CD Players
Shanling EC Zero T Max Gives Portable CDs 1.3 Watts Because the Original Was Apparently Too Polite
Shanling’s $629 EC Zero T Max adds a 1.3-watt battery amp, revised R2R circuitry, dual JAN6418 tubes, USB DAC support and CD ripping.
Shanling EC Zero T Max portable CD Player
Portable CD players are suddenly everywhere again, which is what happens when streaming fatigue collides with a physical format that costs less than vinyl and does not arrive warped. US CD sales jumped 16% to 16.3 million units during the first half of 2026, but many of the new portable players still force buyers to choose between mobility and enough power to drive demanding headphones.
The $629 Shanling EC Zero T Max addresses that problem with a revised battery-powered amplifier delivering up to 1,300mW into 32 ohms, while retaining the original model’s 24-bit R2R DAC, dual JAN6418 tubes, USB DAC, Bluetooth transmission and CD-ripping capabilities.
The CD revival has officially reached the stage where a Discman now requires resistor ladders, vacuum tubes and more output than some desktop amplifiers.
What Changed From the EC Zero T?
Shanling EC Zero T Portable CD Player
The Max is not a different finish wrapped around last year’s electronics.
Shanling replaced the original TPA6120-based headphone section with a revised amplifier built around the Analog Devices AD8397. The balanced 4.4mm output now produces as much as 1,300mW into 32 ohms in transistor mode and 1,162mW in tube mode while operating from the internal battery. The 3.5mm output reaches 361mW into the same load.
The original EC Zero T delivered 551mW into 32 ohms from its balanced output on battery power and required external DC power to reach its maximum 1,220mW specification. Its single-ended output was limited to 158mW on battery. The Max therefore supplies more power away from the wall than the previous model could produce even when plugged into one.
That matters because a supposedly portable player that requires an external power supply to unlock its best amplifier performance is portable in much the same way that a countertop microwave is technically movable.
Shanling has also reduced output impedance from 4.7 ohms on the original 3.5mm output and 6.6 ohms on the balanced output to approximately 0.4 and 0.7 ohms, respectively. That change may be even more useful than the additional power for owners of sensitive multi-driver IEMs, which can react unpredictably when connected to a source with high output impedance.
The R2R DAC Gets Revised Power and Signal Circuits
The EC Zero T Max retains Shanling’s in-house 24-bit R2R DAC module, built around 192 precision resistors with 0.1% tolerance. Users can choose between oversampling and non-oversampling modes, depending on whether they prefer conventional digital filtering or a more direct NOS presentation.
Shanling says it revised the DAC’s power supply and portions of the analog signal path using experience gained during the development of its newer PRO R2R platform. The company claims the changes produce a wider and deeper soundstage with greater midrange and treble transparency. Those claims will require listening rather than obediently copying the brochure, but this appears to be circuit-level work rather than a new firmware filter wearing a party hat.
The dual JAN6418 miniature vacuum tubes also return, with selectable tube and transistor output modes. Shanling isolates the tubes inside a damped mounting structure to reduce microphonic noise, which becomes especially important when two vacuum tubes are sharing a chassis with a spinning optical mechanism.
Still a CD Player and Quite a Bit More
The EC Zero T Max uses a custom CD mechanism with an active magnetic clamp and anti-skip system. It supports gapless CD playback and can rip discs in real time to an attached USB storage device as uncompressed WAV files.
It can also operate as a USB DAC, supporting PCM up to 32-bit/768kHz and DSD512. Analog connectivity includes separate 3.5mm and balanced 4.4mm headphone and line outputs, while coaxial and optical connections allow the Shanling to feed an external DAC or full-size audio system.
Bluetooth 5.3 transmission supports aptX Adaptive, aptX and SBC. The important word is transmission: the Shanling can send CD audio to compatible wireless headphones or speakers, but it is not advertised as a Bluetooth receiver for streaming music from a phone. LDAC is also absent.
