Audio Desk Systeme Gläss Vinyl Cleaner Premium Adds Silent Core One Motor: Vinyl OCD Just Got Quieter
AudioDeskSysteme Gläss gives its $3,599 Vinyl Cleaner Premium the Silent Core One upgrade for quieter, faster ultrasonic record cleaning. Your dirty LPs have no alibi.
Audio Desk Systeme Glass Vinyl Cleaner Premium Gray Angle
Audio Desk Systeme Gläss Vinyl Cleaner Premium with Silent Core One arrives at a moment when vinyl is not just back. It brought friends, bad habits, and a whole lot of filthy records with it. What used to be a quick pass with a carbon fiber brush has turned into a full-blown arms race, where $300 record brushes somehow exist, Spin Clean baths feel like entry level hazing, and the venerable VPI HW 16.5 now costs well over $1,000.
For nearly two decades, Audiodesksysteme Gläss has been the company audiophiles point to when they are done pretending that “good enough” cleaning is actually good enough. Since launching the original fully automatic ultrasonic Vinyl Cleaner in 2009, the brand has helped define what serious record care looks like, evolving through the PRO, PRO X, and Vinyl Cleaner Premium versions while the rest of the category kept chasing the groove dust.
Now comes the latest iteration: the Vinyl Cleaner Premium with Silent Core One. Audio Desk says this version reflects eighteen months of refinement focused on effectiveness, reliability, and lower operating noise. In a category where everyone claims to clean deeper, Audio Desk is betting that doing it better, quieter, and more consistently still matters. Because apparently even dust, smoke, and questionable bodily fluids now require German engineering.
audio-desk-systeme-glass-vinyl-cleaner-premium-colors
Now in Its Fifth Generation
The Audio Desk Systeme Gläss Vinyl Cleaner Premium with Silent Core One marks the fifth generation of the company’s fully automatic ultrasonic record cleaning machine. Audio Desk says the original model was the first ultrasonic based machine designed to thoroughly clean and dry both sides of a record at the same time with a single button press, which helped establish it as one of the category benchmarks.
The Vinyl Cleaner is currently distributed in more than 40 countries across six continents, but there is one important change for U.S. buyers: effective immediately, the Audio Desk Systeme Gläss Vinyl Cleaner Premium with Silent Core One and its accessories will be sold factory direct to customers in the United States for the foreseeable future. Cleaner records, fewer middlemen. Not exactly punk rock, but neither is paying four figures to remove groove sludge.
What Changed Inside the Vinyl Cleaner Premium with Silent Core One?
The biggest update is the in-house developed Silent Core One drive motor, which Audiodesksysteme Gläss says is more powerful, audibly quieter, and more reliable. Drying time has also been reduced by roughly 50 percent, which matters when you are cleaning more than one record and would rather not spend the evening watching a machine inhale moisture like it has union rules.
Audio Desk has also repositioned the water pump for improved cooling, added a new short-circuit-proof software control system with current management, and updated the microfiber cleaning rollers with improved concentricity. The goal is quieter operation and better contact with the record surface. The disc rinsing system now operates at higher pressure for improved effectiveness, while new drying wipers are designed to reduce noise, eliminate the occasional squeak, and last longer.
The practical upgrade may be the most important one: the Vinyl Cleaner Premium with Silent Core One can now be repaired by authorized service locations, so a malfunctioning unit no longer has to be shipped back to Germany for pump or motor service. Audio Desk has also added a new wet filter for improved filtration.
Specifications, Accessories, and What You Actually Get for $3,599
Beyond the Silent Core One updates, the Audio Desk Systeme Gläss Vinyl Cleaner Premium remains a fully automatic ultrasonic record cleaning machine that cleans and dries both sides of an LP in a single cycle of roughly five minutes. It is designed for standard 12 inch records out of the box, with optional kits available for 7-inch singles and 10-inch records.
The unit measures approximately 13 inches wide, 10.6 inches high, and 7.9 inches deep, and weighs roughly 12 to 14 pounds depending on configuration. Water capacity is about 4.5 liters, with a small amount of cleaning concentrate added to distilled water for operation. The new Silent Core One motor is designed for long-term durability, with significantly improved reliability over previous generations.
In the box, you get the Vinyl Cleaner Premium unit, four microfiber cleaning rollers, a wet filter, cleaning fluid concentrate, power supply and mains cable, a microfiber cloth, dust cover, and a user manual. In other words, everything you need to get started short of the distilled water and a stack of records that probably should have been cleaned years ago.
Optional accessories include 7-inch and 10-inch record cleaning kits, replacement microfiber rollers, replacement wet filters, and additional cleaning fluid. The Premium platform is already designed to accommodate these smaller format upgrades, so you are not locked into LP-only cleaning if your collection includes singles.
Unlike vacuum based machines, the Audio Desk Systeme Gläss uses a filtered air drying system rather than suction. The upside is less static buildup after cleaning. The downside? You will have fewer excuses for why your records still sound like they were dragged behind a truck.
audio-desk-systeme-glass-vinyl-cleaner-premium-red
The Bottom Line
The Audio Desk Systeme Gläss Vinyl Cleaner Premium with Silent Core One is not for the casual vinyl listener with a milk crate of beat-up LPs and a $20 brush. At $3,599, it is a serious ultrasonic record cleaning machine for collectors, dealers, archivists, and audiophiles who clean records often and want the process to be fully automatic, quieter, faster, and more reliable than earlier versions.
What makes it unique is the total package: one-button cleaning and drying of both sides of a record, the new in-house Silent Core One motor, roughly 50% shorter drying time, improved rollers, higher-pressure rinsing, better filtration, quieter wipers, and serviceability through authorized locations instead of shipping a broken machine back to Germany like it needs a passport.
What is missing? The price is still brutal, 7-inch and 10-inch cleaning require optional kits, and cheaper ultrasonic options like the HumminGuru HG01 ($599 at Amazon) make a strong value argument for listeners who do not need this level of automation, speed, build quality, or long-term service support.
So what do you get for thousands more? Less babysitting, more consistency, better integration of washing, rinsing, filtration, and drying, faster workflow, and a machine built for heavy use. The HumminGuru makes sense for many vinyl fans. The Audio Desk Systeme Gläss is for the person who looks at a wall of records and sees not a hobby, but evidence.
Where to buy:
For more information: audiodesksysteme.de/premium
2026 Steinway & Sons Model O Loudspeaker near wall lifestyle
We cleaned 200 records with the $3,599 Audio Desk Systeme Gläss Vinyl Cleaner Premium to see if its ultrasonic technology and redesign deliver.
Meet the $49.99 Tiny Vinyl Player for 4 inch records, with Bluetooth, built in speakers and new accessories. Your kids may not be impressed.
Wand’s €8,900 12-inch Dark-Light tonearm goes long at HIGH END Vienna 2026. Lower distortion, more rigidity, and finally, headshell lifts?
A/V Furniture & Accessories
Toneoptic’s CAN record storage system offers modular stackable vinyl storage made in Los Angeles starting at $195 and designed to replace milk crates for...
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
With 500 lumens of LED lighting across a slim beam, no dust or dirt on your vinyl records can hide from the UberLight Frame.
Originally designed for the BBC, the Keith Monks ReduxTwo offers professional grade record cleaning with zero recontamination.
For $375, Toneoptic offers an innovative wall-mounted vinyl record storage solution you'll actually flip out for.
