Western Acoustics Type 2.1 Debuts at AXPONA 2026: A Bookshelf Speaker Grows in Brooklyn
Western Acoustics Type 2.1 lands at AXPONA 2026 with Purifi driver, horn design, and a Brooklyn apartment sensibility that trades flash for texture and intent.
Western Acoustics Type 2.1 Bookshelf Speakers at AXPONA 2026
Western Acoustics started in San Francisco but isn’t rooted there anymore, with production now split between U.S. manufacturing and final assembly in New York City. That alone sets the tone. This isn’t a legacy brand leaning on decades of mythology. It’s a young company trying to figure out where high end audio actually fits in 2026.
The industry loves to talk about disruption, but outside of personal audio, it’s mostly been business as usual. Liam Porr is aiming at that blind spot. His focus isn’t dedicated listening rooms or systems that dominate a house. It’s real spaces. Apartments. Living rooms that double as offices, dining areas, and everything else. Systems that have to fit into life, not the other way around.
The Western Acoustics Type 2.1, debuting at AXPONA 2026 at $6,000 per pair, makes that point pretty clear. It’s a bookshelf speaker designed with modern constraints in mind, not treated like a compromise. That approach feels different, and in this category, different might actually matter.
western-acoustics-type-2-1-axpona-2026
Having received an invite before the show, I was intrigued. Married into Brooklyn, so there’s a little built-in bias, I’ll admit it. You tend to root for your own. But AXPONA doesn’t care about your personal loyalties. It’s a sprawl. Too many floors. Too many rooms. Not enough time. You make cuts, you miss things, and sometimes you don’t even realize it until you’re already heading home.
That almost happened here.
Then eCoustics’ Podcast Producer, Mitch Anderson, sent a text asking if this room was worth a “Best in Show” nod. That was enough. A few legacy brands got bumped down the list. Priorities shifted. Because the last thing I wanted was to get back to Jersey and realize I skipped something that actually mattered.
Based on what I heard, that would have been a mistake.
When I walked into the room, Porr was on a break. No pitch. No backstory. Just the system and thankfully, the crew from Resolution A/V holding things down. That was actually a relief. Sometimes it’s better to hear a speaker before anyone tells you what you’re supposed to hear.
These aren’t cheap for passive bookshelf speakers, and that’s becoming a pattern. Ahem, Dynaudio Legend bookshelf speakers. But after a few minutes and a seat change, which always matters more than people admit, things started to click. Not instantly. Not dramatically. But enough to suggest there was something real underneath.
western-nagra-accuphase-rack-axpona-2026
The system wasn’t exactly slumming it either: an Accuphase integrated amplifier up front, paired with a Technics turntable fitted with a Dynavector moving coil cartridge, feeding into a Nagra phono stage, plus a streamer somewhere in the chain. Sitting on a simple plywood stand that matched the cabinet, the Type 2.1 didn’t try to impress at first, but once it settled in, it started to sing.
Built for listeners who care about both visual restraint and actual performance, the Western Acoustics Type 2.1 doesn’t come across like a lifestyle speaker trying to fake it. The numbers back that up. Its 39 Hz to 18 kHz frequency response proved legitimate low-end reach, and a maximum output of 103 dB at 1 meter means it can scale without falling apart. The presentation isn’t about inflated bass or exaggerated width, it’s about controlled impact and a wide, stable stereo image that holds together when the music gets dense.
Physically, it lands in a practical sweet spot at 16.5″H x 10.5″W x 12.5″D. Large enough to move air, small enough to live in a real room. The cabinet is rigid Baltic birch, finished in maple veneer with a natural polyurethane topcoat, and it feels purpose-built rather than decorative. The solid maple horn, now using a broader profile, feeds a FaitalPRO HF108R 1-inch compression driver into a custom 110° waveguide, which explains the controlled dispersion and consistent tonal balance beyond a single seat. Down low, the Purifi PTT6.5X04 woofer handles bass and midbass duties—no shortcuts there. The enclosure is rear-ported (bass reflex), so placement matters. Give it breathing room or accept the consequences.
western-acoustics-red-grille-axpona-2026
Western Acoustics Type 2.1 with red grille (swappable)
This is also a real step forward from the original Type 2, with a redesigned crossover, increased headroom, and refined horn geometry. Nothing cosmetic about it, it’s about control and usable dynamic range.
