Acoustic Energy AE2 40th Anniversary Standmount Speakers Debut at North West Audio Show 2026
Can the Acoustic Energy AE2 40th Anniversary speakers deliver AE1 precision with greater bass, scale, and output for larger listening rooms?
Acoustic Energy AE2 40th Anniversary Loudspeaker in Walnut Front
Acoustic Energy is extending its anniversary campaign with the AE2 40th Anniversary, a limited-edition standmount loudspeaker that will make its world premiere at the North West Audio Show in Cranage, UK, on June 27-28, 2026.
Following the AE1 40th Anniversary in 2025 and the launch of the fully analog AE Active at High End Vienna 2026, the new AE2 looks back to one of the British brand’s more ambitious compact loudspeaker designs—only with considerably more modern engineering under the gloss finish.
Rather than simply dusting off an old badge and hoping nostalgia does the heavy lifting, Acoustic Energy has redeveloped the AE2 around the later AE2 Signature concept. The new speaker uses technology derived from the AE1 40th Anniversary, adds internal steel reinforcement to reduce cabinet coloration, and is positioned above the AE1 for listeners who want more scale, bass weight, and dynamic capability without surrendering the placement flexibility and imaging strengths of a proper standmount.
The AE2 40th Anniversary will be demonstrated publicly for the first time ahead of its wider launch later this summer. Acoustic Energy’s intent is clear: take the compact-monitor attitude that made the AE1 famous and give it enough muscle to annoy a small floorstander.
From Acoustic Energy: “Building on the unprecedented success of the AE1 40th Anniversary Edition, the AE2 uses the same newly developed woofer and tweeter drive units from the AE1. The AE2 40th Anniversary derives from the legacy of the highly renowned flagship ‘AE2 Signature’ model of the 1990s. The same technological refinements from the AE1 have been used to update the performance to today’s level, along with aesthetic detail sympathetic to the original.”
Acoustic Energy AE2 40th Anniversary Loudspeakers (walnut)
Driver Design
The AE2 40th Anniversary uses the same newly developed tweeter and mid/bass driver platform as the AE1 40th Anniversary, but applies it to a larger offset MTM configuration intended to deliver more bass extension, headroom, and authority. Acoustic Energy has also added strategically placed internal steel plates to reduce cabinet coloration and help the larger enclosure match the quieter, more controlled behavior of its smaller sibling.
The 29mm anodized aluminum dome tweeter carries over the AE1 40th Anniversary’s larger 29mm voice coil and slightly increased radiating area. Like the original AE designs, it is ferrofluid cooled and damped, a combination intended to improve power handling, dynamics, and thermal stability without abandoning the metal-dome character that helped define the brand.
The mid/bass drivers use Acoustic Energy’s spun, hard-anodized aluminum cone design, reinforced with a thick ceramic coating on both sides. The 125mm cone offers more radiating area than the original AE1 driver, which Acoustic Energy says contributes to higher efficiency, lower distortion, and greater air displacement. In the AE2, that shared driver platform is paired with the larger cabinet and twin-driver arrangement to give the speaker more scale than the AE1.
Reduced Cabinet Coloration
Acoustic Energy AE2 40th Anniversary Loudspeakers in black
Acoustic Energy AE2 40th Anniversary Loudspeakers (black)
Acoustic Energy has scaled up the AE2 40th Anniversary with greater bass extension and dynamic headroom, which the company says should translate into lower distortion through the midband and greater transparency at typical listening levels.
The goal was to retain the tonal character and punchy dynamics of the smaller AE1 40th Anniversary within a larger offset M-T-M driver layout. That required more than simply adding a second mid/bass driver and three front-firing bass-reflex ports. To keep the larger enclosure’s coloration in line with the AE1, Acoustic Energy has added strategically placed internal steel plates to the cabinet structure.
The idea is straightforward: deliver the scale and authority expected from a small floorstander while preserving the low coloration, imaging precision, and placement flexibility that made the AE1 such a compelling standmount in the first place.
Performance and Amplifier Matching
Acoustic Energy positions the AE2 40th Anniversary for listening rooms of around 25 square meters (about 270 square feet) and larger, where its additional bass extension and dynamic headroom should give it more authority than the smaller AE1 40th Anniversary.
Its published specifications support that positioning: a claimed frequency range of 35Hz to 45kHz, measured within ±6dB; 88dB sensitivity at 1 metre/2.83V; a nominal 6-ohm impedance; and 200 watts of power handling. Those are sensible figures for a substantial standmount designed to play with more scale and composure than its dimensions might suggest.
