Apple AirPods Max 2 Review: Better ANC, Marginally Better Sound, Tougher Bose Competition
Apple AirPods Max 2 face the original Max and Bose QuietComfort Ultra 2 in this ANC headphone showdown. Better enough, or just safer?
Apple AirPods Max 2 vs. Original vs. Bose QuietComfort Ultra 2nd Gen Wireless Headphones
The Apple AirPods Max 2 arrive in a wireless headphone category that has become far more competitive since the original model launched. Sony, Bose, and Beats have all continued to refine ANC, comfort, battery life, app control, and sound quality, which makes small updates harder to justify at premium pricing.
For existing Apple users, the improvements may be enough: better noise cancelling, tighter ecosystem integration, and slightly improved sound quality. But for anyone still using an older pair of wireless headphones, or considering a move from Sony, Bose, or Beats, the AirPods Max 2 need to offer a clearer reason to switch. Marginally better is still better, but in 2026, it may not be enough. How do they compare to the model they replace?
Physically, these are almost identical headphones: same industrial design, same aluminum construction, same weight, same controls, and the same overall sound signature. Even the improvements, including better ANC, USB-C wired audio, and a slightly firmer low end, feel deliberately restrained rather than transformative.
Compared directly against the original AirPods Max, the overall experience remains remarkably similar. Apple clearly viewed this update as a refinement rather than a reinvention.
airpods-max-2-wireless-headphones-blue-angle
AirPods Max 2 (blue)
Design & Features
The AirPods Max 2, like the original, still feel like one of the most premium wireless headphones Apple has ever made. The aluminum ear cups feel excellent, the suspension headband helps spread the weight better than expected, and Apple’s Transparency, Noise Cancelling, and Adaptive modes remain among the best implementations in the category.
That weight still matters. At 382.2 grams, the AirPods Max 2 never disappear on your head. The balance is good, but after a full record, taking them off feels less like a break and more like your neck filing a polite complaint.
The listening modes are very well executed. Noise Cancelling is excellent with steady background noise and also reduces intermittent sounds effectively. Transparency mode keeps outside sound natural and useful, while Adaptive mode works as a smart middle ground, adjusting continuously based on the listening environment.
airpods-max-2-headphones-earcups-inside-blue
Sound
The AirPods Max 2 retain almost all of the strengths (and occasional weaknesses) of the original model. The stereo image still sounds expansive, the low end still has satisfying weight and impact, and the headphone’s detail retrieval remains impressive for a wireless headphone.
The general tuning philosophy seems unchanged as well: a mostly inoffensive sound with mild elevation in the upper treble and bass, nicely filled-in lower mids that give vocals a nice weight and intimacy, and a laid-back lower treble that remains forgiving across a wide range of music and other content.
Reference Tracks
Bass
The low end comes across as classic Apple. There is a typical elevation to the bass and sub-bass that gives kick drums and bass guitars an enhanced sense of impact and authority.
Listening to “Only When I” by Alice Phoebe Lou, despite the relatively emphasized low end, the separation between kick drum and bass guitar remains nice and distinct, letting each support the arrangement within its own range of low-end frequencies.
Listening to “Escalator” by Ritt Romney, the AirPods Max 2 do a pretty great job reproducing both the sustained sub-bass and pulsating mid-bass rhythm without the two becoming overly blurred together.
While the low end is not as punchy or authoritative as it is on something like a planar magnetic open-back driver Audeze LCD-X or a dynamic open-back like a Focal Clear, it sounds just as good or better than any other closed-back wireless headphone I’ve heard without sacrificing midrange intelligibility.
Midrange
While the low end on the AirPods Max 2 lands decidedly north of neutral, the midrange plays it very safe.
The lower midrange where the fundamental frequencies of melodic elements like vocals, guitars, and pianos sit, is more forward and filled out. Moving into the upper midrange from roughly 1 kHz to 5 kHz, Apple has done the typical Apple thing and kept the amplitude nice and relaxed.
This is where overemphasis becomes most irritating because human hearing is especially sensitive in this range. It is where many urgent sounds live, including babies crying, people screaming, and alarms.
The downside of playing it safe is that some songs and content come across as overly dull or relaxed. One example is “Halloween” by Phoebe Bridgers. The inherently forward lower midrange combined with the relaxed upper midrange of the track makes for an especially wonky rendition of a mix that is usually one of my favorites. The buildup in the upper bass and lower midrange creates a sense of pressure and fullness that needs more upper midrange clarity to keep things balanced.
Generally, Apple did a good job sculpting the midrange to be widely palatable across most music and audio content.
airpods-max-2-headphones-front-blue-cat
Treble
The treble, like the low end, is somewhat emphasized. Fortunately, Apple mostly avoids the kind of sharp lower-treble peaks that can make headphones sound brittle or fatiguing over longer listening sessions.
Instead, most of the added energy seems concentrated higher up in the spectrum, lending cymbals, acoustic textures, reverbs, and ambient details a pleasant sense of air and openness without constantly shoving them into the foreground.
The treble emphasis does occasionally land unpleasantly with sibilance and percussion, depending on how a song is mixed.
Listening to “Fruity” by Rubblebucket, the vocal sibilance rides dangerously close to the edge of unpleasantness without ever fully crossing over. Songs with more aggressive mixes like “Life or Just Living” by Caveman, fall squarely on the side of unpleasant every time the vocalist sings anything sibilant or consonant.
Overall, Apple did a decent job making the AirPods Max 2 sound exciting without becoming overly fatiguing. Some customization would go a long way, but as usual, Apple provides no native EQ control.
