Dan D’Agostino Momentum C2Z Preamplifier Debuts with Z-Circuitry, Optional Streaming Module, and Reference-Level Design
Dan D’Agostino Momentum C2Z preamplifier refines the C2 with Z circuitry and FET output stage. If you have to ask the price this is not your system.
Dan D'Agostino Momentum C2Z Preamplifier with Power Supply
Dan D’Agostino Master Audio Systems has added a new flagship control component to its Momentum lineup with the Momentum C2Z Preamplifier, a two chassis design derived from the earlier Momentum C2 and optimized for use with the company’s Momentum Z Monoblock Power Amplifiers. The visual differences are minimal, limited to the front panel, but the engineering focus is clear: improve system performance within the Momentum ecosystem rather than reinvent the product from scratch.
It also needs to be said plainly that this is ultra high end audio with pricing to match. The Momentum C2Z sits firmly in luxury purchase territory on its own, and building the full matching system with two Momentum Z monoblocks pushes the investment into a range that will make even affluent buyers stop and do the math twice. That does not make it unreasonable in the context of cost no object audio, but it certainly puts the C2Z far outside the reach of anyone shopping for value.
Z-Circuitry
Engineered to take full advantage of the Z circuitry introduced in the Momentum Z monoblock amplifier, the C2Z builds on the established Momentum C2 preamplifier platform with targeted refinements rather than a complete redesign.
It does not replace the original Momentum C2, but instead serves as the more suitable match for the Momentum Z monoblocks. The updated circuitry focuses on improving the electrical interface between preamplifier and power amplifier, with the goal of delivering better system integration, control, and overall sonic accuracy.
“With the C2Z upgrade,” said Dan D’Agostino, Founder of Dan D’Agostino Master Audio Systems, “we set out to do more than refine an already exceptional platform—we wanted to fully exploit the performance of the Momentum Z Monoblock circuitry. We have created a more direct and optimized connection between the preamplifier and the amplifier.”
The FET Factor
At the core of the C2Z is a revised output stage for the Momentum preamplifier, built around a current capable Field Effect Transistor architecture. The goal is straightforward: increase current delivery and improve stability, allowing the preamplifier to drive the Momentum Z amplifier’s input stage more effectively and make full use of the Z circuitry across the system.
This implementation integrates FETs directly into the output stage, enabling higher current delivery where it matters most. The result is a more controlled electrical interface between preamplifier and amplifier, with the C2Z providing current with greater precision and the Momentum Z monoblocks designed to receive and respond to it without bottlenecks.
FETs are well suited to high performance audio applications. Their high input impedance reduces loading on source components, helping preserve signal integrity, tonal balance, and dynamic detail. They also offer low noise and strong linearity, which is critical when handling low level signals at the front end of the amplification chain.
Unlike bipolar devices, FETs operate as voltage controlled components and require minimal input current. That behavior contributes to smoother, more linear transfer characteristics, lower distortion, and a more stable connection between components.
The Momentum Z Amplifier Factor
In the Momentum Z amplifier, the Z circuitry takes a different approach by lowering the input impedance typically associated with FET-based designs. This change allows the amplifier to draw more current from the Momentum C2Z preamplifier, strengthening the electrical interface between the two components.
The result is improved transient response, greater dynamic contrast, and more precise retrieval of musical detail. Rather than treating the preamplifier and amplifier as separate stages, the design focuses on how they interact as a system.
One of the more audible benefits is in low-frequency performance. Bass reproduction shows better control, texture, and definition, particularly at lower listening levels where detail can often be lost. With the full Z circuitry signal path in place, low-frequency information remains more consistent and better resolved without relying on higher volume levels.
Taken together, the Momentum C2Z preamplifier and Momentum Z monoblock amplifiers are designed to function as a tightly integrated system, with an emphasis on dynamic control, low-level resolution, and stable performance across a wide range of listening conditions.
Other Features
momentum-streaming-control
Control: The Momentum C2 and C2Z preamplifiers include a bi-directional remote housed in precision-machined aluminum and Delrin, with full access to unit functions and settings. The remote features an ergonomic layout and an integrated LCD screen that mirrors the information shown on the preamplifier’s front panel display, allowing for straightforward operation from the listening position. An iOS control app is also available for system management, although there is no Android support.
momentum-streaming-module
Optional Digital Streaming Module: The optional Digital Streaming Module adds optical, coaxial, and USB digital inputs, along with network connectivity via Ethernet (RJ45) or Wi-Fi 8 using an external antenna. An active internet connection is required to access streaming services such as TIDAL, Qobuz, and Spotify. The module is also Roon Ready, allowing integration into a Roon-based playback system.
