JBL Debuts Summit Everest and K2 Flagship Loudspeakers at High End Vienna 2026
The new generation Summit Everest and K2 join the previously released Makalu, Pumori, and Ama in an ultimate high-end JBL speaker line-up.
2026 JBL Summit Series Loudspeakers in Macassar Ebony
HARMAN Luxury Audio Group has arrived at High End Vienna 2026 with several new high-end audio products, but the headline for JBL is the next generation of its Summit Everest and Summit K2 flagship loudspeakers.
Timed with JBL’s 80th anniversary, the updated Everest and K2 join the Summit Makalu, Summit Pumori, and Summit Ama, which debuted at High End Munich in 2025. Together, they complete the five-model JBL Summit Series for residential audio.
JBL describes the Summit Series as one of its most advanced loudspeaker efforts for the home, and only the fifth JBL loudspeaker family to carry the “Project” designation in the company’s eight-decade history. That label matters: JBL has historically reserved it for its most ambitious engineering platforms, not just another expensive box with prettier woodwork and a Sherpa-friendly name.
The JBL Project Legacy
Only a select few JBL loudspeakers have ever carried the “Project” designation since 1954, beginning with Project Hartsfield, followed by Project Paragon, Project Everest, and Project K2.
Each JBL Project loudspeaker reflects a particular stage in the company’s high-end engineering work, with changes in driver design, enclosure construction, horn geometry, crossover design, and system integration shaping each generation.
For nearly 40 years, Project Everest and Project K2 have been central to JBL’s high-end loudspeaker development. Successive versions have introduced updates to transducers, compression drivers, cabinet construction, waveguides, and overall system tuning.
The latest generation Summit Everest and Summit K2 carry that tradition forward with patented and proprietary technologies developed at JBL’s renowned Acoustic Center of Excellence in Northridge, California.
Summit Everest
jbl-summit-everest-ebony-front
Summit Everest, named after Earth’s highest mountain, is the flagship of the Summit Series and the successor to four generations of Project Everest loudspeakers released over the years.
Mid/High Frequency: The core of the latest Everest is a newly engineered mid/high-frequency system that combines the output of three patented JBL D2820 2-inch dual-diaphragm, dual-motor compression drivers with a custom-designed, patent-pending 3-into-1 expansion manifold, seamlessly mated to a custom large-format Sonoglass High-Definition Imaging (HDI) horn.
Mid-Bass/Bass: For mid-bass and bass, there are dual 10-inch cast-frame Differential Drive mid-bass drivers and dual 15-inch cast-frame Differential Drive woofers, each utilizing JBL’s triple-layer Hybrid Carbon Cellulose Composite Cone (HC4) for stiffness, low distortion, and exceptional power handling that define a true reference design.
3.5 Way Configuration: The result of its driver configuration, the Everest is a 3.5 Way floor-standing loudspeaker that is designed to support elevated resolution, dynamic authority, tonal precision, and spatial realism across a bandwidth extending from 20 Hz to beyond 23 kHz.
Summit K2
jbl-summit-k2-ebony-front
The Summit K2, named after Earth’s second-tallest mountain, is JBL’s most accomplished 15-inch 3-way floor-standing loudspeaker, built upon the legacy of four generations of Project K2 development. The K2 brings signature musicality forward with measurable advances in resolution, transparency, and tonal accuracy.
Mid/High Frequency: The latest K2 incorporates a newly engineered mid/high-frequency system pairing three patented D2815 1.5-inch dual-diaphragm, dual-motor compression drivers with a custom-designed, patent-pending 3-into-1 expansion manifold and large-format Sonoglass® HDI™ horn.
Mid-Bass/Bass A 10-inch cast-frame Differential Drive mid-bass driver and a 15-inch cast-frame Differential Drive woofer are included, both of which feature HC4 cones. This design anchors the K2’s sonic foundation, delivering the dynamic precision and emotional immediacy that have defined this speaker since its 1989 debut.
The Summit Standard
The Summit Everest and Summit K2 bring together the main technologies developed for the Summit Series, including updated transducers, horn/waveguide geometry, crossover design, and cabinet construction.
A MultiCap crossover network, supporting single-wire, bi-amp/bi-wire, and tri-amp/tri-wire connectivity, replaces traditional large capacitors with a greater number of smaller capacitors, reducing electrostatic resistance and minimizing energy loss for greater signal transfer, increased power handling, and ultra-low distortion.
The Everest and K2 are housed in a precisely engineered enclosure with internally offset, multi-braced, and damped pre-stressed pressed curved-wall construction designed to minimize internal standing waves.
Custom-designed JBL | IsoAcoustic isolation feet decouple the loudspeaker from the supporting surface, contributing to tighter bass performance, a more expansive soundstage, and imaging defined by greater clarity and spatial precision.
Finishes and Binding Posts
jbl-summit-everest-ebony-rear-connections
Summit Everest and Summit K2 are offered with a choice of high-gloss painted black with Summit Platinum accents or high-gloss Macassar Ebony wood veneer with Summit Gold detailing. The Everest and K2 employ sustainably sourced engineered wood cabinetry that reflects JBL’s commitment to materials and execution.
