AVID HiFi Introduces Pulsus II and Pellar II Phono Preamps With Adjustable MM and MC Cartridge Support
AVID HiFi launches Pulsus II and Pellar II phono preamps with MM and MC support, lower noise, and refined analog performance.
AVID HiFi Pulsus II and Pellar II Phono Preamps
Following the May 2026 launch of its flagship Velsonic phono preamp, AVID HiFi is expanding its analog lineup with the Pulsus II and Pellar II phono stages. Both models replace long-serving originals: the Pulsus, introduced in 2010, and the Pellar, which followed in 2012. That is a respectable run in any product category, but especially one built around a format that some people were still declaring dead when those first models arrived.
The vinyl train keeps rolling, and there is no sign that anyone has found the brakes. In 2026, buyers have more turntables, phono cartridges, phono preamps, record-cleaning machines, tonearms, cables, mats, clamps, and other playback accessories to choose from than at any point in the past two decades. AVID’s updated Pulsus II and Pellar II arrive in a market that is no longer treating vinyl as a nostalgic side hobby, but as a serious and increasingly sophisticated part of the high-performance audio ecosystem.
On the inside, both models retain much of what made the originals successful, with targeted performance refinements wrapped in a cleaner, more streamlined exterior. AVID is not a company that releases new models every year simply because it has something new to promote. The original Pulsus and Pellar earned considerable recognition for their musicality, engineering integrity, and long-term reliability—qualities that kept both phono stages relevant for well over a decade.
That kind of longevity suggests that AVID got the fundamentals right from the beginning. The Pulsus II and Pellar II are therefore not reinventions for the sake of it, but the result of genuine advances in design, materials, and the company’s deeper understanding of how these circuits can be improved.
avid-hifi-pellar-ii-phono-stage-back
AVID Pulsus II and Pellar II: Refined, Not Reinvented
The Pulsus II and Pellar II build on the foundations of their predecessors with refinements in several critical areas. AVID points to more careful component selection and improved noise-reduction strategies, intended to deliver greater transparency, lower noise floors, stronger dynamic expression, and a more natural presentation of music. Both models also offer flexible adjustment options for Moving Magnet (MM) and Moving Coil (MC) cartridges.
As noted earlier, the Pulsus II and Pellar II arrive shortly after the launch of AVID’s flagship Velsonic phono preamp. Together, the three models give serious vinyl listeners a broader range of options based on their cartridge requirements, preferred feature set, and budget.
AVID’s expanded three-model phono preamp lineup reflects the company’s continued focus on meaningful engineering rather than annual cosmetic updates. The Velsonic, Pulsus II, and Pellar II mark a new phase for AVID Hi-Fi in the phono-stage category, with choices that extend from more attainable high-performance designs to a no-compromise flagship.
Plusus II and Pellar II Differences: Highlights
Plusus II Pellar II
Two-piece form factor with separate Phono Preamp and Power Supply Units Single-piece Phono Preamp with built-in Power Supply
Dual-mono circuit design with dedicated power regulationSingle board configuration with Low-Noise Op-Amps
Default cartridge loading for MM cartridges at 47K, along with adjustable Cartridge Loading for MM or MC cartridges as needed via DIP switches at the bottom of the unit. Preset 47k for MM cartridges with adjustable resistance for MC cartridges via custom plugs or rear-panel loading
avid-hifi-pulsus-ii-psu-stack
Detailed Comparison
AVID HiFi ModelPulsus II (2026)Pulsus (2010)Pellar II (2026)Pellar (2012)Velsonic (2026)
Product TypePhono PreampPhono PreampPhono PreampPhono PreampPhono Preamp
Price£2,995 / €3,995 / $4,695Discontinued£1,450 / €1,995 / $2,295Discontinued$19,995 / £11,995 / €15,995
Circuit Design Dual-mono topology with dedicated power regulationDual-mono topology with dedicated power regulationSingle-board configuration with low-noise op-amp topologySingle-board configuration with low-noise op-amp topologyFull dual-mono and balanced operation from input to output, which minimizes crosstalk and maximizes channel separation.
