HiFiMAN Arya WiFi Review: A More Affordable Path to Wireless Planar Headphone Performance?
Can HiFiMAN Arya WiFi’s wireless open-back planar headphone tech deliver high-end sound for less, even with a few rough edges?
HiFiMAN Arya WiFi Wireless Headphones
HiFiMAN Arya WiFi arrives as the more affordable sibling to the HE1000 WiFi, bringing open-back planar magnetic drivers, WiFi streaming, Bluetooth connectivity, and a very different approach to wireless listening in the high-end headphone category.
At $1,449, the Arya WiFi is less expensive than the HE1000 WiFi ($2,699), but nobody should mistake it for an inexpensive experiment. This is still a premium audiophile headphone with a very specific promise: better wireless sound quality by moving beyond the usual Bluetooth-first approach and letting listeners stream over WiFi at home or in the office.
That raises the question many people will ask right away: if the HE1000 WiFi delivered an exceptional listening experience but also revealed an operational issue that gave us pause, has HiFiMAN solved enough of the user-experience problem with the Arya WiFi to make the concept feel ready for prime time?
Because at this price, clever engineering is not enough. The Arya WiFi has to sound excellent, feel comfortable, connect reliably, and prove that WiFi headphones are not just another audiophile science project with ear pads.
HiFiMAN Arya WiFi and HE1000 WiFi Headphones
HiFiMAN Arya WiFi (left) vs. HiFiMAN HE1000 WiFi Headphones (right)
Arya WiFi Specs & Technology
Inside the left earcup of the HiFiMAN Arya WiFi is the circuitry that allows the headphone to operate without a traditional source component, DAC, headphone amplifier, or cable hanging off your desk like audiophile spaghetti.
The core of the system is HiFiMAN’s 8mm HYMALAYA Mini DAC, which is specified at 0.0055% THD+N and 105dB channel separation. HiFiMAN also integrates the wireless streaming hardware and headphone amplification inside the earcup, which is rather impressive considering the Arya WiFi remains an open-back planar magnetic headphone weighing 452 grams.
The broader technology package is very similar to the HE1000 WiFi. Both models support WiFi, Bluetooth, and USB Audio operation, along with PCM playback from 44.1kHz to 768kHz, native DSD64 to DSD512, and Bluetooth codec support for SBC, AAC, aptX, aptX HD, and LDAC.
The key difference is the driver. The Arya WiFi uses HiFiMAN’s NEO Supernano Diaphragm Gen.2, while the HE1000 WiFi uses HiFiMAN’s nanometer-thickness diaphragm. HiFiMAN positions the HE1000 WiFi as the higher-resolution model, but the Arya WiFi shares much of the same wireless architecture at a significantly lower price. That makes the comparison more interesting than the price gap might suggest.
hifiman-arya-wifi-headphones-in-box
The Arya WiFi uses HiFiMAN’s planar magnetic driver platform with Stealth Magnets, a design intended to reduce wave diffraction as sound passes through the magnet structure. HiFiMAN says the result is lower distortion and improved clarity, but as always, the listening section is where the marketing language either earns its keep or quietly exits through the side door.
WiFi is the real point of difference here. Bluetooth remains convenient, but even the better codecs are still limited by available bandwidth and device support. By adding WiFi streaming, the Arya WiFi can support lossless and high-resolution playback in a way that conventional Bluetooth headphones cannot.
For listeners using TIDAL, Qobuz, Roon, or local high-resolution files, that matters. For Spotify users, the benefit is less about lossless playback and more about connection flexibility, convenience, and avoiding some of Bluetooth’s usual compromises.
You can also use the Arya WiFi in wired mode via USB-C, or connect it to your playback device via Bluetooth thanks to the embedded Qualcomm QCC5181 chip, which is LDAC-compatible for up to 96kHz playback.
hifiman-arya-wifi-headphones-back
Design & Comfort
The HiFiMAN Arya WiFi follows the same general design language as the HE1000 WiFi, but with a different finish. The Arya WiFi wears a blacked-out look, while the HE1000 WiFi uses the more upscale brown and metallic color scheme. Black is the safer choice and probably the easier one to live with, unless your listening room already looks like a cigar lounge with a DAC budget.
