Noble Audio Iris IEM Launches at $699 With Dynamic Driver and Three Layer Diaphragm
Noble Audio’s $699 Iris IEM combines a custom 10.2mm dynamic driver, three-layer diaphragm, Micarta housing, and modular cable connectivity.
Noble Audio Iris IEMs back with tips
Noble Audio has never shown much interest in keeping its IEM lineup small, but the new $699 Iris is notable for the opposite reason. While some of the brand’s more ambitious recent designs rely on increasingly elaborate combinations of dynamic, planar magnetic, and balanced armature drivers, the Iris keeps the concept focused around one dynamic driver with a three layer diaphragm and neodymium magnets.
Noble calls it “One Driver, One Vision,” which is refreshingly direct in a category that too often mistakes a longer parts list for better sound. The company says the Iris has been designed for clarity, focus, and natural musical flow, with single driver coherence taking priority over specification sheet theatre.
That does not make the Iris a budget IEM. At $699, it is still a serious wired earphone aimed at listeners who care about fit, tuning, and long term musical satisfaction. But it gives Noble a more accessible universal IEM below models such as the $1,399 Lu Ban, without requiring buyers to invest in a miniature science fair for their ears.
The Iris arrives alongside the Vanguard, but the two are distinct additions to the Noble catalog rather than a forced head to head. This article covers the design, features, and intended audience for the Iris. The Vanguard is covered separately in a companion article.
Iris Driver Implementation
noble-audio-iris-nozzle
For the Iris, Noble Audio has taken a more purist approach. Rather than combining multiple driver types and hoping the crossover behaves itself, the Iris relies on a single custom 10.2mm dynamic driver designed to cover the full frequency range from one coherent source.
That driver uses a three-layer PU and PEEK diaphragm with an added coating, supported by a dual neodymium-iron-boron magnet system and a triple-chamber acoustic design. Noble says the goal is a more naturally connected presentation with focused imaging, convincing vocal presence, controlled low-frequency texture, and enough space around instruments to avoid turning everything into a small, expensive traffic jam.
The appeal of a single dynamic driver design is not novelty. It is coherence. With no handoff between separate driver types, Noble is positioning the Iris as an IEM for listeners who value tonal continuity and musical flow.
Style
noble-audio-iris-iems-back-angle
noble-audio-iris-iems-side
The Iris uses a blue CNC-machined Micarta housing inspired by the iris flower. The material gives the universal in ear monitor a distinct appearance while keeping the design aligned with Noble’s broader emphasis on craftsmanship and finish.
Rather than treating the exterior as an afterthought, Noble has paired its acoustic design with a housing that feels considered and visually restrained. The result is a universal IEM that aims to balance fit, materials, and presentation without distracting from its primary job: making music.
Who is the Noble Iris For?
The Noble Iris is aimed at listeners who want a premium wired IEM with a straightforward single dynamic driver design and the flexibility to work across a range of systems.
With an impedance of 34 ohms and a sensitivity rating of 113dB ±3dB at 1kHz, the Iris should be easy to drive from many portable players, headphone DACs, and desktop amplifiers. Noble includes an 8-core OCC cable with interchangeable 3.5mm and 4.4mm plugs, allowing owners to connect the Iris to both single-ended and balanced sources without replacing the entire cable.
Noble Iris Specifications
Noble Model Iris (2026)
Product TypeIEM (In-Ear Monitor)
Price$699 / £649 / €749
DriverSingle 10.2mm custom dynamic driver
Three-layer PU and PEEK diaphragm with coating
Dual neodymium-iron-boron magnet system
Triple sound chamber design
Frequency response10Hz–40kHz
Sensitivity 113dB +/- 3dB at 1kHz
Impedance34Ω
Exterior Design/FinishBlue CNC-machined custom Micarta housing
Connectors3.5mm + 4.4mm replaceable plug
Included Cable8-core OCC cable
noble-audio-iris-iems-back-wired
The Bottom Line
At $699, the Noble Iris is not an entry-level IEM, but it is also not trying to win a driver-count contest. Its appeal is a more focused formula: one custom 10.2mm dynamic driver, a three-layer PU and PEEK diaphragm, triple-chamber acoustic design, and a blue Micarta housing that gives it a more distinctive look than the usual black resin shells.
The most direct competitor is the Meze Advar, which also sells for $699 and relies on a single dynamic driver. The Meze Astru is a logical step-up option for listeners willing to spend $899 on another premium single-driver design, while the Campfire Audio Alien Brain and AFUL Dawn-X sit above the Iris in price and pursue more complex hybrid architectures. Noble’s own $325 Vanguard offers a less expensive way into the company’s current IEM lineup.
The Iris makes the most sense for wired IEM listeners who value a coherent single-driver approach, useful 3.5mm and 4.4mm connectivity from the included cable, and a design that does not look like it was pulled from the same anonymous parts bin as everything else. Whether Noble’s “One Driver, One Vision” promise holds up will come down to the tuning, fit, and how well that driver performs in the real world.
Price & Availability
Noble Audio Iris is priced at $699 / £649 / €749 and is available from nobleaudio.com and selected retailers worldwide.
The Noble Audio Iris will make its public debut at Potafes 2026 Summer Akihabara, the Portable Audio Festival in Japan, on July 11th and 12th 2026.
Discover the best wireless earbuds of 2026 from Sony, Bose, Noble, and more. Our hands-on picks cover sound quality, ANC, comfort, features, and value.
The $519 EPZ 550 pairs five balanced-armature drivers with striking metalwork and refined sound, but its polite bass won't satisfy everyone.
DUNU PRS6 brings MEMS technology to a refined tribrid IEM with strong resolution, clean treble and a clear focus on competitive gaming.
Can Sony’s $120 IER-M500 professional in-ear monitors deliver the sound, comfort, and durability working musicians need?
Melody Wings’ $188 Uranus delivers airy, resolving sound from a quadbrid driver array, but BCD ringing and sharp treble may divide listeners.
The Juzear Light Shuttle combines tribrid drivers, strong sub-bass, clear mids and smooth treble in a competitive sub-$200 IEM.
$99 Bose Noise Cancelling Wired Earbuds arrive in 2026 with ANC, USB-C and no battery. Did the company that helped kill the cable just...
