DAPs
Astell&Kern SP4000T Copper Gives Its Quad Tube Flagship DAP an Even Flashier Finish
The Astell&Kern SP4000T Copper adds a real copper chassis to its four tube flagship DAP, but does the new material improve anything beyond its finish?
2026 Astell&Kern SP4000T Copper DAP Group
Astell&Kern has taken a flagship digital audio player with four vacuum tubes, 54 possible sound configurations and enough mass to make the word “portable” feel legally optimistic, and decided that the missing ingredient was a copper chassis. The question is whether the new material offers any meaningful performance benefit or merely gives collectors another expensive object to polish.
The new Astell&Kern SP4000T Copper expands the recently introduced SP4000T line with a chassis made from copper rather than the stainless steel used for the original silver version.
Pricing and general availability have not been announced, and Astell&Kern has not explained the delay. The timing is worth watching, however. FiiO has already increased prices in response to sharply rising memory costs, while Shanling has warned that AI driven demand and higher component prices will affect both upcoming products and new production runs.
With 256GB of internal storage and no immunity from the same semiconductor supply chain, Astell&Kern may still be calculating the final price or adjusting its production schedule before making a commitment. That remains speculation until the company says otherwise, but the SP4000T Copper is entering a very different cost environment than the one in which the original player was developed.
astell-kern-sp4000t-copper-dap-front-angle
What Is Actually New?
The SP4000T Copper is not a second generation player or a substantially revised platform. Its internal architecture, amplification system, operating system and playback capabilities appear to be unchanged from the silver SP4000T announced ahead of High End Vienna in June 2026.
The original player is already something of an engineering fever dream. It is the first portable digital audio player to use four Raytheon JAN6418 MIL Spec vacuum tubes in a channel separated Quad configuration. Each tube is measured and paired before being mounted on its own modular circuit board.
Listeners can select Triode, Ultra Linear or Pentode tube operation, then combine those settings with OP AMP, TUBE AMP or five Hybrid amplification levels. Three adjustable tube current settings bring the total to as many as 54 possible combinations.
That is either an impressive degree of control or enough menu options to make one forget that the original purpose was listening to music.
Astell&Kern also employs a second generation, five stage anti microphonic system intended to reduce noise caused by movement and external vibration. That matters with subminiature tubes such as the JAN6418, which can become microphonic when used inside something that gets carried around, placed on a desk or dropped into a bag beside three charging cables and a set of keys.
Our hands on experience at CanJam London found the SP4000T powerful, responsive and far more commanding than its portable dimensions might suggest. It also weighs 565 grams, so slipping it into a trouser pocket remains a bold lifestyle choice.
astell-kern-sp4000t-copper-dap-back-angle
The SP4000 Platform With Four Tubes Added
The digital section combines two AKM AK4191EQ delta sigma modulators with two AK4499EX DACs in a fully separated architecture. The design keeps the digital processing and analog conversion stages apart, while the left and right channels receive their own dedicated signal paths.
Astell&Kern also includes its High Driving Mode, TERATON ALPHA power and noise management system, ESA signal alignment, Advanced DAR upsampling and Any Layer HDI circuit boards. Native playback extends to 32 bit/768kHz PCM and DSD512.
Balanced output reaches a claimed 8Vrms, while the 3.5mm single ended output delivers up to 4.2Vrms. Those figures should provide adequate power for most IEMs and a wide range of full size headphones, although difficult planar magnetic models may still be better served by a dedicated desktop amplifier.
Android 15 provides access to current streaming applications, while Astell&Kern’s ADP technology bypasses Android’s normal sample rate conversion to preserve bit perfect playback. The SP4000T is also the company’s first player to use dual Wi-Fi antennas, which Astell&Kern claims can produce approximately twice the 5GHz download performance of its previous design.
Other features include 256GB of internal storage, microSD expansion up to 1.5TB, a six inch 2160×1080 touchscreen, Bluetooth 5.2, aptX HD, LDAC, LHDC, BT Sink, USB DAC operation, ReplayGain, Crossfeed, AK File Drop and USB PD 3.0 charging. The internal 7,450mAh battery is rated for approximately 10 hours of playback, with a full charge requiring around five hours.
Does a Copper Chassis Really Matter?
Copper is substantially more electrically conductive than stainless steel. In a properly designed enclosure, that can make it an effective material for electromagnetic shielding and potentially improve heat distribution. But material conductivity alone does not guarantee better sound. Shielding performance also depends on chassis construction, panel seams, grounding, internal layout and how the enclosure is electrically connected to the circuits inside.
There is also an awkward detail for anyone preparing to claim that the copper exterior transforms the SP4000T: the regular stainless steel model already uses a 99.9 percent pure copper Shield Can around its sensitive audio circuitry. That internal component is specifically intended to block electromagnetic interference and reduce noise before the exterior chassis enters the discussion.
