CD Players
Shanling EC Play Portable CD Player Gives Gen Z Bluetooth 6.0, LDAC, and a Reason to Touch Physical Media
Shanling EC Play gives CDs a Gen Z reboot with Bluetooth 6.0, USB DAC support, balanced output, and a $199 price. Is this Discman war real?
Shanling EC Play portable CD player in hand
Shanling has launched the EC Play portable CD player, a compact modern CD player priced at $199 aimed at younger listeners rediscovering physical media and anyone else tired of paying monthly rent to access albums they supposedly “own.”
The timing is not accidental. CDs have been getting a second look from younger buyers who still stream all day, but also want ownership, artwork, liner notes, and a shelf that looks less like a Target endcap and more like an identity crisis with jewel cases. Shanling clearly sees the opening, and so does FiiO, which means we may be watching the early stages of a very specific hardware feud: the portable CD player war for a generation that gets its news from TikTok and might think the Straits of Hormuz is an influencer house in Dubai.
That is not a complaint. More support for physical media, better portable playback, Bluetooth connectivity, and internal headphone amplification are all good things. But with Shanling and FiiO both pushing new portable CD players into the market, the obvious question remains: how many modern Discman descendants does the market actually need before this becomes less “physical media revival” and more “somebody please take the launch calendar away from the product team”?
shanling-ec-play-silver
Shanling EC Play Gives Gen Z a CD Player With Bluetooth Training Wheels
The Shanling EC Play is a compact portable CD player with an aluminum chassis, a weight of 418 grams, and dimensions of 142 x 125.1 x 26 mm. It is available in Feather Green, Onyx Black, and Moonlight Silver, and the design is clearly built around portability rather than making the user carry a small desktop component in a jacket pocket.
The disc mechanism is one of the more important parts of the design. Shanling uses an active magnetic clamp system adapted from its earlier EC models, which is designed to maintain disc stability by adjusting pressure and positioning during playback. The goal is to reduce vibration and mechanical noise, both of which matter in a portable CD player. The EC Play supports CD, CD-R, and CD-RW playback, along with gapless playback, which is useful for live albums, classical recordings, and albums where the tracks are meant to flow without interruption.
For digital conversion, Shanling uses the Cirrus Logic CS43198 DAC, paired with dual SGM8262 headphone amplifiers. The player includes both 3.5mm single-ended and 4.4mm balanced headphone outputs, with selectable gain settings for different headphones and IEMs. The 3.5mm output delivers up to 177mW at 32 ohms in high gain, while the 4.4mm balanced output reaches up to 700mW at 32 ohms. That gives the EC Play more flexibility than a basic portable CD player, especially for listeners who use wired headphones and want more output than a phone dongle.
Connectivity is broader than CD playback alone. The EC Play includes a 3.5mm coaxial SPDIF digital output, allowing it to function as a compact CD transport for a DAC, hi-fi system, powered speakers, or compatible soundbar. It can also operate as a USB DAC, supporting PCM up to 384kHz/32-bit and DSD256 when connected to a laptop or smartphone.
Wireless support is included through Bluetooth 6.0, with two-way operation. The EC Play can work as a Bluetooth receiver for streaming from a phone or tablet, or as a transmitter to wireless headphones and speakers. Receiver mode supports LDAC, AAC, and SBC, while transmitter mode is limited to SBC. That distinction matters: the better wireless codec support applies when sending music into the EC Play, not when sending CD playback out to wireless headphones.
Battery life is rated at up to 12 hours from the 3450mAh battery, making this Shanling’s longest-lasting portable CD player to date. At $199 the EC Play is not just a throwback device. It is a portable CD player, headphone amp, USB DAC, Bluetooth receiver/transmitter, and compact digital transport in one small package.