The catch is predictable once you see the spec sheet: 4-ohm nominal impedance. These aren’t the kind of speakers you pair with whatever amp happens to be available. They need current. 100 watts per channel feels like the right starting point, and a solid Class A/B amplifier is a safer bet if you want them to behave properly.
At the show, they weren’t being pushed hard. Listening levels were normal, and what came through was coherent and open, with a presentation that stayed composed. The bass was present but not overemphasized, though to be fair, the material wasn’t exactly Metallica or Aphex Twin. That said, you get the sense the latter would be a better test of what these can really do.
western-acoustics-side-axpona-2026
Give them proper power, and they respond in a controlled, predictable way. Undershoot that, and you’re probably not hearing what they’re capable of.
Color me impressed.
Where to buy: $6,000/pair at Western Acoustics
4 Comments
4 Comments
  1. Jeff Mcdooly
    April 14, 2026 at 2:11 pm
    6 grand eh? Does it kcus ym kcid oot?
    • Ian White
      April 14, 2026 at 2:52 pm
      Jeff,
      You would have to ask it. Not sure that was mentioned in the spec sheet. 😉
      IW
  2. Walter
    April 15, 2026 at 10:09 pm
    Hello Ian, can you reach out out to Liam and let him know his website is down? I cant find his contact info.
2026 1MORE S20 Ultra Open Clip-on Wireless Earbuds Colors
The 1MORE S20 Ultra combines LDAC, Bluetooth 6.0, spatial audio, IP66 protection and up to 40 hours of battery life.
2026 Epson Home Cinema LS Series 3LCD 4K Projectors 2026 Epson Home Cinema LS Series 3LCD 4K Projectors
Priced from $1,999 to $2,699, Epson's new line of 4K home theater projectors feature 120Hz gaming, laser light source, and brightness from 2500 to...
2026 Wharfedale NOVA Subwoofers Front Black 2026 Wharfedale NOVA Subwoofers Front Black
Wharfedale’s Nova subs pack DSP, passive radiators, high-level inputs and 8- to 15-inch drivers into a serious fight with SVS and REL.
2026 Neumann KH 350 and KH 310 ii Studio Monitors 2026 Neumann KH 350 and KH 310 ii Studio Monitors
Neumann’s KH 310 II and KH 350 add 32-bit DSP, MA 1 room correction, more power and deeper system integration for pro and home...
2026 FiiO DP11 CD Player Silver 2026 FiiO DP11 CD Player Silver
CD Players
FiiO’s $170 DP11 adds AES, a CS43198 DAC, CD ripping and USB conversion because apparently nobody told the compact disc it was dead.
2026 TRIBIT FlyBuds C3 Wireless Earbuds Woman Lifestyle 2026 TRIBIT FlyBuds C3 Wireless Earbuds Woman Lifestyle
TRIBIT's $39.99 wireless earbuds come feature packed with noise cancellation, Bluetooth 6.0, multipoint and 5-hour battery life per earbud.
Is the Triangle Borea BR04 a true upgrade over the BR03? We compare soundstage, bass, dynamics, RoomFit, and value.
Buchardt Audio’s E50-S adds a larger Satori woofer, higher sensitivity and new tuning as an alternative to the acclaimed E50.
Are the $1,499 Wharfedale Super Denton truly the British Bulldog of standmount speakers, and do they justify their place in the Heritage lineup?
Podcasts
Hi-Fi Bear reveals what makes T10 Bespoke's in-ear computers so special with eCoustics Podcast Producer Mitch Anderson who tries them for the first time.
Podcasts
Loewe returns to the U.S. with Stellar TVs and Leo headphones. At AXPONA 2026, its team explains the brand’s premium design and engineering strategy.
Headphones
At AXPONA 2026, Sr. eCoustics Personal Audio Reviewer, W. Jennings, reveals his favorite headphones, portable gear, and high-end audio systems, along with an exciting...