The Gen.2 headband is comfortable and offers useful adjustment, although it does not provide the same full cup rotation found on some passive Arya and HE1000 models. That limits portability and flat storage, but this is still a better design than HiFiMAN’s older Sundara-style headband or the more basic strap-free assemblies used on models such as the HE400se and HE6se V2.
Build quality is good, but the Arya WiFi does not suddenly become a jewelry-grade headphone because WiFi has joined the party. There is still visible plastic, and the materials do not feel as premium as the price might suggest. That said, at $1,449 and positioned well below the HE1000 WiFi, those compromises are easier to accept.
Comfort remains one of the Arya WiFi’s strengths. The large open-back earcups, suspended headband, and familiar HiFiMAN pad shape make it easy to wear for longer sessions, provided you are comfortable with a firmer-than-average clamp. It is not featherlight, but the weight is distributed well enough that the Arya WiFi never feels like punishment for choosing wireless planar magnetic headphones.
hifiman-arya-wifi-headphones-buttons
The button layout is the same as the HE1000 WiFi. From top to bottom, there is a volume rocker, a function button for switching between WiFi, USB, and Bluetooth modes, and a power button. The buttons use different colors to indicate operating mode, charging status, and battery state. It is straightforward once you learn the color system, although there is still a short adjustment period.
The layout itself is simple and intuitive, and the buttons are easy enough to find by touch. My main issue was with the voice prompt, which was extremely quiet on my review sample. I cannot say whether that is specific to this unit or representative of the product more broadly, but it made mode confirmation less useful than it should be. Volume adjustment also felt too coarse for my liking, with each step creating a larger change than I would prefer.
HiFiMAN keeps the included accessories minimal. The Arya WiFi includes a USB-C to USB-A cable roughly six feet long, and that is essentially it. There is no display case like the one included with the HE1000 WiFi. At $1,449, that does not change the performance case for the headphone, but it is worth noting for buyers expecting a more premium unboxing experience.
hifiman-arya-wifi-headphones-earpads
Setup & Usability
The first thing I tried to do after unboxing the Arya WiFi was connect it to my home WiFi network. That process proved more frustrating than expected.
Setup requires a specific sequence of button presses on the earcup, entering URLs on a smartphone, navigating web pages that feel unfinished, and entering more than one password before the headphones can join the network. If everything works the first time, the process may only take a few minutes. In my case, it repeatedly failed at the final stage when entering my router password, for reasons that were never clear. After roughly 20 minutes, I was eventually able to complete the connection.
That matters because WiFi is the feature that separates the Arya WiFi from a conventional wireless headphone. If users struggle with the setup process, some will likely default to Bluetooth or USB-C operation instead. Those modes are useful, but they also reduce the value of buying the WiFi version in the first place.
HiFiMAN already has the GAIA app, and this seems like the obvious place to guide users through WiFi setup in a clearer and more polished way. A step-by-step setup flow inside the app would be preferable to asking users to rely on a web-based process or a support video. For a company selling a $1,449 wireless planar headphone built around WiFi streaming, the setup experience needs to feel more mature.
Battery life was also a concern. HiFiMAN rates the Arya WiFi at 6.5 to 7.5 hours in WiFi mode and up to 23 hours over Bluetooth. In my testing, WiFi playback landed closer to 5 to 6 hours, which is below the rated figure but not dramatically far off. Bluetooth battery life was more disappointing, coming in around 12 hours, well short of the claimed 23 hours. Battery life will vary with volume level, codec, connection stability, and usage conditions, but that gap is large enough to be noted.
hifiman-arya-wifi-headphones-package
Listening
The Arya WiFi and HE1000 WiFi look closely related, feel very similar on the head, and share much of the same internal wireless architecture. The obvious question, then, is whether they sound the same.
