Aavik Introduces R-188, R-288, and R-588 Phono Preamps Starting at $20,000
Are Aavik’s R-x88 Series the ultimate phono stages for MC and DS Audio optical cartridge users, or just Danish analog excess?
Aavik R-588 Phono Preamplifier Front Angle
Aavik Acoustics, part of Audio Group Denmark, has introduced three phono preamplifiers labeled as the R-188, R-288, and R-588 for ultra high-end vinyl playback systems using Moving Coil cartridges or DS Audio optical cartridges. Built around trickle down technology from Aavik’s flagship R-880 ($73,500) reference phono stage, the new R x88 Series is aimed at listeners who already live deep in the analog trenches and probably don’t need anyone explaining why a $20,000 phono preamp exists.
This is the same Danish audio group behind Børresen, whose $1.15 million M8 Gold Signature loudspeakers we recently covered, so nobody should be shocked that Aavik’s idea of “more accessible” still starts at $20,000.
External phono preamps, also known as phono stages, remain one of the most important but least understood parts of a serious vinyl playback system. Their job is to properly match the output of the phono cartridge to the amplifier or preamp that follows, while applying the RIAA equalization curve that restores the tonal balance of the original recording.
Most phono stages support Moving Magnet cartridges, some add Moving Coil support, but the Aavik R x88 Series takes a more specialized route with MC and DS Audio optical cartridge compatibility. Standard MM cartridge users need not apply.
Aavik R x88 Phono Stage Series
Aavik Acoustics’ three model R x88 Series lineup starts at $20,000 for the R-188 phono preamp, and steps up an additional $5,000 for the R-288 and R-588, respectively. That is Aavik’s version of connecting with a “broader audience,” which still assumes your vinyl budget has its own climate controlled room.
Aavik says the goal is a quiet, low noise connection between cartridge and amplifier that preserves the detail, dynamics, and tonal information cut into the record groove. Each unit is handcrafted in Aalborg, Denmark, using in house production and selected Danish and international partners.
aavik-r588-back
All R x88 models have the same rear panel and inputs.
R x88 Series Shared Features
Versatility: The Aavik R x88 Series supports both Moving Coil cartridges and DS Audio optical cartridges, with adjustable gain and filter settings for system matching. Standard Moving Magnet cartridge support is not included, which makes this a very specific product for very specific vinyl systems.
Noise Rejection: The R x88 Series incorporates Integrated Ansuz Active Tesla Coils, Square Tesla Coils, Analog Dither Circuits, and Anti Aerial Resonance Coils. These technologies are designed to reduce unwanted electrical noise and preserve low level detail before the signal reaches the amplifier.
Extreme Low Noise Floor: The Aavik R x88 Series uses a discrete RIAA input stage built around ultra low noise bipolar transistors arranged in parallel. Aavik specifies a 94 dB signal to noise ratio measured at 1 kHz, which is critical when dealing with the very low output levels of MC cartridges. The Moving Coil input stage is also balanced and floating, meaning it is not connected to ground.
Resonant Mode Power Supply: The R x88 Series also uses custom DC/DC converters designed to generate clean sine wave voltages with very low noise and minimal distortion. The goal is to provide a stable, quiet power foundation for the phono circuit, because with vinyl playback, noise does not need an invitation. It usually finds a way in.
Advanced Circuit Design: The flagship Aavik R 588 adds Aavik’s discrete operational amplifiers and independent voltage rails, which are intended to improve resolution, dynamics, and transparency. In plain terms, the R 588 is where Aavik pushes the circuit design harder for systems where every upstream choice is already under a microscope.
Connectivity: For all of the internal complexity, the R x88 Series keeps the rear panel relatively straightforward. Separate inputs are provided for turntables fitted with Moving Coil and DS Audio optical cartridges, with clearly labeled connections for each. Analog audio line outputs are included for connection to an amplifier or receiver, while RS 232 and 12V trigger connections provide external wired control. A power inlet and rear power switch are also included.
Front Panel Display and Controls: The Aavik R x88 Series includes a large front panel display that shows the active input, display brightness, display dimming, software version, and factory reset option. To the left of the display are physical controls for Standby, Mute, and Input Select/Menu operation. Aavik also includes a wireless remote control for more extensive access, because at $20,000 and up, reaching for the front panel should remain strictly optional.
