LG CineBeam S: Pint-sized 4K UST Projector Goes Up to 100-inches
LG CineBeam S is a compact 4K ultra short throw projector with RGB laser, smart streaming and Dolby Atmos for tight spaces.
LG CineBeam S UST Projector Lifestyle
LG just dropped the CineBeam S, its smallest 4K Ultra Short Throw projector yet, and yes — it’s another so-called “lifestyle” gadget, which increasingly seems to mean “something aspirational that costs more than your first car.” Building on the pint-sized CineBeam Q, the S model promises massive, razor-sharp 4K images (3,840 x 2,160 via pixel shifting) and Dolby Atmos audio, all from a box that looks like it belongs in a Scandinavian design magazine.
LG is pitching it as “Wonder beyond spatial limits,” which is a poetic way of saying it’ll turn your cramped apartment into a surprisingly posh home theater — provided your definition of posh involves spending big on pixels per inch.
The CineBeam S pairs ultra short throw tech with a compact, good-looking design that’s all about saving space without sacrificing screen size. It’s portable enough to move around easily, but still delivers that big-screen feel you want—perfect for anyone juggling limited square footage and lofty entertainment ambitions.
lg-cinebeam-s-pu615u-angle
CineBeam S Design: Compact, Stylish, and Space-Saving for Modern Living
The standout feature of the CineBeam S is its unconventional design. While it borrows some cues from the CineBeam Q, the S takes on a compact cube-like shape. Unlike traditional projectors, its lens doesn’t stick out the front—instead, it’s recessed on the top, allowing it to project light upward at a steep angle. This design is key to its ultra short throw capability, letting it deliver a big image from just inches away from the screen or wall.
Positioned just 3.2 inches (8.1 cm) from the screen or projection surface, this minimalist-designed UST projector delivers bright, detailed images starting at 40 inches diagonally. Move it back to 15.5 inches (39.3 cm), and you’re looking at a generous 100-inch display—all without the bulky setup traditional projectors demand.
Unlike traditional projectors that need long throw distances and complicated mounts, the CineBeam S is a breeze to set up—perfect for tight spaces. Its compact footprint means you won’t have to shuffle furniture or redesign your room just to get the best picture.
lg-cinebeam-s-pu615u-front-screen
When placed 15.5 inches from the screen, the LG CineBeam S creates a 100-inch image.
Color Performance and Light Output: Vivid 4K Visuals with Bright, Accurate Projection
The CineBeam S uses an RGB laser light source that covers 154% of the DCI-P3 color gamut, ensuring precise, vibrant color reproduction that stays true to the creator’s vision.
With 500 ANSI lumens of brightness and a 450,000:1 contrast ratio, it delivers deep blacks and rich, lifelike colors—even in rooms with some ambient light.
Smart Features
The LG CineBeam S fits effortlessly into modern lifestyles, offering features that enhance versatility and ease of use. As a complete home cinema solution, it includes built-in stereo speakers with Dolby Atmos support for immersive, dynamic sound. Running LG’s webOS smart TV platform, it provides easy access to popular streaming services, intuitive controls, and seamless content discovery—all without needing extra devices.
LG CineBeam S WebOS 2024
Users can wirelessly stream content from their smartphone, tablet, or PC using AirPlay 2 and Screen Share, making it simple to share videos, photos, and more without any cables.
Physical Connectivity
Beyond wireless options, the CineBeam S offers physical connections with one HDMI port and two USB Type-C ports, allowing users to hook up external devices easily for a flexible home entertainment setup.
Easy Setup
The CineBeam S makes setup quick and straightforward with Auto Screen Adjustment, delivering sharp, perfectly aligned images in almost any environment. For extra precision, users can tweak visuals without moving the projector using Screen Scaling & Shifting, and adjust for non-white walls with the Wall Color Adjustment feature.
Despite packing powerful projection tech, the LG CineBeam S is ultra-compact—measuring just 4.3 x 6.3 x 6.3 inches (110 × 160 × 160 mm) and weighing 4.19 lbs (1.9 kg), comfortably fitting in one hand. It comes with a redesigned remote that’s sleeker and more intuitive than the CineBeam Q’s, plus support for the LG ThinQ app lets you control the projector right from your smartphone.
From YS Lee, head of IT Business at the LG Media Entertainment Solution Company: “The LG CineBeam S is a testament to our commitment to innovation, and to bringing a truly premium home cinema experience to a wider audience,…This isn’t just a projector; it’s a premium lifestyle solution that combines design and technology excellence to deliver unprecedented flexibility and a new kind of customer value.”
