Emotiva XSP-2 Preamplifier Debuts with Balanced ESS DAC and Modular Streaming Upgrade Path
Emotiva’s XSP-2 preamp adds a balanced ESS DAC, HDMI ARC, MM/MC phono, bass management, and modular expansion for $1,599.
Emotiva XSP-2 Differential Reference Preamplifier Lifestyle
Emotiva has built its reputation on delivering high-performance audio components with solid engineering, serious build quality, and prices that usually make the competition look a little too comfortable.
For 2026, the company is taking another run at the serious two-channel market with the XSP-2 Differential Reference Stereo Preamplifier, a major update to the well-regarded XSP-1 that first arrived in 2013. The new XSP-2 keeps the separates-first mindset intact, but adds a more modern modular platform, including a fully balanced ESS-based DAC module installed from the factory and an expansion path for a future streaming module.
The XSP-2 ships with a pre-installed DAC module that expands its connectivity with HDMI-ARC, USB-C, two coaxial inputs, and two optical inputs. Dedicated shielding keeps the digital section isolated from the preamplifier’s pure analog signal path.
The XSP-2’s fully balanced, fully differential analog signal path is designed to lower noise, reject interference, and preserve low-level detail. It also includes fully balanced bass management for 2.1 or 2.2-channel systems, with independent high-pass and low-pass crossover settings at 40, 60, 80, or 100 Hz, plus stereo or summed mono subwoofer output options.
emotiva-xsp-2-back
The XSP-2 also includes an onboard MM/MC phono section for easy connection to most turntables, along with a dedicated headphone output driven by a current-mode feedback amplifier designed to handle more demanding headphone loads.
All audio switching is handled by fourth-generation hermetically sealed subminiature relays, helping preserve signal purity throughout the audio path while reducing noise, crosstalk, and switching artifacts.
An external processor loop and Home Theater Bypass provide additional flexibility, allowing the XSP-2 to integrate more easily into mixed two-channel and home theater systems.
emotiva-xsp-2-low-pass-filter
The front panel features a large blue OLED display, which is larger than the display used on its predecessor, along with a flexible menu system that can be controlled from the front panel or the included remote. The display is easy to read, and the menu system provides quick access to the XSP-2’s core setup and control features such as MM/MC cartridge select, balance, high pass filter, low pass filter, and selectring subwoofer mono/stereo choices.
“The XSP-1 is one of the most popular products in the history of the brand,” says Dan Laufman, President, Emotiva Audio Corporation. “It’s famous for being a highly flexible preamp that performs well above its price…After years of focused R&D, we’re finally ready to launch a worthy successor that retains the sonic benefits that made the original a hit, but with added flexibility across the board…The XSP-2 is not only a best-in-class preamp for today’s consumers, but it’s also ready for whatever comes next, including a streamer module that is currently in the works. When it launches, all it will take is a few easy steps to add it to the XSP-2.
Comparison
emotiva-xsp-2-xsp-1
Emotiva ModelXSP-2 (2026)XSP-1 (2013)
Price$1,599$999
Product TypePreampllifierPreampllifier
Number of Channels22
Analog Inputs4 pairs – unbalanced RCA inputs
2 pairs – balanced XLR inputs
1 pair – unbalanced RCA Processor Loop Inputs
1 pair – MC/MM phono input (switchable)
1 set (L/R/sub) – unbalanced (RCA) HT Bypass Inputs
1 set (L/R/sub) – balanced (XLR) Bypass Inputs
Digital Inputs1 – HDMI-ARC Input
1 – digital USB (DAC Input); stereo; supports up to 24/768k, DoP up to DoP256, and native DSD up to DSD512
2 – digital coax (S/PDIF) Inputs; stereo; support up to 24/192k
2 – digital optical (Toslink) Inputs; stereo; support up to 24/192k
Audio Outputs1 pair – stereo line level balanced (XLR) Left and Right Main Outputs
1 pair – stereo line level unbalanced (RCA) Left and Right Main Outputs
1 pair – stereo line level balanced (XLR) Left and Right Subwoofer Outputs
1 pair – stereo line level unbalanced (RCA) Left and Right Subwoofer Outputs
1 pair – stereo unbalanced (RCA) Processor Loop Outputs
1 x Headphone; 1/4” stereo jack (front panel).
1 x Headphone; 1/8” stereo jack (front panel).
Control Inputs and Outputs1 – 12 VDC Trigger Output – delivers a 12VDC trigger signal when the unit is on
1 – Trigger Input – accepts inputs between 5V and 12V AC or DC
1 – IR input; wired; accepts standard “passive IR eye.”
