Tiny Vinyl Launches a $49.99 Player for 4 Inch Records Because Apparently They Needed One
Meet the $49.99 Tiny Vinyl Player for 4 inch records, with Bluetooth, built in speakers and new accessories. Your kids may not be impressed.
Tiny Vinyl Player Lifestyle
Tiny Vinyl now has a dedicated belt drive record player with Bluetooth, built in stereo speakers, and accessories for storing and displaying its growing collection of miniature records.
Last year, we covered Tiny Vinyl, the 4-inch record format that puts one song on each side and turns physical music into something closer to a collectible sonic snack. Apparently the snack now requires its own table setting.
The new Tiny Vinyl Player is a $49.99 record player designed exclusively for the company’s miniature vinyl format. It is available through Target in a black leatherette clamshell cabinet with built in stereo speakers, Bluetooth output, and a wired audio connection for external speakers or headphones.
Why Does Tiny Vinyl Need Its Own Player?
Strictly speaking, it does not.
Tiny Vinyl records spin at 33⅓ RPM and can play on many conventional manual turntables. The problem is that their grooves sit very close to the spindle. Automatic stop and return mechanisms can engage before the song is finished, while some tonearms simply cannot travel far enough toward the center of the platter.
tiny-vinyl-player-angle
Tiny Vinyl Player
The dedicated player removes that uncertainty and gives collectors a simple way to use the format without checking tonearm geometry or disabling automatic functions. It also makes Tiny Vinyl more approachable for younger listeners and casual collectors who do not already own a turntable.
Tiny Vinyl says customers began requesting a player almost as soon as the records reached the market. Target also encouraged the company to develop one after the retailer began carrying the format across its stores. According to the company’s founders, more than one million Tiny Vinyl records have now been pressed.
Perhaps the tiny ecosystem is becoming less tiny.
What Does the Tiny Vinyl Player Actually Play?
One format. No plot twist.
The Tiny Vinyl Player supports the company’s 4-inch records at 33⅓ RPM. It does not play conventional 7 inch singles, 10 inch records, 12 inch LPs, or standard 45 RPM releases.
Each Tiny Vinyl record holds up to four minutes of music per side and is issued as a sequentially numbered limited edition. The records use 15 grams of 100 percent bio attributed vinyl, compared with approximately 140 grams for a conventional LP.
That limited playing time means this is not a format for albums, live recordings, or the 17 minute version of anything. It is designed for two songs, collectible artwork, and fans who enjoy owning a physical object connected to a particular artist.
Tiny Vinyl’s official catalog now includes more than 90 released or identified records, most of which sell for $14.99 at Target. The lineup spans artists such as Rihanna, Ariana Grande, Bruno Mars, Chappell Roan, Britney Spears, The Rolling Stones, Black Sabbath, Blink 182, Jimi Hendrix, BTS, and John Williams.
Tiny Vinyl Info
Tiny Vinyl Player Features
The Tiny Vinyl Player is a compact belt drive design measuring approximately 10 inches wide, 5.5 inches tall, and 6.5 inches deep. It weighs 3.88 pounds and requires AC power because there is no internal battery.
Key features include:
  • 33⅓ RPM playback
  • Support for 4 inch Tiny Vinyl records
  • Belt drive mechanism
  • Built in stereo speakers
  • Bluetooth output for compatible speakers and headphones
  • Wired audio output
  • Black leatherette clamshell cabinet
  • Included power cord
  • Compact 10.04 by 5.51 by 6.46 inch dimensions
The player is designed to work immediately out of the box, although records are sold separately.
Please Connect Better Powered Speakers
Nobody should expect room filling bass, meaningful stereo separation, or much dynamic impact from speakers squeezed into a $49.99 record player that is only slightly larger than a shoebox.
Tiny Vinyl acknowledges that the built in speakers are intended for convenient, casual listening rather than high quality playback. Two colleagues who have already purchased it described the sonic playback as “thin” and “lacking bass impact.”
Color me surprised. Not really.
We have not tested the Tiny Vinyl Player, so this is not a sonic verdict. It is, however, a very strong recommendation to connect the player to a better pair of powered speakers.
Use the wired audio output when possible, or connect through Bluetooth if convenience matters more. Even an affordable pair of powered bookshelf speakers should provide greater output, stronger bass, and a more convincing sense of scale than the internal speakers.
Will that transform a 4-inch record into an audiophile pressing? Of course not. But it should make the experience considerably more enjoyable, which is presumably why you bought a record that can hide behind a drink coaster in the first place.
Tiny Vinyl Crate
tiny-vinyl-crate
Tiny Vinyl Crate
The $19.99 Tiny Vinyl Crate provides storage for up to 32 records. It uses a wood frame with black leatherette covering and a velveteen interior, and it is sized so the Tiny Vinyl Player can sit directly on top.
The crate can also accommodate compact discs and cassettes, should your miniature record collection fail to consume every available inch of storage.
Tiny Vinyl 2×2 Frame
tiny-vinyl-frame
For collectors more interested in displaying the artwork, the $14.99 Tiny Vinyl 2×2 Frame holds four record jackets behind a clear shatter resistant window.
