Pro-Ject x Harley-Davidson Turntable Is a $3,299 Record Player That Takes the Bar & Shield Very Seriously
Is the Pro-Ject Harley-Davidson Turntable serious hi-fi or expensive motorcycle merch? Its hardware suggests this isn’t merely a branding exercise.
2026 Pro-Ject Harley-Davidson Turntable
Pro-Ject has spent years demonstrating that a themed turntable does not have to be the analog equivalent of a souvenir T-shirt from the airport gift shop. The Austrian manufacturer has already gone down this road with The Beatles, Metallica, Pink Floyd, AC/DC, Peanuts, Elvis Presley and others, frequently using the collaboration as an excuse to do something genuinely interesting with the hardware.
Harley-Davidson is next, and subtlety has once again been left outside in the parking lot.
The officially licensed Pro-Ject x Harley-Davidson Turntable is a limited special edition priced at $3,299 in the United States, and unlike some lifestyle collaborations that amount to a logo, new paint and an inflated invoice, this one has been designed around Harley-Davidson’s visual identity from the ground up. The shape of the chassis follows the company’s instantly recognizable Bar & Shield logo, turning the entire record player into the branding rather than simply printing it across the top.
No kickstand appears to be included.
Related Review: Pro-Ject 2Xperience SB Sgt. Pepper Limited Edition Turntable Review
pro-ject-harley-davidson-turntable-top
More Than Harley-Davidson Merch
The important part is underneath all of the Milwaukee cosplay.
Pro-Ject uses an Aluminum-MDF sandwich chassis designed to combine rigidity with internal damping, with the sculpted MDF structure topped by precision-machined metalwork. Polished aluminum, stainless steel and a genuine leather record mat reinforce the motorcycle connection without forcing buyers to sacrifice the fundamentals of a serious turntable. Pro-Ject says the leather mat was selected in part to evoke the material and feel of a traditional motorcycle saddle.
The drive system is substantially more interesting than the branding.
pro-ject-harley-davidson-turntable-side
A diamond-cut aluminum sub-platter sits beneath a heavy 300mm glass platter, while a massive 915-gram Harley-Davidson record puck holds the LP against the platter and adds additional damping. Total moving mass for the drive system is 2.75 kilograms, which Pro-Ject says contributes to improved rotational stability.
The platter is driven by a belt and a synchronous AC motor powered through Pro-Ject’s DC/AC generator. Electronic switching between 33 and 45 RPM means owners won’t have to start moving belts around every time they pull out a 45. The three height-adjustable aluminum feet are damped to help isolate the deck from external vibration and acoustic feedback.
In other words, this thing might look like it belongs next to a Road Glide, but Pro-Ject hasn’t forgotten that the actual job is spinning records accurately.
pro-ject-harley-davidson-turntable-back
The Tonearm Isn’t Decoration Either
Pro-Ject equips the Harley-Davidson Turntable with a hand-polished 8.6-inch S-shaped aluminum tonearm using an SME-style removable headshell, high-purity copper internal wiring and a TPE-damped counterweight.
That detachable headshell is more useful than it might initially appear. Cartridge swapping becomes considerably easier, and Pro-Ject specifically designed the arm to accommodate a wider range of cartridges should owners eventually want to move beyond the supplied model. An adaptive gravity-based anti-skating mechanism changes the effective anti-skating force as the stylus travels across the record.
pro-ject-harley-davidson-turntable-pick-it-pro
A Pro-Ject Pick it PRO moving-magnet cartridge, manufactured in Denmark, arrives installed and adjusted. That’s a sensible choice for getting buyers up and running without turning the first evening into a cartridge-alignment seminar.
And if one of these lands at eCoustics for review, I already know what record is going on first.
Dolly Parton’s Jolene.
Parton died on August 25, 2026, at the age of 80, leaving behind one of the most remarkable catalogs and careers in American music. Hearing “Jolene” come off a glass platter covered by a leather mat on a Harley-Davidson turntable sounds a little absurd when you write it down and somehow completely appropriate.
RIP, Dolly.
Pro-Ject Has Been Here Before
Anyone who follows Pro-Ject knows the Harley-Davidson collaboration didn’t appear out of thin air.
We’ve covered its Metallica Turntable, which used the band’s angular logo as a major structural element and paired it with an aluminum sub-platter, glass platter and removable SME headshell. We’ve also covered the rather less restrained AC/DC Turntable, complete with LED lighting and a wild acrylic tonearm inspired by the band’s lightning-bolt logo.
Then there was the Peanuts 75th Anniversary Turntable, the Elvis Turntable, and the considerably more traditional 2Xperience SB Sgt. Pepper Limited Edition, which we actually reviewed and found to be a legitimate high-end turntable beneath all of the Beatles artwork.
Pro-Ject’s Artist Collection has actually gone much further over the years, including multiple Beatles editions, a Rolling Stones model, Ringo Starr and George Harrison decks, the Vienna Philharmonic, Hard Rock Cafe and other collaborations.
