Chesky Audio LC2 Is a $1,995 Speaker Built for Your Den and Desktop Use: AXPONA 2026
Chesky Audio LC2 debuts at AXPONA 2026 with a $1,995 per pair price, unique 3D printed cabinet design, and a clear focus on affordable high end sound.
Chesky Audio LC2 Stand-mount Speakers at AXPONA 2026
Sometimes the best finds at AXPONA 2026 aren’t planned. I walked into Chesky Audio’s room chasing Schiit Audio gear in Room 709; there was plenty of it, including the Yggdrasil Singular DAC, Loki Max, Kara, and a pair of Tyr monoblocks driving the new Chesky LC2 loudspeakers, but no one from Schiit to talk shop. So I stayed put, listened, and let the room tell its own story.
That story changed fast when the pricing banner came into focus: $1,995. Not each. Per pair. In a show full of six-figure loudspeakers, the Chesky LC2 doesn’t just feel affordable; it feels like a direct challenge to how high-end audio defines itself.
And that’s where this gets more interesting. If high-end audio wants a future, it needs more designers like Lucca Chesky. He comes from a family name that carries real weight in the music world, but he’s not coasting on it. He’s studying engineering at Carnegie Mellon University, and it shows in how he approaches both design and people.
There’s no gatekeeping here, no “you don’t belong in this room” energy. The LC1 and now the LC2 are priced where actual listeners can engage, and he speaks about them in a way that makes you feel like you’re part of the conversation and not being lectured from behind a stack of gear you can’t afford.
The kid gets it. And judging by what I heard in that room, he’s not just talking a good game.
Admittedly, a $1,995 price tag only matters if the speakers can actually deliver. The original Chesky LC1 set a high bar, earning multiple “Best of Show” nods from the eCoustics team at previous events; something Chesky made no effort to hide with the awards laid out on the table. So yes, I was a bit late to the party.
Better late than never.
I stayed for several tracks to get a clearer sense of what the team had already heard in the Chesky LC1, and what that might mean for the new Chesky LC2. It didn’t take long to recognize a familiar foundation, but with more scale and a bit more weight behind it, suggesting this isn’t a departure so much as a more developed version of the same idea.
chesky-schiit-room-axpona-2026
Chesky Audio LC2 Stand-mount Speakers with Schiit electronics at AXPONA 2026
An Affordable Speaker With Real Ambition
Much like the original Chesky LC1, the Chesky LC2 sticks to a compact two way monitor format. It pairs a dual chamber aperiodic 1 inch tweeter with a roughly 6.5-inch mid bass driver, both modified in house rather than pulled off a shelf. The familiar passive radiator approach is still here as well, now using larger 8-inch radiators on either side to extend low frequency output without relying on a traditional port.
Where things diverge, and where Chesky is clearly doing its own thing, is the cabinet. The front baffle is a 5/8-inch thick slab of machined aluminum, and the rest of the enclosure is 3D printed around that structure. It is an unusual approach, but the result is a cabinet that feels both rigid and relatively lightweight for its size. Each speaker measures roughly 13 x 9 x 13 inches and comes in just under 30 pounds.
It is also worth noting that these are not outsourced, mass produced boxes. Chesky Audio assembles, finishes, and tests the speakers in New Jersey before they ship. In a category where “designed here, built somewhere else” is the norm, these are actually made in the United States, and that still matters.
Lucca Chesky is also quick to point out that the drivers are not an afterthought. The mid-bass unit uses a cast-basket high-definition design more commonly found in higher-priced speakers, and the tweeter follows that same philosophy. He stops short of naming suppliers, but the implication is clear this is not generic OEM hardware.
chesky-schiit-axpona-2026
Schiit Audio stack powered the Chesky Audio LC2 Speakers at AXPONA 2026.
The crossover is designed in house, although Chesky remains somewhat tight-lipped on specifics. Instead of locking into a fixed number, the crossover point is described as falling somewhere in the 3 to 5 kHz range. On paper, the speaker is rated at 86 dB sensitivity with a 4 ohm impedance that does not dip below 3.1 ohms across a stated 40 Hz to 20 kHz frequency range.
