REL Acoustics No.35 and No.36 Reference Subwoofers Would Like a Word With Your Foundation
At $10K or $12K each, REL’s new flagship No.35 and No.36 Reference subwoofers add new amplifiers and carbon fibre drivers for improved low bass performance.
2026 REL Acoustics No. 35 and No 36 Reference Subwoofers
Reference-quality bass is not cheap. SVS might have something to say about that, but REL Acoustics has spent decades building some of the best subwoofers in the business, so it has more than earned the right to take another shot at the title.
And before anyone starts clutching their wallet, the new Reference No.35 and No.36 are not even close to being the most expensive subwoofers you can buy. There are models on the market that cost four or five times as much. Whether anyone actually needs to spend that kind of money to rearrange the furniture from the listening chair is another question.
REL last refreshed the top end of its Reference lineup in 2022 with the No.31 12-inch and No.32 15-inch subwoofers, both of which established themselves firmly in the ultra-high-end category. Four years later, REL is replacing them with the Reference No.35 and No.36, its next-generation flagship subwoofers.
The names may have changed only slightly, but these are not minor updates. REL is positioning the No.35 and No.36 as full-blown statement products designed for systems where bass extension, scale, speed, and integration are expected to be every bit as serious as the loudspeakers sitting in front of them.
rel-no-35-subwofer-detail
REL No.35 Reference Subwoofer
17 Pounds of Transformer Says REL Is Serious About Bass
At the heart of the new Reference No.35 and No.36 is REL’s new Class AB/D amplifier architecture, which combines the current delivery of a traditional Class A/B power supply with the speed and efficiency of Class D.
The No.35 delivers 900 watts RMS, while the No.36 increases output to 1,000 watts RMS. Both amplifiers are built around a massive 17-pound toroidal transformer, which should tell you rather quickly that REL was not aiming for lightweight engineering here.
“The new amplifiers were the starting point,” says John Hunter, REL President and Lead Designer. “Once we heard what they were capable of, it became clear the drivers had to evolve with them.”
rel-no-36-subwofer-no-grille-front
REL No.36 Reference Subwoofer
Bigger Excursion and a Serious Carbon Fibre Upgrade
The No.36 applies REL’s new 12K Pure Carbon Fibre technology to its 15-inch (380mm) Reference driver, along with a revised suspension designed to allow greater cone movement.
The No.35 uses a 12-inch (300mm) driver with a new cast-aluminium frame and redesigned suspension, giving it an additional 12mm of travel in each direction compared with the No.31. REL has also adopted a finer 12K carbon fibre weave, intended to produce a quieter and more controlled cone.
The payoff is significant: REL says the No.35 can now play louder than the outgoing No.32, despite the latter being the previous 15-inch Reference flagship.
Statement Bass Deserves More Than a Black Box
The engineering inside the new No.35 and No.36 Reference models is only part of the story. REL has paid just as much attention to the cabinets housing all of that hardware.
Inspired by classic wooden runabouts, the enclosures reflect the influence of Franco Serblin, John Hunter’s mentor, and require 12 coats of hand-rubbed lacquer to achieve their final finish. Extensive internal bracing is designed to keep the cabinets inert, allowing the improvements in driver and amplifier control to come through without the enclosure adding its own unwanted contribution.
One REL Is Apparently Never Enough
The No.36 retains the same dimensions as REL’s previous 15-inch Reference models, while the No.35 matches the No.31 exactly. That means existing owners can integrate either model into a Reference Line Array alongside earlier-generation Reference subwoofers.
rel-no-36-subwofers-line-array
REL No.36 Reference Subwoofer Line Array
For more than two decades, Line Arrays have represented REL’s ultimate expression of deep bass. The concept involves vertically stacking and distributing multiple subwoofers within the room, which REL says allows the main loudspeakers to operate with greater scale, clarity, and freedom from low-frequency demands.
Up to three subwoofers can be stacked using REL Couplers (Line Array Connectors), which secure the lower and upper cabinets together. The solid, milled-aluminum couplers bolt directly to each subwoofer and work with the substantial rails underneath the cabinets to create an extremely heavy and rigid bass tower.
As with the outgoing No.31 and No.32, the new models provide the necessary wired connectivity and can also be configured for wireless operation. System settings can be controlled using REL’s Reference wireless remote control.