The internal 5,500mAh battery is rated for up to eight hours through the single-ended output, approximately 7.5 hours through the balanced output and as much as 20 hours when the player is used as a Bluetooth transmitter.
ec-zero-t-max-portable-cd-player-top-open
Shanling EC Zero T Max Specifications
  • Type: Portable CD player, USB DAC and headphone amplifier
  • DAC: Shanling 24-bit R2R module
  • Resistor network: 192 resistors with 0.1% tolerance
  • Digital modes: Oversampling and non-oversampling
  • Tube stage: Two JAN6418 miniature vacuum tubes
  • Amplifier: AD8397-based revised headphone stage
  • Output modes: Tube or transistor
  • Balanced output: Up to 1,300mW into 32 ohms in transistor mode
  • Balanced tube output: Up to 1,162mW into 32 ohms
  • Single-ended output: Up to 361mW into 32 ohms
  • Headphone outputs: 3.5mm and 4.4mm balanced
  • Line outputs: 3.5mm and 4.4mm balanced
  • Digital outputs: Coaxial and optical
  • USB DAC support: PCM up to 32-bit/768kHz and DSD512
  • Bluetooth: Version 5.3 transmitter
  • Bluetooth codecs: aptX Adaptive, aptX and SBC
  • CD ripping: Real-time WAV ripping to USB storage
  • Battery: 5,500mAh
  • Battery life: Up to 8 hours wired or 20 hours over Bluetooth
  • Display: 1.68-inch color LCD
  • Construction: Aluminum chassis with tempered-glass panels
  • Dimensions: 6.2 x 5.9 x 1.1 inches
  • Weight: 1.47 pounds
  • Finish: Titanium gray
What Makes the EC Zero T Max Unique?
Portable CD players with balanced headphone outputs are no longer especially unusual. The Max separates itself by combining a custom R2R DAC, selectable physical tube stage, CD ripping, high-resolution USB DAC support and a genuinely powerful battery-operated amplifier in one component.
The critical improvement is not that it reaches 1.3 watts. The original model could approach that figure when connected to external power. The difference is that the Max provides its full amplifier output from the internal battery while also lowering output impedance enough to work more predictably with sensitive IEMs.
That gives it a broader range than most portable disc players. It can drive efficient earphones, more demanding over-ear headphones, powered speakers or an external DAC without requiring the owner to construct a small equipment shrine beside the CD case.
Three Alternatives
FiiO DM15 R2R
fiio-dm15-r2r-cd-player-silver-left
FiiO DM15 R2R
The $269.99 FiiO DM15 R2R is substantially less expensive and uses FiiO’s own 24-bit resistor-ladder DAC. It provides 3.5mm and balanced 4.4mm outputs, Bluetooth 5.4 transmission, USB DAC operation and digital outputs. Output reaches 812mW into 32 ohms on battery or 1,150mW in desktop mode.
The DM15 is lighter, cheaper and offers newer Bluetooth connectivity. The Shanling counters with substantially more battery-driven power, selectable tube and transistor stages, lower output impedance and a more elaborate analog section.
Cayin CP6
The $699 Cayin CP6 is the closest conceptual rival. It uses two JAN6418 tubes, offers classic tube, modern tube and solid-state sound modes, supports bidirectional Bluetooth 5.4 and includes USB DAC and CD-ripping functions. Its amplifier can produce as much as 1,300mW into 32 ohms when operating in DC power mode.
The Cayin offers more Bluetooth flexibility and three distinct output modes, but uses dual Cirrus Logic DACs rather than an R2R network. The Shanling also reaches its maximum balanced output on battery power rather than requiring external DC power.
Moondrop DiscDream 2 Ultra
The $349 Moondrop DiscDream 2 Ultra provides balanced and single-ended headphone outputs, an optical output, USB DAC operation and approximately eight hours of battery life. It is a simpler and much less expensive route into transportable CD playback.
It does not offer Bluetooth, CD ripping, an R2R DAC or a tube stage. The Moondrop makes sense for listeners who primarily want a well-built portable CD transport and headphone source rather than an entire personal-audio laboratory.
Who Is It For?
