Cayin HA-1A MK3 Packs 2.7 Watts of Pure Tube Class A Into a Compact Headphone Amp
Cayin’s HA-1A MK3 features pure Class A tube amplification with 2.7W output, impedance matching and preamp functionality for $999.
2026 Cayin HA-1A MK3 Tube Headphone Amplifier
CanJam SoCal 2026 offered another reminder that personal audio has developed a rather elastic definition of “reasonable.” We listened to headphone systems approaching $57,000, while new amplifiers from Feliks Audio, Layer Audio Design and others demonstrated just how far manufacturers are willing to push dedicated headphone amplification.
Cayin is heading in the opposite direction with the new HA-1A MK3, the smallest member of its HA-series of tube headphone amplifiers.
Rather than combining a DAC, streamer, touchscreen and enough menu options to require a weekend seminar, the HA-1A MK3 is an old-school analog headphone amplifier built around a pure vacuum-tube, single-ended Class A circuit.
And that simplicity may be its strongest selling point.
The amplifier uses two JJ 12AU7/ECC82 tubes for voltage amplification and a pair of Electro-Harmonix EL84EH/6BQ5 output tubes. Cayin also uses custom-designed output transformers, point-to-point internal wiring and separate power supplies for the voltage and power-amplification stages.
Small Box, Serious Tube Amplifier
At only 240 x 240 x 140mm (9.4 x 9.4 x 5.5 inches), the HA-1A MK3 occupies considerably less desktop real estate than many high-end tube amplifiers.
Do not mistake small for lightweight.
cayin-ha-1a-mk3-tube-headphone-amplifier-front
Cayin HA-1A MK3
The transformers and metal chassis push its weight to 8.8kg, or roughly 19.4 pounds, which is substantial for something that takes up only about 9.4 inches in each direction.
Cayin provides both a 6.35mm headphone output and 4-pin XLR headphone output, along with selectable Low and High impedance settings. Low covers headphones from 8 to 150 ohms, while High is intended for models between 151 and 600 ohms.
That significantly broadens the potential headphone roster compared with traditional OTL tube amplifiers, which generally make the most sense with higher-impedance dynamic headphones.
The international launch materials rate output through the 4-pin XLR connection at up to 2,700mW + 2,700mW. Cayin’s current German product page lists 2,800mW + 2,800mW and 2,500mW + 2,500mW through the 6.35mm output, so there appears to be a minor regional specification discrepancy that Cayin will hopefully clarify before U.S. shipments begin.
There is also an important distinction regarding that XLR connection. Cayin describes it as a balanced headphone output, but the amplifier itself is specified as a single-ended Class A design. A 4-pin XLR connector should therefore not automatically be interpreted as evidence of a fully differential internal amplifier topology.
cayin-ha-1a-mk3-tube-headphone-amplifier-rear
More Than a Headphone Amp
The HA-1A MK3 also includes two pairs of RCA inputs and a dedicated RCA preamplifier output, allowing it to control active loudspeakers or an external power amplifier.
Preamp gain is rated at 9dB with a maximum 5V output.
That makes the Cayin considerably more useful in a small desktop or two-channel system where the headphone amplifier might also serve as the analog control center.
An ALPS volume potentiometer, approximately 50-second delayed startup, automatic muting circuit and removable tube cage round out the package.
There is no DAC, Bluetooth or network streaming.
Good.
