Gaming Headsets
Audeze Maxwell 2 ANC Debuts at CanJam London 2026 With Adaptive Noise Cancellation
2026 Audeze Maxwell 2 ANC Gaming Headset Lifestyle Front
The new Audeze Maxwell 2 ANC addresses the most conspicuous omission from one of the best-sounding wireless gaming headsets on the market. Following the Maxwell 2’s debut in early 2026 and the recent introduction of interchangeable ReSkin earcups, Audeze is adding active and adaptive noise cancellation, expanded smart-audio capabilities, and new visual accents. More significantly, the Maxwell 2 ANC is the first headset in Audeze’s entire headphone lineup to offer ANC.
The original Maxwell did more than raise expectations for gaming audio. It smashed through the category’s glass ceiling and demonstrated that a high-end headphone manufacturer could build a wireless gaming headset with serious planar magnetic performance without charging $2,000 to $4,000 for admission. There is, after all, a finite supply of audiophiles willing to explain that purchase to a spouse, accountant, or divorce attorney.
Sony Interactive Entertainment has never said that Maxwell convinced it to acquire Audeze in August 2023, but the timing is difficult to ignore. The headset gave Audeze a credible path beyond the comparatively limited market for ultra-premium planar magnetic headphones and into the vastly larger PlayStation, PC, and console-gaming ecosystem. It would be surprising if that potential did not feature prominently in Sony’s calculations.
Audeze gave eCoustics an early listen to the Maxwell 2 at CanJam NYC 2026, and its planar magnetic drivers delivered the detail, impact, and spatial precision that made the original such a category disruptor. The missing feature was ANC. With the Maxwell 2 ANC, Audeze has finally filled that hole rather than hoping gamers would stop noticing it.
Related Review: Audeze Maxwell Wireless Gaming Headphones Review
Audeze Adds Gaming Focused Adaptive ANC to the Maxwell 2
audeze-maxwell-2-anc-gaming-headset
Audeze Maxwell 2 ANC (looks identical to Maxwell 2)
The inclusion of ANC and expanded smart-audio capabilities is a welcome addition to the Maxwell platform, which has already earned considerable attention from the media, esports competitors, and audio professionals.
Audeze’s adaptive hybrid noise cancellation system has been engineered specifically for gamers. It combines feedforward and feedback noise reduction with low-latency transparency, reducing external distractions while preserving positional-audio accuracy. According to Audeze’s internal testing, the system delivers a significant reduction in constant low-frequency noise and outperforms typical consumer ANC headphones during gameplay.
The Maxwell 2 ANC also supports AI-controlled ANC settings, voice-activated commands, an improved transparency mode, and simultaneous wired and Bluetooth audio playback. Combined with the full planar magnetic driver system and SLAM technology carried over from the Maxwell 2, these upgrades position the Maxwell 2 ANC as the most advanced gaming headset Audeze has released to date.
audeze-maxwell-2-anc-gaming-headset-connections
Key Features of the Maxwell 2 ANC
  • Adaptive Hybrid Noise Cancellation: ANC microphones embedded within the earcups give users greater control over their listening environment. A low-latency Transparency Mode is also included.
  • Voice-Command Control: Voice commands provide faster access to key settings as gameplay conditions change.
  • Planar Magnetic Drivers with SLAM: Carried over from the Maxwell 2, Audeze’s planar magnetic driver system and SLAM technology are designed to deliver clearer, deeper bass and more precise sound.
  • Improved Comfort: Upgraded ergonomics are intended to reduce fatigue during longer gaming sessions.
  • Versatile Connectivity: The Maxwell 2 ANC supports connections with PCs, game consoles, and mobile devices, making it easier to move between gaming and everyday listening.
  • Style Highlights: Silver accents give the Maxwell 2 ANC a distinct appearance, while the previously introduced limited-edition ReSkin earcups allow users to personalize the headset.
Comparison
Audeze ModelMaxwell 2 ANC (2026)Maxwell 2 (2026)Maxwell (2023)
Product Type Wireless Gaming HeadsetWireless Gaming HeadsetWireless Gaming Headset
PriceFor PlayStation: $429
For Xbox: $449
For Playstation: $329
For Xbox: $349
For Playstation: $299
For Xbox: $329
Wearing StyleOver-ear, Closed-BlackOver-ear, Closed-BlackOver-ear, Closed-Black
Transducer type.Planar magneticPlanar magneticPlanar Magnetic
Transducer size90 mm90 mm90 mm
Magnet type Neodymium N50Neodymium N50Neodymium N50
Magnetic Structure. Fluxor magnet arrayFluxor magnet arrayFluxor magnet array
Diaphragm typeUniforceUniforceUniforce™
Phase ManagementFazorFazorFazor
Acoustic managementSLAMSLAM–
Maximum SPL> 115 dB> 115 dB> 120 dB
Frequency Response10Hz – 50kHz10Hz – 50kHz10Hz – 50kHz
THD<0.1% @ 100dB<0.1% @ 100dB<0.1% (@ 1 kHz, 1mW)
Noise ReductionANCN/AN/A
Bluetooth 5.3YesYesYes
Bluetooth Codec SupportLE Audio, LDAC, AAC, SBCLE Audio, LDAC, AAC, SBCLE Audio, LC3, LC3plus, LDAC, AAC, SBC
Bluetooth MultipointYesYesYes
Wireless DongleUSB-C, ultra-low latencyUSB-C, ultra-low latencyUSB-C
Wired connectionUSB-C digital, 3.5mm analogUSB-C digital, 3.5mm analogUSB-C with dual-audio endpoints and game-chat mix
3.5mm TRRS active
Audeze AppYesYesYes
BatteryLithium-polymer, 1800mAhLithium-polymer, 1800mAhLithium-polymer, 1800mAh
Battery life Over 80hr (wireless, 80dBA)Over 80hr (wireless, 80dBA)Over 80 hrs wireless playback @ 80dBA
Fast chargeUSB-C 5v 1.8A maxUSB-C 5v 1.8A maxUSB-C, 5v 1.8 Amp max – 25% charge / 20min (Full charge 2hr)
audeze-maxwell-2-anc-gaming-headset-kit
The Bottom Line
The Maxwell 2 was unveiled at CES 2026 and quickly established itself as one of the strongest premium gaming headsets on the market. The Maxwell 2 ANC addresses its most obvious omission by adding adaptive hybrid noise cancellation, improved transparency, and expanded smart-audio features without abandoning the 90 mm planar magnetic drivers, Fluxor magnet arrays, Fazor waveguides, and SLAM acoustic technology that distinguish the platform.
