Audio Group Denmark Debuts New Børresen A-Series Loudspeakers at High End Vienna 2026
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
2026 Borresen A-Series Loudspeakers
Børresen is not exactly known for thinking small. Earlier this year, Audio Group Denmark introduced the Børresen M8 Gold Signature, a $1,150,000 loudspeaker built for listeners whose upgrade path apparently includes private banking and reinforced flooring. But at High End Vienna 2026, the Danish brand is showing the other side of its loudspeaker strategy: the new Børresen A-Series, a more attainable lineup positioned between the company’s X-Series and C-Series models.
The new A-Series includes three models: the A1 standmount, and the A2 and A3 floorstanding loudspeakers. Designed and assembled in Aalborg, Denmark, the range brings core Børresen engineering and cabinet design into a part of the lineup that sits well below the brand’s six- and seven-figure flagships, but still above its entry-level X-Series. In other words, this is Børresen trying to make its technology more accessible without pretending that “affordable” suddenly means cheap.
borresen-a1-stand-mount-speakers
Børresen A1
DCC5s Neo Driver Technology
The A-Series uses Børresen’s in-house 5-inch DCC5s Neo mid-bass and bass drivers, built around a three-layer composite diaphragm. A Nomex aramid honeycomb core is sandwiched between carbon fiber skins, giving the cone high stiffness while keeping moving mass low.
Børresen also integrates graphene into the diaphragm structure to increase rigidity and help move unwanted resonances outside the driver’s operating range. The motor system uses a ferrite magnet structure with dual copper caps to reduce inductance in the voice-coil gap. The goal is lower distortion, improved linearity, and faster response to the input signal.
RP94 Ribbon Planar Tweeter
The A-Series uses Børresen’s RP-94 planar ribbon tweeter, a driver also found in the company’s more expensive loudspeakers. Its aluminum-coated membrane weighs just 0.01 grams, allowing it to respond quickly to transient information and reproduce high frequencies with very low moving mass.
In the A-Series, the RP-94 operates from 2.5 kHz to 50 kHz, with sensitivity rated up to 89 dB depending on the model. That extension reaches well beyond the limits of human hearing, but the real point is speed, low distortion, and improved integration with the mid-bass drivers through the crossover region.
borresen-a2-loudspeakers-2026
Børresen A2
Venting
Instead of using a conventional bass-reflex port, the A-Series employs a controlled rear-venting system designed to manage internal air movement without tuning the cabinet around a single dominant resonance frequency. The goal is to reduce compression effects inside the enclosure while avoiding the kind of port behavior that can make bass sound bigger than it actually is.
That approach should help the A-Series deliver cleaner low-frequency performance and a more open presentation, without leaning on artificial bass reinforcement to make a smaller cabinet seem larger.
2.5 Way Configuration
The A-Series follows Børresen’s 2.5-way design approach for the A2 and A3, while the A1 uses a 2-way configuration. The crossover and driver integration are designed to keep frequency distribution as coherent as possible across the operating range.
Compared with more complex 3-way designs, a well-executed 2-way or 2.5-way layout can reduce crossover complexity, minimize phase issues, and preserve more of the signal between amplifier and drivers. The intended result is better integration between drivers, more stable imaging, and a presentation that sounds cohesive rather than stitched together.
borresen-a3-loudspeakers-2026
Børresen A3
Resonance & Grounding
As with all Børresen loudspeakers, resonance control and mechanical grounding remain integral design philosophy. The A-Series is designed to work in synergy with Ansuz Darkz resonance-control devices, designed specifically to lower mechanical noise and improve mechanical stability.
Finishes
The A-Series enclosures are offered in satin walnut and satin black ash finishes, giving the speakers a more restrained Scandinavian look than some of Børresen’s costlier statement models. The design also nods to the original Børresen 0-Series, but in a simpler, more approachable form.
