Edifier MR4.5 Studio Monitors Add Wireless Connectivity and Custom Tuning for Creators
Edifier MR4.5 Desktop Studio Speakers Black Lifestyle
Edifier has expanded its MR Studio Monitor Series for 2026 with the new MR4.5, a near-field active loudspeaker designed for content creators, musicians, producers, and desktop listeners who want greater flexibility without moving into the larger and more expensive MR5.
Positioned between the MR4 and flagship MR5, the Edifier MR4.5 combines studio-focused sound reproduction with wireless connectivity, customizable tuning, and a compact design suitable for home studios, editing suites, gaming systems, and desktop audio setups.
The new model joins the MR3, MR4, and MR5 to complete Edifier’s current studio monitor lineup, offering buyers another option in a category where accuracy increasingly has to share desk space with convenience.
Features and Connectivity
Two Speakers: The Edifier MR4.5 includes two speakers. The active speaker serves as the system hub, handling connectivity, amplification, and signal distribution for both channels. No external amplifier, stereo receiver, or home theater receiver is required. The passive speaker connects to the active speaker using the supplied cable, which carries both power and audio signals.
Adaptable Setup: The MR4.5 includes acoustic tuning and desktop compensation controls that allow users to adjust its performance for different rooms, speaker positions, and listening distances. These controls can be useful when the speakers are placed on a desk, close to a wall, or in a small home studio where placement options may be limited.
Wired and Wireless Connectivity: The MR4.5 supports both wired connections and wireless streaming. Bluetooth 6.0 includes LDAC support for higher-resolution wireless audio, while multipoint connectivity allows the speakers to remain connected to more than one compatible device. This makes it easier to switch between a computer, smartphone, tablet, or other source without repeatedly disconnecting and pairing devices.
edifier-mr45-speaker-drivers
Bi-Amplified Speaker Design: The MR4.5 uses a bi-amplified design with an active crossover that divides the audio signal between the mid-bass driver and tweeter. Edifier designed the system to provide a balanced transition between the drivers and accurate sound reproduction for music production, video editing, gaming, and everyday desktop listening.
Extended Frequency Response: The MR4.5 has a specified frequency response of 50 Hz to 40 kHz. Edifier has tuned the system for a neutral, transparent presentation intended to reproduce recordings without excessive tonal coloration.
Dimpled Tweeter Waveguide: The MR4.5 uses a dimpled tweeter waveguide designed to improve high-frequency extension and clarity while creating a wider listening area. This should provide more consistent performance when the listener moves away from the central listening position.
80 Watts of Total Output: The MR4.5 delivers 80 watts RMS of total system output and a maximum sound pressure level of 98 dB at one meter. Although primarily intended for near-field listening, it should also provide sufficient output for some mid-field setups and medium-sized rooms.
Hi-Res Audio Support: The MR4.5 uses an analog front end and Class D amplifiers and supports digital audio signals up to 24-bit/96 kHz. Wireless playback is available through Bluetooth with LDAC support. Under compatible conditions, LDAC can transmit audio at up to 990 kbps and support signals up to 24-bit/96 kHz.
Wired Connection Options: Balanced XLR and TRS inputs allow the MR4.5 to connect to professional audio interfaces, mixers, and other studio equipment. RCA and 3.5 mm auxiliary inputs accommodate common consumer audio sources, while a headphone output supports private listening.
Bluetooth Multipoint: Bluetooth 6.0 provides a stable wireless connection, while Bluetooth Multipoint allows two devices to remain connected simultaneously. Users can switch between sources without disconnecting and re-pairing each time.
Room Acoustic Compensation: Rear knobs and the EDIFIER ConneX app provide multiple settings for room acoustic compensation, allowing you to adapt to different room modes and achieve the optimal listening experience.
