Sony BRAVIA Theater Trio Speaker System Solves Every Soundbar’s Biggest Problem
Does your giant TV or projector screen make your soundbar look puny? Sony is here for you with their new powered speaker system which goes as wide as you need it to.
Soundbars are popular because they’re easy to set up and provide a sonic upgrade over TV speakers, sometimes a huge upgrade. But as TVs have gotten larger – and wider – every year, soundbars have basically stayed the same size. This means the little bar may not be able to match the audio to the on-screen action in terms of its soundstage width and immersion.
Most soundbars measure in at anywhere from 2 feet wide for the compact ones to around 4.5 feet wide for the larger ones. Sony’s flagship BRAVIA Theater Bar 9 is around 52 inches wide and SONOS’ flagship ARC Ultra is around 46 inches wide. Even the average 65-inch TV is wider than both at 57 inches. And if you’re opting for a 100-inch TV, those are around 88 inches wide – that’s over seven feet wide. This means the edges of your TV may each be up to two feet or more beyond the soundbar’s outermost speakers. And this can lead to the sound seeming much smaller than the picture.
Big-TV-Tiny-Soundbar
Soundbars can’t always keep up with the on-screen action when they are dwarfed by a giant flat panel TV or projection screen.
Sony just addressed this problem with their new BRAVIA Theater Trio. Also known by model number HT-A8, the Trio is a powered three-speaker system with dedicated left, center and right speakers that allows you to place your main speakers on either side of your TV or projection screen for a wider, more immersive soundstage even with the largest TV or projection screens.
Trio_set_front_900px
The Sony BRAVIA Theater Trio comes with a dedicated center channel speaker and a pair of front speakers with front-firing and up-firing drivers.
You may say, “But wait! Doesn’t Sony already offer the BRAVIA Theater Quad for just this reason?” And the answer is “YES!” But the new Trio has something the Quad doesn’t have: a dedicated center channel speaker. And this heps to improve dialog intelligibility compared to the phantom center created by the Quad system. The Trio also supports up to two powered subwoofers, while the Quad currently only supports one.
Based on our listening tests in events in Japan and New York, we’d say the BRAVIA Theater Trio works well on its own to improve the dynamics and immersiveness of TV sound, thanks to its high quality front and up-firing drivers. But it can also be upgraded with rear speakers and one or two powered subwoofers for much more immersive surround sound with deep extended bass.
The BRAVIA Theater Trio is compatible with all of Sony’s current rear speakers and subwoofers including the Bravia Theater Rear 8 and Rear 9 surround speakers and the BRAVIA Theater Sub 7, Sub 8 and Sub 9 powered subwoofers. For best effect, we recommend adding the Rear 9 speakers as they include both front firing and top-firing drivers as well as an integrated swivel stand that allows you to point the front drivers toward your listening position.
exp_sys_Trio_2xSub8_Rear9-motif-xropped-900px
The sound of the Trio system can approach cinematic levels when upgraded with a pair of rear speakers and powered subwoofers.
Which subwoofer you pick will depend on room size and how much you love that low bass. The entry-level Sub 7 would be fine in a small apartment or listening space to fill in that bottom end without shaking the walls. But in a larger room, you may want to consider the larger Sub 8, with one 8” driver or the flagship Sub 9 which features two force-balanced 8-inch bass drivers in a larger cabinet for deeper bass extension. To even out the bass response in all parts of your room, and provide the most substantial bottom end, the BRAVIA Theater Trio supports the addition of a second subwoofer.
Trio_bar_center-skeleton_2way-900px
The BRAVIA Theater Trio center channel features a two-way design with a center tweeter, flanked by dual bass/midrange drivers for clear dialog reproduction.
Like a soundbar, the Trio needs no separate amplifier or receiver as it’s got the power built in. Just connect one HDMI cable from the TV or projector’s HDMI ARC/eARC port to the center channel speaker and plug it into wall power and that center speaker unit communicates wirelessly with the rest of the speakers in the system. The front speakers, and any optional rear speakers and subwoofers do need their own power connections, however, as they need electricity for both the built-in amplifiers and wireless connectivity.
All Hype? Or Is There Some Merit Here?
We got to hear a demo of the full BRAVIA Theater Trio system at Sony’s headquarters in Tokyo earlier this year. It was matched with two of the company’s flagship BRAVIA Theater Sub 9 subwoofers and a pair of the BRAVIA Theater Rear 9s in the rear. The system provided excellent, dynamic sound overall, which was more than a match for the 115-inch BRAVIA 9 II True RGB TV it was paired with. Bass was deep and extended, thanks to the dual subs, and dialog was clear and crisp. Music and effects extended nearly the full width, height and depth of the room, giving the whole experience a dynamic cinematic feel.
Trio_frontLR_skeleton-up-firing-driver-900px
The front left and right speakers that come with the Trio system featured high quality angled up-firing drivers to reflect height channel effects off the ceiling.
The Trio isn’t replacing the Quad. It’s just providing another option for those who like the idea of variable width front left and right speakers and a dedicated center channel, without the wiring complexity of an A/V receiver and passive speakers.
Keep it in the Family (BRAVIA Family)
If you match the Trio up with a Sony TV, then you’ll be able to make all your audio adjustments right in the TV’s quick settings menu, and you’ll be able to take advantage of Sony’s AI-enhanced Voice Zoom 3 feature which elevates dialog without impacting the rest of the soundtrack.
20251030_122026 Sony Quick Settings Menu 900px
When connected to compatible Sony BRAVIA TV, you can make audio adjustments to the BRAVIA Theater Trio from the TV’s Quick Settings menu.
