Yamaha YHT-4970U Home Theater in a Box System Offers a Budget Friendly Soundbar Alternative
Yamaha’s $700 YHT-4970U bundles an RX300A AVR, 5.1 speakers, subwoofer, Bluetooth, and upgrade options as a real soundbar alternative.
2026 Yamaha YHT-4970U Home Theater in a Box System
Yamaha’s new YHT-4970U Home Theater in a Box makes a pretty direct argument against spending $700 on another soundbar. The system bundles Yamaha’s new RX300A AV receiver with a matched 5.1-channel speaker package, speaker wire, and a subwoofer cable, giving first-time home theater buyers a real AVR-based surround system in one box.
No, it will not be as clean or idiot-proof as a soundbar. You will have to run wires. You will have to place speakers. Civilization may survive. The payoff is discrete surround channels, a real receiver at the center of the system, and an upgrade path that most soundbars simply do not offer at this price point.
The RX300A AVR
yamaha-rx300a-front-mic-remote
The RX300A AV receiver included with the YHT-4970U updates the look of Yamaha’s previous entry-level design, moving away from the older RX-V385, which originally arrived in 2018. The new front panel is cleaner and less crowded, with fewer visible buttons and simpler labeling, while still keeping the core controls easy to find. It is not a radical redesign, but it does make the receiver look more current and easier to understand for buyers who may be setting up an AVR-based system for the first time.
The RX300A includes an Anti‑Resonance Technology (A.R.T.) Wedge. This is a center-mounted “fifth foot” from Yamaha’s flagship AVENTAGE series that helps reduce vibration and improve stability, supporting cleaner, more accurate sound reproduction.
The incorporation of HDMI 2.1 supports high‑performance video sources, including 4K/120Hz and 8K/60Hz pass-through, along with Dolby Vision and HDR10+ for improved contrast, color accuracy, and detail. Gaming‑focused features, such as Variable Refresh Rate (VRR) and Auto Low Latency Mode (ALLM), help ensure smooth, responsive gameplay when paired with modern consoles.
yamaha-rx300a-back
Room Correction
The RX300A  provides a setup microphone that enables automatic room correction for the YHT-4970U system by measuring room acoustics and speaker behavior. This allows the receiver to optimize sound performance for the listening environment. An on-screen setup guide further simplifies installation by walking users through connections and configuration step by step.
yamaha-rx300a-rx500a-on-screen-display
Sound Setting Simplicity
The RX300A also includes Yamaha’s Scene buttons, which let users store and recall common settings with a single press. Each Scene can be assigned to an input, sound program, and related playback settings, making it easier to jump between TV, movies, music, and gaming without digging through menus every time. It is a practical feature for an entry-level home theater system because it reduces setup friction and keeps the receiver from feeling like homework with speaker terminals.
yamaha-rx300a-scene-buttons
The RX300A supports Dolby Atmos in two ways. If you run speaker wires to the rear of your room and place speakers there for 5.1 channels, the receiver can add virtual height effects to simulate sound coming from above you. If instead, you want real height channels or you don’t want to run wires to the back of the room, you can configure the receiver for height channels and mount those extra speakers on the ceiling or high on the front or side wall for discrete height effects. This would be a real 3.1.2-channel Dolby Atmos system, with the receiver creating virtual rear channel effects. Note that Yamaha calls this a “3.2.2-channel” configuration, because there is a second subwoofer output on the receiver that could can use if you have a second sub.
And while the RX300A does not natively decode DTS:X, it does support DTS Virtual:X, which is designed to create a more spacious height effect from DTS soundtracks without requiring physical height speakers. That distinction matters. Real height channel decoding and real height speakers will deliver the more convincing immersive sound experience, while virtual processing is the compromise for rooms where adding more speakers is not practical. Useful? Yes. Ideal? Nope. But keep in mind, people, this is an entry level receiver so it can’t do everything.
For wireless connectivity, Bluetooth Multipoint allows two devices (such as a smartphone and tablet) to remain paired simultaneously, making it easy to switch between sources without reconnecting. The RX300A can also be used with Bluetooth headphones or speakers.
