Noble Debuts FoKus Apollo Pro Wireless Headphones at CanJam Singapore 2026
Noble FoKus Apollo Pro debuts at CanJam Singapore 2026 with hybrid dynamic and planar drivers, premium materials, and LDAC support for $699.
Noble FoKus Apollo Pro Wireless Headphones Blue
Noble Audio is using CanJam Singapore 2026 to introduce the FoKus Apollo Pro, a limited run version of its hybrid wireless headphone platform. Building on the original FoKus Apollo, the Apollo Pro adds upgraded acoustic tuning, more premium fabrics and finishes, new voice prompts, and updated ear pads with two new color choices.
However, its unique driver configuration remains the key point. Most premium wireless headphones focus on ANC, app features, battery life, and codec support, but Noble is leaning harder into acoustic design with a hybrid driver platform that combines dynamic and planar magnetic technology in a wireless over-ear portable design.
Debuting May 16th and 17th, the FoKus Apollo Pro is aimed at listeners who want a more refined version of the Apollo concept. However, its limited run release suggests Noble is testing new tuning before committing to a full production roll-out, since the original Apollo model has been quite popular and won numerous industry awards.
noble-fokus-apollo-pro-headphones-red
Noble Fokus Apollo Pro
Refined Hybrid Driver Architecture
At the core of the FoKus Apollo Pro is Noble’s hybrid driver configuration, which pairs a dynamic driver with a planar magnetic driver in each earcup. The design is intended to combine the bass weight and impact typically associated with dynamic drivers with the speed, clarity, and detail retrieval often associated with planar magnetic designs.
Tuning
The Apollo Pro also introduces updated acoustic tuning intended to improve tonal balance, clarity, and overall presentation. Noble says the changes deliver deeper and tighter bass, improved detail retrieval, and a more open soundstage. Combined with Noble’s wireless platform and upgraded construction, the Apollo Pro is positioned as a more refined version of the Apollo for both home and portable listening.
noble-fokus-apollo-pro-headphones-red-buttons
Elevated Materials & Premium Craftsmanship
Noble has also updated the Apollo Pro’s materials and finishing details, with changes focused on appearance, comfort, and portability.
The Apollo Pro uses Italian Alcantara on the headband, revised gunmetal accents, upgraded fabric cabling, and new ear pad materials. Noble says the more breathable fabric on the ear cushions is intended to reduce heat buildup during longer listening sessions.
The packaging has also been made more compact, giving the Apollo Pro a more travel friendly footprint while preserving the premium presentation expected from a limited run release.
Voice Prompt
Apollo Pro also introduces Voice Prompt functionality, replacing traditional notification tones with spoken voice confirmations for key functions and mode changes, including ANC activation and other onboard controls.
Noble’s Flagship Wireless Platform
Powered by the Qualcomm QCC3084 chipset and compatible with the Noble FoKus companion app, the Apollo Pro combines high-end wireless audio performance with everyday usability and customization. With the Noble FoKus App (iOS, Android), users can manage playback settings, EQ adjustments, and access additional headphone functionality.
Wireless support includes LDAC, AAC, aptX, aptX HD, and SBC Bluetooth codecs, giving the Apollo Pro broader compatibility across Android, iOS, and other Bluetooth sources.
Pro Tip: The Apollo Pro also provides wired connectivity via an included 3.5 mm cable with 6.3 mm and 4.4mm adapters.
noble-fokus-app
Comparison
Noble ModelFoKus Apollo Pro (2026)FoKus Apollo (2024)
Product Type Wireless HeadphonesWireless Headphones
Price$699$649
Drivers40mm dynamic driver (bass)
14.5mm planar magnetic driver (mids/treble)
Bluetooth ChipsetQualcomm QCC3084Qualcomm QCC3084
Bluetooth Version5.35.3
Audio CodecsLDAC, AAC, aptX, aptX HD, SBCLDAC, AAC, aptX, aptX HD, SBC
Noise CancellationHybrid ANC technology, up to -35dB.Hybrid ANC technology -20dB to -35dB
Microphones3 microphones per side (integrated) + detachable boom microphone3 microphones per side (integrated) + detachable boom microphone
Frequency Response10 Hz – 40 kHz10 Hz – 40 kHz
Impedance32 Ohms 32 Ohms
ConnectivityBluetooth 5.3, 3.5mm wired input, USB-CBluetooth 5.3, 3.5mm wired input, USB-C
Pro-Specific Upgrade Enhancement MaterialsPremium Italian Alcantara on the headband
Refined, more breathable, replaceable synthetic goatskin earpads
Frame Material: Anodized Aluminum
Earpads Memory foam Korean Protein leather, replaceable
DesignGunmetal Grey finish on the faceplate and frame, with a lighter, more durable anodized aluminum frameAluminum cups, aluminum gimbals, a steel headband, and comfortable, replaceable protein leather/memory foam ear pads
TuningRefined acoustic tuning for enhanced audio performanceNot Indicated
Battery LifeUp to 80 hours (ANC off)
60 hours (ANC on) at 50% volume.
