Wand 12-inch Dark-Light Tonearm to Debut at HIGH END Vienna 2026: Does Length Really Matter?
Wand’s €8,900 12-inch Dark-Light tonearm goes long at HIGH END Vienna 2026. Lower distortion, more rigidity, and finally, headshell lifts?
WAND Tonearm Turntable
The Wand has been one of those tonearms that has intrigued me for years, largely because it never looked like it was designed by committee, or by someone trapped in front of a CAD workstation after midnight with too much confidence and something much stronger than coffee. They do it differently in New Zealand. Its wide to narrow carbon fiber arm profile helped make it instantly recognizable, and the design has built a real following over time. The latest chapter arrives next week at HIGH END Vienna 2026, where Wand will unveil its new 12-inch Dark-Light tonearm, a longer version of the 10-inch Dark-Light that first appeared at Munich High End 2025.
Long tonearms are not new, and neither is the argument over whether the added length is worth the extra real estate and setup demands. Wand already offers 9.5-inch, 10.3-inch, 12-inch, and 14-inch arms, and the company claims a 12-inch arm can reduce distortion by roughly 30% compared to a 9-inch design. That matters if the arm can keep resonance, rigidity, and bearing behavior under control, which is where Wand has always tried to separate itself from the usual aluminum tube and prayer routine.
My own curiosity goes back to some oddball tonearms I tried years ago, including the Japanese RS Labs RS-A1, a rotating headshell design that looked faintly mad but made a persuasive case for thinking differently about geometry and tracking. I also came across The Wand while looking at restored idler drive Lenco turntables, including the Dutch PTP Audio projects built around classic Swiss Lenco decks from the 1970s. PTP adopted The Wand for some of its turntables back in 2014, which only made the rabbit hole deeper. Naturally, I fell in. That is how these things happen.
The new 12-inch Dark-Light is not just about making the arm longer because the internet needs another argument. It is about whether Wand can preserve the speed, low noise, and musical flow that made the shorter model interesting, while taking advantage of the lower tracking distortion that a properly executed 12-inch arm can deliver. For vinyl listeners with the deck, space, cartridge, and patience to make it work, this could be one of the more interesting analog debuts at HIGH END Vienna 2026.
wand-tonearm-series
Handmade in New Zealand, Designed by Simon Brown
Design Build Listen is not just another boutique analog brand making pretty bits for expensive turntables. Based in Aotearoa / New Zealand, the company hand builds The Wand Tonearm along with other audio accessories, including its “No Ring Rings” tube dampers designed to reduce unwanted vibration.
Created by designer Simon Brown and launched in 2011, The Wand Tonearm has earned multiple design awards and five star reviews for its distinctive carbon fiber arm design. Its large diameter arm tube is claimed to be at least four times stiffer than traditional tonearms, which helps explain why The Wand has always felt less like a retro accessory and more like a serious rethink of how a tonearm should work.
Longer Reach, Tapered Stiffness, Serious Vibration Control
The new Wand Dark-Light 12-inch tonearm is not just a longer version built for people with more plinth real estate and stronger opinions. Its core advantage is Wand’s Musical Taper design, which increases the arm tube diameter toward the pivot as length increases. That larger rear section is intended to preserve stiffness rather than sacrifice rigidity, while also allowing more internal brass mass near the bearing assembly.
The added mass lowers the center of gravity and gives vibrational energy a more controlled path away from the cartridge and arm tube. For a 12-inch tonearm, that matters: the longer geometry can help reduce tracking distortion, but only if the arm remains stable, rigid, and free enough to trace the groove properly. The Dark-Light’s appeal is that it tries to balance those demands without turning the design into another heavy analog science project with nicer photography.
wand-12-inch-dark-light-tonearm
Will The Wand Tonearm Work With Your Cartridge?
The Wand Tonearm should work with a wide range of cartridges, which is one reason it has attracted attention from both high end analog users and listeners building more sensible vinyl systems. Design Build Listen says The Wand has been used with cartridges from Lyra, Transfiguration, Koetsu, Kiseki, Dynavector, Denon, Ortofon, Hana, and others, which covers a pretty broad slice of the cartridge world.
The standard Wand Tonearm is considered a medium mass design, with a claimed effective mass of 12.5g, while the 12-inch version is listed at 15g. The Master Series arms add roughly another gram.
