Buchardt Audio Announces S400 MK3 Bookshelf Speaker With Major Design Upgrades
Buchardt Audio unveils the S400 MK3 bookshelf speaker with a larger cabinet, new drivers, and refined crossover. Can it dominate the $2,400 standmount class?
Burchardt S400 MKIII Bookshelf Loudspeaker Natural Oak Front 2026
Great loudspeakers come from all corners of the world, and Denmark has produced more than its fair share of them. Buchardt Audio may not have the century long legacy of some of its Nordic neighbors, but the company has built a loyal following over the past decade with a simple formula: compact loudspeakers that deliver a far bigger, fuller sound than their modest size might suggest.
That approach was cemented with the original S400, which we reviewed in 2021 and quickly became one of the most recommended standmount speakers in its class. Buchardt refined the concept shortly thereafter with the S400 MKII, introducing a revised crossover and higher quality internal components, followed by the S400 MKII Signature with further tuning refinements. For 2026, the Danish brand is pushing the platform forward once again with the announcement of the S400 MK3, the next chapter in a design that has been evolving since its first prototype appeared in 2016.
buchardt-s400-mkiii-loudspeaker-black
Buchardt S400 MK3
Buchardt Audio S400 MK3: Larger Cabinet, New Drivers, and a Ground Up Redesign
The S400 MK3 represents a significant redesign of Buchardt’s most recognizable loudspeaker platform. The new model introduces a larger cabinet, newly developed drivers, improved treble resolution, and greater dynamic capability, while aiming to preserve the balanced and natural presentation that helped define the earlier S400 models. According to Buchardt, almost nothing from the previous S400 generation carries over to the MK3, with the exception of the speaker binding posts.
One of the most visible changes with the S400 MK3 is the increase in cabinet size. Buchardt has expanded the internal volume by roughly 18 percent, giving the designers more room to extend low frequency performance and increase overall dynamic headroom. Despite the added volume, the company says the cabinet retains the clean proportions and minimalist aesthetic that made the original S400 such a recognizable design.
buchardt-s400-mkiii-loudspeaker-natural-oak
S400 MK3 Tweeter: New 26 mm Aluminum Dome with Custom Waveguide
The S400 MK3 features a newly developed 26 mm (1.02-inch) aluminum dome tweeter paired with a redesigned waveguide. Rather than chasing extra brightness or exaggerated top end energy, Buchardt focused on improving refinement and perceived resolution.
The goal was greater clarity and treble detail while maintaining the smooth, natural presentation that has defined the S400 series. According to the company, the new tweeter and waveguide combination helps deliver more precise high frequency dispersion and improved integration with the midbass driver, without introducing listening fatigue.
S400 MK3 Woofer: 7.5-Inch SB Acoustics Driver with Satori PAPYRUS Cone
At the core of the S400 MK3 is a 7.5-inch woofer sourced from SB Acoustics, built around the company’s Satori PAPYRUS paper cone technology. Compared with the driver used in the S400 MKII, the new unit offers 65.5 percent greater displacement headroom, giving the MK3 significantly more room to move air.
The result is increased dynamic capability, stronger bass authority, and more physical impact from a standmount speaker that still maintains relatively compact proportions. Combined with the 18 percent increase in cabinet volume, the new woofer gives the S400 MK3 greater low frequency extension and overall scale than previous versions of the design.
buchardt-s400-mkiii-loudspeaker-walnut-rear
S400 MK3 Bass System: Rear Port Replaces the Passive Radiator
Rather than continuing with the passive radiator used in earlier S400 models, the S400 MK3 adopts a rear mounted portand a traditional bass reflex design. The change allows Buchardt to deliver bass that remains tight, extended, and powerful while taking advantage of the larger cabinet and higher displacement woofer.
The trade off with any ported design is the possibility of minimal port noise under very specific conditions, but in normal listening this should remain largely inaudible. Placement remains relatively flexible for a rear ported speaker; Buchardt recommends leaving at least 5 cm (2 inches) of space between the port and the rear wall to ensure proper airflow and consistent low frequency performance.
S400 MK3 Crossover: Simplified Network with Premium Jantzen Components
Buchardt continues its partnership with Jantzen Audio for the S400 MK3’s crossover network. The updated design uses premium components throughout the signal path but adopts a somewhat simpler topology than the network used in the previous S400 MKII.
The new crossover employs first order filters, a design choice often associated with improved phase coherence and a more natural integration between drivers. While simpler in layout, the network still relies on high quality components to maintain the tonal balance and musical flow that have defined the S400 platform.
