Kanto TUK Grand Debuts at AXPONA 2026 as TUK and YU Series Get Major Upgrades
Kanto debuts TUK Grand and updates TUK, YU6, and YU4 at AXPONA 2026. Can affordable speakers stand out in a high-priced show?
Kanto Audio Tuk Grand Lifestyle
At AXPONA 2026, where $7,000 speakers often felt like the starting point, Kanto Audio took a different path. The company introduced a redesigned generation of powered and passive speakers led by the new TUK Grand flagship, along with updated YU6 and YU4 models that focus on real gains in acoustic performance and a more refined industrial design. In a show filled with statement systems, Kanto leaned into practicality with products aimed at listeners who want strong performance without stretching into four figure territory.
kanto-yu4-green
First introduced in 2014, the YU series helped establish Kanto Audio as a serious player in affordable, well-executed audio. The TUK followed in 2019 and pushed the company further into hi-fi territory with a more ambitious design and feature set.
One detail worth noting: TUK, YU6, and YU4 models are available in both powered and passive configurations, which are clearly outlined in the comparison charts included in this article.
Kanto TUK Grand Flagship Speaker
kanto-tuk-grand-sx30-stand
Kanto Audio positions the TUK Grand as its most ambitious speaker to date. It builds on the foundation of the original TUK with a larger cabinet, increased internal volume, and updated driver integration aimed at delivering greater scale and a stronger sense of presence.
The added cabinet volume and amplification headroom support a wider soundstage and deeper low-frequency extension, with up to 320 watts of total output. The AMT tweeter, a defining element of the TUK line, has been refined in both the TUK Grand and the updated TUK to maintain detail while improving overall balance.
The cabinet design has also been reworked with sharper lines and a more structured form that feels more deliberate than the previous generation without drifting into excess.
Connectivity is in line with expectations for a modern powered speaker system: Bluetooth 5.4, USB-C with support up to 24-bit/96kHz, optical input at the same resolution, RCA, and a dedicated subwoofer output.
Resdesigned Tuk
kanto-tuk-front-pair
A step down from the TUK Grand, the updated TUK follows the same design direction without trying to reinvent the formula.
The cabinet moves away from the rounded edges of the original to a more squared profile. It’s a cleaner look, but it’s not just cosmetic. The sharper geometry helps reduce edge diffraction, which contributes to a more focused and stable soundstage.
Cabinet volume has also been increased, giving the drivers a more solid acoustic foundation. The revised AMT tweeter now incorporates updated waveguide geometry aimed at smoothing out the high-frequency response and maintaining more consistent performance across a wider listening area.
The proportions feel more deliberate this time. There’s a better sense of balance, and the speaker looks like it belongs in a modern space without trying too hard to make a statement.
Under the hood, the TUK remains a powered design with onboard DSP, an AMT tweeter, and a 5.25-inch aluminum woofer. The active crossover includes a high-pass filter that engages when a subwoofer is connected, reducing low-frequency load below 80Hz to improve clarity and control.
Connectivity covers the bases without overreaching. There’s a dedicated phono input, RCA, optical TOSLINK, USB DAC functionality, and a built-in headphone amplifier. Wireless support is handled via Bluetooth 4.2 with aptX HD and AAC.
