Yamaha B200A Soundbar Adds Dolby Atmos, But There’s No Upgrade Path
The compact Yamaha B200A adds Dolby Atmos and built in bass for under $300, but can you live without external surrounds or a subwoofer?
2026 Yamaha B200A Dolby Atmos Soundbar Lifestyle
Not everyone wants a pair of powered speakers, an AV receiver, or a larger soundbar taking over the space around a TV or computer monitor. Yamaha’s new B200A is aimed at viewers and desktop users who want a more immersive audio experience from a compact all in one design, with built in bass support and Dolby Atmos without adding more boxes, cables, or speakers.
The B200A succeeds the popular SR-C20A Compact Soundbar, which arrived in 2020 and was overdue for a replacement. Yamaha has updated the concept with Atmos and a broader feature set, but the B200A remains intentionally self contained: there is no option to add an external subwoofer or surround speakers later.
Compact Dolby Atmos Sound Without the Extra Boxes
The B200A is Yamaha’s most compact Dolby Atmos soundbar. Engineered to make the most of its 23.5-inch, space-saving design, it combines Dolby Atmos with Yamaha’s Hi-Fi-inspired engineering to deliver a richer, more expansive presentation. Proprietary acoustic design and advanced sound processing are intended to create a more immersive experience for movies, TV shows, and gaming.
yamaha-b200a-bass
With its compact width, the B200A is well suited for bedrooms, apartments, home offices, and gaming spaces. Built in Dolby Atmos adds greater dimensionality by expanding the sound field around the listener, while the integrated subwoofer and Bass Extension mode are designed to deliver greater low frequency impact from its compact enclosure.
“The B200A was designed for people who want better sound without giving up valuable space,” said Alex Sadeghian, director of consumer audio at Yamaha. “Whether it’s a bedroom, apartment, home office or gaming setup, the B200A delivers clear, immersive sound in a compact design that’s simple to live with every day.”
The B200A also includes Clear Voice technology for enhanced dialogue clarity. Four optimized sound modes, Movie, Standard, Stereo, and Game, allow users to tailor the presentation for different types of content.
yamaha-b200a-hdmi-earc
In terms of connectivity, the B200A soundbar includes HDMI eARC/ARC, optical, 3.5 mm AUX, and Bluetooth wireless streaming.
For easier installation, the B200A can be placed beneath a TV or monitor, on a media console or desk, or mounted on a wall using its built in keyholes. Its compact footprint also makes it a practical option for rooms where space is limited.
Feature Summary:
  • Dolby Atmos for immersive 3D sound
  • Built in subwoofer with Bass Extension mode
  • Clear Voice technology for improved dialogue clarity
  • Bluetooth wireless streaming
  • HDMI eARC/ARC, optical, and AUX connectivity
  • Movie, Standard, Stereo, and Game sound modes
  • Compact design for bedrooms, offices, and gaming setups
yamaha-b200a-desktop
Comparison
Yamaha Model B200A (2026)SR-C20A (2020)
Product TypeCompact SoundbarCompact Soundbar
Price$249.95$199.95
Output PowerFront L/R: 20 W × 2
Built-in subwoofer: 30 W
Front L/R –   20 W × 2 channels
Subwoofer – 30 W
Speaker EnclosureAcoustic suspension type (non-magnetic shielding) Acoustic suspension type (non-magnetic shielding)
Speaker Drivers (Front L/R) Front L/R: 4.6 cm (1.8”) cone × 2
Frequency response – 230 Hz to 22 kHz
Impedance – 6 Ω
4.6 cm (1.8″) cone × 2
Impedance – 6 Ω
Subwoofer Driver7.5 cm (3”) cone x 1
65 Hz – 230 Hz
Impedance – 4 Ω
7.5 cm (3″) cone x 1
65 Hz – 230 Hz
Impedance – 4 Ω
Passive RadiatorsNot Indicated2
Sound ModesStereo, Standard, Movie, GameStereo, Standard, Movie, Game
Compressed Music Enhancer Not IndicatedYes (for Bluetooth)
Bass ExtensionYesYes
Supported Audio FormatsPCM (up to 2 channels)
Dolby Atmos
Dolby Digital (up to 5.1 channels)
Dolby Pro Logic II (up to 5.1 channels)
Inputs 1 x Digital (optical)
1 in (3.5mm stereo mini jack)
2 x Digital (optical)
1 x Analog (3.5 mm stereo mini)
Outputs 1 x hdmi (TV eARC/ARC) 1 x HDMI (HDMI OUT/TV (ARC))
USB 1 (UPDATE ONLY) 1 (UPDATE ONLY)
Bluetooth Ver 5.3 Ver 5.0
Bluetooth ProfileA2DP, AVRCP A2DP
Bluetooth Codec SupportSBC, MPEG4-AAC SBC, AAC
Bluetooth Range (line-of-sight) Approx. 10 m (33 ft) Approx. 10 m (33 ft)
MusicCast NoNo
MusicCast Surround NoNo
Remote ControlYesYes
Power Supply AC 100 to 120 V, 50-60 Hz AC 100 to 120 V, 50-60 Hz
Power consumption 13 W (Rated) 13 W (Rated)
Standby Power ConsumptionHDMI Control/Bluetooth Standby: Off 0.3 W
HDMI Control/Bluetooth Standby: On 0.4 W
HDMI Control/Bluetooth Standby: Off 0.2 W
Dimensions (WHD)600 x 64 x 94 mm
 23.6” × 2.5” x 3.75”
600 x 64 x 94 mm
23.6″ x 2.5″ x 3.75″
Weight 1.8 kg (3.9 lbs) 1.8 kg (3.9 lbs)
App ControlYes (Yamaha Sound Bar Remote App – iOS & Android Yes (Yamaha Sound Bar Remote App – iOS & Android
yamaha-b200a-app
The Bottom Line
Six years after introducing the SR-C20A, Yamaha finally has a proper replacement for its compact soundbar. The new B200A adds Dolby Atmos, an integrated subwoofer, and updated connectivity while keeping the price below $300 and the cabinet small enough for bedrooms, apartments, desktops, and gaming setups.