Comparison
LG CineBeam S, CineBeam Q Comparison, and Cinebeam HF85LA Comparison
LG ModelCinebeam S (PU615U)
2025
Cinebeam Q (HU710PB)
2024
CineBeam HF85LA
(2019)
Product TypeMini UST ProjectorMini Lifestyle Standard Throw ProjectorCompact UST Projector
Price $1,299$1,299$1,699
(Discontinued)
Light Source3Ch Laser (R, G, B)3Ch Laser (R, G, B)Laser + Phosphor Wheel
Light Source Life20,000 Hrs20,000 Hrs20,000 Hrs
DLP Imaging Chip.47 inch.47 inchNot Indicated
Brightness500 ANSI Lumens500 ANSI Lumens1500 ANSI Lumens
Contrast Ratio450,000:1450,000:1150,000:1
Color SpaceDCI-P3 154%DCI-P3 154% Not Indicated
HDR Support HDR10, HLG
HDR Tone Mapping: (Auto, Dynamic/frame by frame)
HDR10, HLG–
HGIG ModeYesYes–
HID ModeYesYesYes
Aspect Ratio16:9/Original/Full Wide/4:3/Vertical Zoom16:9/Original/Full Wide/4:3/Vertical Zoom16:9/Original/4:3/Vertical Zoom/ All-Direction Zoom
Resolution4K UHD via pixel shifting4K UHD via pixel shiftingFHD (1920 x 1080)
Refresh Rate60Hz, 50Hz, 24Hz60Hz60Hz
FocusMotorized, AutoMotorized, AutoManual
ZoomFixedDigital ZoomFixed Lens
Projector Offset122.5%100%Not Indicated
Filmmaker ModeYesYes–
MEMCYesYes (Trumotion)Yes (Trumotion)
Throw Ratio0.251.21.4
Horizontal / Vertical Image FlipYesYesYes
Projection Screen Size40 – 100 inches50 – 120 inches–
Easy Setup FeaturesAuto Keystone
Edge Adjustment (4/9/15 Point Warping)
Edge Adjustment(4/9/15 Point Warping)
Manual 4 Corner Keystone
HDMIUp to 4K (4096×2160)Up to 4K (4096×2160)Up to 1080p (1920 x 1080)
HDMI ARCYesYesNot Indicated
HDMI CEC (Simplink)YesYesYes
USB2 x USB-C1 x USB 2.02 x USB 2.0
HDCP2.22.22.2
Audio Output Power4W x 23W x 13W x 2
Surround SoundDolby AtmosDolby Atmos–
LG Sound Sync (with Sound Bar)YesYesYes
Smart TV PlatformWebOS 24webOS 6.0webOS
App StoreYesYesYes
Streaming Service SupportNetflix, Disney+, HBO MAX, Hulu, Prime Video, SHOWTIME, YouTube, Apple TV+, and moreNetflix, Disney+, HBO MAX, Hulu, Prime Video, SHOWTIME, YouTube, Apple TV+, and moreNetflix, Disney+, HBO MAX, Hulu, Prime Video, SHOWTIME, YouTube, Apple TV+, and more
Internet BrowserYesYesYes
Bluetooth YesYesYes
Airplay 2 iOS/Mac Video Casting, Mirroring, Audio StreamingiOS/Mac Video Casting, Mirroring, Audio Streaming–
Fan Noise Energy Savings Max (Eco)25 dB(A)25 dB(A)26 dB(A)
Fan Noise Energy Savings Med27 dB(A)27 dB(A28 dB(A)
Fan Noise Energy Savings Min (Bright)29 dB(A)29 dB(A)30dB(A)
Max Power73W65W140W
Console Dimensions (WHD)110 x 160 x 160mm
135 x 135 x 80 mm
5.3 x 5.3 x 3.14 inches
119.4  x 190.5  x 353.1 mm
4.7 x 7.5 x 13.9 inches
Weight1.9 kg
(4.19 lbs)
1.49 kg
(3.28 lbs)
2.99 kg
(6.6 lbs)
Included AccessoriesManual (Simple Book)
Quick User Guide
Remote Control – Normal
Remote Control Batteries
Warranty Card
Warranty Card
LG Magic Remote
Batteries
Warranty Card
LG CineBeam S UST Projector Lifestyle on table
The Bottom Line
LG’s CineBeam S continues the brand’s tradition of pushing boundaries with compact, innovative projectors that combine style and substance. Known mainly for its OLED and QNED TVs, LG also holds a solid spot in the projector market with the CineBeam lineup. The CineBeam S offers pixel-shift 4K UHD resolution, an RGB laser light source, and smart features ready to stream your favorite content out of the box—all in an ultra-short throw design that lets you park it inches from the wall for a big-screen experience.
That said, with just 500 ANSI lumens, the CineBeam S needs a dark room to shine, and HDR impact is limited compared to brighter projectors or TVs. Its modest 2 x 4-watt speakers don’t quite deliver a full Dolby Atmos punch either. But when stacked against competitors like Hisense, Dangbei, XGIMI, Anker, and TCL, LG’s CineBeam S stands out as the only ultra-short throw model compact enough to fit the lifestyle projector niche without sacrificing key features.
If you want a sleek, space-saving UST projector that blends smart tech and solid 4K visuals—and you can control your lighting—it’s a strong contender in an increasingly crowded field.
Price & Availability
LG CineBeam S (model PU615U) is priced at $1,299 at Amazon and LG.
2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle 2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Priced from $2,300 to $3,800, Hisense C3 lifestyle 4K projectors offer triple laser imaging, up to 5,000 lumens, Dolby Vision and 240Hz gaming.
Available only in 77-inch or 83-inch sizes, LG's upper mid-range OLED TVs for 2026 offer key features found in its flagship OLED models.
The 2026 CEDIA Expo was held last week in Denver and eCoustics was there in force to check out the latest in home theater...
LCD panel costs are rising for Samsung, LG and Sony as Chinese suppliers cut production just as cheaper OLED TVs narrow the price gap.
LG denies its smart TVs continuously record conversations, but ACR, network discovery and advertising data raise larger privacy questions.
The blog DoctorBeet uncovered a disturbing problem with some LG Smart TVs on November 18, 2013. All viewing habits were being to sent to LG’s...
LG announces pricing and availability for its 2026 OLED evo G6 and C6 TVs, featuring brighter panels, new processing, and enhanced gaming performance.