Edifier MR Studio Monitors Comparison
Edifier ModelMR5MR4.5 MR4MR3
Product TypePowered Studio MonitorPowered Studio MonitorPowered Studio MonitorPowered Studio Monitor
Price$299.99$249.99$169.99$149.99
Amplifier ConfigurationTri-AmpBi-AmpSingle AmpSingle Amp
Total Output Power (RMS):10W + 10W (Treble)
15W + 15W (Mid)
30W + 30W (Bass)
30W + 30W (Mid-bass)
10W + 10W (Tweeters)
21W+21W18W + 18W
Drivers1″ silk dome tweeters
3.75″ mid drivers
5″ woofers
4.5″ mid-bass drivers
1” tweeters
4” woofers
3.5″ mid-low drivers
Frequency Response46Hz – 40kHz50Hz – 40kHz60Hz-20KHz52Hz-40kHz
Signal-to-Noise Ratio (SNR)≥ 85dB (A)≥ 89dB (A) in monitor mode≥ 85dBA> 85 dB (A)
Audio InputsBalanced XLR
Balanced ¼-inch TRS
Unbalanced RCA
⅛-inch stereo (3.5mm AUX)
Bluetooth
Balanced XLR
Balanced ¼-inch TRS
Unbalanced RCA
Bluetooth
TRS balanced input
RCA unbalanced input
AUX unbalanced input
Balanced 1/4-inch TRS
Unbalanced RCA
3.5mm AUX
Bluetooth
Input SensitivityXLR: 1228 ± 50mV
TRS: 1228 ± 50mV
RCA: 700 ± 50mV
AUX: 600 ± 50mV
Bluetooth: 600 ± 50mFFS
XLR: 1228 ± 100mV
TRS: 1228 ± 100mV
RCA: 500 ± 50mV
AUX: 400 ± 50mV
Bluetooth: 500 ± 50 mVFS
TRS balanced input: +4dBu
AUX/RCA unbalanced input: -10dBV
TRS: 1228 ± 100mV (+4dBu)
RCA: 775 ± 50mV
AUX: 775 ± 50mV
Bluetooth: 800 ± 50mFFS
Bluetooth VersionV6.0V6.0N/AV5.4
Bluetooth CodecsLDAC, SBCLDAC, SBCN/ASBC
CrossoverBass/Mid 155 Hz
Mid/Treble 2600 Hz
2800 Hz2800 Hz Not Indicated
Sound Pressure Level (Max.)101dB (@1 meter)98dB (@1 meter)86dB @1 meter92.5dB @1 meter
Headphone Output1/8-inch stereo1/8-inch stereo1/8-inch stereo1/8-inch stereo
Dimensions (WHD)159 x 264 x 280mm (Active speaker)
159 x 264 x 257mm (Passive speaker)
140 × 244 × 229mm (Active speaker)
140 × 244 × 208mm (Passive speaker)
140 x 228 x 197.5 mm (Active Speaker)
140 x 228 x 184 mm (Passive Speaker)
125.5 x 220 x 185mm (Active speaker)
125.5 x 220 x 176mm (Passive speaker)
Net Weight10.38kg6.63kg4.5Kg3.85kg
In The BoxMR5 Set
Power Cable
Speaker Connecting Cable
3.5mm to RCA Audio Cable
3.5mm-to-3.5mm Audio Cable
Quick Start Guide
Important Safety Instructions
MR4.5 Set
Power Cable
3.5mm to 3.5mm
Quick Start Guide
MR4 Set
Power Cable
Quick Start Guide
MR4 Set
Power cable
Speaker
connecting cable
3.5mm to RCA audio cable
3.5mm-to-3.5mm audio cable
Quick start guide
Important safety instructions
Edifier MR4.5 Desktop Studio Speakers Black Angle
The Bottom Line
Although Edifier has enjoyed success with its MR Studio Monitor Series, a substantial gap remained between the MR4 and MR5 in both price and features. The MR4.5 fills that space by adding Bluetooth, LDAC, balanced XLR connectivity, room compensation, app-based adjustments, and an active bi-amplified crossover—features not offered by the more basic MR4.
The MR4.5 also provides a logical step down from the MR5, which uses a larger three-way driver configuration, a tri-amplified active crossover, and 110 watts of total output. Those additional capabilities may make the MR5 better suited to larger rooms and more demanding studio applications, but they may be unnecessary for desktop users and smaller production spaces.
The MR4.5 does not include HDMI ARC or eARC, USB audio, optical connectivity, or a phono input. Buyers who require HDMI eARC, USB-C, and optical inputs should consider Edifier’s M90 active speakers. The Onkyo Creator Series GX-30ARC goes further by combining HDMI ARC, USB-C, optical, and a line/phono input for direct connection to a turntable with a moving-magnet cartridge.
edifier-mr45-rear-speaker-inputs
Price & Availability
2026 Lumin S2 Network Audio Player Silver
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Magico A3 2027 Loudspeakers Lifestyle Magico A3 2027 Loudspeakers Lifestyle
Magico rebuilds the A3 with M9-derived engineering, new drivers and a new cabinet. The other upgrade? Entry-level Magico now costs $25,000.
2026 JBL PartyBox Ultimate 2 Party Speaker Lifestyle 2026 JBL PartyBox Ultimate 2 Party Speaker Lifestyle
The $1,800 JBL PartyBox Ultimate 2 packs 1,500 watts, Wi-Fi 6, Roon, AI karaoke and a touchscreen into a light show speaker that isn't...
2026 TDM Neo Headphone Speaker Black in hand 2026 TDM Neo Headphone Speaker Black in hand
TDM Neo headphones twist into a Bluetooth speaker, offering one device for private listening and the occasional need to become everyone’s DJ.
2026 Esoteric F-01 Integrated Amplifier Black Edition 2026 Esoteric F-01 Integrated Amplifier Black Edition
Edifier’s affordable studio monitors combine balanced tuning, useful connectivity, app control, and impressive bass for their size.
At $499 per pair, the versatile Edifier R2750DB MKII wireless speakers feature three-way sound, HDMI eARC and LDAC Bluetooth for desktop, bookshelf or stand-mount...
Can Edifier’s $149 HECATE G5 MAX challenge Sony Pulse Elite with THX Spatial Audio+, low-latency wireless, and 305-hour battery life?
26 Best in Show winners crowned at CES 2026 across multiple categories including TVs, projectors, loudspeakers, home theater, portable audio, headphones and more.
Edifier’s M90 is a "cross-scenario, multi-purpose" active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and...
At $369, the Edifier M90 are versatile wireless speakers that also include HDMI eARC for easy connectivity to PCs or TVs. Just make sure...
Podcasts
On this live stream podcast, the eCoustics team discusses the very best of what we saw and heard at CES 2026 in Las Vegas.