The answer is almost, but not quite. The two models are clearly cut from the same cloth, and the Arya WiFi gets closer to the HE1000 WiFi than the price difference might suggest. That makes the less expensive model a more interesting proposition than expected.
Among the wireless headphones I have heard, HiFiMAN’s WiFi models are among the most technically capable, even when used over Bluetooth. For this review, however, most of my listening was done in WiFi mode, using a mix of Spotify streams and high-resolution FLAC files. That matters because WiFi playback is the main reason these headphones exist, and it is the mode that gives the Arya WiFi its best chance to separate itself from conventional Bluetooth designs.
hifiman-arya-wifi-headphones-angle
Bass
The Arya WiFi has a slightly elevated bass response, but it is not tuned like a consumer noise-cancelling headphone trying to win a fistfight in the low end. The bass sits just above the rest of the spectrum, giving music some added weight, warmth, and physical presence without overwhelming the midrange.
It is not the fastest or most controlled bass I have heard from a planar magnetic headphone, but that comparison mostly involves high-end wired models with dedicated amplification. Against other wireless headphones, the Arya WiFi is much stronger. Bass notes start and stop cleanly, texture is easy to follow, and there is very little sense of bloat or overhang.
Sub-bass extension is also impressive for an open-back wireless headphone. The Arya WiFi can reproduce very low information with useful audibility, including material around the 20Hz region, although there is some slight roll-off as it approaches the lowest octave. On Hans Zimmer and James Newton Howard’s “Why So Serious?,” the deep rumble around the 3:30 mark was clearly present, which is not something every open-back headphone manages convincingly.
Midrange
Moving up from the bass, the transition into the lower midrange is smooth and well controlled. Male vocals do not sound thickened or pushed back by excess upper-bass energy, which helps the Arya WiFi maintain good clarity through the lower registers.
The midrange itself is slightly relaxed compared to the bass and treble, but I would not call the Arya WiFi a strongly V-shaped headphone. It has some extra energy at the frequency extremes, while the center of the presentation remains smooth, open, and even-handed.
That character works in its favor with vocals and acoustic instruments. The Arya WiFi does not push singers forward in the way some midrange-focused headphones do, and listeners who prefer a more relaxed presentation may find it easier to live with over longer sessions. Compared with something like the Sennheiser HD600, the Arya WiFi is less intimate and less midrange-forward, but it still presents vocals and instruments with convincing timbre and very good tonal balance.
On Dominique Fils-Aimé’s “Birds,” breath detail, vocal texture, and the space around her voice were easy to hear without sounding exaggerated. The Arya WiFi does not put the singer right in your lap, which is probably healthier for everyone involved, but it does a strong job of preserving the natural shape and presence of the performance.
Treble
The Arya WiFi follows the HE1000 WiFi with a treble balance that is more forgiving than some of HiFiMAN’s older or brighter-leaning models, including the Arya Organic and HE6se V2. It still sounds open and detailed, but it avoids the sharper edge that can make long listening sessions feel like a test of character.
There is enough presence in the upper registers to show what the planar magnetic drivers can do, particularly with cymbal decay, small percussion details, and the air around instruments. Fine detail is easy to follow, but the Arya WiFi does not push treble information forward just to create the impression of resolution.
“La lune” by L’Impératrice is one of my regular treble test tracks because of the faint triangle hit that runs through much of the song. The Arya WiFi keeps that detail audible within the mix without turning it into a distraction. It has the clarity to reveal the upper-frequency information, but enough restraint to keep the presentation smooth and listenable.
Soundstaging & Imaging
HiFiMAN’s egg-shaped open-back headphones are known for producing a wide, spacious soundstage, and the Arya WiFi continues that pattern. The presentation is larger than average for a wireless headphone, with good width and a convincing sense of height, although it does not sound quite as expansive as some of the wired Arya variants, including the Arya Organic and Arya Unveiled.
