Fezz Audio Luna Integrated Amplifier Brings Vacuum Tube Heat to the U.S. Without the Cold War Baggage
Fezz Audio Luna brings Polish tube engineering, Toroidy transformers, bold finishes, and modern flexibility to U.S. hi-fi customers.
Fezz Audio Luna Integrated Amplifier Big Calm Maroon Front Angle
Fezz Audio is not some boutique tube brand trying to sell Americans a misty-eyed postcard from Eastern Europe. Designed and manufactured in Poland, the new Fezz Audio Luna Integrated Amplifier arrives in the U.S. through Bluebird Music Distribution as part of a much bigger story: the rise of serious Polish and Eastern European hi-fi brands that are no longer asking for a seat at the table. They’re building the table, wiring it properly, and probably using better transformers while they’re at it.
The Luna is a modern EL34-based tube integrated amplifier with selectable Ultralinear and Triode modes, modular expansion options, HT and Sub Out connectivity, and remote control support; which is not exactly your uncle’s dusty tube amp that needs three candles, a prayer, and a forgiving loudspeaker to behave. It is now shipping in the U.S. at $3,495, which puts Fezz Audio in a very interesting position for listeners who want real tube amplification with modern system flexibility, without pretending that 1962 was the peak of civilization — although it was a very good year for music and cinema.
The Luna is available in Big Calm, Black Ice, Burning Red, EverGreen, Moonlight, Republika, and Sunlight finishes, and several of them are far more striking in person than the spec sheet suggests. EIC Ian White has seen some of Fezz’s finishes firsthand, and apparently nobody in Poland got the memo that former Soviet Bloc colors were supposed to be drab, beige, and emotionally unavailable.
fezz-audio-luna-sunlight-front
Fezz Audio Luna Integrated Amplifier in Sunlight Finish
Toroidal Transformer Technology
At the core of the Fezz Luna is one of the company’s key engineering strengths: toroidal output transformers developed in-house by Toroidy, Fezz Audio’s sister company. That matters because most tube amplifiers still rely on conventional EI-core output transformers, making Fezz’s approach less common and very much part of its identity.
The claimed benefits are lower noise, reduced electromagnetic interference, wider bandwidth, and better control. In practical terms, the goal is not to strip away the warmth people expect from tubes, but to tighten the presentation with cleaner edges, quicker transients, and firmer bass. Tubes with discipline. Poland apparently did not come here to make syrup.
Dual Sonic Character
The Luna provides users the flexibility to tailor sound through selectable operating modes:
  • Triode Mode – This supports a more intimate, harmonically rich presentation with classic tube warmth
  • Ultralinear Mode – The mode supports greater power, dynamic impact, and control
This dual approach allows the amplifier to adapt more easily to different speakers, recordings, and personal preferences. The Luna effectively provides two distinct sonic profiles within a single design.
Amplification
The Luna employs classic EL34 push-pull circuit topology, delivering 40 watts per channel in ultralinear mode and 20 watts per channel in triode mode. Users can easily switch between modes, choosing between the harmonic richness and intimacy of triode operation or the greater dynamics and authority of ultralinear performance. A robust, well-filtered power supply using Torodial transformers ensures stability and consistent operation across a wide range of loudspeakers.
fezz-audio-luna-big-calm-back
Modular Design
Recognizing the needs of modern listeners, the Luna features a modular expansion system that allows users to integrate additional functionality directly into the amplifier. Optional modules include:
This add-on options approach ensures the amplifier remains relevant as system requirements need to be updated, eliminating the need for unnecessary external components.
Connectivity & Control
Unlike many traditional tube amplifiers, the Luna is designed to integrate easily into contemporary audio systems.
Features include:
  • Home Theater Bypass
  • Subwoofer Output
  • Remote Control Operation
This connection and operational flexibility allow Luna not only to serve as a high-performance amplifier but as a centerpiece for a complete audio system.
No Compromise Product Engineering
With its in-house transformer foundation and tighter control over production, Fezz Audio has a real engineering story to tell at this price point. The Luna is not just another tube integrated amplifier in a nice chassis with a glowing glass sales pitch. Its use of Toroidy toroidal output transformers, Polish manufacturing, and modern connectivity give it a more distinctive position in a crowded integrated amplifier market.