Included AccessoriesCompact carry case
Detachable boom mic
3.5mm cable
6.3mm adapter
4.4mm adapter
Airplane adapter
EVA Carrying Case
Detachable boom mic
3.5mm cable
6.3mm adapter
Airline Adapter
USB-C Cable
noble-fokus-apollo-pro-headphones-blue-input
The Bottom Line
The FoKus Apollo Pro gives Noble a more serious foothold in full size wireless headphones by leaning on something most rivals are not offering: a hybrid dynamic and planar magnetic driver platform inside a Bluetooth headphone. Add LDAC, AAC, aptX, aptX HD, and SBC support, upgraded materials, revised tuning, Italian Alcantara, more breathable ear pads, and limited run positioning, and this becomes more than a cosmetic Apollo refresh.
What appears to be missing is the broader ecosystem strength of Apple, Sony, Sonos, Bowers & Wilkins, and Bose. Those brands bring deeper app integration, stronger ANC reputations, spatial audio platforms, and mainstream retail muscle. Noble’s play is different: better driver story, enthusiast credibility, premium materials, and a more focused sound-first approach.
Price & Availability
The Noble FoKus Apollo Pro is being shown at CanJam Singapore, May 16-17, 2026. Global availability is available at NobleAudio.com and selected retailers for $699 USD / £649 / €749. However, these may not stick around long as only a limited production run was announced — not a permanent addition to the lineup.
The original Noble FoKus Apollo is available for $649 at Amazon.
2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Esoteric K1XE CD Player and PS1XE Power Supply Esoteric K1XE CD Player and PS1XE Power Supply
CD Players
CDs are making a comeback, and Esoteric isn't holding back. The $45,000 Grandioso K1XE SACD player adds a new G2 DAC and an optional...
Bumpboxx Retroboom Portable Boombox in Red, Silver, Black Bumpboxx Retroboom Portable Boombox in Red, Silver, Black
The $299 Bumpboxx Retroboom packs 200 watts of peak power, Bluetooth, RGB lighting and 30-hour battery life into a retro boombox without tapes or...
Esprit Generation 10 Cables Esprit Generation 10 Cables
Audio Cables
Esprit Generation 10 cables arrive in the U.S. with redesigned conductors, connectors, and insulation. Nine ranges span $499 to $59,999.
2026 Goldmund Mimesis Statement Preamplifier 2026 Goldmund Mimesis Statement Preamplifier
Goldmund's Mimesis Statement uses three chassis, separate channel power supplies and redesigned analog circuitry. A flagship with a startling price.
2026 Jamo HYG 5 WiFi Speaker Dark Grey Lifestyle 2026 Jamo HYG 5 WiFi Speaker Dark Grey Lifestyle
Jamo's $399 HYG 5 WiFi speaker offers Qobuz Connect, TIDAL Connect, AirPlay 2, Google Cast and three active drivers in a Scandinavian design.
Discover 7 of the best affordable audio gifts under $500 for 2026, including premium headphones, wireless speakers, and hi-fi upgrades worth keeping.
Sony's NFL WH-1000XM6 headphones feature five exclusive team designs you can't buy. Find out how to enter the 2026 sweepstakes before November 30.
Can the $325 Noble Audio Vanguard compete with the best IEMs under $500? Excellent build and detail meet analytical tuning and fierce rivals.
Which IEMs stood out at CanJam SoCal 2026? We tested 35 models from $75 to $8,000, including hybrids, flagships, prototypes and affordable standouts.
Can Noble Audio’s $899 Artemis combine audiophile sound, strong ANC and repairability well enough to justify its luxury price?
These 8 new headphones and IEMs have us curious in 2026, from Sony’s 1000X ANC flagship to Final, Meze, HiFiMAN, Audeze and Noble.
Is the Noble Audio Vanguard the strongest sub-$350 hybrid IEM for listeners who want premium shells, 1DD + 2BA drivers, balanced connectivity, and USB-C...
Noble Audio's $699 Iris IEM combines a custom 10.2mm dynamic driver, three-layer diaphragm, Micarta housing, and modular cable connectivity.