A full copper enclosure may provide another layer of shielding, but Astell&Kern has not published comparative noise measurements, distortion figures or listening test data showing that the Copper version performs differently from the stainless steel model.
The company has made similar claims for previous copper editions, including the SP4000 Copper, describing the material as beneficial for conductivity, shielding and signal integrity. It also applies a multilayer coating to limit oxidation and preserve the appearance of the copper surface. Those are technically plausible benefits, but they remain manufacturer claims unless supported by direct measurements between otherwise identical models.
In other words, the SP4000T Copper is not automatically snake oil. Copper is a legitimate engineering material, and this is more substantial than changing the paint color and inventing a paragraph about “earthy musicality.”
But without comparative test results, it is difficult to argue that the copper chassis will produce a meaningful audible improvement. The most obvious changes are appearance, exclusivity and possibly weight. The copper version is therefore best understood as a luxury material option with a technically defensible backstory, not a confirmed sonic upgrade.
If the price premium is modest, buyers may reasonably choose it for the appearance and added collectibility. If Astell&Kern adds several hundred dollars because copper apparently requires its own security detail, then customers will mostly be paying for jewelry that happens to play DSD512.
astell-kern-sp4000t-dap-fron-back-side
Key Specifications
  • DACs: Dual AKM AK4499EX
  • Digital processors: Dual AKM AK4191EQ
  • Vacuum tubes: Four Raytheon JAN6418 MIL Spec tubes
  • Amplification: OP AMP, Tube and five stage Hybrid modes
  • Tube operation: Triode, Ultra Linear and Pentode
  • Maximum configurations: 54
  • Maximum playback: 32 bit/768kHz PCM and DSD512
  • Display: Six inch, 2160 x 1080 touchscreen
  • Operating system: Android 15
  • Internal storage: 256GB
  • Expansion: microSD cards up to 1.5TB
  • Balanced output: 4.4mm, up to 8Vrms
  • Single ended output: 3.5mm, up to 4.2Vrms
  • Wireless: Dual band Wi Fi, Bluetooth 5.2
  • Bluetooth codecs: aptX HD, LDAC, LHDC, AAC and SBC
  • Battery: 7,450mAh
  • Rated playback: Approximately 10 hours
  • Standard model dimensions: 85.7 x 150 x 19.5mm
  • Standard model weight: 565 grams
The Bottom Line
The Astell&Kern SP4000T was already one of the most elaborate portable players on the market, combining four vacuum tubes, multiple amplification modes, flagship AKM conversion and enough output power to challenge some desktop systems.
The Copper edition does not appear to change any of that. It wraps the existing platform in a more conductive, more visually distinctive and almost certainly more expensive enclosure.
Could the copper chassis provide incremental shielding or thermal benefits? Yes.
Has Astell&Kern demonstrated that it sounds better? Not yet.
For existing SP4000T owners, this is not an upgrade. For buyers who were already considering the player and prefer copper, it is a legitimate material choice. For collectors, it will probably be irresistible because Astell&Kern understands that the shortest route to an audiophile’s wallet sometimes involves a periodic table.
Price & Availability
Astell&Kern has not announced final Copper edition pricing. Its global product page currently lists the standard SP4000T at $3,300, while several U.S. dealers list the silver model at $3,620. That makes it reasonable to expect the copper version to land above $3,500, although any exact figure would be speculation until Astell&Kern confirms it.
August 2026 Demonstrations
Astell&Kern says the SP4000T Copper will be available for demonstration at several upcoming audio events in China and the United States.
The August calendar includes the Hong Kong High End Audio Visual Show, running August 7-9 at the Hong Kong Convention and Exhibition Centre, followed by SIAS Shenzhen from August 14-16 at the Shenzhen Convention and Exhibition Center.
The major U.S. portable audio event later in the month is CanJam SoCal, scheduled for August 29 and 30 at the Irvine Marriott in California.
2026 Audiolab PPA7 Phono Preamp Black LIfestyle
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
2026 T+A Solitaire T Pro Wireless Headphones 2026 T+A Solitaire T Pro Wireless Headphones
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
2026 Vinnie Rossi Canta Integrated Amplifier Angle 2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
2026 Sony Walkmans 2026 Sony Walkmans
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
DAPs
DAPs
FiiO’s M25 VERITA and M25 R2R finally launch with AKM or resistor-ladder DACs, 1.7W per channel, 31-band PEQ and the same price.
DAPs
Portable CD players are back in 2026. We compare 10 models from FiiO, Shanling, Moondrop, Cayin and Syitren, with prices and key features.
DAPs
DAPs
Shanling M0 Pura packs hi-res playback, dual DACs, microSD storage, Bluetooth, and USB DAC support into a tiny $129 DAP.