The black wood frame measures approximately 11 by 11 inches, uses magnetic closures for easier access, and can be mounted on a wall or placed on a flat surface. The records themselves are not included.
The Bottom Line
The Tiny Vinyl Player is not pretending to replace a conventional turntable, and anyone expecting it to compete with a proper analog system has wandered into the wrong aisle at Target.
This is a compact, affordable player for collectors who already own Tiny Vinyl records, younger listeners discovering physical music, or anyone whose automatic turntable cannot reach the format’s unusually close inner grooves. It also makes a fun desk system or gift without requiring the space and expense of a full size turntable setup.
Owners of a compatible manual turntable do not need it. Listeners expecting full size LP performance should avoid it entirely.
For everyone else, the Tiny Vinyl Player completes an amusing and increasingly popular collectible ecosystem. Just connect it to better powered speakers. Tiny records are one thing. Tiny sound does not have to be part of the deal.
Price & Availability
The Tiny Vinyl Player and accessories are available exclusively through Target at the time of publication.
3 Comments
3 Comments
  1. ORT
    July 25, 2026 at 4:37 pm
    Hmmmmmmm…Given that I, a not-so-rich-and-powerful-not-even-close-to-being-a-cloistered-member-of-the-pious-press suffer from a rare, errrr…”problem” taxinomically designated as “achondroplasiaphobia” it would seem odd that I think kinda-sorta highly of (alliteration ALERT!) Tiny Turntables.
    Will I buy one? Probably not as the cost of diminutive disc is too prohibitive for a retarded…retired person such as myself. I also have a dreadful fear of spiders. And giant spiders with certain folk astride them? Instant prayers to the Most High for a heart attack to take me out.
    Thus endeth the remotive revelatons for the day. Cool stuff but *SHUDDER*…I cannot buy one.
    ORTson Welles
    • Ian White
      July 26, 2026 at 12:10 am
      ORT,
      Took one for the team. My 13 year-old has it. She thinks it’s very lame compared to the Andover. She bought her type of music (total waste of money) and played it. No bass as I predicted. She plugged it into my Triangle Borea BR03 BT. Sounded a lot better, but a basic Pro-Ject wipes the floor with it. She’s leaving it in her room for show. Already back on her Sennheiser cans and her iPhone the iFi dongle I gifted her.
      IW
  2. ORT
    July 28, 2026 at 12:09 pm
    Ian, speaking of Pro-Ject,I am awaiting delivery of my new Pro-Ject Peanuts 75th Anniversay turntable. I will make use of the BlooToof feature as I often just sit and listen in the early hours via headphones. I bought it because I am a Peanuts Enthusiast and while I really wanted the Elvis ‘table I could not afford it. Yet. That will hopefully be my next ‘table.
    ORT
2026 Coturn CT-TWO by Thorens portable turntable
Thorens helped create a €599 turntable that fits in a backpack, runs for 20 hours, and streams vinyl over Bluetooth. Clever engineering or a...
Sonus faber IsoAcoustics GAIA Titan Neo Loudspeakers Isolation Feet Sonus faber IsoAcoustics GAIA Titan Neo Loudspeakers Isolation Feet
A/V Furniture & Accessories
IsoAcoustics GAIA-TITAN Neo series of speaker isolation feet are designed for extra large speakers weighing 320 to 620 lbs each.
2026 Pro-Ject Audio Debut Carbon The Original Turntable Satin Black 2026 Pro-Ject Audio Debut Carbon The Original Turntable Satin Black
Pro-Ject revives the Debut Carbon for $649 with a carbon tonearm and Ortofon-made cartridge. Is it worth saving $50 over the EVO 2?
2026 Acoustic Energy 500 Series Loudspeakers 2026 Acoustic Energy 500 Series Loudspeakers
Acoustic Energy redesigns its 500 Series with Corinium drivers, new cabinets, and four models starting at £650. Is the upgrade worth it?
2026 Schiit Magni 6 Headphone Amplifier 2026 Schiit Magni 6 Headphone Amplifier
Splurge Audio Video Hi-Fi Tech Gifts 2026
Wand’s €8,900 12-inch Dark-Light tonearm goes long at HIGH END Vienna 2026. Lower distortion, more rigidity, and finally, headshell lifts?
AudioDeskSysteme Gläss gives its $3,599 Vinyl Cleaner Premium the Silent Core One upgrade for quieter, faster ultrasonic record cleaning. Your dirty LPs have no...
Toneoptic’s CAN record storage system offers modular stackable vinyl storage made in Los Angeles starting at $195 and designed to replace milk crates for...
Tiny Vinyl drops 31 titles at $14.99 each, including hits from Sinatra to Black Sabbath. Cool collector's item or tiny vinyl disaster? Time will...
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
With 500 lumens of LED lighting across a slim beam, no dust or dirt on your vinyl records can hide from the UberLight Frame.
For $375, Toneoptic offers an innovative wall-mounted vinyl record storage solution you'll actually flip out for.
The Record Doctor X now cleans both sides of the record at the same time and it's $400 less than the VPI HW16.5.