The vision behind the A-Series has been with me for a long time, rooted in the ideas that shaped the 0-Series. The goal was not to replicate it, but to carry that philosophy forward — refining it, simplifying it where possible, and making it more accessible without losing its essence.”  — Michael Børresen, Co-founder & CTO, Audio Group Denmark
Børresen A-Series Speakers Comparison
borresen-a-series-loudspeakers-angle
Børresen ModelA1A2A3
Product TypeBookshelf/Stand-mount SpeakerFloorstanding SpeakerFloorstanding Speaker
Price (pair)EUR 10,000
USD 12,000
EUR 16,000
USD 19,000
EUR 21,000
USD 25,000
Speaker Type2-Way, Vented2.5 Way, Vented2.5 Way, Vented
Tweeter 1 x RP94 Ribbon Planar 1 x RP94 Ribbon Planar 1 x RP94 Ribbon Planar
Bass/midrange Driver 1x Børresen DCC5s driver 1x Børresen DCC5s driver 1x Børresen DCC5s driver
Bass Driver Not Applicable1x Børresen DCC5s driver 2x Børresen DCC5s driver
Frequency response 45Hz – 50kHz 35Hz – 50kHz 25Hz – 50kHz
Sensitivity 89 dB/1W 89 dB/1W 89 dB/1W
Impedance Ω >6 Ω >6 Ω >6 Ω
Recommended Amplifier Power> 50 W > 50 W > 50 W
Dimensions (HWD) Without stand
41.7 cm x 21.1 cm x 44.6 cm
16.42 in x 8.31 in x 17.56 in
With stand:
112.3 cm x 29.5 cm x 46.4 cm
44.21 in x 11.61 in x 18.27 in
113.2 cm x 30 cm x 57.8 cm
44.57 in x 11.81 in x 22.76 in
132 cm x 34.4 cm x 62.3 cm
51.97 in x 13.54 in x 24.53 in
Weight Without stand
14 kg / 30.9 lbs
With Stand
27.5 kg / 60.6 lbs
44 kg / 97.0 lbs 54 kg / 119.0 lbs
Finish Walnut, Black ash, White Walnut, Black ash, White Walnut, Black ash, White
Borresen A3 Top Angle
Børresen A3 (top)
The Bottom Line
The Børresen A-Series is not “affordable” in the normal human sense of the word, but for Børresen, a lineup starting around $12,000 per pair does represent a more attainable step into the brand’s loudspeaker ecosystem. That matters because the A-Series is not just a cosmetic exercise. It brings core Børresen technologies into a lower price tier, including the RP-94 planar ribbon tweeter, in-house 5-inch DCC5s Neo drivers, low-mass composite diaphragms with graphene reinforcement, controlled rear venting, and a simpler 2-way or 2.5-way crossover approach depending on the model.
What makes the A-Series interesting is not that Børresen has suddenly gone budget. It has not. The real story is that Audio Group Denmark is trying to make its speed, low-mass driver philosophy, and Danish-built cabinet execution available well below its cost-no-object models, including the seven-figure M-Series flagships. That still leaves the A-Series in a brutally competitive price class, with strong alternatives from brands like Wilson Audio, Audience, Auer Acoustics, Aequo Audio, and others. At this level, spec sheets are only the first round. The buying decision will come down to whether the A-Series delivers the kind of speed, coherence, imaging, and tonal balance that justifies the price in the room where it actually has to play music.
borresen-a1-stand-mount-speaker-angle
Børresen A1
Price & Availability
After its showing a High End Vienna, the Børresen A-Series speaker line will be available beginning October 2026 through Authorized Audio Group Denmark Dealers at the following prices (may vary by region):
  • Børresen A1 – EUR 10,000 / USD 12,000
  • Børresen A2 – EUR 16,000 / USD 19,000
  • Børresen A3 – EUR 21,000 / USD 25,000
2026 Beyerdynamic AVENTHO Y Wireless Headphones in white lifestyle
Can beyerdynamic shake up $150 wireless headphones? AVENTHO Y adds ANC, 90 hour battery life, Bluetooth 6.0 and replaceable parts.
2026 AWOL LuxVision UST Projector Lifestyle 2026 AWOL LuxVision UST Projector Lifestyle
Can AWOL's $5,999 LuxVision change premium UST projection with 4K/120Hz, 6,000 ISO lumens, 10,000:1 contrast and optical image shift?
2026 Kaleidescape Compact Terra Prime 246TB SSD Movie Server 2026 Kaleidescape Compact Terra Prime 246TB SSD Movie Server
Can the Atlantis Lab AT-23 Pro deliver deep bass and room-filling dynamics without a subwoofer? Our review explains why it deserves attention.
Klipsch debuts Reference Premiere III at Audio Advice Live 2026 with Onkyo, a 7.4.4 Atmos system, anniversary Klipschorn and Rebellion.
The $1,099 Q Acoustics 3040c brings twin C3 drivers to smaller rooms, but costs only $100 less than the larger 3050c in the U.S.