Comparison
REL Acoustics ModelNo.35No.36
Product Type Powered SubwooferPowered Subwoofer
Price$10,000$12,000
Subwoofer TypeClosed box, front-firing driverClosed box, front-firing driver
Amplifier TypeClass AB/DClass AB/D
Power Output900 watts1,000 watts
Driver12 inch (305mm) long throw, carbon fibre cone with inverted carbon fibre centre cap, die-cast alloy chassis15 inch (380mm) long throw, carbon fiber cone with inverted carbon fibre centre cap
Low-Frequency Extension -6 dB at 17 Hz -6 dB at 15 Hz
Input ConnectorsHigh-level Neutrik SpeakOn
Low-level stereo RCA and XLR, LFE RCA, LFE XLR
Output ConnectorsHigh-level Neutrik
SpeakOn, LFE RCA, LFE XLR, Line XLR, Line RCA
High-level Neutrik
RCA Gain Control Range80 dBNot Indicated
Dual Parametric Filter (EQ)YesYes
Protection SystemFully Electronic Set Safe
D.C. Fault
Output Short
D.C. Fault
Output Short
Mains Input Voltage220-240 volts, 110-120 volts for certain markets220-240 volts, 110-120 volts for certain markets
Fuses8 Amp semi-delay, 230 volts operation; 15 Amp semi-delay, 115 volts operation8 Amp semi delay 230 volts operation
Dimensions (WHD)25.12 x 17 x 28.5 in.
(638 x 435 x 724 mm)
29 1/4 x 21.3 x 32 1/8 in.(743 x 541 x 816 mm)
Weight 130 lbs (59 kg)202.5 lbs (91.8 kg)
Finish Piano Black Lacquer, 12 coatsPiano Black Lacquer, 12 coats
Wireless Capability via Optional REL AirShip DirectYesYes
What’s In The BoxReference No.35 Subwoofer
Grille
6′ AC Power Cord
32′ Neutrik Speakon cable
User Manual & Warranty Information
Reference Remote
Batteries (AAA x2)
Mains Lead
Reference No.36 Subwoofer
Grille
6′ AC Power Cord
Reference Remote
Batteries (AAA x2)
Line Array Mounting Hardware
rel-no-35-36-subwofers-rear
The Bottom Line
The No.31 and No.32 were already formidable subwoofers, which makes the No.35 and No.36 interesting for a different reason. REL did not simply install larger amplifiers, fiddle with the DSP, and declare victory. The new models combine revised carbon-fibre drivers, substantially reworked Class AB/D amplification, increased excursion, extensive cabinet construction, and compatibility with REL’s existing Reference Line Array ecosystem.
That last point might be the most unusual part of the entire upgrade. The No.35 and No.36 retain the dimensions of their predecessors, allowing existing Reference owners to integrate the new models with earlier REL subwoofers in a Line Array rather than starting over. At this level, where someone could conceivably have three very expensive subwoofers stacked on top of one another, backward compatibility suddenly becomes a rather meaningful feature.
At $10,000 for the No.35 and $12,000 for the No.36, none of this comes cheaply. There are also some extremely capable alternatives for considerably less money. The SVS 17-Ultra R|Evolution models deliver enormous output from 17-inch drivers for less than $3,000, while the PS Audio Foundry F12 offers a 12-inch driver, 1,000-watt amplifier, DSP, wireless capability, and even stackability for $2,749. MartinLogan and DALI also offer serious alternatives for high-end music and home theater systems.
What REL is selling for the additional money is not simply more bass. The Reference models are built around REL’s particular approach to integration, high-current amplification, high-level connectivity, elaborate cabinetry, and the ability to create a vertically stacked Reference system that can grow with an existing installation. There are cheaper ways to reach subterranean frequencies and shake the drywall. Quite a few of them, actually.
The No.35 and No.36 are aimed at listeners who want REL’s interpretation of statement-level bass and have a system capable of exposing the differences. Whether that refinement is worth $10,000 or $12,000 will require a serious audition, but at least REL is offering something more distinctive than another gigantic driver attached to an even more gigantic Class D amplifier.
And if a single No.36 somehow fails to satisfy you, REL will happily let you stack three of them. At that point, the limiting factor may no longer be bass response. It may be your homeowner’s insurance.
Price & Availability
All REL Subwoofers and related accessories are available through Authorized Dealers, including optional AirShip Direct for an extra $399.
  • REL Reference No.36 (15-inch) – $12,000
  • REL Reference No.35 (12-inch) – $10,000
2027 JBL L150 Classic Loudspeakers Lifestyle without grilles
2026 Adam Audio H715 Reference Open-back Studio Headphones 2026 Adam Audio H715 Reference Open-back Studio Headphones
AT $699, ADAM Audio's flagship H715 Reference headphones, combine Sonnox calibration, balanced Hi-Fi mode, and studio monitoring in one design.
2026 Audio-Technica ATH-AWX7000 Headphones 2026 Audio-Technica ATH-AWX7000 Headphones
Audio-Technica's $3,800 ATH-AWX7000 combines Japanese Cypress wood, luxury craftsmanship, and new 58mm drivers. Can it challenge the best closed-back headphones?
2026 Final A8000 DC IEM Back Front 2026 Final A8000 DC IEM Back Front
Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
Audio Cables
Esprit Generation 10 cables arrive in the U.S. with redesigned conductors, connectors, and insulation. Nine ranges span $499 to $59,999.
Goldmund's Mimesis Statement uses three chassis, separate channel power supplies and redesigned analog circuitry. A flagship with a startling price.
