HiFiMAN HE1000 WiFi Review: Can Wireless Planar Headphones Finally Replace Cables?
Can HiFiMAN’s HE1000 WiFi deliver true high-end planar sound without the cable, or do setup headaches and weak battery life hold it back?
HiFiMAN HE1000 WiFi Wireless Planar Magnetic Headphones in the Box
HiFiMAN helped turn planar magnetic headphones into a serious personal audio category, and the company has never been shy about taking weird swings. Nanometer-thin diaphragms, Stealth Magnets, and open-back designs that look like they escaped from an engineering lab with no adult supervision — this is familiar territory. But the HiFiMAN HE1000 WiFi is not just another wireless headphone with a luxury badge and a bigger invoice.
The high-performance wireless headphone market has already moved well past “good for Bluetooth.” The Focal Bathys MG pushed wireless ANC into more serious audiophile territory at $1,499, while the DALI IO-12 went even higher at $1,750 with its SMC driver technology and hi-fi-first tuning. Mark Levinson’s No. 5909 also helped prove that premium wireless headphones could be more than airport jewelry for people who alphabetize their boarding passes.
HiFiMAN, however, has taken a bigger and riskier step. At $2,699, the HE1000 WiFi is an open-back planar magnetic headphone with built-in WiFi streaming, Bluetooth, USB audio, Stealth Magnet drivers, and support for high-resolution playback well beyond what conventional Bluetooth headphones can deliver. It is less “wireless ANC rival” and more “high-end headphone system with the cable surgically removed.”
The question is whether WiFi streaming actually moves the HE1000 closer to wired high-end headphone performance, or whether HiFiMAN has spent two years building one of the smartest ideas in wireless headphones and left just enough unfinished to make the price sting.
HiFiMAN HE1000 WiFi
Specifications and Technology
The HE1000 WiFi is more than a passive planar magnetic headphone with wireless connectivity added on. HiFiMAN has integrated a complete playback chain inside the earcup, including its HYMALAYA Mini DAC, headphone amplifier, and WiFi streaming platform. The HYMALAYA Mini DAC measures only 8mm, which makes the internal packaging impressive given the limited space available inside a headphone.
The DAC section is specified with THD+N of 0.0055% and 105dB of channel separation. Via USB-C, the HE1000 WiFi supports up to 768kHz/32-bit PCM and DSD512, which is far beyond the resolution of most commercially available music files. Those figures are technically impressive, but the more relevant question is how well the DAC, amplifier, wireless platform, and planar drivers work together as a complete system.
As expected from a headphone carrying the HE1000 name, the driver section includes HiFiMAN’s nanometer-thickness diaphragm and Stealth Magnet technology. These are designed to reduce unwanted acoustic interference, improve transient response, and preserve clarity. The engineering is familiar from HiFiMAN’s higher-end planar magnetic headphones, but the WiFi implementation makes this version meaningfully different from the passive HE1000 models.
The main feature is WiFi streaming. Bluetooth has improved, and the HE1000 WiFi still supports it, but Bluetooth remains limited by codec bandwidth and compression. WiFi gives the headphone a wider path for high-resolution and lossless playback over a home or office network, which is the core argument for this product. The goal is straightforward: deliver more of the sound quality associated with a wired planar headphone while retaining the freedom of wireless listening.
That does not automatically make the HE1000 WiFi better than every premium Bluetooth headphone, nor does it remove the usual questions about app support, setup, stability, battery life, and daily usability. But it does give HiFiMAN a different technical angle in a category where most wireless headphones are still built around Bluetooth first. At its asking price, that difference needs to be clearly audible and easy to live with.
They can also be used over standard Bluetooth, with a Qualcomm QCC5181 chip that supports LDAC for up to 96kHz playback. That is more than enough for Spotify, YouTube, and most casual listening sessions where convenience matters more than chasing every last bit. Bluetooth also gives the HE1000 WiFi a meaningful battery life advantage over WiFi mode, but we’ll get to battery longevity shortly.
Design & Comfort
hifiman-he1000-wifi-headphones-kit
A quick word on what comes in the package. Technically, it is not really a box, but the same kind of faux leather-wrapped display case HiFiMAN has used with other HE1000 models. It looks the part, although the previous hardback owner’s manual has been replaced by a more ordinary paperback version. Accessories are also minimal: one six-foot USB-C to USB-A cable. That is about it. When the headphone is wireless, HiFiMAN clearly decided the accessory drawer did not need to audition for Hoarders.