The AE2 is not being pitched as a difficult loudspeaker, but it should reward an amplifier with proper current delivery and some reserve power. The goal is the weight and room-filling authority of a compact floorstander, combined with the imaging, low cabinet coloration, and placement flexibility that remain central to the AE1 and AE2 design philosophy.
Crossover & Cabinet Finish
The AE2 40th Anniversary uses a minimalist, low-order crossover network set at 2.2kHz. Acoustic Energy says the approach is intended to preserve the lively, direct character of the original AE2 Signature, rather than bury the music beneath a small mountain of crossover components.
The cabinet is available in High Gloss Black or High Gloss Walnut, with each finished in ten layers for a properly luxurious appearance. At 385 x 235 x 315mm (HWD) and 14.5kg each, the AE2 is a substantial standmount, but not one that requires a civil-engineering permit before you put it on proper stands.
Comparison
Acoustic Energy ModelAE2 40th Anniversary EditionAE1 40th Anniversary Edition
Product TypeStandmount SpeakerStandmount Speaker
Price (pair)€2,799 £1,049 – £1,500
Design2-way, Three front reflex ports2-way, twin front reflex ports
Tweeter1 x 29mm anodized aluminium dome1 x 29mm anodized aluminium dome
Mid/Bass Driver2 x 125mm spun, hard-anodised aluminium cone1 x 125mm spun, hard-anodised aluminium cone
Frequency Range (±6dB)35 Hz – 45 kHz50Hz – 45kHz
Sensitivity (1m/2.83V)88 dB87dB
Power Handling200 W150W
Crossover Frequency2.2 kHz2.8kHz
Impedance6 ohms6 ohms
Cabinet18–32mm RSC HDF/bitumen construction, braced18–22mm RSC HDF/bitumen construction, braced
GrillesCloth, magnetic fitCloth, magnetic fit
Dimensions (HWD)385 x 235 x 315mm295 x 180 x 255mm
Weight14.5 kg each7kg each
FinishesHigh Gloss Walnut, High Gloss BlackHigh Gloss Walnut, High Gloss Black
The Bottom Line
The AE2 40th Anniversary is not simply an AE1 40th Anniversary in a larger cabinet with a fancier badge. Its real purpose is to take the newer AE1-derived driver platform and apply it to a larger offset M-T-M design with twin mid/bass drivers, three front-firing ports, and additional steel cabinet reinforcement.
That makes it the more ambitious option for AE1 fans who want greater bass weight, higher output capability, and more convincing scale in rooms of roughly 270 square feet and larger, but still prefer the imaging precision and placement flexibility of a proper standmount speaker.
It is aimed at listeners with a capable amplifier, proper stands, and no interest in buying a full-size floorstander simply because their room needs more than a compact monitor can comfortably deliver. The AE2’s appeal is straightforward: more authority than the AE1 without abandoning the fast, direct, metal-driver character that made Acoustic Energy’s original compact speakers such enduring cult favorites.
Price & Availability
The AE2 is expected to be available by the end of 2026 with a recommended retail price of €2,799 per pair (US pricing not yet available) with a choice of Walnut or Piano Black finishes through Authorized Acoustic Energy Dealers in the US, UK, and Other Regions.
For those attending the UK Northwest Audio Show held from June 27-28, getting a listen to these will be worth the stop.
2026 Audiolab PPA7 Phono Preamp Black LIfestyle
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
2026 T+A Solitaire T Pro Wireless Headphones 2026 T+A Solitaire T Pro Wireless Headphones
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
2026 Vinnie Rossi Canta Integrated Amplifier Angle 2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
2026 Sony Walkmans 2026 Sony Walkmans
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
Does the Triangle AIO Twin look better in Macassar? The $899 wireless stereo system adds real wood veneer while keeping vinyl and hi-res streaming.
Are the $1,499 Wharfedale Super Denton truly the British Bulldog of standmount speakers, and do they justify their place in the Heritage lineup?
At $499 per pair, the versatile Edifier R2750DB MKII wireless speakers feature three-way sound, HDMI eARC and LDAC Bluetooth for desktop, bookshelf or stand-mount...
Loudspeakers
Dynaudio says U.S. warranties will remain valid after its North American exit, but repair centers and future distribution remain unresolved.
Loudspeakers
NEAD will distribute Jamo, Energy, Juke Audio, XLO and OXS across the U.S. and Canada as two familiar speaker brands plan their return.
Loudspeakers
Dynaudio says support will continue as it exits North America and closes its U.S. subsidiary, but dealer and warranty questions remain.
