iFi ZEN Air Blue 2 DAC Debuts with Bluetooth 5.4 and aptX Lossless Support
At $129, the iFi Audio ZEN Air Blue 2 adds aptX Lossless Bluetooth streaming to any amp or speakers, making it ideal for upgrading older systems without replacing gear.
IFi Zen Air Blue 2
iFi Audio is updating its entry-level wireless DAC lineup with the ZEN Air Blue 2, a $129 Bluetooth receiver designed to replace the original ZEN Air Blue while adding meaningful upgrades where it counts. The new model introduces Bluetooth 5.4 with aptX Lossless alongside LDAC, LHDC/HWA, AAC, and SBC support, giving it broader high-resolution codec compatibility than most options at this price.
Rated for a 10-meter (approximately 30 feet) range, the ZEN Air Blue 2 also benefits from an improved antenna design for more stable connections at the edge of that distance, making it a practical way to add modern wireless streaming to amplifiers, AV receivers, or powered speakers via RCA outputs without changing the rest of the system.
ifi-zen-air-blue-2-front
ifi-zen-air-blue-2-back
IFi Zen Air Blue 2
The ZEN Air Blue 2 uses a dedicated three stage internal design built around a Qualcomm QCC3095 Bluetooth chipset, an ESS Sabre DAC reportedly the ES9023 for digital to analog conversion, and iFi AMR custom “OV” Operationsverstärker op amps to maintain signal integrity through the output stage.
It also supports a wide 5 to 12V DC input range, making it suitable for home systems as well as automotive, marine, or other battery powered setups. An automatic power on function is included for vehicle use, allowing the unit to start with the engine.
Comparison
zen-air-blue-vs-blue-2
iFi ModelZEN Air Blue 2 (2026)ZEN Air Blue (2022)
Product TypeBluetooth DACBluetooth DAC
Price$129$99
DACESS Sabre ESS Sabre
Bluetooth Version​Bluetooth 5.4Bluetooth 5.0
Bluetooth Formats​SBC,
AAC,
aptX,
aptX HD,
aptX Adaptive,
aptX Lossless,
LDAC,
SBC,
AAC,
aptX,
aptX HD,
aptX Adaptive,
aptX LL,
LDAC,
LHDC/HWA Codec
Bluetooth Chipset​Qualcomm QCC3095​Qualcomm QCC 5100 Series
Bluetooth Connection Distance​10m​10m​
Output​RCA L/R​RCA L/R
Output Voltage​2.1Vrms @ 0dBFS​2.05V (+/-0.05V )
Output Impedance​≤51Ω​<50Ω
SNR​109dB (A)​109dB (A)
DNR​110dB (A) @ 0 dBFS​109dB (A) @ 0 dBFS​
THD+N​<0.005% 10k Load @ 0dBFS<0.0015% 10k Load @ 0dBF
Frequency Response10Hz-20kHz (-3dB @ 44.1kHz)​
20Hz-40kHz (-3dB @ 96kHz)​
20Hz – 20kHz +0/-0.5dB @ 44.1kHz)
1Hz – 44khz +0/-3.0dB (>= 88.2kHz)
Power Supply Requirement​DC 5-12V/≥0.5A (centre +ve)​DC 5V, ≥ 0.5A (centre +ve)
Power Consumption​5V ≤0.25W; 9V ≤0.34W; 12V ≤0.45W​<2.5W
Dimensions​158 x 100 x 35 mm (6.2” x 3.9” x 1.4”)<50Ω
Net Weight​305g (0.67lbs)​295g (0.65 lbs)
Limited Warranty12 months;
24 months in EU​
12 months;
24 months in EU​
In The Box1x Zen Air Blue 2
1x USB to DC Cable
1x Quick Start Guide
1x Warranty Card
1x Short Antenna
1x Long Antenna
1x Zen Air Blue
1x USB to DC Cable
1x Warranty Card
The Bottom Line
The iFi Audio ZEN Air Blue 2 succeeds by keeping things simple and focused. At $129, it delivers a rare combination at this price point: Bluetooth 5.4 with aptX Lossless, broad codec support, and a stable wireless connection that makes it easy to bring modern streaming into older systems without replacing core components. That’s the angle—it’s not trying to be everything, just a clean bridge between your phone and your existing hi-fi.
What it doesn’t offer is just as clear. There’s no headphone output, no balanced connections, and no advanced control over DAC settings or outputs. If you want a more flexible desktop DAC or preamp, options like the Topping E50 II or Fosi Audio S3 give you more to work with for not a lot more money.
The ZEN Air Blue 2 is for listeners who already have an amplifier, receiver, or powered speakers they like and just need a reliable, high quality Bluetooth front end. It also makes sense in secondary systems or even in a car or boat where its wide voltage support and auto power on are actually useful. If your goal is straightforward wireless playback with minimal fuss, it fits. If you want control and expandability, look elsewhere.
Pricing & Availability
Michi Q430, P430, and S430 Lifestyle
Do the new Michi Prestige P430 preamp and S430 power amp offer a smarter route into Rotel’s high-end separates lineup?
DALI BASIK Subwoofer Family DALI BASIK Subwoofer Family
Can DALI’s $800 BASIK SUB bring better bass to compact hi-fi systems without dominating the room?
2026 SVS SoundPath Multi-Path Wireless Audio Adapters 2026 SVS SoundPath Multi-Path Wireless Audio Adapters
A/V Furniture & Accessories
The $229.99 SVS SoundPath Multi-Band adapter kit claims to transmit 24-bit stereo up to 165 feet with only 15 milliseconds of latency.
Wisdom Audio Insight Series P3M Wisdom Audio Insight Series P3M
In-Ceiling Speakers
Wisdom Audio's ICS3FR in-ceiling speakers, SUB2 in-wall subwoofer and customizable P3m Series speakers enable audiophile sound that stays hidden.
Bic OWT65 On-Wall Speakers Vertical Bic OWT65 On-Wall Speakers Vertical
Dongle DACs
iFi GO link 2 Max adds dual ESS DACs, 241mW output, S-Balanced tech, and hi-res PCM/DSD support to an $85 USB-C dongle DAC.
iFi iDSD GR 2 features PCM1795 DAC, 1,513mW output, K2HD, aptX Lossless, LDAC, OLED control, and a $529 price.
iFi's ZEN Air Phono 2 adds MM and MC support with accurate RIAA playback and low noise, offering a flexible $129 upgrade for turntables...
Dongle DACs
The $59 iFi GO link 2 USB-C Dongle DAC makes the case that smaller is better for hi-res audio listening, but what do you...
High-power headphone output, Bluetooth 5.4 with lossless codecs, PCM768/DSD512 support, multiple digital and RCA analog inputs in one compact DAC/amp.
Can the iFi NEO Stream 3 and ZEN Stream 3 stand out in the crowded sub-$1,000 streamer market where WiiM, Bluesound, Eversolo, and Cambridge...