Phono Cartridge CompatibilityMoving Magnet (MM)
Moving Coil (MC)
Moving Magnet (MM)
Moving Coil (MC)
Moving Magnet (MM)
Moving Coil (MC)
Moving Magnet (MM)
Moving Coil (MC)
Moving Magnet (MM)
Moving Coil (MC)
Cartridge LoadingHigh flexibility; multiple resistance (100R–47k) & capacitance (100pf–500pf) settings via bottom DIP switchesHigh flexibility; multiple resistance (100R–47k) & capacitance (100pf–500pf) settings via bottom DIP switchesPreset 47k for MM; adjustable resistance via custom plugs or rear-panel loadingPreset 47k for MM; adjustable resistance via custom plugs or rear-panel loadingAdjustable via front panel controls
Inputs1 (pr) x RCA  w/Ground1 (pr) x RCA  w/Ground2 (pr) x RCA with Ground2 (pr) x RCA with Ground1 (pr) x RCA
1 (pr) x XLR
With Ground
Outputs1 (pr) x RCA Line1 (pr) x RCA Line1 (pr) x RCA Line1 (pr) x RCA Line1 (pr) x RCA Line
1 (pr) x XLR
Noise< -81dB MM
<-67dB MC
< -81dB MM
<-67dB MC
< -81dB MM
<-67dB MC
< -81dB MM
<-67dB MC
< -81dB MM
 <-67dB MC
Distortion< 0.001%< 0.001%< 0.001%< 0.001%< 0.001%
RIAA Equalization5Hz – 70kHz ±0.5dB5Hz – 70kHz ±0.5dB5Hz – 70kHz ±0.5dB5Hz – 70kHz ±0.5dB5Hz – 70kHz ±0.5dB
Gain40dB – 60dB – 70dB40dB – 60dB – 70dB48dB – 60dB – 70dB48dB – 60dB – 70dB35dB-40dB-45dB-50dB-55dB-60dB-65dB-70dB
Resistance100R – 300R – 500R – 1K – 5K – 10K – 47K100R – 300R – 500R – 1K – 5K – 10K – 47K47K – 500Ω – CUSTOM47K – 500Ω – CUSTOM10R-30R-100R-200R-300R-400R-500R-800R-1K-5k-10K-47K
Capacitance100pf – 200pf – 500pf100pf – 200pf – 500pf100pf100pf100pf – 200pf – 500pf – 1.5nf – 10nf – 20nf
Subsonic FilterNoneNoneNoneNone1st ORDER SLOPE, -3dB@10Hz
Output Impedance20Ω20Ω20Ω20Ω20Ω
ControlsUnderside controls for:
Gain Level (MM – MC Low and MC High)
Resistance
Capacitance
Resistance
Capacitanc
Front-panel rotary controls allow you to switch gain, resistance, and capacitance without needing to open the chassis or use DIP switches.
