Three years ago, iFi Audio introduced a rather unusual flagship headphone amplifier. The original iCAN PHANTOM could handle sensitive IEMs, dynamic headphones, demanding planar magnetics, and electrostatic headphones from the same chassis, eliminating the separate energizer normally required for the latter.
That remains an extremely uncommon combination, but it is not new for 2026.
With the iCAN PHANTOM 1.5, iFi is not reinventing its $3,749 flagship or dramatically increasing its already formidable output power. Instead, it has concentrated on making an amplifier that was already designed to accommodate almost any headphone easier to match, easier to control, and somewhat easier to live with.
The biggest changes include a wider 0dB, 12dB, and 24dB gain range, stronger IEMatch attenuation for sensitive earphones, a new VU meter display, revised controls and interface, and expanded Nexis app functionality. The underlying proposition remains the same: one rather expensive box instead of several rather expensive boxes.
Headphone collectors will understand the distinction immediately. Everyone else is probably wondering when owning multiple $3,000 headphones became a problem requiring its own consolidation strategy.
Related Reading:
- The Best Headphones From CanJam London 2026
- STAX SR-009D Debuts: Iconic Electrostatic Headphone Line Gets Its Most Advanced Update Yet
- Audeze CRBN2 Electrostatic Headphone At CanJam NYC 2026: Is This The Best Headphone In The World?
One Amplifier for Almost Everything
The $3,749 iCAN PHANTOM 1.5 is an analog headphone amplifier, preamplifier, and electrostatic energizer designed to handle IEMs, conventional dynamic headphones, difficult planar magnetics, and electrostatic models from one chassis.
Power is certainly not the problem. The PHANTOM can deliver more than 15,000mW maximum balanced into 16 ohms, more than 9,030mW RMS balanced into 32 ohms, and more than 27V into a 600-ohm load. Single-ended output reaches more than 5,760mW maximum into 16 ohms and more than 3,120mW RMS into 32 ohms.
For electrostatic headphones, the PHANTOM provides a 230V Normal Bias output and a Pro/Custom output with selectable bias settings from 500V to 640V. The electrostatic drive stage itself is rated at up to 640V RMS in Custom/Pro mode and 320V RMS in Normal mode.
iFi iCAN PHANTOM 1.5 Specifications
- Type: Analog headphone amplifier, preamplifier, electrostatic energizer
- Amplification: Fully differential balanced PureWavePRO
- Input Stages: Discrete Class A solid-state and Class A tube
- Tubes: Matched General Electric 5670 pair
- Modes: Solid-State, Tube, Tube+
- Maximum Balanced Power: >15,000mW into 16 ohms
- RMS Balanced Power: >9,030mW into 32 ohms
- Maximum Single-Ended Power: >5,760mW into 16 ohms
- Maximum Balanced Voltage: >27V into 600 ohms
- Electrostatic Output: Up to 640V RMS
- Gain: 0dB, 12dB, 24dB
- IEMatch Attenuation: Up to 12dB single-ended / 24dB balanced
- Frequency Response: 0.5Hz to 500kHz, -3dB
- SNR: >145dB(A) balanced / >130dB(A) single-ended
- Dimensions: 10.1 x 7.3 x 4.7 inches
- Weight: 9.3 pounds
- Price: $3,749 USD
Tubes or Solid-State? Pick One
The PHANTOM 1.5 uses two separate switchable Class A input stages rather than inserting tubes into a common signal path. The solid-state section uses discrete JFET circuitry, while the tube stage employs matched GE 5670 tubes.
There is also Tube+, which reduces loop gain and negative feedback to emphasize more of the tubes’ harmonic character. In practical terms, owners can move between solid-state, Tube, and Tube+ without owning three amplifiers — which is useful considering headphone enthusiasts have demonstrated a remarkable ability to fill every available shelf.
XBass offers three levels of analog low-frequency adjustment, while XSpace provides separate spatial processing matrices for headphones and loudspeakers. The 1.5 revision also increases gain from the original PHANTOM’s 0/9/18dB settings to 0/12/24dB, while stronger IEMatch attenuation provides more usable volume range with highly sensitive IEMs.
A new VU meter display, revised user interface, improved volume control feel, anti-fingerprint glass coating, and expanded Nexis app support round out the changes. Nexis can handle remote control, diagnostics, firmware updates, product renaming, resets, and real-time monitoring of tube condition.
The Bottom Line
There are alternatives, but this remains a very short list.
The Apos x ES Lab HYDRA, which won one of our Best in Show awards at CanJam SoCal 2026, can drive conventional dynamic and planar magnetic headphones along with 580V Pro Bias electrostatic models. Plus its 20-watt-per-channel speaker output adds another layer of flexibility.
The two amplifiers approach the problem rather differently. The HYDRA uses a fixed 580V electrostatic bias and puts greater emphasis on versatility between headphones and loudspeakers. The iCAN PHANTOM 1.5 goes further at the extremes, however, with IEMatch for sensitive earphones and selectable electrostatic bias settings that accommodate a broader range of electrostatic headphones. It also adds Solid-State, Tube, and Tube+ operating modes, three gain settings, XBass, XSpace, and app-based control.
The Linear Tube Audio Z10e is more expensive alternative. At $6,950, it can drive electrostatic, dynamic, and planar magnetic headphones while also functioning as a 12-watt-per-channel integrated amplifier for loudspeakers. It is considerably more expensive and follows a very different all-tube design philosophy.
What keeps the PHANTOM 1.5 unusual is not simply that it can drive electrostatic headphones; the original PHANTOM already did that. It is the combination of electrostatic support, substantial power for difficult planar magnetics, low-noise operation and attenuation for sensitive IEMs, selectable tube and solid-state stages, adjustable analog processing, and extensive load matching in one chassis.
At $3,749, calling it inexpensive would require a concussion. But for someone already using separate amplifiers for IEMs, planar headphones, and electrostatics, the consolidation argument is not nearly as absurd as the price initially makes it sound.
Pricing & Availability
The iFi Audio iCAN PHANTOM 1.5 is priced at $3,749 USD and is available through iFi Audio and select authorized dealers.
Related Reading:
- Apos Launches $1,800 SJY Argos Electrostatic Headphones And $2,200 Hydra Amp For Headphones And Speakers
- Audeze CRBN2 Electrostatic Headphones Review: Is It Time To Sell Your Loudspeakers?
- IFi’s ICAN Phantom Headphone Amp Will Drive Planar & Electrostatic Headphones
- Meet The STAX SR-007S—Electrostatic Tech So Next-Level, Your Old Headphones Are Jealous