We already own enough products desperately trying to become computers.
cayin-ha-1a-mk3-tube-headphone-amplifier-closeup
cayin-ha-1a-mk3-tube-headphone-amplifier-power-button
Cayin HA-1A MK3 Specifications:
  • Amplifier Type: Pure tube, single-ended Class A
  • Tubes: 2 x JJ 12AU7/ECC82, 2 x Electro-Harmonix EL84EH/6BQ5
  • Headphone Outputs: 6.35mm, 4-pin XLR
  • 6.35mm Output: Up to 2.5W + 2.5W
  • 4-pin XLR Output: Up to 2.7W + 2.7W in international launch materials
  • Impedance Settings: Low 8-150 ohms; High 151-600 ohms
  • Frequency Response: 20Hz – 24kHz ±3dB
  • SNR: 110dB A-weighted
  • Inputs: 2 pairs RCA
  • Preamp Output: RCA
  • Maximum Preamp Output: 5V
  • Preamp Gain: 9dB
  • Volume Control: ALPS potentiometer
  • Dimensions: 240 x 240 x 140mm
  • Weight: 8.8kg / 19.4 lbs
  • Finishes: Black or Silver
  • MSRP: $999
The Competition
The Feliks Audio Echo Vibe ($1,095) remains one of our favorite affordable tube headphone amplifiers, but its OTL architecture and 350mW output make it a very different proposition. It is particularly compelling with high-impedance dynamic headphones, whereas the Cayin’s transformers, selectable impedance ranges and substantially greater output power should make it suitable for a broader selection of headphones.
At $1,499, the Layer Audio Design GEN-300B features a single-ended Class A 300B circuit and can drive both headphones and efficient loudspeakers with up to 10 watts per channel through its speaker outputs. It is more ambitious as an integrated amplifier, but also considerably larger and heavier.
The Cayin occupies an interesting space between them.
It delivers a traditional transformer-coupled tube circuit, meaningful headphone output, wide impedance compatibility and preamp functionality without turning a desktop headphone system into a piece of living-room furniture.
cayin-ha-1a-mk3-tube-headphone-amplifier-angle
Cayin HA-1A MK3
Where to Buy:
1 Comment
1 Comment
  1. ORT
    September 19, 2026 at 9:49 pm
    A thing of beauty is indeed a joy forever. “SIGH”…I just ordered a Marantz Model 60n in the silver/gold finish to match my CD60. What has this to do with the Cayin HA-1A MK3? Nothing.
    And everything. It is said that beauty is in the eye of the beholder but I tell you this, long after both mortal beauty and eyesight have faded, memory remains. My late and much beloved mother taught me as a child that no one dies alone who has a lifetime of memories with them. I should like to add that when those memories have a soundtrack with them, it is even better. It is not that our lives are too short, but that we spend so little time living them with those we love and who love us.
    ORT
2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Esoteric K1XE CD Player and PS1XE Power Supply Esoteric K1XE CD Player and PS1XE Power Supply
CD Players
CDs are making a comeback, and Esoteric isn't holding back. The $45,000 Grandioso K1XE SACD player adds a new G2 DAC and an optional...
Bumpboxx Retroboom Portable Boombox in Red, Silver, Black Bumpboxx Retroboom Portable Boombox in Red, Silver, Black
The $299 Bumpboxx Retroboom packs 200 watts of peak power, Bluetooth, RGB lighting and 30-hour battery life into a retro boombox without tapes or...
Esprit Generation 10 Cables Esprit Generation 10 Cables
Audio Cables
Esprit Generation 10 cables arrive in the U.S. with redesigned conductors, connectors, and insulation. Nine ranges span $499 to $59,999.
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
FiiO's $380 CLASS A headphone amp can switch to Class AB with low-impedance headphones. Here's what FiiO says and why the distinction matters.
DUNU PRS6 brings MEMS technology to a refined tribrid IEM with strong resolution, clean treble and a clear focus on competitive gaming.
Can Sony’s $120 IER-M500 professional in-ear monitors deliver the sound, comfort, and durability working musicians need?
Eversolo brings 180 watts of Class AB power while FiiO answers with EL34 tubes and pure Class A. Two Chinese amplifiers, two very different...
Sony revives the XM4 with improved ANC, a replaceable battery and updated processing. At $299.99, does it still offer enough value?
Melody Wings’ $188 Uranus delivers airy, resolving sound from a quadbrid driver array, but BCD ringing and sharp treble may divide listeners.