Power Supply External Power SupplyRegulated with a 35VA transformerExternal Power SupplyRegulated with a 35VA transformerSingle-chassis integrated power supply
Internally Regulated 25va Transformer
Double Regulated with 300va Toroidial Transformer
Vottage Input100-240vac 50/60Hz 10 Watts Max100-240vac 50/60Hz 10 Watts Max100-240vac 50/60Hz 10 Watts Max100-240vac 50/60Hz 10 Watts Max100-240vac 50/60Hz 10 Watts Max
Dimensions (WDH)160 x 239 x 70mm
(6.3 x 9.41 x 2.8 in)
PSU: 160 x 247 x 70mm (6.3 x 9.72 x 2.8 in)
120 x 220 x 70mm160 x 253 x 70mm
(6.3 x 9.96 x 2.8 in)
120 x 220 x 70mm463 x 338 x 100mm
(18.23 x 13.31 x 4 in) Preamp and PSU Combined
Net Weight1.3 kg
(2.9 lbs)
PSU: 1.9 kg (4.2 lbs)
1.0 kg
(2.2 lbs)
PSU: 1.7 kg (4 lbs)
1.9 kg
(4.2 lbs)
1.6 kg
(3.5 lbs)
12.2 kg
(27 lbs)
PSU: 14.9 kg (33 lbs)
avid-hifi-pulsus-ii-rear-angle
The Bottom Line
The AVID Pellar II and Pulsus II are not budget phono preamps with a nicer faceplate. Both are serious, UK-built MM/MC phono stages aimed at vinyl listeners who have moved beyond the built-in phono input on an integrated amplifier and want lower noise, better cartridge matching, and a more substantial long-term analog upgrade.
What makes AVID’s new pair interesting is the company’s refusal to treat either model as a disposable annual refresh. These are successors to designs that remained in service for more than a decade, now updated with revised component selection, lower-noise engineering, and a cleaner industrial design. The Pellar II is the more accessible entry point for listeners with one well-chosen turntable and cartridge, while the Pulsus II is the step-up option for systems where the phono stage is expected to extract more from a serious moving coil cartridge and a higher-resolution analog front end.
Competition is not exactly thin. The $2,495 MoFi UltraPhono Pro offers front-panel gain and loading adjustments, balanced and single-ended outputs, and a very different feature set. The $2,899 Cyrus 40 PPA adds four configurable inputs, balanced outputs, remote control, and upgrade potential for listeners running multiple turntables or tonearms. The tube-based Muarah MU-2 remains another compelling option around the Pellar II’s price, particularly for listeners who want easy cartridge loading changes and a warmer, more relaxed presentation.
The obvious question is whether the $4,695 Pulsus II delivers enough of a performance advantage over the $2,295 Pellar II to justify its substantial premium. That answer will depend heavily on cartridge quality, system resolution, and how deeply invested the buyer is in moving coil playback. For most vinyl listeners, the Pellar II is likely to be the more rational AVID entry point. The Pulsus II is for owners of more ambitious analog systems who are willing to pay considerably more to chase lower noise, greater refinement, and a higher ceiling.
And yes, there are far less expensive ways into external phono preamps. The iFi ZEN Air Phono 2 remains a sensible low-cost MM/MC option, but it belongs in a different conversation.
avid-hifi-pellar-ii-front-angle
Price & Availability
The AVID HiFi Pulsus II and Pellar II phono preamps are designed and manufactured in the UK. Both will be available through authorized AVID dealers worldwide beginning July 2026.
  • The Pulsus II is priced at £2,995 / €3,995 / $4,695.
  • The Pellar II is priced at  £1,450 / €1,995 / $2,295.
2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
2026 Sony Walkmans 2026 Sony Walkmans
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
Rega Replay Turntable Rega Replay Turntable
Rega Replay turntable weighs just 2.2 kg and reportedly costs £259. How does its skeletal design compare with the Planar 1 and its rivals?
2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection 2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection
Linn's new 343 brings Pistonik bass to a compact floorstander, with Exakt Integrated and powered-bass versions starting at $67,500 per pair. Worth the premium?
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Are Aavik’s R-x88 Series the ultimate phono stages for MC and DS Audio optical cartridge users, or just Danish analog excess?
iFi's ZEN Air Phono 2 adds MM and MC support with accurate RIAA playback and low noise, offering a flexible $129 upgrade for turntables...
Rega's Aos MC borrows from the company’s $7000 reference phono stage at around $2300. Is it the new sweet spot for serious MC vinyl...
At $2,495, MoFi Electronics’ UltraPhono Pro brings MasterPhono design DNA to a more attainable phono preamp with fully discrete, low noise, MM/MC flexibility, and...