The real question is whether the growing number of modern portable CD players from Shanling, FiiO, and others reflects actual demand, or whether everyone in Shenzhen decided the Discman needed a 2026 reboot and a balanced output.
shanling-ec-play-colors-stacked
Specifications
  • Display: 1.12-inch screen
  • Disc Support: CD, CD-R, CD-RW
  • Playback: Gapless playback
  • Drive System: Active magnetic clamp system with custom CD drive
  • DAC: Cirrus Logic CS43198
  • Headphone Amp: Dual SGM8262
  • Headphone Outputs: 3.5mm single-ended, 4.4mm balanced
    • Max Output Power:
      3.5mm: 177mW at 32 ohms
      4.4mm balanced: 700mW at 32 ohms
  • Digital Output: 3.5mm coaxial SPDIF
  • USB DAC: PCM up to 384kHz/32-bit, DSD256
  • Bluetooth: Bluetooth 6.0
  • Receiver Codecs: LDAC, AAC, SBC
  • Transmitter Codec: SBC
  • Battery: 3450mAh
  • Battery Life: Up to 12 hours
  • Dimensions: 142 x 125.1 x 26 mm
  • Weight: 418 g
  • Finishes: Feather Green, Onyx Black, Moonlight Silver
  • Price: $199 / €220 / £209
The Bottom Line
The Shanling EC Play is not just another cheap portable CD player with Bluetooth stapled on for marketing purposes. Its strongest selling points are the compact aluminum chassis, active magnetic clamp system, Cirrus Logic CS43198 DAC, dual headphone amps, 3.5mm and 4.4mm outputs, USB DAC mode, coaxial SPDIF output, and up to 12 hours of battery life. At $199, it sits in the sweet spot between basic CD nostalgia bait and the more expensive portable hi-fi players trying to turn a CD collection into a personality test.
What is missing? The big one is better Bluetooth transmission codec support. EC Play can receive LDAC, AAC, and SBC, but when sending audio out to wireless headphones or speakers, it is limited to SBC. That means the best listening experience will still come from wired headphones, especially through the 4.4mm balanced output. There is also no mention of onboard CD ripping, which gives the FiiO DM13 an advantage for users who want to archive discs to USB storage. FiiO’s DM13 includes CD ripping and both 3.5mm and 4.4mm outputs, while Moondrop’s DiscDream models also compete in the compact hi-fi CD player space.
Who is this for? The EC Play makes the most sense for listeners who still buy CDs, want a small portable player with a real DAC and headphone amp section, and plan to use wired headphones or IEMs. It is also a useful option for someone who wants a compact CD transport for a desktop DAC, hi-fi system, powered speakers, or soundbar. For Gen Z buyers building a physical media shelf while still living on TikTok and Spotify, it offers the ritual without demanding total analog obedience. For older listeners, it is basically a Discman with fewer bad memories and a balanced output.
The real competitors are the FiiO DM15 R2R, Moondrop DiscDream 2 ($179 at Amazon), Shanling’s own higher-end EC models, and cheaper lifestyle players like the Syitren R300 ($99 at Amazon). The EC Play’s job is to prove there is room for another modern portable CD player in a market that is suddenly more crowded than anyone expected. The question is not whether physical media has appeal again. It clearly does. The question is whether enough people want a $199 portable CD player with serious headphone output when the FiiO and Moondrop camps are already handing out Gordie Howe elbows in the same aisle.
Where to buy:
2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
2026 Sony Walkmans 2026 Sony Walkmans
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
Rega Replay Turntable Rega Replay Turntable
Rega Replay turntable weighs just 2.2 kg and reportedly costs £259. How does its skeletal design compare with the Planar 1 and its rivals?
2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection 2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection
Linn's new 343 brings Pistonik bass to a compact floorstander, with Exakt Integrated and powered-bass versions starting at $67,500 per pair. Worth the premium?
CD Players
FiiO’s $170 DP11 adds AES, a CS43198 DAC, CD ripping and USB conversion because apparently nobody told the compact disc it was dead.
DAPs
DAPs
Will Shanling DAPs and CD players cost more? AI demand is raising component prices and could force some models out of production.
Portable CD players are back in 2026. We compare 10 models from FiiO, Shanling, Moondrop, Cayin and Syitren, with prices and key features.
CD Players
Shanling’s $629 EC Zero T Max adds a 1.3-watt battery amp, revised R2R circuitry, dual JAN6418 tubes, USB DAC support and CD ripping.
CD Players
Cayin's $699 CP6 portable CD player combines dual tubes, Class A power, balanced output, Bluetooth, USB DAC support and CD ripping.
DAPs
DAPs
Shanling M0 Pura packs hi-res playback, dual DACs, microSD storage, Bluetooth, and USB DAC support into a tiny $129 DAP.
