Dongle DACs
Schiit Finally Goes Portable With $99 Vestri Dongle DAC
Schiit Vestri is a $99 dongle DAC with balanced power, no screen, USA assembly, and enough attitude to make rivals say “oh Schiit.”
Schiit Vestri Dongle DAC
Schiit Audio has spent the better part of a decade owning the $99 conversation in hi-fi, but until now, it refused to follow the herd into the dongle DAC trenches. That changes with the surprise debut of the Schiit Vestri at CanJam Singapore 2026, a compact USB DAC and headphone amp that finally gives long suffering fans what they’ve been asking for since the first smartphone killed the headphone jack. Took them long enough. Thor waited less time for Ragnarök.
Priced at $99, Vestri is not just another “me too” stick. It is Schiit doing what it does best, dropping into a crowded category late, undercutting expectations, and daring everyone else to explain their pricing. No screen, no nonsense, just a stealth LED interface beneath the surface, simple controls, and both 3.5mm and 4.4mm outputs for those who have already gone balanced and are not going back.
schiit-vestri-dongle-dac-top-bottom
Schiit Vestri: $99 Dongle DAC, Balanced Output, No Screen, Maximum Attitude
Schiit Audio has officially entered the dongle DAC and portable headphone amp category with Vestri, a $99 USB powered DAC and headphone amplifier that debuted at CanJam Singapore. Pre-orders are open now, with shipments scheduled to begin May 28.
Vestri includes both 4.4mm balanced and 3.5mm single ended headphone outputs, capacitive touch controls, Schiit’s Unison USB receiver, and the company’s Mesh D/A conversion platform, which combines a time and frequency domain optimized digital filter with an ES9018 delta sigma DAC.
“I joke when I say ‘Vestri is the only dongle that matters,” explained Jason Stoddard, Schiit’s Co-Founder. “Which is beyond cheeky, but in a field of 10,000 lookalike products all using the same off the shelf technology, it has a grain of truth.”
schiit-vestri-dongle-dac-input
The balanced output delivers up to 400mW RMS into 32 ohms, 320mW into 50 ohms, and 120mW into 300 ohms. The single ended output provides up to 200mW RMS into 32 ohms, 150mW into 50 ohms, and 40mW into 300 ohms. That should make Vestri suitable for a very wide range of headphones and IEMs, although the absolute hardest to drive models will still want something larger and less pocket friendly — so it’s clearly not the only dongle that matters.
The design is classic Schiit mischief with actual engineering behind it. Vestri uses a seamless milled aluminum chassis with a glass front panel, but skips the OLED screen found on many portable DACs.
“No screens,” Stoddard said. “Screens burn in and are a wear item. We want to design for the next generation, not the next sale.”
Instead, Vestri uses individual LEDs embedded beneath the glass for its interface. Schiit says they are run conservatively for long life.
schiit-vestri-dongle-dac-pcb
“It’s the eternal screen,” Stoddard joked. “If you don’t drop it in the sand or in your coffee, Vestri should last far past its warranty.” Duly noted. Not IPX7 rated apparently.
Controls include volume, Loudness, invert, and NOS modes, all accessible through capacitive touch buttons under the glass. Loudness contour is a useful feature at lower listening levels, while NOS mode gives users another playback option without turning the product into a settings circus.
Vestri is also made in the USA on Schiit Audio’s own SMD assembly line in Corpus Christi, Texas.
“We’ve been making products in the USA since we started in a garage 16 years ago,” Stoddard said. “No need to change anything for Vestri.”
Schiit Vestri Key Specs:
  • USB receiver: Schiit Unison USB
  • D/A conversion: Schiit Mesh with ES9018 delta sigma DAC
  • Supported formats: 16-bit/44.1 kHz to 32-bit/192 kHz
  • Outputs: 4.4mm balanced and 3.5mm single ended
  • Power output: up to 400mW RMS balanced, 200mW RMS single ended into 32 ohms
  • Frequency response: 20Hz to 20kHz, ±0.05dB
  • THD: less than 0.0002%, 20Hz to 20kHz
  • SNR: greater than 118dB, A weighted
  • Output impedance: less than 0.5 ohms
  • Controls: volume, NOS, invert, Loudness
  • Display: no OLED screen, embedded LEDs under glass
  • Chassis: milled aluminum with glass front
  • Power: USB powered, 0.9W typical
  • Size: 2.4 x 1.4 x 0.44 inches
  • Weight: 4 oz
  • Made in: USA, Corpus Christi, Texas
  • Warranty: 2 years
The Bottom Line
At $99, Vestri lands in one of the most crowded categories in portable audio, but the combination of balanced output, Unison USB, Mesh conversion, touch controls, no screen, two year warranty, and USA manufacturing gives Schiit a very real point of difference. Sneaky Schiit, indeed.
