OXS Storm A2 Brings 7.1 Surround and ANC—For Gamers Who Hate Losing and Spending
OXS Storm A2 delivers budget-friendly wireless gaming headphones with 7.1 virtual surround, hybrid active noise cancellation, ultra-low latency, and versatile cross-platform support.
OXS Storm A2 Gaming Headphones Lifestyle
In a category dominated by high-end contenders like the Audeze Maxwell, the fight for the best wireless gaming headset has never been more intense. The OXS Storm A2 enters the arena swinging with 7.1 virtual surround, hybrid ANC, and ultra-low latency—all at a budget price point. With gamers demanding more immersive audio and seamless performance, the Storm A2 positions itself as a serious underdog challenger in a fiercely competitive headset market.
OXS Audio isn’t new to the game. The brand previously turned heads with its Thunder Pro 5.1.2 Gaming Sound System and the Storm G2 Wireless Gaming Headset—both of which delivered surprisingly strong performance for their price. With the Storm A2, OXS looks to build on that momentum and go head-to-head with bigger names in the wireless gaming audio space.
oxs-storm-a2-front
Storm A2 Specs: Not Just Another Cheap Headset With Flashy Lights
Audio: The OXS Storm A2 incorporates 40mm neodymium full-range dynamic drivers complemented by onboard “Xspace” 7.1 virtual surround sound technology. These features are designed to provide immersive audio for game or movie viewing.
Gaming Support: For gamers, the Storm A2 touts lag-free real-time audio with its 2.4GHz wireless dongle, with an ultra-low latency of less than 20ms.
Hybrid Active Noise Cancellation: To make sure every sound is crystal clear, the Storm A2 incorporates Hybrid Active Noise Cancellation. This enables the A2 to deliver realistic bass, mids, and highs without noise interference.
oxs-storm-a2-noise-cancellation
EQ: To further enhance sound quality, the Storm A2 offers two EQ modes. Users can toggle between Surround and Standard settings, allowing them to tailor the audio to fit gaming, movies, or casual listening.
Microphone: In addition to immersive listening, the Storm A2 features a detachable omnidirectional microphone via a 3.5mm connection. Equipped with five built-in mics and enhanced sensitivity, it delivers crystal-clear voice capture—ideal for in-game commands or team chats. The built-in mic also supports hands-free calls when you’re off the clock.
oxs-storm-a2-mic
Device Compatibility: The Storm A2 Gaming Headset offers broad cross-platform compatibility with four connection modes: Bluetooth 5.4, USB-A dongle, USB-C dongle, and wired USB. Its 2.4GHz ultra-low latency wireless and Bluetooth 5.4 ensure seamless performance across a wide range of devices—including PCs, laptops, PS4/PS5, Xbox, Switch, tablets, and smartphones. With support for both Type-A and Type-C dongles, the Storm A2 makes connecting to your gear hassle-free, no matter your setup.
oxs-storm-a2-gaming-headphones-with-adapter
Wearing Comfort: With a lightweight metal frame, memory foam earpads, and sweat-resistant materials, the Storm A2 is built for long-haul comfort during marathon gaming sessions. Its portable, foldable design makes it easy to pack and carry, while the all-day wearability means you can game, stream, or chat without feeling like your head’s in a vise.
