Naim Uniti Star Lite Drops Its CD Drive and the Supply Chain Is to Blame
Why does Naim’s new Uniti Star Lite lose CD playback during a CD resurgence? A discontinued drive forced Naim to rethink its 70W streaming amplifier.
2026 Naim Audio Uniti Star Lite Streaming Amplifier Angle
The Naim Uniti Star has always occupied an unusual but useful place in the British manufacturer’s all-in-one lineup. It combined network streaming, a DAC, 70 watts per channel of Class A/B amplification, HDMI ARC, analog and digital connectivity, CD playback and bit-perfect CD ripping in one very handsome aluminum box.
The new Naim Uniti Star Lite keeps almost all of that formula intact, but the CD drive and ripping capability are gone. Before anyone starts yelling that Naim has surrendered to streaming and tossed the Compact Disc into the same bin as MiniDisc and HD DVD, that isn’t actually what happened.
Naim didn’t decide that nobody wants CDs anymore.
It ran out of the CD drive it needed.
And considering what has happened to CD sales in 2026, the timing could hardly be more ironic.
What Happened to the Uniti Star
naim-uniti-star-with-cd-drive
Naim Uniti Star (with CD Player on left side, 2017 model)
naim-uniti-star-lite-front
Naim Uniti Star Lite (without CD player, 2026 model)
This story actually started months before today’s launch.
On March 31, 2026, a post on Naim’s official community forum explained that the optical drive used in the Uniti Star had been discontinued and was no longer available. Naim therefore stopped production and reserved the mechanisms it still had for future service and repair requirements. At that point, the company was considering either finding another suitable mechanism and modifying the Star accordingly or developing what was described rather prophetically as a revised “Nova-lite” version.
Fast-forward to August 26 and we have the Uniti Star Lite.
Naim describes the new model as the “natural evolution” of the Uniti Star ($5,699 at Amazon and Crutchfield), which is marketing language doing some fairly strenuous stretching exercises. The more straightforward explanation appeared again on Naim’s forum today: the company could no longer source a suitable CD drive, so removing the playback and ripping mechanism became necessary. Naim also says there is a small performance improvement with the revised model, although it has not published enough technical detail for us to start inventing reasons why.
That last part is important. There is no evidence that Naim suddenly decided physical media was pointless or removed the CD drive because customers had collectively abandoned the format.
The supply disappeared.
naim-uniti-star-lite-front-top
So What Exactly Is the Uniti Star Lite
Strip away the name and the Star Lite is remarkably close to the outgoing Star.
The amplifier remains a 70-watt-per-channel Class AB design into 8 ohms, and Naim retains the full-width 432mm chassis, its superb top-mounted rotary volume control, five-inch color LCD display and ZigBee RF bi-directional remote. The Star Lite weighs 11kg compared with 12kg for the outgoing Star, which is probably what happens when you remove an entire optical transport rather than asking it to go on Ozempic.
Digital file support remains comprehensive. WAV playback extends to 32-bit/384kHz, while FLAC, AIFF and ALAC are supported up to 24-bit/384kHz; DSD64 and DSD128 are also supported. USB playback handles sample rates through 384kHz, while S/PDIF inputs support up to 24-bit/192kHz depending on the connection.
Streaming support includes Qobuz, Qobuz Connect, TIDAL, TIDAL Connect, Spotify Connect, Apple AirPlay 2, Google Cast, Roon Ready, UPnP and Internet Radio, along with Bluetooth aptX Adaptive. Control is handled through the Focal & Naim app, and multiroom Party Mode can synchronize as many as six compatible Naim streamers.
It also works with Google Assistant and Siri and supports Control4, Crestron, Elan, RTI and Savant home-automation platforms. HDMI ARC remains on board, which means the Star Lite can still serve as the hub of a rather serious two-channel television system without requiring an AVR and seven speakers scattered around the room.
naim-uniti-star-lite-back
Inputs & Outputs
The physical connectivity is generous:
  • 1 x stereo RCA analog input
  • 1 x 5-pin DIN analog input
  • 2 x optical Toslink inputs up to 24-bit/96kHz
  • 1 x coaxial RCA input up to 24-bit/192kHz
  • 1 x coaxial BNC input up to 24-bit/192kHz
  • HDMI ARC
  • 2 x USB Type-A ports
  • RCA analog output
  • 3.5mm headphone output
  • Ethernet and dual-band Wi-Fi
  • Speaker-level outputs
  • 70 watts per channel into 8 ohms
  • 5-inch color LCD display
  • ZigBee RF remote
  • Dimensions: 16.9 x 3.75 x 10.43 inches
  • Weight: 24.25 pounds / 11kg
Those specifications are almost a photocopy of the original Star minus the feature that put “Star” in a different lane to begin with: the optical drive.
Where Does Star Lite Fit in the Uniti Family
This is where things get slightly strange.
We’ve covered the Naim Uniti Atom extensively and reviewed it as one of the products that helped define the modern premium streaming-amplifier category. The Atom is considerably smaller and delivers 40 watts per channel into 8 ohms, making it a better fit for smaller rooms and easier loudspeaker loads. It also has fewer physical inputs than the Star Lite.
We also reviewed the Uniti Atom Headphone Edition, which takes the same basic streaming concept and removes the loudspeaker power amplifier altogether in favor of a substantially more capable headphone amplifier and preamplifier outputs. It’s really a different animal, despite sharing the Atom name and much of the same industrial design.