The Sony BRAVIA Theater Trio system can decode Dolby Atmos and DTS:X immersive surround sound, in both lossless and lossy versions. However, unlike the BRAVIA Theater Bar 8 and Bar 9 as well as the QUAD system, the Theater Trio does not support 360 Reality Audio, an immersive format for music which competes with Dolby Atmos. To be fair, the catalog of music titles available in 360RA format is pretty limited, so this omission is not likely to be a deal breaker for most buyers.
20240517_153703-queen-dts-x-900px
The BRAVIA Theater Trio can decode IMAX Enhanced DTS-X soundtracks like “Queen Rock Montreal” on Disney+ on select devices (including most recent Sony TVs).
The BRAVIA Theater Trio is certified IMAX Enhanced, which means it can decode the IMAX Enhanced DTS-X soundtracks on Blu-ray Disc, UHD Blu-ray and in streaming services including Disney+ and Sony Pictures Core, applying the necessary EQ to the soundtrack for maximum impact.
For wireless connectivity, the Theater Trio supports WiFi 6e network for high reliability as well as Bluetooth and Apple AirPlay 2.
New Improved Calibration Microphone
While previous Sony home theater products have used the microphone built into your phone for calibration, the BRAVIA Theater Trio comes with a dedicated high quality mic that plugs into your phone’s USB-C port for greater accuracy. This helps the system to better identify speaker positions and compensate for less-than-perfect speaker placement and room anomalies.
BRAVIA-Trio-Calibration-Microphone-20260427_151236-900px
The BRAVIA Theater Trio comes with a new calibration microphone which plugs into the USB-C port on most recent Android and Apple phones.
Speaking of speaker placement, the BRAVIA Theater Trio also has Sony’s 360 Spatial Sound Mapping (360 SSM) on board. This system compensates for imperfect speaker placement by creating phantom speaker channels all over the room in order to reproduce a more cohesive and expansive dome of sound.
BRAVIA-Theatre-Bar-9-360-Spatial-Sound-Mapping-900px
Sony 360 Spatial Sound Mapping can compensate for less than perfect speaker placement by generating virtual speaker channels where no physical speakers exist.
What’s The Catch?
At $2,199, Sony’s BRAVIA Theater Trio is significantly more expensive than Sony’s flagship soundbar, the BRAVIA Theater 9 ($1,198 at Amazon). And if you opt for the fully loaded system, with a pair of BRAVIA Theater Sub 9 subwoofers ($899 each) and BRAVIA Theater Rear 9 speakers ($748/pair), the list price of the full TRIO system gets pretty close to $5,000 (MSRP). At that price point, you might consider putting together a full home theater system with receiver and external speakers. You’ll be able to get better bang for your buck this way, though the set-up and wiring will be more complicated.
BRAVIA-Theater-Trio_with_Rear9_2 Sub9-900px
The Trio can be upgraded with rear channel speakers and up to two powered subwoofers. Shown here are the Trio with a pair of BRAVIA Theater Rear 9 speakers and two BRAVIA Theater Sub 9 subwoofers.
The Bottom Line
Apparently Sony likes to give its customers options. While soundbar-based systems offer simple set-up, the soundstage can be a bit narrow, simply due to the size of the bar. By offering an option to widen that stereo separation and keep a dedicated center channel for dialog reproduction, Sony is now giving buyers of extra large TVs and projection-based systems another potential solution. And it’s one we haven’t seen other companies match.
The Sony BRAVIA Theater Trio offers the wireless simplicity of a soundbar system with a hint at the performance of home theater separates. Its option to add not only rear speakers with up-firing height drivers but also up to two powered subwoofers gives buyers a clear upgrade path toward an audio system that can keep up with the visuals on a plus-sized TV screen. If you already own or are planning to purchase an extra large TV or home theater projection system, and the price point is within your budget, then the Sony BRAVIA Theater Trio is definitely worth a look and a listen.
Pricing & Availability
The Sony BRAVIA Theater Trio is available June 1, 2026 for $2,199.99 at authorized Sony dealers, with pre-orders being accepted now.
2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Esoteric K1XE CD Player and PS1XE Power Supply Esoteric K1XE CD Player and PS1XE Power Supply
CD Players
CDs are making a comeback, and Esoteric isn't holding back. The $45,000 Grandioso K1XE SACD player adds a new G2 DAC and an optional...
Bumpboxx Retroboom Portable Boombox in Red, Silver, Black Bumpboxx Retroboom Portable Boombox in Red, Silver, Black
The $299 Bumpboxx Retroboom packs 200 watts of peak power, Bluetooth, RGB lighting and 30-hour battery life into a retro boombox without tapes or...
Esprit Generation 10 Cables Esprit Generation 10 Cables
Audio Cables
Esprit Generation 10 cables arrive in the U.S. with redesigned conductors, connectors, and insulation. Nine ranges span $499 to $59,999.
Our favorite home theater projectors of 2026 deliver best-in-class performance across UST, lifestyle, and long throw categories.
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
Sony's NFL WH-1000XM6 headphones feature five exclusive team designs you can't buy. Find out how to enter the 2026 sweepstakes before November 30.
Which TVs are worth buying in 2026? Our hands-on tested Editors’ Choice winners cut through the hype to reveal the best OLED, Mini LED...
Our picks for best televisions of 2025 offer the best picture quality and value at their price and size.
LG's flagship soundbar, the Sound Suite H7, just got support for DTS:X surround, but good luck making that work on an LG TV.
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
Can Sony’s $120 IER-M500 professional in-ear monitors deliver the sound, comfort, and durability working musicians need?
