Triangle AIO Twin Gets a Macassar Makeover Because French Speakers Refuse to Dress Down
Does the Triangle AIO Twin look better in Macassar? The $899 wireless stereo system adds real wood veneer while keeping vinyl and hi-res streaming.
2026 Triangle AIO Twin Wireless Speakers in Macassar Lifestyle
The Triangle AIO Twin was already one of the better dressed wireless speaker systems under $1,000, but apparently French audio companies consider standing still a form of surrender.
Triangle has introduced a new Macassar finish for the AIO Twin, wrapping its compact cabinets in a genuine wood veneer inspired by Macassar ebony. The dark brown base is crossed by vertical grain and fine golden highlights that shift in appearance depending on the lighting and viewing angle.
In other words, it should look considerably more expensive than another pair of rectangular black boxes parked beside your turntable.
The new veneer is paired with the AIO Twin’s familiar oblong magnetic grille, now covered in a deep brown fabric supplied by Scandinavian textile specialist Gabriel. The combination gives the system a warmer, more traditional appearance that should work particularly well in Art Deco, mid-century and contemporary interiors.
Related Reading: Triangle AIO Twin Wireless Speakers and Thetis 340 Subwoofer Review
Same Speaker, Better Suit
triangle-aio-twin-wireless-speakers-macassar
Triangle has not made any acoustic or connectivity changes for the Macassar edition.
The AIO Twin remains a two-speaker stereo system built around one active loudspeaker containing the amplification and connections. The second passive speaker is powered through the supplied three-meter speaker cable.
Each cabinet uses a 1-inch silk-dome tweeter and 5-inch midrange/bass driver, with 50 watts of Class D amplification available for each channel. Triangle specifies a frequency response of 56Hz to 22kHz and recommends the system for rooms measuring up to approximately 269 square feet.
Wi-Fi streaming supports files up to 24-bit/192kHz, while Bluetooth 5.0 includes aptX, aptX HD, aptX LL, AAC and SBC. AirPlay, Spotify Connect, UPnP/DLNA playback and Triangle AIO multiroom support are also included.
Available streaming services through the Triangle AIO app include Spotify, Qobuz, TIDAL, Deezer, Amazon Music and TuneIn internet radio.
triangle-aio-twin-wireless-speaker-macassar-back
Physical connections include a switchable RCA line-level/MM phono input, 3.5mm auxiliary input, optical digital input, Ethernet, USB-A for storage devices or charging and a mono subwoofer output. The USB connection does not operate as a USB DAC input for a computer.
Why the AIO Twin Still Works
When we reviewed the AIO Twin, its warmer tonal balance, texture, dynamic punch and fatigue-free presentation made it a more appealing long-term listen than Triangle’s less expensive Borea BR03 BT.
The AIO Twin also produced surprisingly convincing bass for its size, although adding a subwoofer remains worthwhile for larger rooms, movies or listeners determined to remind the neighbors that they still own a copy of Madvillainy.
The system’s versatility continues to be its strongest selling point. Buyers can connect a turntable, stream high-resolution music, add a CD player, improve the sound from a television and build a multiroom system without purchasing a separate amplifier or network streamer.
The omissions have not changed either. There is still no HDMI ARC/eARC input, which makes TV integration less seamless than it could be, and the USB-A port cannot be used as a digital connection from a laptop or desktop computer. Optical works perfectly well with a television, but HDMI would make volume and power control easier.
Macassar veneer cannot fix that, although it does make the disappointment look rather elegant.
triangle-aio-twin-wireless-speaker-macassar-grille-on-lifestyle
The Bottom Line
The Macassar edition does not improve the sound, add HDMI or turn the AIO Twin into an entirely new product. It simply gives one of the most versatile wireless stereo systems under $1,000 a more luxurious finish.
For listeners who want real stereo sound, vinyl playback, high-resolution streaming and TV connectivity without filling the room with components and cables, the AIO Twin remains a compelling option. It now also looks considerably less likely to have arrived with the office furniture.
Price & Availability
The Triangle AIO Twin wireless speakers are available for $899/pair at Amazon and Best Buy in English Green, Abyss Blue, Linen Grey, White, Black, Brown Maple, Eggplant, and now Macassar. However, the Macassar finish appears to be out of stock on Triangle’s U.S. website at the time of publication.
2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
2026 Sony Walkmans 2026 Sony Walkmans
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
Rega Replay Turntable Rega Replay Turntable
Rega Replay turntable weighs just 2.2 kg and reportedly costs £259. How does its skeletal design compare with the Planar 1 and its rivals?
2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection 2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection
Linn's new 343 brings Pistonik bass to a compact floorstander, with Exakt Integrated and powered-bass versions starting at $67,500 per pair. Worth the premium?
Is the Triangle Borea BR04 a true upgrade over the BR03? We compare soundstage, bass, dynamics, RoomFit, and value.
Can Sonos 27 make existing speakers more useful with AI control, portable rear surrounds and direct Wi-Fi headphone linking?
Naim’s CI-Uniti 102 combines 150 watts per channel, streaming, HDMI eARC, and multiroom flexibility in a compact amplifier that raises awkward questions for the...
Will Nagaoka’s Japanese cartridge and stylus price increases reach the U.S. now that MoFi Distribution has taken over American distribution?
WiiM is bringing its streamers, amplifiers, speakers, and home theater products to Best Buy nationwide. The bigger question is whether the retailer can properly...
