YG Acoustics Titan Loudspeakers Are Really $1 Million Per Pair
7 feet tall and and weighing 1,000 pounds, YG Acoustics flagship 5-way loudspeakers come in fully active, semi-active or passive versions.
YG Acoustics Titan Loudspeakers Pair
The ultra high-end loudspeaker category has been rather busy in 2026, which is either a sign that the market still has serious money to spend or that nobody in this business knows how to tap the brakes. Wilson Audio has already made a very large statement with the $788,000 per pair Autobiography, while Børresen’s M8 Gold Signature pushes the conversation into seven figure territory. Now YG Acoustics has entered the same rarefied air with Titan, the first model in its new flagship Ultimate Range and arguably the most talked about new loudspeaker at AXPONA 2026.
This is not a speaker aimed at the casually curious. Titan is YG’s attempt to plant a flag at the top of the mountain, where the air is thin, the rooms are large, and your bank account needs to barely flinch when the invoice is opened.
Attack of the Titans?
Five years of research and three years of product development later, YG Acoustics has arrived at Titan, the most ambitious loudspeaker the company has released to date. It is the first model in YG’s new Ultimate Range and is designed to showcase the brand’s latest engineering work while pushing further into the ultra high end loudspeaker category.
Titan is not trying to disappear visually. It stands approximately 7 feet tall, or 84.5 inches, and weighs about 1,000 pounds. That is half a ton before the crates, the room treatment, and the quiet conversation with your financial advisor. Inside the cabinet, YG uses a seven driver symmetrical array supported by a custom designed sub bass driver.
yg-acoustics-titan-loudspeaker-front
YG Acoustics Titan Versions & Pricing
YG Acoustics offers the Titan in three configurations, giving ultra high-end buyers some room to choose between passive operation, active sub bass support, and a fully active system. “Some room” being relative when the starting point is $880,000 per pair.
Titan Passive: $880,000 per pair
The Titan Passive is a fully passive five-way loudspeaker that uses an external crossover with YG Acoustics’ Ultracoherent circuits. Crossover points are specified at 35 Hz, 90 Hz, 360 Hz, and 1.85 kHz.
Titan with Active Sub: $910,000 per pair
The Titan with Active Sub uses a passive four-way system with an external crossover and Ultracoherent circuits at 90 Hz, 360 Hz, and 1.85 kHz. Sub-bass duties are handled by a dedicated external 1,000-watt amplifier with DSP tuned crossover control for the 12.5-inch (32 cm) driver, including room correction support. The active sub-bass section is time aligned to integrate with the passive drivers.
YG Titan sub-Bass Driver and 1KW Amp (Active Sub Option)
Titan Live: $1,000,000 per pair
The Titan Live is the fully integrated active version of YG Acoustics Titan. It includes dedicated amplification and DSP for each channel, covering the high, midrange, low, and sub bass sections. Each tower is partnered with an external amplifier using 8 x 700-watts with an optimized DSP crossover.
The system connects to the Live Controller using glass fiber optic cables, with support for Roon Ready streaming, analog and digital inputs, and a high quality phono stage. In other words, this is the version for buyers who want the full YG ecosystem, not just a pair of loudspeakers and a nervous conversation with their amplifier dealer.
The Drivers
High frequencies are handled by YG’s lattice tweeter set inside a unique oval waveguide flanked by proprietary YG aluminum cone drivers arranged symmetrically above and below it: a pair of 15 cm (6-inch) mid-range drivers, a pair of 18 cm (7.25-inch) mid-bass drivers, and a pair of 26 cm (10.25-inch) bass drivers.
yg-acoustics-titan-loudspeaker-top-half
The tweeter, midrange, mid-bass, and bass array is supported by a custom 32 cm (12.5 inch) YG aluminum cone sub bass driver with an ultra high field magnet structure. YG says each driver is phase aligned across a wide frequency range to support a point source presentation.
The goal is improved clarity, more precise imaging, and a wider listening area. That matters with a loudspeaker this large, because nobody spending this kind of money wants to sit with their head locked in one exact spot like they are being scanned for replicant behavior.
More details are included in the specifications chart later in the article.
Driver array includes:
  • One 26 mm (1”) Tweeter: Proprietary YG Lattice hybrid construction
  • Dual 15 cm (6 inch) midrange drivers: Proprietary YG aluminum cone drivers with neodymium magnets and close pair matching.
  • Dual 18.5 cm (7.25 inch) midbass drivers: Proprietary YG aluminum cone drivers with neodymium magnets and close pair matching.
  • Dual 26 cm (10.25 inch) bass drivers: Proprietary YG aluminum cone drivers with ultra high field magnets and close pair matching.
  • 32 cm (12.5 inch) sub bass driver: Proprietary YG aluminum cone driver with an ultra high field magnet and close matching.
Cabinet Construction
The Titan cabinet uses a five layer construction, another example of YG Acoustics’ focus on structural rigidity, resonance control, and fit and finish.
yg-acoustics-titan-loudspeaker-angle
The side panels use three layers of aerospace grade aluminum alloy, with precision engineered damping materials between them. That creates the five layer structure and gives the cabinet additional stiffness without relying on brute mass alone.
The front faceplates are machined from solid aerospace grade aluminum measuring 75 mm, or 3 inches, thick. YG says the aluminum is heat treated to optimize its crystalline structure before being milled to extremely tight tolerances.
Inside the cabinet, Titan uses advanced bracing, composite resin damping, and computationally optimized diffuser and absorber structures to reduce internal resonances and help the drivers operate with fewer cabinet related distortions.
In addition, the subwoofer section at the bottom maximizes cabinet volume by tapping into a channel that runs up the entire back of the Titan.
