Coastal Source Unveils Hardscape Razor Outdoor Speakers That Can Fit in Tight Spots
Coastal Source’s first line of outdoor speakers feature ultra-shallow drivers to provide impressive performance from a slim enclosure.
Coastal Source Razor Trellis Outdoor Speaker
Coastal Source, makers of outdoor audio and lighting options for residential and commercial applications has announced nationwide shipping of its full line of hardscape Razor outdoor speakers that was first shown at CEDIA 2023 in Denver.
Tip: The Coastal Source Razor line has received the CEDIA 2023 Global Best New Hardware Award and the Technology Designer 2023 Performance Home Awards for Best Design and the 2023 HTSA Innovation Award.
From Coastal Source Co-Founder and CEO Franco D’Ascanio: “Razor is all about setting new standards for innovation and installer-centric design that defy the elements in every respect. Drawing on our years of outdoor experience, we have designed these low-profile architectural speakers to be rugged enough for outdoors and refined enough for indoors. We are truly gratified by the response from our partners to this important new line introduction.”
Razor speakers are designed to provide high performance in a slim, visually pleasing form factor that can easily disappear into the background if desired. Razor Speakers can be used on hardscapes such as walls, decks, as well as horizontal and vertical corners.
Fully modular construction allows for numerous applications and performance levels with options for bi-amped subwoofer/satellite configurations along with tri-amped solutions that utilize external subwoofers. Integrated and universal mounting brackets for surface, corner, hanging, ganging, and post mounting are included.
The Razor Speaker line boasts custom-designed, engineered, and optimized ultra-shallow drivers to provide impressive performance from a slim enclosure.
Coastal Source Razor Speakers under Outdoor TV
Core Features
Design: The new Razor Speaker brings modern-day style and superior sound performance to a low-profile speaker system allowing Coastal quality high-performance audio to make its debut on hardscapes such as walls, decks, and horizontal & vertical corners.
Flexibility: Fully modular construction allows for numerous applications and performance levels
with options for bi-amped sub/sat configurations along with tri-amped solutions that utilize external subs. Integrated and universal mounting brackets for surface, corner, hanging, ganging, and post mounting.
Materials: Razor speakers are designed with high-quality color through aluminum enclosures with a composite grille.
Acoustic Fractal Waveguide Tweeter Bridge: This is designed to improve clarity and efficiency.
Performance: The Razor Speaker line boasts custom-designed, engineered, and optimized ultra-shallow drivers to provide impressive performance from a slim enclosure.
System: The Razor line is built to be part of a  patented Coastal Source Plug+Play™ system or can be easily integrated into existing systems.
Coastal Source Razor Speaker Line
Razor Models
The Razor speaker line comes in Three Series: Razor 100, 200, and 300, and includes eight models.
100 Series:
  • RZ110 Satellite Speaker
200 Series:
300 Series:
  • RZ310 High Power 3-Way Speaker
  • RZ320 Passive 2.1 Soundbar
  • RZ330 Passive 3.1 LCR Soundbar
  • RZ340 Line Source Speaker
  • RZ350 Quad-Driver Subwoofer
Coastal Source Razor Speakers On-Wall Installation
Specifications: 100 & 200 Series
100 Series
RZ110
200 Series
RZ210
200 Series
RZ220
Speaker TypeSingle Driver Satellite Speaker2.5-way3-way
ConstructionAluminum extrusion, Aluminum wall  bracket, composite grilleAluminum extrusion, Aluminum wall bracket, composite grilleAluminum extrusion, Aluminum wall bracket, composite grille
Driver Complement1 x 5.25-in coaxial1 x 5.25-in coaxial, 2x LF radiators1 x 5.25-in coaxial, 2x LF woofers
Power Handling75W75W SAT75W SAT / 200W SUB
Frequency Response80Hz-20kHz (@-6dB with EQ preset)60Hz-20kHz (@-6dB with EQ present)100Hz-20kHz SAT, 40-100Hz SUB (@-6dB with EQ present)
Sensitivity88dB (1W/1m)88dB (1W/1m)88dB SAT / 83.5dB SUB (1W/1m)
Dispersion110° conical (@-6dB) 110˚ conical (@-6dB)110˚ conical (@-6dB)
Impedance8 ohms 8 ohms8 ohms SAT
8 ohms SUB
MountingCorner (direct), Surface (bracket)Corner (direct), Surface (bracket) Corner (direct), Surface (bracket)
Speaker ConnectorCMC Male PigtailCMC Male Pigtail2x Male CMC Pigtails (bi-amplified)
Size (HWD)10.63 x 10.5 x 3.38in 21.63 x 10.5 x 3.38in 21.63 x 10.5 x 3.38in
Size with Bracket (HWD)10.63 x 10.5 x 4 21.63 x 10.5 x 4in 21.63 x 10.5 x 4in
Weight8.9 lbs 13.9 lbs 18.6 lbs
Warranty5-Year Limited 5-Year Limited5-Year Limited
Coastal Source Razor Speakers Poolside Installation
Specifications: 300 Series