HiFiMAN has used its Gen. 2 headband on the HE1000 WiFi, which is a bit of a mixed bag. The upside is weight reduction, with the newer design shaving roughly 20 to 30 grams compared to some older HiFiMAN headbands. The trade-off is that it does not offer the same 360-degree earcup swivel found on the wired HE1000 and Arya models. It does feel reasonably sturdy, however, and should survive the occasional knock without requiring a grief counselor.
hifiman-he1000-wifi-headphones-earpad
The earcups retain the familiar egg-shaped profile used across the HE1000 and Arya lines, but they are slightly deeper here to accommodate the internal circuitry. That extra depth does not hurt comfort. One of the long-standing advantages of this design is the amount of space inside the pads, with little risk of the driver or earpad pressing against the outer ear.
Materials are a mix of metal and plastic, which helps keep weight under control while still giving the HE1000 WiFi some visual connection to HiFiMAN’s higher-end models. At 452 grams, or almost exactly one pound, it is not especially light, but it is manageable for an open-back planar headphone with built-in amplification, DAC, Bluetooth, and WiFi streaming hardware.
The catch is that the build quality and finish do not fully communicate a $2,699 asking price. It feels solid enough, and comfort is generally strong, but this is not the kind of physical object that immediately makes the near-three-grand number feel self-explanatory. The HE1000 WiFi is clearly betting that the sound quality and wireless execution will do the heavy lifting. At this price, they need to.
The color? I like it, although I can see it being somewhat divisive. It is more interesting than another safe silver or black finish, and there is a faint luxury-car interior vibe to it — Rolls-Royce or Bentley from a distance, with the understanding that nobody from Crewe is losing sleep over the upholstery.
Comfort is far less debatable. The suspension strap distributes the weight evenly across the head, making longer listening sessions easy to manage without obvious hotspots or fatigue. Clamp force is on the firmer side, but I actually prefer that here. The HE1000 WiFi stays put when you move your head, which is rather important when the whole point is wireless freedom.
hifiman-he1000-wifi-headphones-buttons
The controls are sensibly arranged and easy to understand. From top to bottom, there is a volume rocker, a function button that switches between WiFi, USB, and Bluetooth modes, and a power button. The function button includes an indicator light for the selected mode, while the power button uses colored lighting to show charging and battery status. The volume control could use finer adjustment, but the overall layout is simple and practical, which is exactly how it should be.
Battery life, unfortunately, is where things get less flattering. In my testing, the HE1000 WiFi managed roughly five hours over WiFi and about 12 hours over Bluetooth, the latter falling well short of HiFiMAN’s quoted figure of up to 23 hours. Charging takes around the claimed four hours, which is not exactly a rapid turnaround. In daily use, that means you need to charge them at the end of the night or risk starting the next day with a very expensive pair of silent earmuffs.
HE1000 WiFi Setup: Brilliant Idea, Clumsy Execution?
Most wireless headphones are easy to get running. Power them on, open the Bluetooth menu on your phone, select the model, and you are usually listening within seconds. Not exactly NASA.
The HE1000 WiFi is different, and not always in a good way. Connecting the headphones to my home network proved more troublesome than expected, and the process feels less polished than it should for a product at this level.
HiFiMAN seems aware of the issue, because the company has released several setup videos to guide users through the process. That helps, but it also says something. Getting the HE1000 WiFi online requires users to navigate local network pages that look rather basic, follow multiple steps, and make sure the headphones are properly connected before WiFi playback becomes available. For some audiophiles, especially those comfortable with networking and streaming hardware, this may not be a major obstacle. For everyone else, it could be the point where the WiFi promise starts to feel more like homework.
That matters because the HE1000 WiFi’s best argument is its WiFi mode. If setup friction pushes owners toward Bluetooth or wired use out of frustration, the product loses some of its reason for being. Bluetooth works, and it is useful, but nobody is spending $2,699 on these because they needed another Bluetooth headphone.
There is also the issue of software support. Not every music app can cast over WiFi in the way the HE1000 WiFi requires, and some services reserve that functionality for paid tiers. Spotify and YouTube Music, for example, require premium subscriptions for casting support. That does not make the HE1000 WiFi unusable, but it does mean buyers need to understand exactly how they plan to stream before assuming WiFi playback will be seamless across every app they use.