Tuk Comparison
Kanto Audio ModelTuk Grand PoweredTuk Grand PassiveTuk PoweredTuk Passive
Product Type Powered Wireless Speaker SetPassive Speaker SetPowered Wireless Speaker SetPassive Speaker Set
Price (Pair)$999.99
$799.99$899.99$699.99
Tweeter 1 x 28 mm × 35 mm Air Motion Transformer (AMT)1 x 28 mm × 35 mm Air Motion Transformer (AMT)1 x 28 mm × 35 mm Air Motion Transformer (AMT)1 x 28 mm × 35 mm Air Motion Transformer (AMT)
Woofer1 x 6″ aluminum concave cone with air-combing waveguide1 x 6″ aluminum concave cone with air-combing waveguide1 x 5.25″ aluminum concave cone with air-combing waveguide1 x 5.25″ aluminum concave cone with air-combing waveguide
Amplifier TypeClass-D with DSP, precision tuned using Klippel NFSN/AClass-D with DSP, precision-tuned using Klippel NFSN/A
Power Output320 W peak power (160 W RMS)N/A260 W peak power (130 W total RMS)N/A
Frequency Response50 Hz – 20 kHz50 Hz – 20 kHz40 Hz – 20 kHz40 Hz – 20 kHz
High / Low-Pass Filter80 Hz (selectable)N/A80 Hz (selectable)N/A
Input2 × RCA line-level
1 × Optical (TOSLINK) (24-bit / 96 kHz)
1 × USB (24-bit / 96 kHz)
1 × Bluetooth 5.4 (aptX HD, aptX Adaptive, SBC, AAC)
N/A2 × RCA line-level
N/A
Output1 × Subwoofer OutN/A1 × Subwoofer OutN/A
Speaker TerminalsActive-to-passive knurled five-way binding postPassive knurled five-way binding postActive-to-passive knurled five-way binding postPassive knurled five-way binding post
Bottom Mounting Hole1/4″-201/4″-201/4″-201/4″-20
Input Voltage / FrequencyAC 100–240 V, 50/60 HzN/AAC 100–240 V, 50/60 HzN/A
Auto Power DownYes (can be disabled)N/AYes (can be disabled)N/A
Auto Power UpYes (can be disabled)N/AYes (can be disabled)N/A
Standby Power Consumption< 0.5 WN/A< 0.5 WN/A
USB ChargingNot IndicatedN/AUSB charge 5 V 2 AN/A
RemoteIncludedN/AIncludedN/A
Speaker GrilleIncludedIncludedIncludedIncluded
Dimensions (each speaker)7.3″ W × 10″ D × 12″ H7.3″ W × 10″ D × 12″ H8.6″ W × 11.6″ D × 13.8″ H8.6″ W × 11.6″ D × 13.8″ H
FinishBlack, White, Walnut, Burled Engineered Wood, and Butter.Black, White, Walnut, Burled Engineered Wood, and Butter.Black, White, Walnut, Burled Engineered Wood, and Butter.Black, White, Walnut, Burled Engineered Wood, and Butter.
Kanto YU6 and YU4 Series
kanto-yu6-yu4
In addition to the TUK Grand and updated TUK, Kanto Audio has introduced next-generation YU6 and YU4 models that stay close to the company’s core playbook but clean up the execution.
Driver integration has been revised, supported by updated DSP tuning and electronics, which together aim to deliver a wider and more stable soundstage than the outgoing versions. These aren’t radical departures, but they are meaningful refinements where it counts.
The cabinets and front baffles have been fully reworked. The new design looks more controlled and modern, but the bigger story is improved driver alignment and dispersion. That translates into more consistent performance across the listening area rather than a narrow sweet spot.
Powered YU6 and YU4 models continue to focus on simplicity. Amplification and connectivity are built in, including Bluetooth 5.3, phono, USB-C, RCA, and a subwoofer output. They’re clearly aimed at real-world setups where space and flexibility matter, whether that’s a living room, desktop, or small studio.
Passive versions carry over the same cabinet and acoustic updates for those who prefer to bring their own amplification into the equation.
Across the lineup, the design changes are doing double duty. Subtle shaping of the front baffle and tweeter waveguides helps manage high-frequency dispersion, which keeps stereo imaging more stable even off-axis. The result is a presentation that holds together better in actual rooms, not just in the ideal listening position.
YU6: The YU6 incorporates a Class D amplifier rated at up to 200 watts peak power. Its 5.25-inch Kevlar woofers and 1-inch silk dome tweeters are designed to support detailed, controlled sound reproduction without overreaching.
YU4: The YU4 uses a 4-inch Kevlar woofer paired with a 1-inch silk dome tweeter, a straightforward configuration that prioritizes balance over scale. It includes a built-in phono preamp for direct turntable connection, and wireless support is handled via Bluetooth 4.0 with Qualcomm aptX.