300 Series ModelRZ310 RZ320 RZ330 RZ340RZ350
Speaker TypeHigh Power 3-WayPassive 2.1 SoundbarPassive 3.1 LCR SoundbarLine Source Quad-Driver Passive Subwoofer
ConstructionAluminum extrusion, Aluminum wall bracket, Kydex composite grilleAluminum extrusion, Aluminum wall bracket, Kydex composite grilleAluminum extrusion, Aluminum wall bracket, Kydex composite grilleAluminum extrusion, Aluminum wall bracket, Kydex composite grilleAluminum extrusion, Aluminum wall bracket, Kydex composite grille
Driver Complement1 x 5.25coaxial, 4 x 5.25” LF Woofers2 x 5.25” coaxial, 3 x 5.25” LF woofers3 x 5.25”coaxial, 2 x 5.25” LF woofers6 x 5.25” coaxials4 x 5.25” LF woofers
Power Handling75W SAT / 400W SUB 75W SAT (x2) / 300W SUB75W SAT (x3) / 200W SUB500W 400W
Frequency Response100Hz-20kHz SAT, 40-100Hz SUB (@-6dB with EQ present)100Hz-20kHz SAT, 40-100Hz SUB (@-6dB with EQ present)100Hz-20kHz SAT, 40-100Hz SUB(@-6dB with EQ present)100Hz-20kHz (@-6dB with EQ present)40Hz – variable, present dependent (@-6dB with EQ present)
Sensitivity88dB SAT / 86dB SUB (1W/1m)88dB SAT / 85dB SUB (1W/1m)88 dB SAT / 83.5dB SUB (1W/1m)93dB (1W/1m)86dB (1W/1m)
Dispersion110˚ conical (@-6dB) 110˚ conical (@-6dB) 110˚ conical @-6dB 100˚ horizontal, 28” high vertical sound layer – vertical (@-6dB)Omnidirectional-horizontal, 180˚ – vertical
Impedance8 ohms SAT, 8 ohms SUB8 ohms SAT, 6 ohms SUB8 ohms SAT, 8 ohms SUB6-8 ohms8 ohms
MountingCorner (direct), Surface (bracket)Corner (direct), Surface (bracket) Corner (direct), Surface (bracket) Corner (direct), Surface (bracket)Corner (direct), Surface (bracket)
Speaker Connector2x CMC Male Pigtails (bi-amplified)3x CMC Male Pigtails (tri-amplified)4x CMC Male Pigtails(quad-amplified)CMC Male PigtailCMC Male Pigtail
Size (HWD)36 x 10.5 x 3.38in 36 x 10.5 x 3.38in36 x 10.5 x 3.38in 36 x 10.5 x 3.38in 36 x 10.5 x 3.38in
Size with Bracket (HWD)36 x 10.5 x 4in36 x 10.5 x 4in36 x 10.5 x 4in36 x 10.5 x 4in36 x 10.5 x 4in
Weight30.6 lbs26.6 lbs31.4 lbs33.6 lbs 27.3 lbs
Warranty5-Year Limited5-Year Limited5-Year Limited5-Year Limited5-Year Limited
Coastal Source Razor Speakers Hanging Installation
Finishes
The Coastal Source Razor Line is available in either a white powder coat or black finishes. Razor speakers incorporate aluminum enclosures with a composite grille.
Availability and Pricing
For more information on availability, dealers, and pricing, visit Coastal Source or browse their FAQs.
2026 Fyne Audio F1-10 Anniversary Loudspeakers
Fyne Audio celebrates a decade with its most advanced IsoFlare driver, integrated SuperTrax and just 30 pairs of the $50,000 F1-10 Anniversary.
2026 Cambridge Audio Spira 1 Turntable Colors 2026 Cambridge Audio Spira 1 Turntable Colors
Cambridge Audio's $499 Spira turntable pairs Bluetooth, a steel platter and five colorful finishes with its new L/R active speaker lineup.
Lampizator Horizon 2 DAC Lampizator Horizon 2 DAC
LampizatOr’s Horizon 2 adds Aphrodite tech, a redesigned tube stage and upgrades for owners who already spent car money on a DAC.
C Seed Bugatti TV at CEDIA Expo 2026 C Seed Bugatti TV at CEDIA Expo 2026
C SEED and Bugatti turn a folding 4K MicroLED television into a 137-inch kinetic sculpture with Tourbillon design and Wisdom Audio.
2026 MartinLogan USR51 Slim 5.1-channel A/V Receiver 2026 MartinLogan USR51 Slim 5.1-channel A/V Receiver
MartinLogan's first-ever home theater receiver delivers 5.1 channels of surround sound in a compact form factor that may look familiar.
Apple TV 4K, HomeView, HomePod mini 2, and Home Collection 2026 Apple TV 4K, HomeView, HomePod mini 2, and Home Collection 2026
Apple launches a $299 Apple TV 4K, $149 HomePod mini 2, $299 HomeView and four-speaker surround.
Can Coastal Source turn the backyard into a true high-end system? Its CEDIA 2026 lineup combines outdoor audio, lighting and simplified power.
KEF takes Uni-Q outdoors with new landscape speakers, bollards, subwoofers and GaN KASA amps. Can it challenge Theory Audio Design?
Andover Audio FreePlay vs KEF Muo: which portable Bluetooth speaker sounds better at home, outdoors, and on the road?
Can the Andover Audio FreePlay deliver true stereo sound, long battery life, and real durability in a portable Bluetooth speaker?
Coastal Source 1000 Series Bollards bring ribbon tweeters, modular configurations, and serious all-weather sound to luxury outdoor installations.
Bang & Olufsen teams with Antolini on Beosound Haven, a high end outdoor speaker concept that blends stone, design, and integrated audio.
Available in green or gray, Triangle’s GARDEN 7 outdoor speaker delivers 360-degree sound, IP66 weatherproofing, and LED lighting at a reasonable price.
Priced from $225, Polk Audio Atrium Series outdoor speakers bring high-quality sound to patios, pools, and outdoor entertainment spaces.