Power Supply: The power supply is housed in a separate chassis that connects to the C2 or C2Z preamplifier. It incorporates dedicated custom toroidal transformers for the analog and digital sections, helping to isolate critical circuits. Internal filtering is designed to reduce RF noise and address power line irregularities, supporting more stable overall operation.
Comparison
Dan D’Agostino Momentum ModelC2Z (2026)C2 (2024)
Product TypePreamplifierPreamplifier
PriceTBD$55,000 to $65,000
Frequency Response0.1 Hz to 1 MHz, -1 dB
20 Hz to 20 kHz, ±0 dB
Signal-to-Noise Ratio>110 dB, A-weighted
 >120 dB, unweighted
>110 dB, A-weighted
 >120 dB, unweighted
Gain11.5 dB+10 dB
Input Impedance1 MΩ1 MΩ
Output Impedance0.01 Ω 0.05 Ω
Distortion (full output)<0.00066% <0.002%
Analog Input3 pr balanced XLR stereo
1 pr unbalanced RCA stereo
Digital Inputs with Optional Digital Streaming Module (DSM)1 ea SPDIF coaxial
RJ45 Ethernet
Optical
USB-B
Wi-Fi
1 ea SPDIF coaxial
RJ45 Ethernet
Optical
USB-B
Wi-Fi
Outputs2 pr balanced XLR stereo
1⁄4-inch headphone
1⁄4-inch headphone
Dimensions (WHD)17.0 x 8.9 x 15.2 in
43.2 x 22.6 x 38.6 cm
Weight73.0 lb / 33.1 kg73.0 lb / 33.1 kg
momentum-c2-preamplifier-rear
Momentum C2 (rear)
The Bottom Line
The Momentum C2Z is not a ground-up redesign, but it does introduce meaningful changes where they matter. The revised output stage with FET-based current delivery is specifically engineered to work with the lower input impedance of the Momentum Z monoblocks, creating a more tightly coupled interface between preamplifier and amplifier. That system-level thinking is the real story here. This is not about adding features for the sake of it, but refining how the components interact to improve control, stability, and low-level detail.
What also stands out is the execution. At 73 pounds and built as a dual-chassis design with a dedicated power supply, the C2Z reflects the same emphasis on materials, isolation, and power management that defines the rest of the Momentum line. It is a physically and electrically substantial preamplifier, designed to anchor a reference-level system.
The reality, however, is the cost. While final pricing has not been confirmed, expectations in the $50,000 to $60,000 range place the C2Z firmly in cost-no-object territory. Building the intended system with two Momentum Z monoblocks at $125,000 each pushes the total investment into a level that requires serious financial commitment, even before speakers and source components enter the equation.
At this level engineering, everything comes separate. An optional Digital Streaming Module leaves nothing to chance, but adds to total cost of ownership. Same deal for adding a phono stage. If you need to ask the price, you can’t afford it.
Price & Availability
The official price of the Dan D’Agostino Momentum C2Z Preamplifier is still forthcoming, but its predecessor, the C2, is priced between $55,000 and $65,000.
Dan D’Agostino Audio components can be purchased through Authorized Dealers in the US, Canada, Mexico, and internationally.
For more information: dandagostino.com
2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
2026 Schiit Mani 3 Phono Preamp 2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Can 64 Audio’s $3,999 Ocean flagship IEM justify its price with isobaric bass and 32 passive tuning combinations?
What did Focal and Naim bring to Audio Advice Live 2026? A $210K Diva Alta Utopia, Scala’s North American debut, Hekla and a $5,297...
What is Playback Distribution bringing to Audio Advice Live 2026? Three rooms featuring a Vienna Acoustics North American loudspeaker debut, PMC Speakers, CANVAS HiFi,...
Loudspeakers
Can OJAS bring new listeners to high-end audio? Devon Turnbull’s Cooper Hewitt listening room shows why the industry needs to leave its bubble.
Klipsch debuts Reference Premiere III at Audio Advice Live 2026 with Onkyo, a 7.4.4 Atmos system, anniversary Klipschorn and Rebellion.
The SDX 3100 HV handles native DSD1024, streaming, and analog preamplification, while the A 3100 HV delivers 500 watts per channel. Together, they cost...
Loudspeakers
Dynaudio says support will continue as it exits North America and closes its U.S. subsidiary, but dealer and warranty questions remain.