The speaker binding posts are rhodium-plated, wrapped in carbon fiber, with Ohno-Continuous-Cast (OCC) long-crystal oxygen-free silver-plated copper internal wiring.
JBL 2026 Summit Series Comparison
jbl-summit-loudspeakers-black-full-line
JBL Summit Series in high gloss black
JBL Summit ModelEverest
(2026)
K2
(2026)
Makalu
(2025)
Pumori
(2025)
AMA
(2025)
Speaker Type3.5-way floor-standing Floor-standing Reference Loudspeaker3-way floor-standing Floor-standing Reference Loudspeaker3-Way Bass Reflex Floor-standing Reference Loudspeaker3-Way, Bass Reflex Floor-standing Reference Loudspeaker2-Way, Bass Reflex Stand-mount Reference Loudspeaker
Price (pair)$159,990$99,990$44,995$29,995$19,995
High Frequency ControlHDI™ Sonoglass® HornHDI™ Sonoglass® HornHDI™ Sonoglass® HornHDI™ Sonoglass® HornHDI™ Sonoglass® Horn
Tweeter (HF Transducer)D2820 2-inch dual-diaphragm, dual-motor compression driversD2815 1.5-inch dual-diaphragm, dual-motor compression driversD2830K: Dual 3-inch (75mm) Teonex® D2 Compression DriverD2815K: Dual 1.5-inch (38mm) Teonex® D2 Compression DriverD2815K: Dual 1.5-inch (38mm) Teonex® D2 Compression Driver
Mid-Bass (MB Transducer)Dual 10-inch HC4, Differential Drive Motor10-inch HC4, Differential Drive Motor
8-inch HC4, 2.5″ Voice Coil, Ferrite Motor, Cast Frame8-inch HC4, 2.5″ Voice Coil, Ferrite Motor, Cast FrameN/A
Woofer (LF)15-inch HC4, 3″ Voice Coil, Differential Drive Motor15-inch HC4, 3″ Voice Coil, Differential Drive Motor12-inch HC4, 3″ Voice Coil, Differential Drive Motor10-inch HC4, 2.5″ Voice Coil, Ferrite Motor8-inch HC4, 2.5″ Voice Coil, Ferrite Motor
Ports22221
Input TypeBi-amp / Bi-wire Capable with Dual Sets of Binding PostsBi-amp / Bi-wire Capable with Dual Sets of Binding PostsBi-amp / Bi-wire Capable with Dual Sets of Binding PostsBi-amp / Bi-wire Capable with Dual Sets of Binding PostsBi-amp / Bi-wire Capable with Dual Sets of Binding Posts
CrossoverMultiCap™ with Bi-amp/Bi-wire and tri-amp/tri-wireMultiCap™ with Bi-amp/Bi-wire and tri-amp/tri-wireMultiCap™ with Bi-amp/Bi-wireMultiCap™ with Bi-amp/Bi-wireMultiCap™ with Bi-amp/Bi-wire
Finish High-gloss black with Platinum accents
High-gloss Macassar Ebony wood veneer with Summit Gold detailing
Black High Gloss / Ebony Veneer w/ GlossBlack High Gloss / Ebony Veneer w/ GlossBlack High Gloss / Ebony Veneer w/ Gloss
Dimensions (HWD)56.8″ x 39.1″ x 27.3″50.4″ x 25.0″ x 18.1″43.4″ x 18.3″ x 15.5″41.6″ x 15.5″ x 14.7″Speaker: 18.6″ x 12.1″ x 13.2”
Stand: 21.7″ x 16.2″ x 16.2″
Weight 523 lbs239 lbs152.6 lbs140.8 lbs58 lbs
jbl-80-years-benson-boone
JBL Celebrates 80th Anniversary
JBL is celebrating its 80th anniversary in 2026, marking eight decades since James B. Lansing founded the company in 1946. That is not a small footnote in audio history. JBL has been part of professional studios, cinemas, concert venues, home audio systems, cars, portable speakers, headphones, and more than a few cultural moments where the sound system mattered as much as the crowd.
The brand’s reach is unusually broad. JBL Professional continues to play a major role in cinemas, studios, stadiums, houses of worship, clubs, and live venues, while JBL’s consumer division has become one of the most visible names in portable audio and headphones. Few audio companies can claim that kind of spread without sounding like the marketing department got loose with the espresso machine. In JBL’s case, the claim has some weight behind it.
Founded by one of the most important loudspeaker engineers of the 20th century, JBL built its reputation on high-output loudspeakers, studio monitors, professional sound reinforcement, and home audio products that helped define what American hi-fi looked and sounded like. The company’s history includes major technical achievements in loudspeaker design and recognition from both the film and recording industries, including Academy Awards for sound engineering achievements and a Grammy Award for its long-running contribution to concert, studio, cinema, and broadcast sound.
jbl-80-year-legacy
That legacy still matters because JBL is not just trading on old photographs and orange grilles. The company remains active across professional, luxury, portable, automotive, and personal audio, while also investing in spatial audio, adaptive sound, immersive listening, and more sustainable product design. Not every one of those phrases needs a parade, but they do point to where JBL thinks audio is going next.
