Marshall Milton A.N.C Wireless Headphones Launch with Foldable On-Ear Design
Marshall Milton A.N.C. brings on-ear ANC, LDAC, 80-hour battery life, wired playback, and a replaceable battery for $229. Disposable? Not quite.
2026 Marshall Milton ANC Headphones Black in-hands
Marshall has expanded its wireless headphone lineup with the new Milton A.N.C., a foldable on-ear model that brings adaptive noise cancellation, long battery life, and the brand’s familiar amp-inspired design to a more portable form factor. Priced at $229.99, Milton A.N.C. offers 50+ hours of playback with ANC on and up to 80 hours with ANC off, putting it squarely in the travel-friendly headphone category without forcing listeners into a full-size over-ear design.
The design sticks closely to Marshall’s house style: square TPU molded ear caps, textured leather surfaces, brass logo hardware, powder-coated metal arms, and memory foam cushions intended to make the on-ear fit less punishing over longer sessions.
Over-Ear vs. On-Ear: Many wireless headphones use an over-ear design, with larger earcups that surround the ears. The Marshall Milton A.N.C. uses an on-ear design instead, meaning the earcups rest directly on the ears. That usually makes the headphones more compact and easier to pack, although comfort and isolation can vary depending on ear shape, clamping force, and how long you wear them.
marshall-milton-anc-headphones
Design and Comfort Is Just The Start
Battery Life and Replaceable Battery: Design and comfort are a good starting point, but battery life and usability matter just as much once the headphones leave the box. The Marshall Milton A.N.C. is rated for up to 80 hours of wireless playback with ANC off and 50+ hours with ANC enabled, which gives it enough stamina for commuting, travel, and long listening sessions without constant charging anxiety.
Milton A.N.C. is also Marshall’s first wireless headphone with a replaceable battery, although the spare battery is sold separately. That matters because battery degradation is usually where wireless headphones start their slow walk to the drawer of forgotten electronics. A replaceable battery does not make them immortal, but it is a practical move in a category that could use fewer disposable “premium” products.
Connectivity, ANC, and Spatial Audio: The Marshall Milton A.N.C. supports Bluetooth 6.0 with LE Audio and is compatible with SBC, AAC, LC3, and LDAC codecs. That gives it broader wireless codec support than many lifestyle headphones, especially with LDAC for higher-bitrate Bluetooth playback from compatible devices. For users who still prefer a wired option, Milton A.N.C. also supports a USB-C to 3.5mm connection.
Adaptive ANC is included and is designed to analyze surrounding noise and adjust the level of noise cancellation in real time. That should help reduce distractions during commuting, travel, work, movies, calls, or extended listening sessions. When users need to hear what is happening around them, Transparency mode lets outside sound back in without removing the headphones.
Milton A.N.C. also includes Soundstage Spatial Audio, Marshall’s in-house spatialization algorithm. Activated through the Marshall app, Soundstage is designed to add a greater sense of depth and width to stereo tracks. It will not magically turn a bad mix into Abbey Road. But for listeners who want a wider presentation from standard stereo content, it gives Milton A.N.C. another feature beyond battery life, ANC, and the usual Marshall attitude.
marshall-milton-anc-headphones-folded
Additional Key Features:
The Marshall Milton A.N.C. is built around a foldable on-ear design intended for daily use and travel. The headphones can be folded down for easier packing and unfolded quickly when it is time to listen, which is the whole point of choosing on-ear portability over larger over-ear cans.
Marshall says the Milton A.N.C. uses newly developed 32mm drivers tuned by its in-house acoustic engineers. The company describes the sound as part of its long-running “signature sound” approach, with improved bass and treble extension and support for Hi-Res Audio playback. Translation: Marshall is leaning on the rock-and-roll heritage again, but at least there is actual driver development behind the leather jacket.
The Milton A.N.C. also includes Adaptive ANC and Transparency mode. Multiple microphones analyze surrounding noise and adjust cancellation automatically, while Transparency mode lets outside sound back in when users need situational awareness. Disabling ANC is not the same thing as Transparency mode; one turns noise cancellation off, while the other actively passes external sound through the microphones.
Adaptive Loudness is designed to preserve tonal balance at lower volume levels or when outside noise interferes with listening. Marshall says the feature raises bass and lower midrange output to help maintain a more natural balance without forcing users to crank the volume. That is useful in theory, especially for commuting, but it will depend on how subtly Marshall applies it. Too much “help” and the bass starts driving the bus.
The M Button: To further support ease of use, the Milton has a single onboard button that can access key headphone functions. For example, you can use the button to Toggle between ANC and Transparency mode or turn soundstage spatial audio on and off. Switch between preferred EQ settings. Go directly to a Spotify playlist with Spotify Tap, a voice assistant, or take a call using a voice assistant without the need to pick up the phone.
Packaging: Milton A.N.C has 42% recycled material by weight, reducing the need for virgin resources and helping lower environmental impact. Recycled materials typically have a smaller carbon footprint than virgin materials, though actual savings vary by material and process.