Firmware updates are another sore spot. Bluetooth updates run through HiFiMAN’s GAIA app, but WiFi module updates require manually downloading files and uploading them through a browser-based local interface. That feels clumsy for a headphone built around WiFi.
HiFiMAN needs to fold the entire update process into one app. These issues do not ruin the HE1000 WiFi, but they do make the experience feel less polished than the hardware concept deserves.
hifiman-he1000-wifi-headphones-side
Listening
The HiFiMAN HE1000 WiFi delivers a listening experience that very few headphones currently offer. Being able to listen to lossless music without being tied to a desk, or dealing with a cable brushing against your shirt every time you move, is genuinely liberating. You can walk around the house or office and still listen at a level that feels closer to a serious headphone rig than a typical wireless setup. Yes, you could plug a passive headphone into a DAP and get some of that mobility, but not carrying anything at all is a different proposition.
That is the HE1000 WiFi’s strongest argument. It gives you real freedom without reducing the experience to background listening. That alone helps offset some of the complaints about setup, build quality, and day-to-day usability. The better news is that the headphones also sound very good on their own terms.
The jump from Bluetooth to WiFi is not subtle. Detail retrieval improves, staging opens up, and the presentation feels more composed. To give the HE1000 WiFi the best possible chance, I spent most of my listening time in WiFi mode, playing lossless FLAC files from my phone.
What became clear rather quickly is that the HE1000 WiFi does not simply follow HiFiMAN’s older house sound. There is still plenty of planar speed and openness, but the tuning has moved in a slightly different direction. Let’s start with the bass.
Bass
Throughout the review process, I compared the HE1000 WiFi with the HE1000 Unveiled, which I had on hand and know well. The first meaningful difference showed up in the bass.
The HE1000 WiFi does not deliver the kind of exaggerated low-end weight found in many wireless headphones, especially ANC models, but there is a subtle midbass lift that gives music some added warmth and body. It is not overdone, and it helps the headphone sound a little fuller without turning the presentation thick or sluggish.
Sub-bass extension is also strong, with only a slight sense of roll-off below roughly 30Hz. On Hans Zimmer and James Newton Howard’s “Why So Serious?,” the deep 20Hz rumble was still present enough to be felt, not merely heard. That is not something every open-back planar handles convincingly, and it gives the HE1000 WiFi more low-end authority than expected.
Midrange
A bass lift usually comes with a trade-off, and with the HE1000 WiFi, that shows up in the midrange. Compared again with the HE1000 Unveiled, the wireless model sounds a little more restrained through the mids and does not deliver the same top-tier clarity or immediacy. Vocals are smooth and well controlled, but they do not step forward with the same transparency, and guitar solos do not quite dig in with the emotional pull you get from the HE1000 Unveiled or Audio-Technica ATH-ADX7000.
That is not a deal-breaker. The HE1000 WiFi has a relaxed, easygoing midrange that many listeners may actually prefer, especially for longer sessions. It is not trying to spotlight every breath, string scrape, or studio chair creak like a detective with a grudge. It is more forgiving than that.
The context matters as well. We are comparing the HE1000 WiFi against serious wired audiophile headphones that live in rarefied air. The fact that HiFiMAN’s wireless implementation can stay in the conversation at all is impressive. It may not match the best passive models for midrange openness or resolution, but it gets close enough to make the cable start looking less essential.
Treble
Some previous HiFiMAN headphones, including the Arya Organic, could lean a little hot in the upper frequencies. The HE1000 WiFi avoids that trap. There is still plenty of treble energy and sparkle, but it walks the line between excitement and sharpness without turning cymbals into dental work.
Extension is excellent, with enough air and control to give woodwinds, hi-hats, and upper harmonics real presence. L’Impératrice’s “La lune” was a good example, with the faint triangle hits cutting through the mix cleanly and sounding natural rather than etched for effect.
There are no obvious peaks or dips that call attention to themselves, which helps the HE1000 WiFi maintain a more natural and cohesive presentation. HiFiMAN got the treble balance right here: lively, open, and detailed, but not aggressive enough to make you start bargaining with the volume control.
Soundstaging & Imaging
The HE1000 WiFi does not throw an especially wide soundstage, but what it does inside that medium-sized space is far more important. Imaging is impressively precise, especially for a wireless headphone, and placement feels stable rather than vague or artificially stretched.