OXS Storm A2 and G2 Wireless Gaming Headset Comparison
OXS Model NumberStorm A2 (2025)Storm G2 (2024)
Product Type Wireless Gaming HeadsetWireless Gaming Headset
Price$129.99$79.99
Wearing StyleOver-Ear Closed BackOver-Ear Closed Back
Audio ConfigurationXspace 7.1 Virtual Surround Sound (in Surround EQ)7.1 Virtual Surround Sound (in Surround Mode
Speaker Driver40mm Full-range Dynamic50mm Full-range Dynamic
Noise Cancellation (Acoustic)Hybrid Active Noise CancellationAdvanced Passive Noise Cancellation
EQ ModeSurround (7.1 Virtual Surround Sound Effect) StandardSurround (Virtual 7.1 Surround Sound Effect), Game, Music
Frequency Response20Hz – 20kHz20 – 20KHz
Sensitivity110 dB SPL/mW@1kHz by HATS100±3dB
Impedance36 ohmsNot Indicated
Distortion<5%≤3%
MicrophoneType: Detachable Omni-Directional Mic + Built-in Mic
Noise Cancelation: ENC
Plug: 3.5mm AUX Plug
Frequency Response: 100 – 8 kHz
Sensitivity: -42±3dB
Type: Detachable Omni-Directional Mic + 1 Built-in Mic
3.5mm AUX Plug
Frequency Response: 50 – 10 KHz
Sensitivity: -42 +/-2dB
Wireless ConnectivityWireless 2.4GHz (USB-A Dongle + USB-C Dongle)
Latency: < 20ms
2.4GHz (Via Type A + Type C 2 in 1 Dongle)
< 25ms
BluetoothVer: 5.4
Range: 10m
Latency: 180ms
Ver: 5.3
Range: 10m
Latency: 180ms
Wired USB-C Cable 3.5mm AUX Cable
RGB LightsNot IndicatedYes
Battery Capacity1000mAh1000mAh
Battery Play Time 70H (ANC OFF, 70% Volume)Lights Off, 50% Volume: 40 hours
Lights On, 50% Volume: 24 hours
Charging Time1H 40Min4 hours
Power Input5V 0.5A5V 0.5A
Headphone ConstructionABS + Aluminum + Stainless Steel + Leather + Memory FoamABS + Stainless Steel + Leather + Memory Foam
Earcup ConstructionMemory Foam + Skin-Friendly Protein LeatherMemory Foam + Skin-Friendly Protein Leather
Package Dimensions (WDH)188 x 64 x 220 mm
 7.4 x 2.5 x 8.7 inches
185 x 98 x 205 mm
 7.3 x 3.9 x 8.1 inches
Item Weight293 g (with Mic);
284 g (without Mic)
250 grams
What’s in the Box1 x Storm A2 Headphones
1 x 2.4G Dongle (USB-A & USB-C in 1 unit)
1  x Charging Cable (USB-A to C)
1 x Detachable Microphone (3.5mm AUX)
1 x Storage Bag
1 x User Manual
1 x TechnicalSpecifications
1 x Safety and Maintenance
1 x  Headphone
1 x  2-in-1 2.4G Dongle (Type A + Type C)
1 x  Type C Charging Cable
1 x 3.5mm Aux Cable
1 x Microphone Foam Tip
1 x User Manual
1 x Headphone Bag
oxs-storm-a2-in-the-box
The Bottom Line
OXS may not flood the market with options, but what they do offer punches well above its price class—especially the Storm A2, which prioritizes serious features like hybrid ANC over gimmicks like RGB lighting. If you want a versatile headset that can handle gaming, music, movies, and marathon battery life without breaking the bank or your patience, the Storm A2 is a smart pick in a sea of flashy but forgettable contenders.
However, with competition (refer to our related reading section below) from Sony, Audeze (also owned by Sony), and Beyerdynamic, a lesser-known brand such as OXS, may not be as visible in the market, but its offerings are worth checking out, especially with their prices.
Also, if you prefer gaming-optimized earbuds over full-size headphones, Final and Cleer Audio have options that you should consider at reasonable prices.
Price & Availability
1 Comment
1 Comment
  1. Anton
    June 26, 2025 at 6:28 am
    Kudos to eCoustics for actually covering the entry-level with as much enthusiasm as the mid-tier and Uber expensive segments. Nobody else is doing that…certainly not Stereofool or The Absolute Farce. Twittering Idiot also gave up on affordable audio years ago.
    Kudos to Robert.
2026 Steinway & Sons Model O Loudspeaker near wall lifestyle
Audeze and Audiokinetic bring native head tracking to Wwise with the Maxwell 2 ANC, giving game developers new tools for spatial audio creation.
Gaming Headsets
Sony’s new PlayStation Pulse and Pulse Edge headsets add larger planar magnetic drivers, PlayStation Link, Bluetooth and ANC.
Gaming Headsets
Can Sennheiser and Mercedes-AMG turn the HD 620S into a serious gaming headset while Sennheiser’s consumer business remains for sale?
Gaming Headsets
The planar magnetic specialist says it is deeply involved with unreleased PlayStation hardware. Sony’s 2023 acquisition now looks less like a headphone deal and...
Loudspeakers
NEAD will distribute Jamo, Energy, Juke Audio, XLO and OXS across the U.S. and Canada as two familiar speaker brands plan their return.
Gaming Headsets
Can Edifier’s $149 HECATE G5 MAX challenge Sony Pulse Elite with THX Spatial Audio+, low-latency wireless, and 305-hour battery life?