The Harley-Davidson model feels like one of the more natural pairings. Both companies trade heavily on mechanical design, nostalgia, customization and owners who become very attached to the brand. Some of those owners also have enough disposable income to spend $3,299 on a record player that looks like a motorcycle badge.
Funny how that worked out.
What’s Actually Unique?
The biggest difference is that Pro-Ject hasn’t simply taken a conventional rectangular deck and dressed it up for Harley-Davidson. The Bar & Shield silhouette is fundamental to the chassis, while the leather, polished aluminum, stainless steel, heavyweight puck and exposed mechanical elements extend the theme into the materials themselves.
More importantly, the underlying hardware isn’t compromised for the sake of the visual stunt.
The heavy drive system, regulated motor power, aluminum sub-platter, glass platter, adjustable feet, removable headshell and Pick it PRO cartridge give this enough legitimate analog engineering to separate it from the mountain of licensed consumer products designed primarily to sit on a shelf.
Is it expensive? Absolutely. You are paying a significant premium for the industrial design, licensing and scarcity. There are excellent conventional turntables available for $3,299 that don’t arrive wearing a Harley-Davidson tattoo.
But that’s also missing the point.
Nobody considering this wants it to disappear into a rack.
pro-ject-harley-davidson-turntable-high-end-2026
Technical Specifications
  • Drive: Belt drive
  • Speeds: 33 / 45 RPM with electronic speed switching
  • Chassis: Aluminum-MDF sandwich construction
  • Platter: 300 mm heavy glass
  • Sub-platter: Diamond-cut aluminum
  • Total moving drive mass: 2.75 kg
  • Record puck: 915 grams
  • Record mat: Genuine leather
  • Tonearm: 8.6-inch hand-polished S-shaped aluminum
  • Headshell: Removable SME type
  • Effective arm length: 218.5 mm
  • Effective arm mass: 23.8 g
  • Anti-skating: Adaptive gravity-based
  • Cartridge: Pro-Ject Pick it PRO MM
  • Main bearing: Stainless-steel axle in brass bushing
  • Output: 5-pin DIN
  • Included cable: Connect it Phono E 5P/RCA
  • Feet: Three height-adjustable damped aluminum feet
  • Dimensions: 543 x 124 x 437 mm
  • Power consumption: 4W / 0W standby
  • Manufacturing: Made in Europe
harley-davidson-motorcycle-side
The Bottom Line
The Pro-Ject x Harley-Davidson Turntable could easily have become a very expensive piece of licensed memorabilia. It isn’t.
The $3,299 asking price undoubtedly includes a healthy premium for that Bar & Shield logo and the limited-edition status, but the underlying turntable uses legitimate Pro-Ject engineering and some unusually substantial hardware. The custom chassis, 2.75-kilogram moving drive mass, 915-gram puck, aluminum sub-platter, regulated motor system and versatile S-shaped tonearm make this far more interesting than another celebrity record player wearing a fancy paint job.
You can absolutely buy a superb turntable for less.
It just won’t look remotely like this.
And that’s sort of the entire point.
Pricing & Availability
The Pro-Ject x Harley-Davidson Turntable will sell for $3,299 and should arrive in both hi-fi dealer and Harley-Davidson showrooms by mid October 2026. With availability beyond the traditional hi-fi dealer network, the value proposition gets interesting. Put one beside a $40,000 motorcycle inside a Harley showroom and suddenly a $3,299 turntable doesn’t look quite so expensive.
We haven’t been told an exact production quantity, other than quantities will be limited. So waiting could be risky, and another production run is not guaranteed.
In addition, international pricing is set at €2,590 across Europe and £2,299 in the UK.
For more information: project-audio.com
1 Comment
1 Comment
  1. ORT
    August 27, 2026 at 2:39 am
    While I am a big Harley-Davidson enthusiast my younger brother and his wife are even crazier than I am. They used to own 4 Harleys but dropped it to 3 now. I fully expect them to buy another. But, I cannot afford this one so I must pass. I have 3 Beatles ‘tables and am awaiting my 75th Anniversary Peanuts ‘table.
    Pro-Ject makes a high quality product as does Harley.
    ORT
2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle 2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Beck’s $110 Ride Lonesome One-Step uses 24/96 files sourced from analog masters because audiophiles needed something new to argue about.
Playback is now Dual’s exclusive U.S. distributor as the app-controlled CS 629Q clears FCC certification. Is automatic vinyl playback ready for a comeback?
Does Verve’s new 2LP edition of John Coltrane’s Ascension finally offer the definitive vinyl version of his 1966 free jazz landmark?
Is Amy Winehouse’s Back to Black 20th Anniversary Edition worth buying? The 3LP and 3CD sets add unreleased demos and rare 2007 live recordings.
Rhino Rocktober 2026 brings 54 vinyl releases to record stores, including Rhino Hi-Fi and Reserve titles, but many are not entirely new.
Rhino’s Coltrane 100 box spans five labels and 37 tracks on six LPs. Is it worth buying instead of standalone albums?