Yu Comparison
Kanto Audio ModelYu6 PoweredYu6 PassiveYu4 PoweredYu4 Passive
Price (Pair)$549.99$349.99$449.99$249.99
Tweeter 1 x Silk dome tweeter1 x Silk dome tweeter1 x Silk dome tweeter1 x Silk dome tweeter
Woofer1 x 5.25″ Abaca-reinforced paper1 x 5.25″ Abaca-reinforced paper1 x 4″ Abaca-reinforced paper1 x 4″ Abaca-reinforced paper
Amplifier TypeClass-D with DSP for precise tuningN/AClass-D with DSP for precise tuningN/A
Power Output200 W peak power (130 W RMS)N/A160 W peak power (110 W RMS)N/A
Frequency Response55 Hz – 20 kHz (±3 dB)55 Hz – 20 kHz (±3 dB)60 Hz – 20 kHz (±3 dB)60 Hz – 20 kHz (±3 dB)
High / Low-Pass Filter80 HzN/A80 HzN/A
Input1 × RCA with selectable phono pre-ampN/A1 × RCA with selectable phono pre-ampN/A
Speaker Terminals4-way knurled binding posts4-way knurled binding posts4-way knurled binding posts4-way knurled binding posts
Input Voltage / Frequency100–250 V, 50–60 HzN/A100–250 V, 50–60 HzN/A
Auto Power DownYes, selectableN/AYes, selectableN/A
Auto Power UpYes, selectableN/AYes, selectableN/A
USB ChargingNot IndicatedN/ANot IndicatedN/A
Speaker GrilleNot IndicatedNot IndicatedNot IndicatedNot Indicated
Dimensions (each speaker)6.9″ W × 8.4″ D × 10.7″ H6.9″ W × 8.4″ D × 10.7″ H5.5″ W × 8.1″ D × 9.2″ H5.5″ W × 8.1″ D × 9.2″ H
FinishWhite, Black, Walnut, Ice Blue, and Green.White, Black, Walnut, Ice Blue, and Green.White, Black, Walnut, Ice Blue, and Green.White, Black, Walnut, Ice Blue, and Green.
The Bottom Line
Kanto Audio is taking a practical, modular approach that makes sense in the real world. Offering the same core speakers in both powered and passive versions gives buyers flexibility that a lot of competitors still gloss over. You can keep it simple with an all-in-one powered setup or build around the passive versions with your own amplification. Same drivers, same cabinet design, different paths.
What’s missing is just as important. The wireless models do not support higher-end codecs like aptX Lossless or LDAC, and there’s no HDMI input, which limits integration with TVs compared to some rivals. On the plus side, the inclusion of a dedicated subwoofer output across the powered lineup is a smart move and adds real system scalability.
Competition is not light. Brands like KEF, ELAC, Cambridge Audio, Audioengine, and Fluance all offer strong alternatives in both powered and passive compact speaker categories, many with deeper feature sets or more established hi-fi credibility.
Who is this for? Listeners who want flexibility without complication. Desktop users, small room setups, and anyone building a secondary system will find a lot to like here. It’s also a good entry point for buyers who want better sound than typical lifestyle speakers without diving headfirst into separates.
Pricing & Availability
Tuk Grand and Tuk will launch with the following colors: Black, White, Walnut, Burled Engineered Wood, and Butter.
  • Tuk Grand (Powered):  $999.99
  • Tuk Grand (Passive): $799.99
  • Tuk (Powered): $899.99
  • Tuk (Passive): $699.99
Yu4 and Yu6 will launch with the following colors: White, Black, Walnut, Ice Blue, and Green.
  • Yu6 (Powered): $549.99
  • Yu6 (Passive): $349.99
  • Yu4 (Powered): $449.99
  • Yu4 (Passive):  $249.99
Both lines are expected to be available by summer 2026.
2026 Horizon 30 Pro Lifestyle Projector in living room
XGIMI’s new HORIZON 30 projectors combine brighter RGB triple-laser light engines, improved contrast and 4K/120Hz gaming in a flexible lifestyle design.
2026 Fosi Audio DAP Neo in pocket 2026 Fosi Audio DAP Neo in pocket
DAPs
The $80 Fosi Audio DAP Neo delivers iPod nostalgia, lossless playback, Bluetooth and expandable storage. Can it win over the streaming generation?
2026 JMGO Iris Ultra Projectors 2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle 2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
Does the Triangle AIO Twin look better in Macassar? The $899 wireless stereo system adds real wood veneer while keeping vinyl and hi-res streaming.
Are the $1,499 Wharfedale Super Denton truly the British Bulldog of standmount speakers, and do they justify their place in the Heritage lineup?
At $499 per pair, the versatile Edifier R2750DB MKII wireless speakers feature three-way sound, HDMI eARC and LDAC Bluetooth for desktop, bookshelf or stand-mount...
Loudspeakers
Dynaudio says U.S. warranties will remain valid after its North American exit, but repair centers and future distribution remain unresolved.
Loudspeakers
NEAD will distribute Jamo, Energy, Juke Audio, XLO and OXS across the U.S. and Canada as two familiar speaker brands plan their return.
Loudspeakers
Dynaudio says support will continue as it exits North America and closes its U.S. subsidiary, but dealer and warranty questions remain.