That combination suggests an easy enough load for most modern amplifiers, whether it is a vintage Kenwood receiver, a newer NAD integrated, or even a well-sorted ST-70 style tube amp build. But if our experience with the Chesky LC1 taught us anything, it is that specs do not tell the whole story. The LC1 benefited from more power than you might expect, and giving it better amplification paid off.
Until we get the Chesky LC2 in for a full review, it is too early to say how closely it follows that pattern.
Chesky LC2 in a Real Room at AXPONA 2026
Sound wise, the Chesky LC2 delivers clean mid-bass with solid detail and impact for a speaker of this size, but sub-bass is limited. That is not a surprise given the form factor. In a nearfield setup such as a desktop or small studio, there is enough low end to get by without a subwoofer, but in a larger room, adding one would make sense.
The midrange is where things come into better focus. There is a clear emphasis on clarity and balance, which aligns with what you would expect from anything carrying the Chesky name. Vocals come through naturally without sounding nasal or forced, and strings have enough presence to avoid sounding thin. That is not always a given with compact speakers, where cabinet limitations can work against natural timbre. The construction here likely plays a role, but that is something that needs more controlled listening to fully evaluate.
The top end had good energy and dynamic presence, but this is where the limitations of the show environment start to creep in. Between room noise and less than ideal setup conditions, it would be premature to draw firm conclusions without spending more time with the speakers in a more controlled space.
The Bottom Line
I can see several use cases for the Chesky LC2. Those looking for unpowered monitors for nearfield use will find them easy to live with as a standalone pair, and they also make sense in smaller rooms where space is limited. For larger spaces or mixed use systems that pull double duty for music and home theater, Chesky offers two, three, and five speaker packages that can be built out as needed.
Adding a subwoofer would round things out in those scenarios. Models like the REL Tzero or SVS 3000 Micro R|Evolution come to mind as good matches, offering tight, controlled low end without taking over the room or the budget.
With that kind of setup, the LC2 starts to make a lot of sense for multi purpose spaces where flexibility matters just as much as performance.
Where to buy: $1,995/pair at Chesky Audio
Lampizator Horizon 2 DAC
LampizatOr’s Horizon 2 adds Aphrodite tech, a redesigned tube stage and upgrades for owners who already spent car money on a DAC.
C Seed Bugatti TV at CEDIA Expo 2026 C Seed Bugatti TV at CEDIA Expo 2026
C SEED and Bugatti turn a folding 4K MicroLED television into a 137-inch kinetic sculpture with Tourbillon design and Wisdom Audio.
2026 MartinLogan USR51 Slim 5.1-channel A/V Receiver 2026 MartinLogan USR51 Slim 5.1-channel A/V Receiver
MartinLogan's first-ever home theater receiver delivers 5.1 channels of surround sound in a compact form factor that may look familiar.
Apple TV 4K, HomeView, HomePod mini 2, and Home Collection 2026 Apple TV 4K, HomeView, HomePod mini 2, and Home Collection 2026
Apple launches a $299 Apple TV 4K, $149 HomePod mini 2, $299 HomeView and four-speaker surround.
Apple HomeView Lineup 2026 Apple HomeView Lineup 2026
Gadgets
Apple's $299 HomeView leads a new smart home lineup with Siri AI, security cameras, smart locks and thermostats. Can Apple finally simplify the connected...
Apple TV 4K 2026 with remote control Apple TV 4K 2026 with remote control
Apple's 2026 Apple TV 4K adds Siri AI, A19 power and four-HomePod surround. At $299, does it offer enough to justify upgrading?
Can Castle’s new Tintagel and Walmer speakers challenge established rivals with ribbon tweeters, real wood cabinetry, and pricing from $2,749?
Can a $1,100 Canadian standmount really embarrass pricier rivals? Paradigm’s 220B v2 makes a surprisingly convincing case and looks the part.
Is the Triangle Borea BR04 a true upgrade over the BR03? We compare soundstage, bass, dynamics, RoomFit, and value.
Buchardt Audio’s E50-S adds a larger Satori woofer, higher sensitivity and new tuning as an alternative to the acclaimed E50.
Are the $1,499 Wharfedale Super Denton truly the British Bulldog of standmount speakers, and do they justify their place in the Heritage lineup?