Imaging is the stronger part of the presentation. The Arya WiFi places sounds with very good precision, and that matters more to me than absolute stage size. On TOOL’s “Chocolate Chip Trip,” the headphone made it easy to follow the individual layers, percussion hits, and spatial effects without turning the mix into a blur. That track can become a mess on less capable headphones. The Arya WiFi kept it organized.
Detail retrieval is also strong. The Arya WiFi does not leave much feeling hidden, especially in WiFi mode with high-quality source material. The HE1000 WiFi still has a slight edge in resolution and low-level information, but the gap is not large. You are most likely to notice it during direct comparisons, not during normal listening. That is probably the healthier way to experience music anyway.
hifiman-arya-wifi-headphones-back-side
The Bottom Line
The HiFiMAN Arya WiFi makes a strong case for itself because it delivers much of the HE1000 WiFi experience at a significantly lower price. It does not quite match the more expensive model for resolution or refinement, but the gap is small enough that many listeners will find the Arya WiFi the more sensible buy.
Sound quality is the main reason to consider it. The Arya WiFi offers a spacious presentation, strong imaging, extended bass, smooth mids, and a treble balance that is detailed without becoming aggressive. In WiFi mode, it feels like a meaningful step beyond most Bluetooth headphones, especially with lossless or high-resolution material.
The problems are not sonic. The WiFi setup process needs to be more polished, and battery life is only fair in WiFi mode and disappointing over Bluetooth based on my testing. Those issues matter because they affect daily use, and they make the Arya WiFi feel less finished than it should at $1,449.
Still, if you can live with the setup process and the need for frequent charging, the Arya WiFi is the better value in HiFiMAN’s WiFi headphone lineup. The HE1000 WiFi remains the more capable headphone, but the Arya WiFi gets close enough where the extra money becomes harder to justify.
Pros:
  • Built-in WiFi streaming supports higher-quality wireless playback than conventional Bluetooth headphones
  • Can also be used over USB-C or Bluetooth
  • Comfortable fit with good weight distribution for longer listening sessions
  • Spacious soundstage, strong imaging, and excellent detail retrieval for a wireless headphone
  • More affordable than the HE1000 WiFi while retaining much of the same wireless architecture
Cons:
  • Build quality is good, but the visible plastic and limited accessories do not fully match the price
  • First-time WiFi setup is more complicated and less polished than it should be
  • Battery life fell short of HiFiMAN’s stated figures in testing
  • Bluetooth mode is useful, but does not deliver the main benefit of buying the WiFi version
Our Ratings
★★★★★★★★★★ Sound Quality
★★★★★★★★★★ Comfort
★★★★★★★★★★ Usability
★★★★★★★★★★ Build Quality
★★★★★★★★★★ Value
Where to buy:
The best wireless headphones of 2026, tested by eCoustics. Our Editors’ Choice picks from Sony, Bose, Focal, DALI and more cover ANC, sound and...
Shopping for wireless noise cancelling over-ear headphones in 2025? Here are our picks for the best you can buy on any budget.
Over-Ear Headphones
Sixteen years and several near misses later, the $1,899 HiFiMAN HE6 Remastered finally delivers the magic. But can your headphone amplifier handle it?
AT $699, ADAM Audio's flagship H715 Reference headphones, combine Sonnox calibration, balanced Hi-Fi mode, and studio monitoring in one design.
TDM Neo headphones twist into a Bluetooth speaker, offering one device for private listening and the occasional need to become everyone’s DJ.
Over-Ear Headphones
The HiFiMAN HE600 revives the spirit of the legendary HE-6 with less weight and easier amplification, but does it capture the original magic?
What were the best headphone systems at CanJam SoCal 2026? We heard standout rigs from RAAL, Chord, Meze, Grado, HiFiMAN, SJY and more.
Can R-2R audio stand out in crowded TWS? HiFiMAN's $299 Svanar Wireless 2 adds Bluetooth 6.0, LDAC, ANC and a smaller HYMALAYA Mini DAC.