The Luna is still a tube amplifier, so expectations should be grounded in what that means: tone, texture, dimensionality, and a more tactile presentation. But Fezz is also aiming for better control, lower noise, and more system flexibility than many traditional tube designs offer. For listeners who want tube character without giving up modern usability, the Luna looks like a smart and credible option. Eastern Europe is no longer knocking. It brought its own soldering iron.
“Fezz Audio has created something truly special with the Luna,” said Jay Rein, president of Bluebird Music. “Its combination of toroidal transformer technology, classic tube topology, and modern usability delivers a level of performance and versatility that stands out in its class.”
Specifications
Fezz Audio ModelLuna
Product TypeVacuum Tube Integrated Amplifier
Price$3,495
Amplifier ClassAB
Maximum Output Power (ultralinear mode)2 x 40 W
Maximum Output Power (triode mode)2 x 20 W
Output Impedance4Ω / 8Ω
Inputs3x RCA
1x DIRECT
Input Impedance50 kΩ
THD(1 kHz at full power): <0,05%
S/N Ratio-82 dB
Input Sensitivity0.7 V
Frequency Response16 Hz – 115 kHz
Damping Factor>20
Tubes4x EL34
3x 12AX7
Bias Adjustment TypeAuto
Subwoofer OutputYes
Equipment Card Slot ExtensionYes – 1
Remote ControlIR Remote
Tube CageYes
Power Consumption170 W (at idle);
250 W (at full power)
Dimensions354 x 420 x 235 mm
13.94 x 16.5 x 9.25 inches
Net Weight20 kg
44 lbs
Available FinishesBig Calm
Black Ice
Burning Red
EverGreen
Moonlight
Republika
Sunlight
fezz-audio-luna-black-ice
Fezz Audio Luna Integrated Amplifier in Black Ice Finish
The Bottom Line
Fezz Audio may not be the loudest Polish hi-fi brand in the U.S. market, but it is one of the more interesting ones, and the Luna Integrated Amplifier gives Bluebird Music another credible piece of Eastern European tube artillery to work with. Between the Equinox Tube DAC with Lampizator Technology, the Evolution series amplifiers, and now the refreshed Luna Vacuum Tube Integrated Amplifier, Fezz is building a real identity around Polish manufacturing, in-house transformer expertise, and tube gear that feels modern without pretending valves were invented last Thursday.
What makes the Luna different is its use of Toroidy toroidal output transformers, its selectable operating modes, and a level of production control that many tube brands at this price do not have. At roughly $3,500, it is not inexpensive, but in the vacuum tube integrated amplifier category, it is not wildly out of bounds either.
The misses are pretty clear. The optional MM phono stage really should have been included, especially in an amplifier aimed at listeners who are likely spinning records. Tubes and vinyl belong together. Charging extra for that feels a little like selling pierogi and billing separately for the sour cream. A built-in headphone amplifier also would have made the Luna more useful for late-night listening and smaller dedicated systems.
The Luna is best suited for listeners who already understand the appeal of tube amplification and want a modern integrated amp for a dedicated two-channel room. It also makes sense for someone with a serious home theater setup elsewhere who wants a separate music-first system with some warmth, texture, and Polish engineering muscle. Add the phono stage if vinyl is part of the plan. And Bluebird Music should absolutely keep bringing more Fezz Audio products into the U.S. market, because this is the kind of brand that makes the category more interesting.
Price & Availability
Fezz Audio’s Luna Integrated Amplifier is Shipping in the USA through the Bluebird Music Dealer Network for $3,495.
Although not confirmed, it is estimated that each add-on module is priced at about $300.
For more information: fezzaudio.com
2026 Steinway & Sons Model O Loudspeaker near wall lifestyle
The $6,500 MOON 371 challenges expensive separates with exceptional sound, serious engineering, and a few surprises. Is this Simaudio’s finest value yet?
Eversolo brings 180 watts of Class AB power while FiiO answers with EL34 tubes and pure Class A. Two Chinese amplifiers, two very different...
Best in Show at T.H.E. Show SoCal 2026: the most impressive high end hi-fi systems, from active speakers to tube powered analog rigs.
Headphones
At AXPONA 2026, Sr. eCoustics Personal Audio Reviewer, W. Jennings, reveals his favorite headphones, portable gear, and high-end audio systems, along with an exciting...
Weiss DAC204-MK2 arrives in the U.S. and Canada with an upgraded ESS DAC, improved jitter control, and a refined analog output stage.