The B200A’s real appeal is its simplicity. At just 23.5 inches wide, it can sit beneath a smaller TV or computer monitor without dominating the space, and the integrated subwoofer means there is no separate bass module to accommodate. For buyers who want better sound without adding more boxes, cables, or speakers, that compact all in one approach makes a lot of sense.
There is, however, a Dolby Atmos caveat. The B200A does not support external surround speakers or an external subwoofer, so the entire Atmos presentation has to be created by the drivers and processing inside the soundbar. That can certainly make the presentation sound larger and more immersive, but it is not the same experience as a system with discrete surround and height speakers and a dedicated external subwoofer. Buyers should think of the B200A as a compact all in one system rather than the starting point for a home theater that can grow over time.
yamaha-b200a-bluetooth
Bluetooth is similarly basic. The B200A can receive Bluetooth streams from compatible smartphones, tablets, and computers, but it cannot transmit audio to Bluetooth headphones, earbuds, or wireless speakers. Yamaha also provides control through its Sound Bar Remote App, but there is no support for the company’s MusicCast wireless whole home platform, which limits its appeal as part of a larger Yamaha music system.
Yamaha’s Clear Voice technology remains a useful feature for improving dialogue intelligibility, although ZVOX continues to be a very tough competitor in that department. Its AV835 ($269.99) and AV855 ($369.99 MSRP) use AccuVoice and SuperVoice processing with multiple levels of dialogue enhancement, while PhaseCue provides virtual surround without the more marketable Dolby Atmos badge. If dialogue clarity is the priority rather than Atmos, ZVOX deserves to be on the same shopping list.
Yamaha B200A Remote Control
Included remote control.
The B200A is ultimately more interesting because of where Yamaha has positioned it. It is compact enough for desktop and gaming use, includes its own bass support, works equally well with a smaller TV or computer monitor, and does not require users to find space for a separate subwoofer. The tradeoff is that what you buy on day one is essentially what you will still have several years from now.
Those who want more flexibility within Yamaha’s lineup have several options. The SR-B30A retains an all in one design but adds a subwoofer output, while the SR-B40A includes a separate wireless subwoofer. Yamaha’s True X Series moves further up the ladder with models that support wireless surround expansion, Wi-Fi streaming, and additional connectivity. And if your compact soundbar budget somehow mutates into the price of a decent used car, the $3,499.95 True X Surround 90A sits at the other end of Yamaha’s lineup with dedicated wireless surrounds, a wireless subwoofer, MusicCast, Dolby Atmos, DTS, and AURO-3D.
yamaha-b200a-soundbar-angle
Pricing & Availability
The Yamaha B200A sound bar will be available in November 2026 for $249.95 through Yamaha’s Soundbar Page and Authorized Retailers.
The SR-C20A  sound bar was discontinued in 2023 and is no longer available through Yamaha and may no longer be available through authorized retailers
Splurge Audio Video Hi-Fi Tech Gifts 2026
Exclusive Videos
The $479 WiiM Bar offers excellent music playback and streaming, but aggressive compression hurts Dolby Atmos. Is this Sonos alternative worth buying?
Dongle DACs
Questyle's QCC Dongle Pro2 brings LDAC, Bluetooth 6.1, and low-latency gaming to more devices. Is the wireless upgrade worth its compromises?
After years of hands-on testing, these are the soundbars and speaker bar systems for home theater that impressed us most in 2026.
Most soundbars promise Dolby Atmos and deliver disappointment. These are the rare models that actually sound convincing and are worth recommending in 2025.
LG's flagship soundbar, the Sound Suite H7, just got support for DTS:X surround, but good luck making that work on an LG TV.
FiiO's $380 CLASS A headphone amp can switch to Class AB with low-impedance headphones. Here's what FiiO says and why the distinction matters.
Hi-Fi Components
Bose now spans ANC, luxury hi-fi, connected audio, automotive and gaming. The FMOD acquisition makes its larger strategy harder to ignore.