Very high compliance cartridges still need some care, but Design Build Listen notes that even a Shure V15Vx measured at a 7Hz resonance, which remains usable. Lower compliance moving coil cartridges are also considered a good match.
Denon DL-103 and Ortofon 2M models appear to be among the most popular cartridge choices with Wand users, which makes sense. One is a classic low output moving coil with a long history, and the other is a widely used moving magnet family that covers a broad range of budgets. Wand also recommends Hana moving coil cartridges, especially the Hana ML.
The practical takeaway is that The Wand is not a one-cartridge science project. It should work with many common MM and MC cartridges, provided setup is done properly and the turntable is not being asked to rescue warped records from the witness protection program. As always, compliance, cartridge weight, counterweight range, and phono stage compatibility still matter, but for most users, The Wand should not create a matching crisis.
Will The Wand Fit Your Turntable?
The Wand is designed around Rega-style mounting dimensions, but that does not mean it is the obvious upgrade path for every Rega Planar 3, Pro-Ject Debut PRO, or other sub-$1,000 turntable. This is a serious tonearm, and not an inexpensive one, so the better question is whether the turntable, cartridge, plinth, and overall system justify the move. Bolting a high-end tonearm onto an entry-level deck can work mechanically, but it may not be the smartest use of the budget. Vinyl has enough ways to separate you from your money without handing it the keys.
Where The Wand makes more sense is on turntables with the space, adjustability, and mechanical foundation to take advantage of it. Design Build Listen offers mounting information and kits for a wide range of decks, including the Linn LP12, Technics SL-1200 and SL-1500 family, including newer GR models, Lenco L75 family turntables, Thorens TD-160 and TD-150 models, Thorens TD-318 family turntables, Michell turntables, and SME-style armboards.
The 10.3-inch Wand is especially interesting because it was designed to deliver much of the appeal of a 12-inch arm in a more compact footprint. Design Build Listen describes it as the longest arm intended to fit on a Linn LP12 or Technics SL-1200 family turntable, which gives owners of those decks a way to go longer without needing a battleship-sized plinth.
Suspended turntables should not be ruled out automatically. The Wand weighs roughly 500g, which is in the same general territory as an SME 3009 and somewhat heavier than many Rega arms. That means most properly adjustable suspended decks should be able to accommodate it, but setup matters. Arm height, lid clearance, suspension adjustment, mounting geometry, and counterweight clearance all need to be checked before anyone starts drilling holes and pretending this is IKEA furniture.
The Bottom Line
At €8,900, the Wand 12-inch Dark-Light tonearm is not a casual upgrade. It is built for serious turntables, serious cartridges, and vinyl listeners who care about geometry, stiffness, resonance control, and setup precision.
Its appeal is the way Wand tackles the 12-inch tonearm problem: lower tracking distortion, a tapered carbon fiber arm tube designed to maintain rigidity, internal brass mass for vibration control, and, finally, headshell lifts for better day-to-day usability.
This is for experienced Linn, Technics, Lenco, Thorens, Michell, and custom plinth users, not someone trying to turn a budget deck into an analog miracle. It is available now and can be heard at Vienna High End in Halle 5, S15.
For more information: designbuildlisten.com
2026 Audiolab PPA7 Phono Preamp Black LIfestyle
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
2026 T+A Solitaire T Pro Wireless Headphones 2026 T+A Solitaire T Pro Wireless Headphones
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
2026 Vinnie Rossi Canta Integrated Amplifier Angle 2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
2026 Sony Walkmans 2026 Sony Walkmans
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
Meet the $49.99 Tiny Vinyl Player for 4 inch records, with Bluetooth, built in speakers and new accessories. Your kids may not be impressed.
AudioDeskSysteme Gläss gives its $3,599 Vinyl Cleaner Premium the Silent Core One upgrade for quieter, faster ultrasonic record cleaning. Your dirty LPs have no...
Audio-Technica launches new turntable accessories for cartridge alignment, platter speed calibration, phono cables, and headshell wires.
A/V Furniture & Accessories
Toneoptic’s CAN record storage system offers modular stackable vinyl storage made in Los Angeles starting at $195 and designed to replace milk crates for...
Clearaudio’s Mini Toolkit provides precision tools for perfect turntable setup, cartridge alignment, and vinyl care for the best possible sound.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
With 500 lumens of LED lighting across a slim beam, no dust or dirt on your vinyl records can hide from the UberLight Frame.