The Speakers and Subwoofer
yamaha-yht-4970-speakers
The RX300A is the control center of the YHT-4970U, but Yamaha also includes the rest of the basic 5.1-channel speaker package in the box. The system comes with two compact front speakers, two compact surround speakers, a compact center channel speaker, and an 8-inch, 50-watt powered subwoofer, with the speakers and subwoofer connecting to the receiver using standard speaker wire and audio cable connections.
Pro Tip #1: The package includes one powered subwoofer, but the RX300A provides two subwoofer outputs, so a second subwoofer can be added later if the room or your bass addiction demands backup.
Pro Tip #2: Because the RX300A uses standard passive speaker connections and powered subwoofer outputs, the included speakers are not a dead end. Owners can upgrade the front, center, surround speakers, or subwoofer later without replacing the entire system. That is one of the biggest advantages over most soundbar packages: the YHT-4970U starts as a complete system, but it does not have to stay frozen that way forever.
Comparison
Yamaha ModelYHT-4970U (2026)YHT-4950U (2019)
Product TypeHome Theater-in-a-BoxHome Theater-in-a-Box
Price$699.99$559.99
Included AVRRX300ARX-V385
Channels5.2 5.1
Decodable Channels 5.1 5.1
Amplified Channels5 5
Output Power 70 W (8 ohms, 20 Hz – 20 kHz, 0.09% THD, 2-ch driven)
145 W (6 ohms, 1 kHz, 10% THD, 1-ch driven)
145 W (6 ohms, 1 kHz, 10% THD, 1-ch driven) (JEITA)
Bi-amp Capable YesYes
Surround Sound Decoding Formats Dolby Atmos
Dolby True HD
Dolby Digital Plus
Dolby Digital
DTS
Dolby True HD
Dolby Digital Plus
Dolby Digital
DTS-HD Master Audio
DTS- HD High Resolution
DTS
DTS 96/24
DTS Neo:6
Surround Sound Post Decoding Formats Dolby Surround
DTS Virtual:X
Not Indicated
Network Decoding Formats NoNo
USB Decoding Formats MP3
MPEG4-AAC
WM
WAV
MP3
MPEG4-AAC
WMA
WAV
HDMI Decoding Formats PCM (8ch max)PCM (8ch max)
Sound Modes Pure Direct
Straight
Movie
All Channel Stereo
2 Channel Stereo
Night
Direct
Straight
Enhancer
Bass program
BD/DVD
TV
CD
Radio
Zone B Yes Not Indicated
Room Calibration Room Correction YPAO
Other Features Dialogue Level
Subwoofer Trim
Extra Bass
Lip Sync
Dialogue Level
Subwoofer Trim
Extra Bass
Lip Sync
HDMI Connections4 Inputs / 1 Output 4 Inputs / 1 Output
HDMI Features HDMI 2.1
8K60Hz/4K120Hz
eARC, ARC
VRR
ALLM
QMS
HDCP 2.3
CEC
Auto Lip Sync
Deep Color
x.v. Color
HD audio playback
HDMI Version 2.0b
Video Upscaling To 4K
eARC, ARC
HDCP 2.2
CEC
Auto Lip Sync
Deep Color
x.v. Color
HD audio playback
High Dynamic Range (HDR) Support HDR10+
HDR10
Dolby Vision
Hybrid Log-Gamma
HDR10
Dolby Vision
Hybrid Log-Gamma
Headphone Output 1 1
Subwoofer Pre-outs 2 1
HDMI 4 Inputs / 1 Output 4 Inputs / 1 Output
Analog RCA Inputs 2 2
Analog Aux InputNo1 x 1/8″ / 3.5 mm Aux (Front)
Optical Input 1 1
Coaxial Input 1 2
USB 1 (Audio File Playback from a Mass Storage Device, Firmware Updates) 1
FM/AM Tuner Yes / No Yes/Yes
Bluetooth Yes (Ver. 5.3, Multipoint) Yes (Version 2.)1
Streaming No (Streaming through Bluetooth only)No (Streaming through Bluetooth only)
Wi-Fi / Ethernet Port NoNo
Speaker Output 5 (binding post terminals) 5 (binding post terminals)
Speaker Design2 x Front, Bass Reflex
2 x Surround: Bass Reflex
1 x Center: Acoustic Suspension
Speaker System Frequency ResponseNot Indicated28 Hz to 25 kHz
Speaker System Power HandlingNominal Input Power 30 W per Channel
Max Input Power 100 W per Channel