Specifications
Marshall ModelMilton A.N.C
Product Type Wireless On-Ear Headphones
Price$229
Driver TypeDynamic
Driver Size32 mm
Driver Sensitivity99.3 dB SPL (1mW @ 1kHz)
Driver Impedance32 Ω
Frequency range20-20,000 Hz (SBC, AAC, LC3)
20-40,000 Hz (LDAC at 96kHz)
Play time50 hours with Bluetooth and ANC
80 hours with Bluetooth only
Battery PreservationYes
Wireless ChargingNo
Quick Charging15 minutes gives 9.5 hours of playtime
Charging time2 hours to full recharge 
Exchangeable BatteryYes
Wireless connectivityBluetooth 6.0
Wired connectivityUSB-C to 3.5mm
Bluetooth range10 m / 30 ft
Bluetooth CodecsSBC, AAC (MPEG-2), LC3, LDAC
ControlsControl knob, M-button
Marshall App Yes – iOS and Android
Microphone & RemoteYes
Active Noise CancellationYes
Microphones6
Bluetooth Multipoint ConnectivityYes
DimensionsNot provided
Weight231 g / 8.2 oz
ColorwaysBlack
Foldable designYes
Included AccessoriesMarshall Milton A.N.C. Headphones
USB-C to USB-C Cable: (for charging)
USB-C to 3.5mm Cable: (wired audio connection)
Travel case
RepairabilityYes
Country of originDesigned and engineered in Sweden. Made in China.
If you compare Milton A.N.C. with our other on-ear headphones, like the beloved design of Major V, you’ll notice a few big differences. We’ve increased the ear cushion size to help keep the sound in and improve passive noise attenuation. Larger earpads and softer memory foam also mean the headphones are more comfortable to wear over longer periods. We’ve introduced an entirely new driver system tuned to improve bass and treble extension, delivering dynamic Hi-Res audio with rich details. On top of that, 6 microphones optimally placed for ANC and call complement the acoustic design for highly effective noise reduction,” says Nicolas Pignier Delafontaine, Senior Manager, Audio & Acoustic at Marshall Group
“With Milton A.N.C., we have created a premium, yet durable headphone that is easy to bring with you wherever life takes you. Our design and engineering teams have worked for years to bring the immersive feeling of Adaptive ANC into our beloved on-ear form factor, and we couldn’t be prouder of the results. Its portable design makes it a sleek contender to heavier over-ear alternatives, without compromising on features. The combination of adaptive ANC with 80 hours battery life is guaranteed to take on-the-go music listening sessions to the next level,” says Evelina Lindström, Product Manager at Marshall Group.
marshall-milton-anc-headphones-app
The Bottom Line
The Marshall Milton A.N.C. enters a crowded wireless headphone category with a few things that help it stand out: an on-ear foldable design, up to 80 hours of battery life, 50+ hours with ANC enabled, wired and wireless connectivity, app control, LDAC support, adaptive ANC, Transparency mode, and a replaceable battery. That last one is the real eyebrow raiser. Most wireless headphones eventually become landfill candidates when the battery fades, so Marshall deserves credit for making serviceability part of the story instead of pretending lithium-ion cells are blessed by the Pope.
At $229, Milton A.N.C. looks like a credible option for listeners who want a more compact alternative to over-ear ANC headphones without giving up long battery life or modern codec support. It makes the most sense for commuters, travelers, students, and Marshall loyalists who want a portable headphone with classic styling and enough stamina to survive more than one bad week.
The competition is not exactly asleep at the pub. The Fender Mix costs more at $299 but claims up to 100 hours of battery life. The Final UX5000 at $250 brings aptX and aptX Adaptive support. The Skullcandy Aviator 900 at $299 counters with THX Spatial Audio, which some listeners may prefer over Marshall’s Soundstage processing. Budget buyers also have the EarFun Wave Pro at around $80, with LDAC and multiple ANC modes, though it clearly plays in a different build and brand category.
Milton A.N.C. is not the cheapest, not the longest-lasting, and not the only model chasing spatial audio and ANC. But its combination of foldable on-ear portability, long battery life, LDAC, adaptive noise cancellation, Marshall design, and a replaceable battery gives it a sharper identity than many lifestyle headphones at this price. That matters. In this category, looking cool is easy. Surviving the commute without becoming another dead gadget in a drawer is the harder trick.
Price & Availability
The Marshall Milton A.N.C. wireless headphones are priced at $229 at Marshall.com and will be available at select retailers beginning May 27th 2026.
Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet
2026 Nagra AMP II-S Stereo Power Amplifier 2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
2026 Schiit Mani 3 Phono Preamp 2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
EarFun's flagship wireless noise cancelling headphones for 2026 offer adaptive ANC, Auracast, aptX Lossless, 90-hour battery life and custom EQ.
Sony revives the XM4 with improved ANC, a replaceable battery and updated processing. At $299.99, does it still offer enough value?
Bose brings Auracast, LC3 and LE Audio to its $449 QuietComfort Ultra Gen 2, although Android compatibility and beta restrictions still apply.
Marshall’s $499.99 Bromley 150 party speaker combines 360-degree sound, stage lighting, 40+ hour battery life, Auracast, and mic and instrument inputs.
Technics made a splash in 2024 with their AZ100 in-ear TWS ANC earbuds. Can lightning strike twice with their new flagship over-ear headphones?
Nothing's $399 Headphone (1) Pro uses three drivers, xMEMS treble and Flat EQ. Clever engineering, or has Nothing finally over-engineered something useful?
Bose improves its flagship ANC headphones with USB Type-C audio, better battery life and familiar comfort, but Gen 1 owners face a tougher decision.