That combination is what makes the Maxwell 2 ANC unusual. Noise cancellation is hardly new to gaming headsets, but pairing gaming-focused adaptive ANC with Audeze’s full-size planar magnetic driver technology is far less common. Its primary competition includes the SteelSeries Arctis Nova Pro Omni ($399), Turtle Beach Stealth Pro II ($349), and the Razer Kraken V4 Pro ($399).
Those rivals offer their own advantages, including lighter designs, hot-swappable batteries, elaborate control hubs, and aggressive competitive-gaming tuning. Audeze’s strongest argument remains sound quality, particularly for gamers who also expect one headset to handle music, movies, voice chat, and everyday listening without sounding like a plastic helmet full of angry bees.
At $429 for the PlayStation version and $449 for Xbox, the Maxwell 2 ANC is aimed at serious console and PC gamers who prioritize planar magnetic clarity, bass extension, positional accuracy, and effective isolation over low weight or bargain pricing. It is not an impulse purchase, but it is considerably less expensive than the SteelSeries Arctis Nova Elite and occupies a rare position between conventional premium gaming headsets and Audeze’s far more expensive audiophile headphones.
Sony’s acquisition of Audeze appears to be paying dividends. Rather than sanding away the company’s audiophile identity, the Maxwell platform is bringing its planar magnetic technology to a much larger audience. The Maxwell 2 ANC is the most complete version of that strategy so far—and potentially the model that finally eliminates the strongest reason some gamers had for buying something else.
audeze-maxwell-2-anc-gaming-headset-lifestyle-side
Pricing & Availability
All models support Windows, macOS, Android, iOS, and Nintendo Switch. The Maxwell 2 ANC will be demonstrated at CanJam London 2026 from July 18-19.
2026 CINEST Core E1 UST Projector Media Console Front View see-thru
A/V Furniture & Accessories
CINÈST Core Collection media consoles integrate UST projector placement, AV storage, cooling, cable management, and optional floor-rising screens.
Mantelbar with Sonos Arc Soundbar over Fireplace Lifestyle Mantelbar with Sonos Arc Soundbar over Fireplace Lifestyle
NextLevel's Mantelbar hides a Sonos Arc soundbar or speakers inside the fireplace mantel. Clever architecture, or has the mantel finally earned its keep?
2026 Marshall Bromley 160 Party Speaker Lifestyle 2026 Marshall Bromley 160 Party Speaker Lifestyle
Marshall’s $499.99 Bromley 150 party speaker combines 360-degree sound, stage lighting, 40+ hour battery life, Auracast, and mic and instrument inputs.
2026 Nothing Headphone (1) Pro Lifestyle 2026 Nothing Headphone (1) Pro Lifestyle
Nothing's $399 Headphone (1) Pro uses three drivers, xMEMS treble and Flat EQ. Clever engineering, or has Nothing finally over-engineered something useful?
2026 Bose Noise Cancelling Wired Earbuds Lifestyle 2026 Bose Noise Cancelling Wired Earbuds Lifestyle
$99 Bose Noise Cancelling Wired Earbuds arrive in 2026 with ANC, USB-C and no battery. Did the company that helped kill the cable just...
2026 Clearaudio Compact Phono in Silver and Black Front 2026 Clearaudio Compact Phono in Silver and Black Front
Gaming Headsets
Sony’s new PlayStation Pulse and Pulse Edge headsets add larger planar magnetic drivers, PlayStation Link, Bluetooth and ANC.
Gaming Headsets
Can Sennheiser and Mercedes-AMG turn the HD 620S into a serious gaming headset while Sennheiser’s consumer business remains for sale?
Gaming Headsets
Beyerdynamic expands its MMX gaming lineup with the $149.99 MMX 100 Wireless and an unusual $179.99 open-back MMX 130 Wireless.
Gaming Headsets
The planar magnetic specialist says it is deeply involved with unreleased PlayStation hardware. Sony’s 2023 acquisition now looks less like a headphone deal and...
OXS Storm A2 delivers budget-friendly wireless gaming headphones with 7.1 virtual surround, hybrid active noise cancellation, ultra-low latency, and versatile cross-platform support.
