iFi ZEN Air DAC 2 Debuts with Balanced 4.4mm Output and Increased Power Output
iFi ZEN Air DAC 2 adds a 4.4mm balanced output, higher power, and a dedicated power button, upgrading its entry level desktop DAC and headphone amp design.
iFi ZEN Air DAC 2 Front Angle
The entry level desktop DAC and headphone amp category is not short on competition, and iFi Audio knows it. With established options from Schiit Audio, FiiO, and Topping setting a high bar under $200, iFi’s new $129 ZEN Air DAC 2 arrives as a direct response. It builds on the original Zen Air with a revised DAC stage, higher output power, a balanced 4.4 mm headphone output, and a cleaner midnight blue design, all aimed at listeners who want a simple and affordable desktop upgrade without stepping into mid-tier pricing.
Designed Around A New DAC
The ZEN Air DAC 2 uses a bit-perfect DAC from Cirrus Logic that iFi has deployed across a range of its portable products. The focus here is on stable, low noise decoding rather than shaping the sound. This is the first time that implementation has been used in one of its entry level desktop units, and any gains in clarity, dynamics, and distortion are likely to be incremental rather than dramatic. Support for high resolution formats includes PCM up to 384 kHz and DSD256, which is standard for this category.
ifi-zen-air-dac-2-angle-left
Balanced Headphone Output
The ZEN Air DAC 2 adds a balanced 4.4 mm headphone output, a feature previously limited to the standard ZEN series. It allows use with compatible balanced headphones, which can help lower noise and crosstalk depending on the setup. For conventional headphones, a 6.3 mm single ended output is also included.
With the addition of balanced circuitry, the ZEN Air DAC 2 offers higher output than its predecessor. iFi claims up to three times more headphone drive, which should provide better control with a wider range of headphones, especially when using the balanced output.
Rated output is ≥5.57 V / 484 mW at 64 ohms via the 4.4 mm connection, and ≥3.02 V / 286 mW at 32 ohms through the 6.3 mm single ended output.
ifi-zen-air-dac-2-back
XBass+ and PowerMatch
To provide more support for increased power output when needed, the ZEN Air DAC 2 includes two of iFi audio’s favorite analog audio features, which can be instantly toggled via the dedicated buttons on the front panel.
  • XBass+: This feature enhances low frequencies for additional energy and excitement, and is essential for restoring the bass often lost in open-backed headphones.
  • PowerMatch: This features provided an additional 6dB of gain to bring hard-to-drive headphones to life.
Refined Design
Alongside the updates and added features, the ZEN Air DAC 2 includes a few practical refinements that improve day to day use, including a new midnight blue finish with a metal front panel that feels more consistent in a desktop setup, and a dedicated power button added in response to user feedback that makes it easier to control without having to disconnect cables or power sources.
Comparison
ifi-zen-air-dac-2-vs-original
iFi Audio Model ZEN Air DAC 2 (2026)ZEN Air DAC (2022)
Product TypeDesktop DAC and Headphone AmpDesktop DAC and Headphone Amp
Price$129$99
Hi-Res Support PCM Up to 384kHz; DSD256 PCM Up to 384kHz; DSD256
DAC Bit-Perfect DSD & DXD DAC by Cirrus Logic Bit-Perfect DSD & DXD DAC by Burr Brown
DXD 352.8/384kHz 352.8/384kHz
MQA–Renderer
Input Connector USB-CUSB-B
RCA Line OutputYesYes
Headphone Outputs 6.3mm
4.4mm
6.3mm
Headphone Output Power ≥3.02V/286mW @ 32Ω (6.3mm)
≥5.57V/484mW @ 64Ω (4.4mm)
≥3V/280mW @ 32Ω (6.3mm)
DNR 118 dBA113 dBA
SNR 118 dBA113 dBA
THD+N ≤0.0011% (6.3mm, 1.27V @ 16Ω)
≤0.0015% (4.4mm, 2.4V @ 32Ω)
≤0.04% (6.3mm @ 0dBFS)
<0.04% (100mW @ 16Ω)
Fascia Material Metal Polymer
Other Features XBass+
PowerMatch
Power Button
XBass
PowerMatch
Line Output Voltage 2V; 3.4V max. (variable gain) 1V; 3.3V max
Headphone Output Impedance <0.7Ω (3.5mm); <1.4Ω (4.4mm) <1Ω
Signal-to-Noise Ratio 118dBA (both outputs) <-113dB(A) @ 0dBFS
Dynamic Range 118dBA (both outputs) 113dBA
Frequency Response 20Hz-90kHz (-3dB) 20Hz – 20kHz +0/-0.5dB (at 44.1kHz sample rate)
Power Supply Requirements USB-C 5V/>1A USB or DC 5V, ≥ 0.5A
Power Consumption No signal ~0.55W
Max signal ~3.55W
No Signal ~0.5W
Max Signal ~2.5W
Chassis Color Midnight Blue Soft Ash
Dimensions 158 x 100 x 35mm
6.2 x 3.9 x 1.4”
158 x 117 x 35 mm
6.2 x 4.6 x 1.4″
Net Weight 315g (0.69 lbs) 315g (0.69 lbs)
ifi-zen-air-dac-2-lifestyle
The Bottom Line
The iFi ZEN Air DAC 2 sticks to its role as an affordable, no-nonsense entry point into desktop audio, but adds enough to stay relevant in a crowded field. The move to a revised DAC implementation, higher output power, and the addition of a 4.4 mm balanced headphone output are meaningful upgrades at this price, especially for users with harder to drive headphones or balanced cables.
At the same time, the removal of MQA support signals a shift in priorities that not everyone will miss, but some might notice. This is aimed at listeners who want a simple, compact DAC and headphone amp that can also double as a basic preamp for powered speakers, without stretching beyond a modest budget or overcomplicating the setup.
Pricing & Availability
For more information: ifi-audio.com
2026 Steinway & Sons Model O Loudspeaker near wall lifestyle
LampizatOr’s Horizon 2 adds Aphrodite tech, a redesigned tube stage and upgrades for owners who already spent car money on a DAC.
iFi’s $699 iDSD GR 2 MT adds Steve Levine tuned PCM and DSD filters, a ceramic PCB, upgraded I/V stage and Audio Note Kaisei...
The $599 iFi GO pod Max adds aptX Lossless, powerful amplification and interchangeable connectors to turn high end wired IEMs into wireless earphones.
Dongle DACs
The Druid R2R DAC delivers smooth, fluid sound, balanced outputs, and swappable op-amps without the usual high-end price.
The Sendy Audio KYLIN pairs Class A power, rich dynamics and old school controls with superb build quality, but its noise floor limits IEM...