Comparison
S400 MK3
(2026)
S400 MKII Signature Edition
(2023)
S400 MKII
(2021)
S400
(2019)
Product TypeBookshelf SpeakerBookshelf SpeakerBookshelf SpeakerBookshelf Speaker
Price (Pair)$2400$2,850$2,400$1,833
Operating Principle2-way passive bass reflex system2-way passive radiator system2-way passive radiator system2-way passive radiator system
Tweeter1″ Waveguided custom aluminum dome with neodymium matrix motor0.74″ Custom fine weave soft fabric textile with CDC aluminum waveguide0.74″ Custom fine weave soft fabric textile with CDC aluminum waveguide0.74″ Custom fine weave soft fabric textile with CDC aluminum waveguide
Mid / woofer7.5” SB Acoustics Satori PAPYRUS™ paper cone with  6″ Linear long stroke paper cone6″ Linear long stroke paper cone6″ Aluminum cone with break-up optimization
Passive Radiator–5×8″ Long stroke passive radiator5×8″ Long stroke passive radiator5×8″ Long throw passive radiator with very low mass added
PortYes–––
Impedance4 ohms4 ohms4 ohms4 ohms
Sensitivity88 dB87 dB87 dB87 dB
Frequency response +/- 3dB (in-room)33 – 20,000 Hz33 – 40,000 Hz33 – 40,000 Hz33 – 40,000 Hz
Crossover Point2400hz1800hz1800hz2000hz
Power RecommendationFrom 30 watts –  Upper limit depends on use case, please contact Budchart for recommendations.40 – 200 W40 – 200 W40 – 200 W
Dimensions (HWD)392 x 198 x 280 mm
(15.4” x 7.8” x 11”)
365 x 180 x 280 mm
(14.4” x 7” x 11”)
365 x 180 x 280 mm
(14.4” x 7” x 11”)
365 x 180 x 240 mm
(14.4” x 7” x  9.4”)
Weight (each)8.5 kg7.5 kg7.5 kg9 kg
Speaker Grilles4 x 7.5″ Included Black acoustical optimized fabric grillesIncludedIncludedIncluded
Cabinet15mm Fiberboard HMR.E2 Moisture-proof with internal bracing. Either painted or real wood veneered.15mm HDF with internal bracing.15mm Fiberboard HMR.E2 Moisture-proof with internal bracing.
15mm Fiberboard HMR (Moisture-proof) with internal bracing
buchardt-s400-mkiii-speaker-terminals-rear
The Bottom Line
The Buchardt Audio S400 MK3 continues a design philosophy that Buchardt clearly believes in: compact standmount speakers engineered to deliver the scale, bass authority, and dynamics normally associated with much larger loudspeakers. With its larger cabinet, higher displacement woofer, new waveguided tweeter, and simplified crossover, the MK3 looks like a meaningful evolution of a platform that has been steadily refined since 2016.
At $2,400 USD per pair, the S400 MK3 enters one of the most competitive segments in the loudspeaker market. Models from KEF, Wharfedale, Paradigm, Acoustic Energy, and Chesky Audio are all fighting for the same buyers looking for high performance from relatively compact cabinets. The S400 MK3’s appeal will likely come down to its reputation for delivering big, room filling sound and strong bass output from a standmount design, making it a compelling option for listeners who want serious scale without moving to floorstanding speakers.
buchardt-s400-mkiii-loudspeaker-black-grille-off
Pricing and Availability
The S400 MK3 is available through Buchardt’s website for pre-order, with 75 pairs offered per finish at the introductory price (see below). Estimated delivery is expected to start by late Summer 2026.
  • S400 – $2,400 in black/white or $2,574 in real wood veneer (US)
  • S400 – €2,300 in black/white or €2,450 in real wood veneer (EU)
Pre-order now at buchardtaudio.com and save €200.
2 Comments
2 Comments
  1. Pierre Martinez
    April 24, 2026 at 5:58 pm
    Great speaker brand. I have never heard the S400, but the E50’s sounded great at Axpona this year.
    I just purchased the Buchardt P300 as that is within my budget.
    The P300 is very well balanced; I do not need anything else for my 11 by 14 feet room.
    I am glad I bought them and also I met Mads at Axpona this year; great person.
    • Ian White
      April 27, 2026 at 11:13 am
      Pierre,
      I agree. He’s earned his success the old fashioned way. I really like what he’s bringing to the table.
      IW
2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle 2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Can Castle’s new Tintagel and Walmer speakers challenge established rivals with ribbon tweeters, real wood cabinetry, and pricing from $2,749?
Can a $1,100 Canadian standmount really embarrass pricier rivals? Paradigm’s 220B v2 makes a surprisingly convincing case and looks the part.
Is the Triangle Borea BR04 a true upgrade over the BR03? We compare soundstage, bass, dynamics, RoomFit, and value.
Buchardt Audio’s E50-S adds a larger Satori woofer, higher sensitivity and new tuning as an alternative to the acclaimed E50.
Does the Triangle AIO Twin look better in Macassar? The $899 wireless stereo system adds real wood veneer while keeping vinyl and hi-res streaming.