The Passive Crossover
The passive crossover is the result of the art and science of speaker engineering. The crossover is built on bespoke multi-layer PCB material with advanced dielectric properties and internal resonance damping.
yg-acoustics-titan-external-crossover
Each crossover circuit is precisely milled in-house from extra-thick, high-purity copper, with traces optimized through simulation to eliminate interference and distortion. The crossover is housed externally in an enclosure crafted entirely from a specially selected polymer material. The external placement eliminates any field interactions with the crossover signal.
YG Acoustics Titan Specifications
YG Acoustics Model Titan
Speaker Design5-Way (Available in passive, Active Sub, and Live versions)
Price per pair$880,000 (passive)
$910,000 (passive with active sub)
$1,000,000 (fully active)
Cabinet  ConstructionSide Panels: 3 aerospace aluminum layers with two damping layers in between for a total of five.
Front and Back: 3″ thick monolithic slabs of aerospace aluminum with specially engineered damping chambers
Speaker TypeFloorstanding loudspeaker
TweeterOne 26 mm (1”) proprietary YG Lattice hybrid tweeter
MidrangeDual 15 cm (6”) proprietary YG aluminum cone midrange drivers, neodymium magnets, and exceptional matching
Dual 18.5 cm (7.25”) proprietary YG aluminum cone mid bass drivers, neodymium magnets, and exceptional matching
WooferDual 26 cm (10.25”) proprietary YG aluminum cone bass drivers, ultra-high field magnets, and exceptional matching
32 cm (12.5”) proprietary YG aluminum cone sub-bass driver, ultra-high field magnets, exceptional matching
CrossoverPassive: External crossover with Ultracoherent circuits at 35 Hz, 90 Hz, 360 Hz, and 1.85 kHz
Frequency ResponseUsable output extends from below 20 Hz to 40 kHz
Sensitivity88 dB
Impedance4 Ohms average
2.2 Ohms minimum
Dimensions (HxWxD)215 x 54 x 108 cm
(84.5 x 21.5 x 42.5 inches)
Weight 455 kg (1,000 lbs) per tower unpacked
yg-acoustics-titan-loudspeaker-left
YG Acoustics Titan Loudspeaker with external crossover behind speaker.
The Bottom Line
The YG Acoustics Titan is not just the first model in the company’s new Ultimate Range. It is YG’s statement that it wants a seat at the same very expensive table as the Wilson Audio Autobiography, Børresen M8 Gold Signature, and Sonus faber Suprema. That table does not come with a kids’ menu.
What makes Titan interesting is not one single trick feature, but the complete system approach: a massive seven driver symmetrical array, dedicated 12.5-inch sub bass driver, five layer cabinet construction, phase aligned driver integration, and three available configurations: passive, active sub bass, and fully active Titan Live. That flexibility is unusual for a loudspeaker at this level, especially when buyers can choose between traditional external amplification, active low frequency support, or a complete YG controlled ecosystem with amplification, DSP, streaming, digital inputs, analog inputs, and a phono stage.
Prospective buyers need to think beyond the loudspeaker price. The passive and active sub versions still require serious amplification, sources, cabling, setup expertise, and a room large enough to let a 7 foot tall, 1,000 pound loudspeaker breathe. With output extending below 20 Hz and up to 40 kHz, a 4 ohm average impedance, and a 2.4 ohm minimum load, Titan is not something you casually drop into a living room next to the sectional and hope for the best. It needs space, power, proper setup, and a system built around it.
Titan is aimed at listeners who already understand the cost of entry in the ultra high-end category and want YG’s most ambitious expression of scale, control, and engineering. Everyone else can admire it from a safe distance, preferably outside the freight elevator.
yg-acoustics-titan-loudspeaker-gold
YG Acoustics Titan in special gold finish that could double the price.
Price & Availability
YG Acoustics Titan (aluminum version) is available now through Authorized Dealers in three configurations:
  • Titan Passive – $880,000 per pair
  • Titan w/Active Sub – $910,000 per pair
  • Titan Live – $1,000,000 per pair
A gold version is also available for roughly $2 million per pair, depending on market pricing and thickness of gold plating.
Sound Clip from AXPONA 2026
For more information: yg-acoustics.com
2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
2026 Sony Walkmans 2026 Sony Walkmans
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
Rega Replay Turntable Rega Replay Turntable
Rega Replay turntable weighs just 2.2 kg and reportedly costs £259. How does its skeletal design compare with the Planar 1 and its rivals?
2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection 2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection
Linn's new 343 brings Pistonik bass to a compact floorstander, with Exakt Integrated and powered-bass versions starting at $67,500 per pair. Worth the premium?
2027 Naim Mu-so Utopia Lifestyle Speaker 2027 Naim Mu-so Utopia Lifestyle Speaker
Magico rebuilds the A3 with M9-derived engineering, new drivers and a new cabinet. The other upgrade? Entry-level Magico now costs $25,000.
Is it possible for a $60 Bluetooth speaker to improve your TV's sound? IKEA’s BADKRUKA adds optical input, stereo pairing, 25W output and Spotify...
Can 64 Audio’s $3,999 Ocean flagship IEM justify its price with isobaric bass and 32 passive tuning combinations?
Are the ATC SCM20ASL worth $10,999? These British active loudspeakers deliver world-class sound, brutal honesty, and serious built-in power.
Can the Atlantis Lab AT-23 Pro deliver deep bass and room-filling dynamics without a subwoofer? Our review explains why it deserves attention.
Loudspeakers
Armour Home boss Charlie Henderson explains how Q Acoustics, Goldring and QED plan to rebuild U.S. visibility, expand products and reach younger listeners.
What did Focal and Naim bring to Audio Advice Live 2026? A $210K Diva Alta Utopia, Scala’s North American debut, Hekla and a $5,297...
