Viaim Rise AI Agent Earbuds Use Bose Audio Tuning and Turn Meetings Into Notes and Tasks
Can AI earbuds actually improve your workday? Viaim Rise records meetings, creates notes, and helps turn conversations into actionable tasks.
2026 Viaim Rise AI Wireless Earbuds inside case angle
Viaim is a relatively unknown brand offering wireless earbuds with a built-in AI through a crowdfunding campaign on Indiegogo. Early backers can initially pledge $259 for early access to Viaim Rise AI Agent Earbuds with smart charging case. Rise can record meetings, calls, and conversations, then turn those recordings into transcripts, editable notes, summaries, follow-ups, and task drafts. Viaim’s AI agents can take that process a step further by helping move approved tasks forward rather than leaving you with another transcript to sort through later.
So are the Viaim Rise genuinely more useful than conventional wireless earbuds with a few AI features sprinkled on top? Let’s take a closer look.
viaim-rise-earbuds-exterior
Premium Audio With Bose Tuning
On the more traditional wireless earbud side of the equation, the Rise uses an 11mm bass driver and 6mm treble driver, with a claimed frequency response of 20Hz to 40kHz. The earbuds also feature Sound by Bose audio tuning, giving Viaim some outside expertise where sound quality is concerned.
Wireless connectivity is handled by Bluetooth 5.4, with support for the high-resolution LDAC and LHDC codecs for compatible devices and streaming sources.
Multipoint connectivity is also supported, allowing the Rise to remain connected to more than one compatible device. Active Noise Cancellation (ANC) is included for reducing surrounding noise while listening to music or taking calls, with the latter also benefiting from the Rise’s extensive microphone array.
Battery life is rated at up to 30 hours of music playback or 22 hours of call time, although the actual numbers vary depending on how the earbuds and AI features are being used. We break those figures down in the chart below.
For commuters, travelers, and anyone planning to use them away from a desk, the Rise earbuds carry an IP55 rating for dust and water resistance. The charging case, however, is not water-resistant, so dropping the whole package into the pool remains a decidedly poor productivity hack.
viaim-rise-earbuds-inside-case-open-front-back
AI Features and Vitana Assistant
As mentioned earlier, listening to music and making calls are only part of what the Viaim Rise is designed to do. Its bigger differentiator is an extensive collection of AI recording, transcription, organization, and productivity toolsbuilt around the earbuds, smart case, Viaim software, and Vitana AI assistant.
Together, those elements turn the Rise into a wearable system for capturing information, understanding the context behind it, and turning conversations into something potentially useful. Instead of recording a meeting and then manually moving the information between transcription, note-taking, and productivity apps, Viaim is attempting to handle much of that process within a single ecosystem.
Audio Capture: A tap can start recording calls, in-person meetings, and other conversations, with transcription support for 78 languages and 145 accents. The smart case can also record independently when the earbuds are not being worn, which is one of the more unusual aspects of the Rise system. Viaim says recording only begins when initiated by the user and provides a visible indication that recording is active.
Understanding: Viaim’s Spaces organize recordings, documents, previous decisions, and other project information so the AI has more context than a standalone meeting transcript. Vitana, Viaim’s built-in AI assistant, can then search across that information and identify decisions, potential risks, action items, and next steps.
Acting on What Was Recorded: Vitana can turn recorded conversations into summaries, editable notes, follow-ups, and task drafts that are ready to review when the meeting ends. Viaim’s Task Broker is designed to route approved actions to supported productivity and AI tools, moving Rise beyond simply recording and summarizing what was said. Importantly, Viaim says the user must approve external actions before they are executed.
Conversational AI: Vitana isn’t limited to meetings and work-related recordings. While listening, users can ask questions about what they have heard, including music and podcasts, and receive an answer through the earbuds. Rise can pause playback for the interaction and then resume listening afterward, keeping the phone out of the process as much as possible.
That combination is what makes the Rise more interesting than wireless earbuds with an AI transcription feature bolted on. The real question is whether Viaim can make all of those pieces work together seamlessly enough that users actually rely on them rather than retreating to the collection of apps they already use.
Viaim Rise Earbuds Specifications
Viaim ModelRise (VI-A10)
Product Type Wireless Earbuds
Price$399 ($259 Early Bird)
ColorSilver
Drivers 11 mm Bass Driver + 6 mm Treble Driver
Frequency Response 20 Hz – 40 kHz
Sound By BoseYes
Bluetooth Version 5.4
Multi-point Yes
Audio Certification Hi-Res Audio Wireless
Supported Audio Codecs SBC, AAC, LDAC, LHDC
Earbud Microphones 3 Mics + 1 VPU Bone Conduction Mic (per earbud)
Charging Case Microphones 3 Array Microphones
Total Microphone Count 11 Microphones
Music Playback (ANC OFF) Earbuds: 8 hours | Total with case: 30 hours
Music Playback (ANC ON) Earbuds: 6 hours | Total with case: 22 hours
Voice Call (ANC OFF) Earbuds: 5 hours | Total with case: 22 hours
Voice Call (ANC ON) Earbuds: 4 hours | Total with case: 18 hours
Charging Method USB-C Wired Charging Wireless Charging (Up to 5W)
Fast Charging Capability 5 mins charging = ~1 hour playback time
Magsafe CompatibleYes
IP RatingEarbuds: IP55
Charging Case: Non-waterproof
Earbud Dimensions 31 mm x 22 mm x 25 mm
Charging Case Dimensions 64.8 mm x 57.4 mm x 24.4 mm
Earbud Weight (Single) Approx. 4.8 g
Charging Case Weight Approx. 65 g
Total Package Weight Approx. 265 g
viaim-rise-earbuds-interior
The Bottom Line
There is certainly no shortage of wireless earbuds to choose from, and the sheer number of models has probably made the buying process more confusing rather than easier. Breaking them down by purpose helps. Some earbuds are designed primarily for music listening, others for workouts, travel, gaming, or maximum noise cancellation. The Viaim Rise takes a considerably different approach by putting AI-driven productivity at the center of the experience.