As with other egg-shaped HiFiMAN designs, the tall driver geometry helps create a convincing sense of height when the recording calls for it. The center image is clearly locked in, and individual layers remain easy to follow even during busier passages.
TOOL’s “Chocolate Chip Trip” is a useful stress test here, because the track is basically Danny Carey throwing percussion, electronics, and spatial chaos around the room to see what survives. The HE1000 WiFi keeps those sounds organized, with effects appearing from distinct positions rather than collapsing into a confused blob. It may not be the widest presentation HiFiMAN has ever produced, but the focus and positional accuracy are excellent.
hifiman-he1000-wifi-headphones-bottom
The Bottom Line
The HiFiMAN HE1000 WiFi is one of the more compelling wireless headphone concepts to come along in years because it does something most premium wireless models still do not: it treats sound quality as the main event, not a bonus feature hiding behind ANC, app tricks, and faux-luxury packaging.
What makes it unique is the WiFi streaming implementation. The ability to walk around the house or office listening to lossless music through an open-back planar headphone without a cable hanging off your body is not a small thing. It changes how and where you listen. The HE1000 WiFi delivers much of the speed, openness, bass control, treble refinement, and imaging precision listeners expect from a serious HiFiMAN planar design, but without chaining you to the desk like a suspect in a bad procedural.
It is not perfect. The setup process is clumsy, firmware updates feel less polished than they should, battery life is underwhelming, and the build quality does not fully sell the premium positioning. The midrange is also smoother and less immediate than the HE1000 Unveiled, so those expecting the same level of transparency from HiFiMAN’s best passive designs should temper expectations.
But taken as a complete product, the HE1000 WiFi is still a bold and largely successful swing. It is for listeners who want high-end planar sound with real freedom of movement, who mostly listen at home or in an office, and who are willing to tolerate some early-adopter friction for a genuinely different experience.
The bigger question is whether the less expensive Arya WiFi, which we are also reviewing, can deliver enough of the same magic for a lot less money. If it gets close, HiFiMAN may have an even more interesting problem on its hands.
Pros:
  • Excellent sound quality for a wireless headphone
  • WiFi streaming delivers a clear step up over Bluetooth
  • Lossless playback without being tethered to a desk
  • Strong bass extension with tasteful midbass warmth
  • Smooth, non-fatiguing midrange
  • Treble is lively, airy, and well controlled without getting sharp
  • Precise imaging and strong layer separation
  • Comfortable for long listening sessions
  • Secure fit with firmer clamp force
  • Supports WiFi, Bluetooth, and USB modes
  • LDAC support over Bluetooth
  • Clever all-in-one design with built-in DAC, amplifier, and streamer
Cons:
  • Setup process is more complicated than it should be
  • WiFi firmware updates require an awkward browser-based process
  • Battery life is disappointing, especially in WiFi mode
  • Charging time is slow
  • Build quality and finish do not fully feel premium
  • Volume control could use finer adjustment
  • No 360-degree earcup swivel like some wired HiFiMAN models
  • Midrange lacks the clarity and immediacy of the best passive HE1000 models
  • Not all music apps or free service tiers support WiFi casting
  • Early-adopter product that still needs software polish
Our Ratings
★★★★★★★★★★ Sound Quality
★★★★★★★★★★ Comfort
★★★★★★★★★★ Usability
★★★★★★★★★★ Build Quality
★★★★★★★★★★ Value
Where to buy:
Meze Audio's POET Jazz Special Edition features 11 individually hand-painted planar headphones at $2,399 each. Same acclaimed sound, no repeat performances.
TDM Neo headphones twist into a Bluetooth speaker, offering one device for private listening and the occasional need to become everyone’s DJ.
Over-Ear Headphones
The HiFiMAN HE600 revives the spirit of the legendary HE-6 with less weight and easier amplification, but does it capture the original magic?
What were the best headphone systems at CanJam SoCal 2026? We heard standout rigs from RAAL, Chord, Meze, Grado, HiFiMAN, SJY and more.
Can R-2R audio stand out in crowded TWS? HiFiMAN's $299 Svanar Wireless 2 adds Bluetooth 6.0, LDAC, ANC and a smaller HYMALAYA Mini DAC.
Can beyerdynamic shake up $150 wireless headphones? AVENTHO Y adds ANC, 90 hour battery life, Bluetooth 6.0 and replaceable parts.
Major headphone brands disagree over 24-bit/192kHz lossless wireless audio as Apple, Android and codec compatibility complicate what comes next.