The EC Zero T Max makes the most sense for CD collectors who use a mixture of sensitive IEMs and full-size headphones and want one component that can travel between portable and desktop systems.
It also suits listeners who prefer R2R conversion or want the option of switching between a tube and solid-state presentation without purchasing two separate headphone amplifiers.
Who Should Avoid It?
Anyone who only wants to play CDs through efficient earbuds can spend substantially less on the FiiO DM15 R2R, Shanling EC Play or Moondrop DiscDream 2 Ultra.
The Max also lacks LDAC and Bluetooth reception, while its 1.47-pound weight stretches the meaning of “portable.” You can carry it, but nobody is clipping it to a tracksuit and running the Jersey Shore boardwalk unless their chiropractor has fallen behind on the boat payments.
The Bottom Line
The Shanling EC Zero T Max is the version the original EC Zero T probably should have been from the beginning.
It preserves the unusual combination of physical CD playback, R2R conversion and real vacuum tubes while addressing the original model’s most obvious weaknesses: limited battery-powered output and relatively high output impedance.
The result is not merely a louder EC Zero T. It is better suited to both demanding over-ear headphones and sensitive IEMs, while still functioning as a USB DAC, CD ripper, Bluetooth transmitter and digital transport.
Portable CD playback in 2026 has become remarkably sophisticated. It has also become remarkably expensive, but at least Shanling remembered to improve the parts that matter.
Price & Availability
The Shanling EC Zero T Max is priced at $629 and is now shipping to distributors. Shanling lists European pricing at €689 and says the player will be offered in titanium gray. Final US dealer pricing and local availability may vary as inventory reaches regional distributors.
For more information: en.shanling.com
1 Comment
1 Comment
  1. ORT
    July 28, 2026 at 1:22 am
    Hmmmm…In the centre console of my RAM EmoDiesel (my brother’s term for it!) I carry a $69 portable CD player for travel. Since I am a semi-invalid, I never travel…Damn me…Damn me all too well!
    Now is the Winter of our Disc-content made glortius Summer by this CD of Yorx…NOT! The Shanling EC Zero T Max (what a mouthful) is a bit more beautimus than others in the same way Sophia Loren is very pretty but Audrey Hepburn is more loverly. Hear me cry, “A wHorse! A wHorse! My Thingdom for a wHorse! Alas poor Yorx, I knew them wHoratio”…I take liberties, I know.
    I grow weary of steaming music. More often than not, I play the same records every week or so. Some CDs too on my Marantz CD60. I am my mother’s son. She would’ve liked this CD Player but we both enjoyed listening to my grandmother’s VINYL record of “Oklahoma!” far more than I ever realized until this moment in time.
    ORT
Goldmund Telos 9800 Amplifier - Front, Front Angle, Rear Views
Acoustic Signature-Merlin Neo Turntable in silver front angle view Acoustic Signature-Merlin Neo Turntable in silver front angle view
2026 Hegel H200 Integrated Streaming Amplifier Lifestyle Black 2026 Hegel H200 Integrated Streaming Amplifier Lifestyle Black
Hegel's H200 and A200 share a 150-watt Class AB platform, but buyers must choose between built-in streaming or a fully analog signal path.
2026 Bose QuietComfort 2nd Gen Wireless Headphones Lifestyle Colors 2026 Bose QuietComfort 2nd Gen Wireless Headphones Lifestyle Colors
Outdoor Tech Gift Guide Summer 2026
Suno will press AI songs onto $45 PETG records, but who actually needs one and does AI generated music belong in the vinyl revival?
DAPs
Will Shanling DAPs and CD players cost more? AI demand is raising component prices and could force some models out of production.
Portable CD players are back in 2026. We compare 10 models from FiiO, Shanling, Moondrop, Cayin and Syitren, with prices and key features.
CD Players
Cayin's $699 CP6 portable CD player combines dual tubes, Class A power, balanced output, Bluetooth, USB DAC support and CD ripping.
Global paid music subscriptions reached 865 million as streaming captured 86% of spending, while vinyl and physical music continued to grow.
Movies