What makes Vestri stand out is not just the price, it is the refusal to follow the usual template. No off the shelf reference design, no fragile OLED screen, and no anonymous tuning. Instead, Schiit leans on its own USB implementation, its own digital filter approach, and a balanced output stage that actually delivers meaningful power for a dongle at this price. The Loudness control is also a smart inclusion that most competitors ignore, especially for real world listening on the move.
What is missing is just as important. There is no app, no Bluetooth, no wireless anything, and no high resolution streaming integration. Codec chasing is not part of the story here. If you want LDAC, aptX Lossless, or a feature heavy interface, you will have to look elsewhere. Some users will also question the lack of a screen, even if Schiit makes a valid long term durability argument.
Do you know what could make the Vestri even more interesting? Running the 3.5mm output with a 3.5mm to RCA cable into the new Schiit Buf Tube Buffer, and then into a pair of active loudspeakers. Use your smartphone as your network player and insert some “warmth” into the speakers if they need it.
The competition is fierce and not exactly forgiving. Dongles from brands like FiiO, iFi Audio, Questyle, Shanling, and Hidizs dominate this space with feature rich designs, app support, and a wide range of DAC implementations. Many offer more bells and whistles, but few will match Vestri’s combination of balanced power, in house engineering, and made in USA production at this price.
This is for listeners who want a simple, durable, plug and play DAC and headphone amp that focuses on sound and power over features. If Schiit delivers on performance, Vestri is going to be a problem for a lot of very comfortable competitors.
Where to buy: $99 at Schiit.com (available May 28, 2026)
4 Comments
4 Comments
  1. Asgard
    May 19, 2026 at 7:19 pm
    Finally. Geez these guys took bloody forever to bring this to market.
    Hard to argue with the pricing.
    Stick that in your ear Loki!
    • Ian White
      May 19, 2026 at 7:32 pm
      Asgardian,
      I truly hope it’s not a stinker. The market waited for 5 years for them to get off the Schitter and make one.
      We shall see.
      Thanos
  2. Asa
    May 19, 2026 at 9:23 pm
    In a world of $100,000.00+ speakers, you can’t really go wrong with this $99 Schiit? Seems like the perfect nightstand dongle or one you fly with. You either fill up your car with gas one week or buy one of these. I’ll take 2+.
    This is the way.
    • Ian White
      May 19, 2026 at 9:38 pm
      Asa,
      This IS the way. I’m in Vegas. And up $103. Just enough to buy one. Don’t even joke about gas. Spent $62 to fill up a Mazda CX-5. It was $42 before.
      IW
2026 ASCENDO THE MULE 10 Kick Woofer
2026 Adam Audio H715 Reference Open-back Studio Headphones 2026 Adam Audio H715 Reference Open-back Studio Headphones
AT $699, ADAM Audio's flagship H715 Reference headphones, combine Sonnox calibration, balanced Hi-Fi mode, and studio monitoring in one design.
Schiit Audio is finally building a music streamer with Forkbeard and 10 years of software support. Hell hasn't frozen over, but CanJam Dallas might...
Dongle DACs
Questyle's QCC Dongle Pro2 brings LDAC, Bluetooth 6.1, and low-latency gaming to more devices. Is the wireless upgrade worth its compromises?
The $999 Schiit Freya 2 lets listeners switch between passive, solid-state, tube, and two hybrid operating modes from a single balanced preamplifier.
Dongle DACs
Dongle DACs
Questyle’s $399 M18i Max packs Current Mode Amplification, dual DACs, Bluetooth, and serious headphone power into a portable design.
Dongle DACs
Can iFi eliminate the dongle DAC? The $79 GO cable builds an ESS DAC and headphone amp directly into a USB C cable for...
Did Schiit improve Bifrost by moving beyond True Multibit? Bifrost 3 adds Mesh, EQ, 32/384 USB and drops the price to $699.
Can SMSL’s new R100 and D400 MK2 compete with FiiO, Schiit and Topping in the increasingly crowded DAC market below $1,000?
