R2R DAPs 2026 FiiO M25 Veritas and M25-R2R DAPs
DAPs
FiiO’s M25 VERITA and M25 R2R finally launch with AKM or resistor-ladder DACs, 1.7W per channel, 31-band PEQ and the same price.
Silent Angel H1 Silent Angel H1
Silent Angel’s $849 H1 combines dual ESS DACs, streaming, local storage, high-res playback, and VitOS in one compact digital hub.
2026 FiiO FT15 Headphones 2026 FiiO FT15 Headphones
FiiO’s $499 FT15 gets a bigger planar driver, thinner diaphragm and lighter chassis, and we already have first impressions from CanJam London.
WiiM Bar debuts at High End Vienna 2026 with Dolby Atmos, DTS:X, RoomFit, HDMI eARC, and expandable 3.0.2 surround from $479.
Is it possible for a $60 Bluetooth speaker to improve your TV's sound? IKEA’s BADKRUKA adds optical input, stereo pairing, 25W output and Spotify...
The compact Yamaha B200A adds Dolby Atmos and built in bass for under $300, but can you live without external surrounds or a subwoofer?
Can serious home theater disappear into the room? Sonance pairs an 82.7-inch soundbar with redesigned PowerPipe X hidden subwoofers.
The TCL Q95K combines 11.1.4 channels, 22 drivers, wireless surrounds, dual 7-inch subwoofer drivers and Bang & Olufsen tuning.
Is Apple building a four-HomePod surround system? audioOS 27 code reveals rear speakers, room calibration, bass management, and mystery hardware.