Above Star Lite sits the regular Uniti Nova, which produces 80 watts per channel from Class AB amplification. Ten additional watts on a spec sheet hardly explains the entire difference; the Nova uses a more ambitious power supply, larger transformer, upgraded internal components and additional isolation, along with more analog connectivity. That’s the model for buyers who prioritize outright two-channel performance and don’t need a disc mechanism.
Then there is the Uniti Nova PE, which we reviewed in 2025. That model jumps to 150 watts per channel into 8 ohms and 250 watts into 4 ohms, swaps Class AB for Class D and is intended to drive considerably more demanding loudspeakers and larger rooms. It remains the muscle car of the conventional Uniti lineup, although at $9,999 it also requires substantially more financial enthusiasm.
Naim has also pushed the Uniti concept into custom installation with the CI-Uniti 102, a compact 150-watt Class D streamer/amplifier with DSP, HDMI, network integration and support for much larger multiroom systems. We’ve covered it repeatedly at CES, AXPONA and in our dedicated coverage because it demonstrates how far Naim has expanded the Uniti idea beyond the beautiful aluminum box sitting on your credenza.
The Star Lite therefore lands between the Atom and Nova in a fairly logical performance position, even if the name makes the family tree look like somebody married a cousin.
The CD Timing Is Almost Comical
Had Naim made this change five years ago, nobody would have found it especially surprising.
But U.S. CD sales increased 16% to 16.3 million units during the first half of 2026, according to Luminate’s 2026 Midyear Report. Even after removing K-pop releases — where collectible packaging and multiple editions have had a considerable impact — CD sales were still up 6.7%.
Nobody should confuse that with CDs suddenly overthrowing streaming or vinyl. Records remain the larger physical format, and streaming still owns the music business by an enormous margin.
But we’ve also watched manufacturers respond with an unusual wave of new hardware. Accuphase just introduced the DP-470, while we’ve covered new CD players and transports from Michi, Quad, FiiO, Shanling, Cayin and others; our recent roundup of 10 portable CD players you can buy in 2026 would have sounded like satire only a few years ago.
So yes, there is some comedy in Naim removing the CD drive just as manufacturers and consumers rediscover silver discs.
The important part is why. Naim didn’t misread the market and declare CD dead — its supplier stopped making the mechanism. That’s a very different story and also a reminder of how dependent high-end audio manufacturers remain on increasingly scarce optical-drive components.
You can’t build a $4,000-plus audiophile component around a random laptop drive from a parts bin and hope nobody notices.
At least not if you want to remain Naim.
The Bottom Line
The Naim Uniti Star Lite is less a clean-sheet new product than the solution to a manufacturing problem Naim could no longer avoid. The original Star’s CD mechanism disappeared from the supply chain, production stopped, remaining drives were retained for servicing existing owners, and Naim ultimately rebuilt the concept without optical playback or ripping.
What remains is still a compelling all-in-one streaming amplifier: 70 watts of Class AB power, an excellent control ecosystem, extensive digital and analog connectivity, HDMI ARC, high-resolution streaming and one of the nicest physical interfaces in the category. Naim also claims a modest sonic improvement, although we’ll reserve judgment until somebody puts one in front of us.
The awkward part is positioning. Buyers who wanted the Star specifically because it could spin and rip CDs have lost the feature that made it unique, while those who never cared about discs now have something that looks suspiciously like a more affordable route toward the Uniti Nova.
And in 2026, when CD sales are actually climbing again?
Sometimes the supply chain has a sense of humor.
One important caveat for North American readers: Naim has confirmed to eCoustics that the Uniti Star Lite will not be offered in North America. That makes this a far less relevant proposition for U.S. and Canadian buyers, who will need to look elsewhere in Naim’s Uniti range or consider competing all in one streaming systems.
Price & Availability
Naim’s U.S. product page was live on August 26, 2026, but did not list a U.S. MSRP at the time of publication. UK retailers are listing the Uniti Star Lite at £3,199, with initial availability beginning in August.
For more information: naimaudio.com
2026 CMF Speaker S and M by Nothing
CMF’s first Bluetooth speakers combine Nothing-style design with Auracast, USB-C audio, IP68 protection and prices starting at just $59.
2026 Horizon 30 Pro Lifestyle Projector in living room 2026 Horizon 30 Pro Lifestyle Projector in living room
XGIMI’s new HORIZON 30 projectors combine brighter RGB triple-laser light engines, improved contrast and 4K/120Hz gaming in a flexible lifestyle design.
2026 Fosi Audio DAP Neo in pocket 2026 Fosi Audio DAP Neo in pocket
DAPs
The $80 Fosi Audio DAP Neo delivers iPod nostalgia, lossless playback, Bluetooth and expandable storage. Can it win over the streaming generation?
2026 JMGO Iris Ultra Projectors 2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
Hi-Fi Components
Can Fidelity Imports turn its U.S. and Canadian growth into a successful UK hi-fi operation when Fidelity Imports UK opens October 1?
The $999 Schiit Freya 2 lets listeners switch between passive, solid-state, tube, and two hybrid operating modes from a single balanced preamplifier.
Can a $1,100 Canadian standmount really embarrass pricier rivals? Paradigm’s 220B v2 makes a surprisingly convincing case and looks the part.
CD Players
FiiO’s $170 DP11 adds AES, a CS43198 DAC, CD ripping and USB conversion because apparently nobody told the compact disc it was dead.
Hi-Fi Components
Why has Fidelity Imports UK selected Matrix Audio as its second brand, and what does the digital audio specialist add to its UK launch?
Marantz MCR 60n combines a CD player and streaming amplifier with HDMI eARC, MM phono and optional Dirac Live. Is this the all-in-one hi-fi...