Cabinet Construction: The Aavik R-x88 series phono preamps were designed by Flemming Erik Rasmussen and Michael Børresen. The hybrid enclosure combines wood, copper, and steel. This combination is designed to support exceptional resonance control and structural stability, complemented by a visually appealing cabinet design.
aavik-r588-front-corner-top
The physical design of all Aavik R x88 models are the same.
Key Differences Between Models
R-188: The Aavik R-188 is the “entry level” model in the R-x88 Series, which is doing a lot of work when the starting price is $20,000. It features 36 Active Tesla Coils, 72 Active Square Tesla Coils, and 3 dither circuits.
R-288: The Aavik R-288 steps up from the R-188 with 72 Active Tesla Coils, 144 Active Square Tesla Coils, and 6 dither circuits. Aavik positions the additional noise reduction hardware as a path to greater clarity and lower noise within the same core platform.
R-588: The Aavik R-588 is the flagship model in the R-x88 Series, with 108 Active Tesla Coils, 216 Active Square Tesla Coils, and 9 dither circuits. It also adds discrete operational amplifiers and independent voltage rails, making it the most advanced version of the lineup for systems where the phono stage is expected to do more than just sit quietly on the rack looking expensive.
aavik-r588-rear-corner
Comparison
Aavik ModelR-188 R-288 R-588
Product TypePhono PreampPhono PreampPhono Preamp
Price$20,000$25,000$30,000
MC (Moving Coil) InputsFloating RCA (1 set)
Max input: 5mVrms
Gain: 58dB or 64dB @ 1 kHz
Input load resistance adjustable from 50 ohm to 10k ohm
Max input: 5mVrms
Max input: 5mVrms
Frequency Response (MC) 58dB: +0.1/-0.4dB (20Hz-20kHz)
64dB: +0.1/ 1.1dB (20Hz-20kHz)
Optical InputRCA (1 set)
Max input: 500mVrms
Gain: 26dB
RCA (1 set)
Max input:
500mVrms
Gain: 26dB
RCA (1 set)
Max input: 500mVrms
Gain: 26dB
Frequency Response (Optical) +0.1/-0.3dB (20Hz-20kHz) +0.1/-0.3dB (20Hz-20kHz) +0.1/-0.3dB (20Hz-20kHz)
Output1 pair of RCA outputs.
Distortion: <0.05% (THD at 1kHz, nominal input)
Output impedance: 70 ohms
AAVIK Noise ReductionActive Tesla Coils: 36
Active Square Tesla Coils: 72
Dither circuitry: 3
Active Tesla Coils: 72
Active Square Tesla Coils: 144
Dither circuitry: 6
Active Tesla Coils: 108
Active Square Tesla Coils: 216
Dither circuitry: 9
Power ConsumptionStandby: <1W
On: <15W
Standby: <1W
On: <15W
Standby: <1W On: <40W
Dimensions440 x 430 x 116mm
17.3 x 16.9 x 4.6 inches
440 x 430 x 116mm
440 x 430 x 116mm
Weight21kg / 46lbs 21kg / 46lbs 21kg / 46lbs
Mains Voltage and Current100-240V AC – 50-60 Hz max 3,15 A 100-240V AC – 50-60 Hz max 3,15 A 100-240V AC – 50-60 Hz max 3,15 A
Enclosure Classification (IP rating)IP10 IP10 IP10
aavik-r188-front
The Bottom Line
The Aavik R-x88 Series phono stages are not for casual vinyl listeners, MM cartridge users, or anyone still debating whether an external phono preamp is worth it. These are ultra high end analog components built specifically for systems using Moving Coil or DS Audio optical cartridges, with serious attention paid to noise reduction, power supply design, and signal purity.
What makes the R-x88 Series unusual is the combination of MC and optical cartridge support, Aavik’s extensive use of Ansuz noise reduction technologies, and a three model structure that starts at $20,000 and only climbs from there. The R-188, R-288, and R-588 are clearly aimed at vinyl listeners who have already invested heavily in the turntable, cartridge, amplification, and loudspeakers surrounding them.
Who is this for? The obsessed analog listener with a very serious system, a very quiet listening room, and a willingness to spend real money chasing the last few layers of resolution from the groove. Everyone else can keep walking. Denmark has locked the door behind them.
Price & Availability
All Aavik products are available through Authorized Audio Group Denmark Dealers.
2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle 2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Aavik U-301 Unity Amplifier combines streaming, DAC, preamp and 300-watts per channel in a $17,000 all-in-one component.
AVID HiFi launches Pulsus II and Pellar II phono preamps with MM and MC support, lower noise, and refined analog performance.
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