Comparison to AirPods Max 1
While the tuning feels more similar than different compared to the original AirPods Max, the upper and lower extremities of the frequency range come across as subtly firmer and more defined. Bass sustain feels more convincing, and upper-treble information like percussion and cymbals sounds smoother and slightly less digital.
airpods-max-2-vs-original-headphones
AirPods Max 1 (silver) vs. AirPods Max 2 (blue)
Plugging the AirPods Max 2 in via USB-C for wired listening also improves the sound modestly, further refining many of the qualities above. The difference is not night and day, but for someone seeking the most natural sound possible from the AirPods Max 2, listening via USB-C is the best way to get there.
The improvements to noise canceling and transparency functions are similarly incremental. If you compare the two models side by side, the newer model is clearly superior in overall attenuation of environmental noise. The AirPods Max 2 do a more even job across the frequency spectrum, whereas the original model lets slightly more lower-treble information through to the listener.
However, the difference is not night and day. The original already did a fantastic job and the new version only slightly improves on the former.
For anyone deciding between the old version and the new version, I would suggest the AirPods Max 2 as the superior product. But is the upgrade from the original worth the money? I don’t think so. The two products are more similar than different so I would wait for the next iteration.
Comparison to Bose QuietComfort Ultra 2
airpods-max-2-blue-vs-bose-quietcomfort-ultra-2-black
Bose QuietComfort Ultra (2nd Gen) vs. AirPods Max 2
The Bose QuietComfort Ultra (2nd Gen) feels like the more rational product. It is lighter, more comfortable, has notably better battery life, folds up more easily and compactly, and includes native EQ sound and noise cancelling level customization. Ultimately, the Bose is a more practical design for listening on the go.
Next to the Bose, the AirPods Max 2 feels more like an Apple luxury fashion accessory. The materials are nicer, the integration is more seamless with my iPhone, and all three listening modes (Transparency, Noise Cancelling, Adaptive) sound more natural despite the lack of customization.
In terms of sound, the Bose QuietComfort Ultra 2 sounds surprisingly different compared to the AirPods Max 2 for two headphones competing in the same space. The Bose takes Apple’s V-shaped frequency response and puts it into warp drive – both the low bass and the upper trouble are more emphasized on the Bose. Ultimately, I find the QC Ultra 2 less detailed and more fatiguing than the AirPods Max 2 with a generally more artificial sound.
However, between the QC Ultra II’s significantly lower price, lighter weight, and inclusion of EQ customization, I would sooner recommend the Bose to someone looking for a solid sounding over-ear noise canceling headphone.
airpods-max-2-front-vs-original-vs-bose-quietcomfort-ultra-2
The Bottom Line
The AirPods Max 2 are, ultimately, a product for people who already know they want an AirPods Max.
If you’re deeply invested in Apple’s ecosystem, value best-in-class transparency mode and noise cancellation, care about industrial design, and want a wireless headphone that sounds genuinely good without requiring much thought or tweaking, the AirPods Max 2 stands out as one of the most compelling options on the market.
They still feel uniquely Apple in both the best and worst ways: beautifully built, thoughtfully integrated, and exceedingly expensive.
At the same time, this update feels particularly conservative. The AirPods Max 2 improves on the original model in nearly every category – but only slightly. The sound is more refined, the ANC is more effective, and USB-C wired audio is a genuinely welcome addition. But none of it fundamentally changes the experience. Existing AirPods Max owners are not missing much.
Personally, there are very few situations where I would prefer listening to the AirPods Max 2 over my much-loved AirPods Pro 2 earbuds. Between the AirPods Max 2’s less-neutral sound signature and dramatically heavier weight, I simply get along better with the sound and form factor of the AirPods Pro 2.
If my goal is to listen to headphones with the best possible sound quality, I prefer wired open-back headphones. If convenience is the mission, I’m always going to choose the pocketable AirPods Pro 2. Maybe if Apple were to add some EQ customization to the AirPods Max 2, this conclusion may have looked very different but based on Apple’s track-record, I won’t hold my breath.
Pros
  • Best-in-class Transparency, Noise Canceling, and Adaptive modes
  • Spacious and detailed sound
  • USB-C audio support
  • Apple ecosystem integration
Cons:
  • Below average battery life
  • Heavy
  • No built-in EQ customization
  • Expensive!
airpods-max-2-vs-bose-quietcomfort-ultra-2
Ratings Compared
AirPods Max 1AirPods Max 2Bose QC Ultra 2
Sound Quality3.543.5
Comfort334.5
Usability554
Build Quality554.5
ANC4.555
Total21/2522/2521.5/25
Where to buy:
Discover the best wireless earbuds of 2026 from Sony, Bose, Noble, and more. Our hands-on picks cover sound quality, ANC, comfort, features, and value.
Our favorite wireless noise cancelling earbuds of 2025 include Bose, Sony, Technics and Bowers & Wilkins.
Discover the best wireless speakers of 2026, from portable Bluetooth models to high-end stereo systems.
After years of hands-on testing, these are the soundbars and speaker bar systems for home theater that impressed us most in 2026.
DAPs
Apple's iPod turns 25 with a playable 404-page tribute. We explain the hidden Brick game, the DAP alternatives, and why we'd rather have a...
Developers have found a way to restore Dolby Atmos height effects from Blu-ray soundtracks on Apple TV 4K. It's an impressive technical achievement, but...
Bose acquires Skullcandy after their Sound by Bose partnership. Here's why the deal matters for headphones, McIntosh, Sonus faber, and the audio industry.
Apple Music finally comes to Bluesound and BluOS with native streaming and multiroom playback. But what about lossless and hi-res audio?