Speakers Impedance6 Ohms6 Ohms
Speakers SensitivityFront, Surround: 83 dB, 2.83 V/m
Center: 84 dB, 2.83V/m
Speaker Drivers1x 2.75″ / 69.85 mm Full-Range Cone per Speaker1x 2.75″ / 69.85 mm Full-Range Cone per Speaker
SubwooferPowered, Bass Reflex (twisted flare port)
Power Output RMS: 50 W (5 Ohms, 100 Hz, 10% THD)
Dynamic: 100 W (5 Ohms)
Frequency Response: 28 to 200 Hz
Driver: 1x 8″ / 203.2 mm Cone
Power Consumption 260W AVR: 400W
Subwoofer: 40W
Standby Power Consumption ≤0.3W ≤ 0.2 W
Auto Power Standby Yes Yes
App Not IndicatedNot Indicated
Dimensions (AVR)434W x 157H x 319D mm
17-1/8”W x 6-1/8”H x 12-1/2”D
17.13″W x 6.31″H x 12.56″D
Dimensions (Speakers)Not IndicatedFront and Surrounds: 4.38 x 6.88 x 4.63″ / 111.13 x 174.63 x 117.48 mm
Center: 10.88 x 4.38 x 4.63″ / 276.23 x 111.13 x 117.48 mm
Dimensions (Woofer)11” W x 11” H x 13” D
Included Accessories Remote Control
Batteries
FM Antenna
Setup Mic
Microphone Stand
Quick Guide
Safety Guide
Remote Control
Batteries
AM/FM Antenna
Setup Mic
Microphone Stand
Quick Guide
Safety Guide
The Bottom Line
The Yamaha YHT-4970U makes sense for buyers who want a real 5.1-channel AVR-based home theater system without buying every piece separately. It also offers a flexible configuration option to use front height speakers instead of surround speakers for Dolby Atmos, in case running wires to the back of your room is problematic. For $700, it delivers discrete speakers, a powered subwoofer, Bluetooth, HDMI connectivity, and a genuine upgrade path.
The limitations are clear. There is no discrete 5.1.2-channel option for Dolby Atmos. That would take 7 amplifier channels, where this only has 5. And the RX-300A receiver doesn’t support DTS:X decoding. But in today’s Dolby Atmos-heavy streaming and physical media ecosystems, this may not be that big a deal to most buyers. Also, the included speakers are likely the starting point, not the finish line. The good news is that the RX300A uses standard speaker and subwoofer connections, so owners can upgrade the speakers or add a second subwoofer later as budget and available space allow.
Who is it for? First-time home theater buyers, secondary rooms, and anyone who wants actual surround sound instead of another soundbar trying to do architectural drawings with DSP.
Pricing & Availability
  • Yamaha YHT-4970U 5.1-Channel Home Theater in a Box – $699.95 (July 2026)
  • Yamaha RX300A 5.2-Channel AVR – $399.95 (June 2026)
2026 Steinway & Sons Model O Loudspeaker near wall lifestyle
The compact Yamaha B200A adds Dolby Atmos and built in bass for under $300, but can you live without external surrounds or a subwoofer?
Sony brings back the home theater in a box with a system that can match the largest TVs with rich cinematic sound. But it...
Yamaha's NX-70A wireless speakers bring HDMI eARC, YPAO, Roon Ready support, and active stereo performance for around $3,500.
Does your giant TV or projector screen make your soundbar look puny? Sony is here for you with their new powered speaker system which...
Yamaha’s RX300A and RX500A AV receivers start at $399 with HDMI 2.1, room correction, streaming, and a cleaner entry level design.
Can Bose make home theater easier? The Lifestyle Ultra Soundbar and Subwoofer add Dolby Atmos, SpeechClarity, AirPlay, and Google Cast.
SVS Sound R|Evolution Experience Tour hits St. Louis, Atlanta, and Paramus NJ with live demos, Atmos setups, expert tips, and big giveaways.