“For 80 years, JBL has been defined by an uncompromising pursuit of acoustic excellence, and the Project loudspeakers have always represented the absolute summit of that pursuit,” said David Tovissi, Vice President & GM, HARMAN Luxury Audio. “With Summit Everest and Summit K2, we are honoring four generations of legendary engineering while introducing technologies that move the state of the art forward. These are reference loudspeakers built for listeners who refuse to compromise and who recognize what it means to own the very best.”
jbl-summit-everest-ebony-lifestyle-no-grille
JBL Summit Everest Loudspeakers in High-gloss Macassar Ebony wood veneer with Summit Gold detailing.
The Bottom Line
With Summit Makalu, Pumori, and Ama introduced in 2025, JBL expanded the Summit Series below its established Everest and K2 flagships. The arrival of the latest Summit Everest and Summit K2 completes the line at the top, giving JBL a five-model residential flagship range tied directly to its Project loudspeaker heritage.
What makes Everest and K2 different is not just scale or price. These are JBL’s statement platforms for horn-loaded compression-driver design, large-format woofers, advanced cabinet construction, and high-output, low-distortion playback in larger rooms. Everest remains the larger dual-15-inch statement model, while K2 continues as the more compact single-15-inch flagship. Both are built for listeners who want JBL’s studio, cinema, and professional audio DNA translated into a domestic loudspeaker system.
These are not lifestyle speakers, and they are not for casual background listening. They are for large rooms, substantial amplification, careful setup, and buyers who want the most ambitious version of JBL’s high-end sound at home. The Summit Ama, Pumori, and Makalu may be more realistic choices for many systems, but Everest and K2 exist for the customer who wants the top of the JBL mountain and has the room, budget, and patience to let them work properly.
jbl-summit-k2-ebony-lifestyle
JBL Summit K2 Loudspeakers in High-gloss Macassar Ebony wood veneer with Summit Gold detailing.
Pricing & Availability
The JBL Summit Everest and JBL Summit K2 will be globally available later in 2026 through authorized JBL Summit dealers and partners, with the following prices:
  • Everest: $159,990 USD (159,998 EUR / 139,998 GBP) per pair
  • K2: $99,990 USD (84,998 EUR / 71,998 GBP) per pair
Previously released in 2025, the Summit Models that round out the prestigious speaker line.
  • Makalu: $45,000 USD (43,998 EUR / 36,998 GBP) per pair
  • Pumori: $30,000 USD (30,998 EUR / 26,998 GBP) per pair
  • Ama: $20,000 USD (17,498 EUR / 14,995 GBP) per pair including stands
For more on the JBL Summit Series, visit jbl.com/summit-series
2 Comments
2 Comments
  1. Metalhead
    June 7, 2026 at 4:37 pm
    Cannot afford them, will probably never hear them, but I have a deep admiration and appreciation for large JBL’s. I got in front of JBL 4350’s way back and listened to the entire Rolling Stones – Sticky Fingers and those JBL’s absolutely floored me. Instant lust and desire and that demo still to this day brings back memories.
    Have a wonderful engaging stereo that I enjoy but Man, those 4350’s I still want.
    Congratulations to anyone scoring a pair of one these models. Bet your rock collection will be involving and fun .
    • Ian White
      June 7, 2026 at 5:55 pm
      Metal,
      The scale alone is worth the price of admission.
      They also need a lot of power to really open up.
      IW
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
A/V Furniture & Accessories
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Magico A3 2027 Loudspeakers Lifestyle Magico A3 2027 Loudspeakers Lifestyle
Magico rebuilds the A3 with M9-derived engineering, new drivers and a new cabinet. The other upgrade? Entry-level Magico now costs $25,000.
2026 JBL PartyBox Ultimate 2 Party Speaker Lifestyle 2026 JBL PartyBox Ultimate 2 Party Speaker Lifestyle
The $1,800 JBL PartyBox Ultimate 2 packs 1,500 watts, Wi-Fi 6, Roon, AI karaoke and a touchscreen into a light show speaker that isn't...
2026 TDM Neo Headphone Speaker Black in hand 2026 TDM Neo Headphone Speaker Black in hand
TDM Neo headphones twist into a Bluetooth speaker, offering one device for private listening and the occasional need to become everyone’s DJ.
WiiM Bar debuts at High End Vienna 2026 with Dolby Atmos, DTS:X, RoomFit, HDMI eARC, and expandable 3.0.2 surround from $479.
The 2026 CEDIA Expo was held last week in Denver and eCoustics was there in force to check out the latest in home theater...
Can JBL Cove challenge Sonos, HEOS and Bluesound with Whole Home audio, Dolby Atmos and automatic room tuning?
Can 64 Audio’s $3,999 Ocean flagship IEM justify its price with isobaric bass and 32 passive tuning combinations?
Can the Atlantis Lab AT-23 Pro deliver deep bass and room-filling dynamics without a subwoofer? Our review explains why it deserves attention.
What did Focal and Naim bring to Audio Advice Live 2026? A $210K Diva Alta Utopia, Scala’s North American debut, Hekla and a $5,297...