That is what makes the Rise genuinely unusual. Its earbuds and smart case can capture meetings, phone calls, and conversations, while Viaim’s Vitana AI platform can turn those recordings into transcripts, summaries, editable notes, follow-ups, and task drafts. Spaces can connect recordings with documents and previous project information, while Viaim’s Task Broker is designed to move approved actions into supported productivity and AI platforms. The important distinction is that Viaim is trying to move beyond simply telling you what happened in a meeting and toward doing something with that information afterward. Viaim also states that users must approve external actions before they are executed.
The Rise is not solely a productivity tool. Viaim has equipped it with an 11mm bass driver and 6mm treble driver, Sound by Bose audio tuning, ANC, multipoint connectivity, and support for the Hi-Res LDAC and LHDC Bluetooth codecs. It also includes 3D Spatial Audio, and Viaim specifically states that the sound remains positioned as the listener turns their head, so spatial audio and head tracking should not be counted among its omissions.
There are still some audio features worth noting at its $399 price point. Viaim’s currently published Rise materials do not list aptX Adaptive, aptX Lossless, LC3, Auracast, or Dolby Atmos support. That does not automatically make the Rise deficient — LDAC and LHDC already provide high-resolution Bluetooth options — but listeners shopping primarily for the most comprehensive collection of premium wireless-audio features may find competing models more appealing.
That also gets to the heart of who should actually buy the Rise. This is not a pair of $399 wireless earbuds attempting to win solely on audiophile sound quality, ANC performance, or codec support. Viaim is targeting people who spend their days moving between meetings, calls, projects, and conversations and want their earbuds to become part of that workflow. For that customer, recording a meeting and having AI organize and act on the information may be substantially more valuable than another Bluetooth codec.
Competition?
There are surprisingly few direct competitors because most premium wireless earbuds still use AI for things such as call processing, noise cancellation, translation, or access to a voice assistant. They generally do not combine recording, transcription, meeting intelligence, and subsequent workflow tools in the manner Viaim is proposing.
The Soundcore AeroClip 2 Pro is the closest rival we have covered. Its built-in recording system can capture in-person meetings, online meetings, and both sides of phone calls. Recordings are transferred to the Soundcore app, where AI can generate meeting summaries using different templates and make previous recordings searchable. Like the Rise, Soundcore is positioning the AeroClip 2 Pro as both an audio product and a wearable productivity tool. Its U.S. price and final launch date have not yet been announced.
The Nothing Ear (3a) offers a much less expensive and less ambitious interpretation of the same idea. At $99, its Audio Snapshot feature can capture audio from podcasts, videos, meetings, lectures, and other media, while the earbuds also support call recording. Captured material can be transferred to the Nothing X app for playback, editing, sharing, and transcription. It does not offer anything approaching Viaim’s Spaces, contextual project intelligence, or agent-driven task execution, but it demonstrates how quickly recording and transcription features are moving into mainstream wireless earbuds.
And that is where the Viaim Rise separates itself from both. Soundcore comes closest with meeting recording, AI summaries, and searchable recordings, while Nothing delivers useful capture and transcription tools for a fraction of the price. Viaim is attempting to connect the entire chain — capture the conversation, understand its context, identify what needs to happen next, and help execute approved actions.
Whether that is worth $399 will depend heavily on how well Vitana, Spaces, and Task Broker work outside a controlled demonstration. But if Viaim can deliver the experience as advertised, the Rise is not simply another expensive pair of wireless earbuds with AI sprinkled on top. It represents an emerging category of wearable AI productivity devices that also happen to play music.
Price & Availability
The Viamin Rise crowdfunding campaign went live at Indiegogo on September 8, 2026 at 9 AM EDT. Early backers can get a super early-bird price of $259 against a $399 MSRP.
2026 Audio-Technica ATH-AWX7000 Headphones
Audio-Technica’s $3,800 ATH-AWX7000 combines Japanese Cypress wood, luxury craftsmanship, and new 58mm drivers. Can it challenge the best closed-back headphones?
2026 Final A8000 DC IEM Back Front 2026 Final A8000 DC IEM Back Front
Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet
2026 Nagra AMP II-S Stereo Power Amplifier 2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
Sennheiser's flagship wireless earbuds for 2026 deliver warm sound, capable ANC, and replaceable batteries. At $299, can they compete with Sony's best?
TRIBIT's $39.99 wireless earbuds come feature packed with noise cancellation, Bluetooth 6.0, multipoint and up to 8 hours of battery life per charge.
Are Apple AirPods 5 a better value at $129 and $149? Apple cuts the price of its wireless-charging model by $30 for 2026.
Can open-back headphones work as everyday wireless cans? Audio-Technica’s ATH-AL5NC add LDAC, ANC, wired playback and up to 75 hours of battery life.
AI has become the garnish nobody ordered on almost every new consumer electronics product, but Soundcore is taking a somewhat different approach at IFA...
EarFun unveils Air Pro 4+, Clip 2, and Wave Pro X at CES 2026 with hybrid ANC, Bluetooth 6.0, lossless audio, AI translation, and...