Note: The XSP-2 will work with a variety of passive 3-wire IR sensors
1 x Trigger input and output:
1 x IR input and output
Remote ControlYesYes
Analog Audio Performance (Line Level Inputs)Maximum output level; balanced (XLR) is 8VRMS, and unbalanced (RCA) is 4 VRMS
Frequency response: 20 Hz to 20 kHz +0 / -0.1 dB
Frequency response: 5 Hz to 80 kHz +0 / -2.7 dB
THD+noise; 1 kHz; A-weighted: <0.0005%
S/N ratio; balanced (XLR); A-weighted: > 119 dB
S/N ratio; unbalanced (RCA); A-weighted: > 117 dB
Maximum Output Level (main outputs): +12 dB.
Frequency response: 20 Hz to 20 kHz +/- 0.017 dB
Not indicated
THD+noise  1 kHz, < 0.006% (unbalanced into unbalanced out).
S/N ratio > 114 dB (balanced into unbalanced out).
S/N ratio 113 dB (unbalanced into unbalanced out).
Analog Audio Performance (Phonol Input)THD+noise; 1 kHz; A-weighted; Moving Magnet: <0.01%
THD+noise; 1 kHz; A-weighted; Moving Coil: <0.1%
S/N ratio; A-weighted; Moving Magnet: > 95 dB
S/N ratio; A-weighted; Moving Coil: > 80 dB
Moving Magnet – THD (total harmonic distortion, ref 10 mV): < 0.001%.
THD (total harmonic distortion, ref 1.0 mV) Moving Coil < 0.008%  S/N A-weighted
Moving Magnet > 96 dB.
S/N A-weighted, Moving Coil: > 79 dB.
Audio Performance (Digital Inputs)Frequency response: 20 Hz to 20 kHz +0 / -0.1 dB
THD+noise; 1 kHz; A-weighted: <0.0008%
S/N ratio; A-weighted: > 112 dB
The frequency response shown was measured with a high-resolution digital source. At lower sample rates, the frequency response will be limited by the sample rate of the content.
Not Applicable
Power Requirements115 VAC or 230 VAC @ 50 / 60 Hz (automatically detected)115 VAC or 230 VAC +/- 10% @ 50 / 60 Hz (automatically detected and switched).
Dimensions17” wide x 5-1/4” high (without feet) x 14-1/2” deep (without connectors)
17” wide x 5-2/4” high (including feet) x 15” deep (including knobs and connectors)
17” wide x 6” high x 16.5” deep (includes feet and terminals)
Weight 13 lbs (unboxed)28 lbs (unboxed)
Expansion Slots2 x rear panel slotsNone
emotiva-xsp-2-angle
The Bottom Line
The Emotiva XSP-2 looks like a strong value play in the serious two-channel preamp category. It’s competitively priced and feature packed with a fully balanced analog signal path, built-in MM/MC phono stage, balanced bass management, Home Theater Bypass, an external processor loop, and a factory-installed ESS-based DAC module for $1,599.
What makes the XSP-2 more interesting than a typical stereo preamp is its modular architecture. The two rear expansion slots give Emotiva room to add future functionality, and the included DAC module already brings HDMI-ARC, USB, coaxial, and optical digital inputs without turning the XSP-2 into a compromised digital-first control box. The analog section remains the main event.
The catch is obvious but important: the XSP-2 is a preamplifier, not an integrated amplifier. It still needs to be connected to a power amplifier before it can drive a pair of loudspeakers. Emotiva’s own options include the XPA-2 Gen3 stereo power amplifier at $1,499, a pair of XPA-DR1 Differential Reference monoblocks at $1,699 each, or one of its Build-Your-Own XPA Gen3 power amplifiers starting at $1,499.
Also missing at launch is built-in streaming. Emotiva says a streaming module is in the works, but for now, anyone who wants network playback will still need to add an external streamer or use one of the XSP-2’s digital inputs. HDMI-ARC is useful for TV integration, but this is still a two-channel preamp, not a surround processor or all-in-one streaming amplifier.
Pro Tip: You may also desire to include one or two subwoofers into the mix, such as the xs12e ($399 each).
Price & Availability
The Emotiva XSP-2 Differential Reference preamplifier is available now for $1,599 at Emotiva.com.
Can Emotiva shake up high end home theater? The $4,799 LXP-16 and $5,999 LXR-11 add 9.4.6, Dirac ART, 8K HDMI and four sub outputs.
Can Emotiva’s BasX TA2+ revive the stereo receiver? With 135W power, HDMI ARC, balanced inputs, and phono support, it targets modern 2 channel systems.
Emotiva introduces an affordable line of fully balanced hi-fi separates for a discounted package price of $2,599.
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
Priced from $399 to $1,999/pair, eight new Emotiva Airmotiv X loudspeakers feature a thinner new design for stereo or home theater setups.
