Essence Earis Premium Personal TV Audio System Targets Clearer Dialogue and Private Hi-Res Listening
Can the $699 Essence Earis Premium deliver clearer dialogue and better personal TV audio than wireless headphones from Sennheiser?
Woman Wearing Earis Premium TV Audio Enhancer
Essence For Hi-Res Audio has introduced the Earis Premium Personal TV Audio System, a wireless personal-audio solution designed for viewers who want clearer dialogue, independent volume control, and a more immersive listening experience without relying on TV speakers, a soundbar, or a conventional two-channel or multichannel system.
Essence, which manufactures HDMI DACs and also represents brands including Amphion, Acoustic Energy, FIBBR, and ATI, is positioning Earis Premium as more than a simple TV listening headset. The system is designed to reproduce dialogue, music, ambience, and movie effects with greater clarity while allowing the listener to control volume without changing the level for everyone else in the room. The Earis Premium receiver provides up to nine hours of battery life and recharges when placed in its transmitter and charging base.
Solving a Problem
Wide-dynamic-range movie and television soundtracks can shift quickly from quiet dialogue to dramatically louder music and effects, often sending viewers reaching for the remote to adjust the volume. Earis Premium takes a different approach by moving the audio system directly to the listener through a personal headset, allowing the user to hear dialogue and other program material at a comfortable level without changing the volume for everyone else in the room.
The Earis Premium is designed for longtime audio enthusiasts whose hearing has changed with age, viewers who have difficulty following dialogue, couples who prefer different listening levels, late-night viewers, and apartment or condominium residents who want high-quality sound without disturbing neighbors. It could also appeal to home-theater owners looking for a personal listening alternative when firing up the full system is impractical—or when they are simply tired of riding the volume control through every quiet conversation and explosive action sequence.
The Wireless Receiver
earis-premium-receiver
The 2-ounce under-chin wireless receiver integrates a Wolfson WM8918 24-bit DAC/headphone amplifier, 14.8 mm moving-coil transducers, 24-bit/48 kHz PCM operation, and dedicated 2.4 GHz wireless transmission. The result is a short, purpose-built signal path designed specifically for personal television audio, rather than relying on conventional Bluetooth headphones or earbuds that were designed to serve a much broader range of listening applications.
By using its own 2.4 GHz wireless connection, Earis Premium is built around the specific requirements of TV viewing, where reliable transmission, dialogue intelligibility, and synchronization between the picture and sound are particularly important.
“Designed and engineered in Germany, Earis Premium impressed me because it did far more than improve dialogue clarity,” said Bob Rapoport, founder of Essence For Hi-Res Audio. “Full range music, ambience, localization, effects and dramatic impact were all preserved. What I heard was the actual Hi Res Audio soundtrack of shows like House of the Dragon; I was immersed in the realism of the production’s sound design in a new and more direct way than my two-channel in-room system could take me. It was addictive.”
Personal Volume and Balance Controls
The Earis Premium provides a rotary volume control along with a separate left/right balance control on the rear of the under-chin receiver, giving listeners direct control over both overall listening level and channel balance.
Independent volume control allows one viewer to listen at a preferred level without forcing everyone else in the room to accept the same setting. The balance control can compensate for differences in hearing between the left and right ears, helping restore a more natural stereo balance and improve image localization.
A single Earis Premium transmitter can also support two headset receivers, making the system practical for couples or two viewers who both want a personalized listening experience.
earis-premium-back
Audio Specification Highlights
The Earis Premium has a stated frequency response of 20 Hz to 16 kHz, with maximum output rated at 122 to 125 dB SPL and latency of less than 47 milliseconds. The DAC section is specified at a 96 dB signal-to-noise ratio and 0.005% total harmonic distortion (THD).
The transmitter accepts 24-bit/48 kHz PCM stereo through its optical digital input and also provides an analog input, allowing the Earis Premium to work with a broad range of televisions and other source components.
You Can Even Add a Subwoofer
Earis Premium can also be used alongside a powered subwoofer. With the main speakers turned down and the subwoofer left active, the headset handles the personal stereo presentation while the subwoofer continues to reproduce the lowest bass frequencies in the room.
That combination gives the listener the clarity and independent volume control of the Earis Premium while preserving some of the physical low-frequency impact of a conventional home-theater system, creating a more full-range personal viewing experience without running the entire speaker system at normal listening levels.
earis-premium-base-back
Earis Premium Personal TV Audio System Specifications:
Essence For Hi-Res Audio Model Earis Premium
Product TypePersonal TV Audio System
Price$699
Maximum OutputUp to 125 dB SPL
Digital Audio InputOptical PCM stereo up to 24bits/48k
Analog Input3.5mm
Microphone Input3.5mm
Modulation method PCM Analog-over-digital
Transmission Carrier frequency2.4 GHz~2.5 GHz
Signal-to-Noise Distance-87 dB
Transmission Power10 dBm
Audio latency< 47 ms
Transmission Range> 70 m
Temperature Range0 °C to 45 °C
Power Supply5 Volt DC / 1.5 A
Power Adapter 100-240 Volt 50-60 Hz 300mA
Stethoset receiver
Harmonic Distortion 1kHz<1% at 500mVrms
Frequency Response20 Hz – 16 kHz
Sound Pressure Level (SPL)122 dB SPL at Input=1KHz/500mVrms
Earpad Material Silicone rubber
Power Supply 3.7V 400mAh, Lithium-polymer rech. battery
Running Time Per Charge9 hours
Charging time 2 hours
Weight (battery incl.) 61 g
Dimensions (mm) 244 x 112.5 x 24
Operating Temperature Range 0 °C – 45 °C
Pocket receiver
Connection 3.5mm stereo jack socket, 16 Ohm minimum
Power supply 3.7V 400mAh, Lithium-polymer rech. battery
Running Time Per Charge 9 hours
Charging Time 2 hours
Weight (battery incl.) 41 g
Dimensions (mm) 63 x 24 mm
earis-premium-charging
The Bottom Line
The Earis Premium is not the first wireless TV listening system, but its combination of a 2-ounce under-chin receiver, dedicated 2.4 GHz transmission, 24-bit/48 kHz PCM playback, independent volume and balance controls, support for two receivers, and the unusual ability to integrate with a powered subwoofer gives it a more audiophile-oriented spin on the category.
There are compromises. The Earis Premium is a stereo-only system with no Dolby Atmos or spatial-audio support, and its digital connectivity is limited to optical PCM rather than HDMI/eARC. At $699, it also costs considerably more than several Sennheiser TV-listening systems. Sennheiser remains the most obvious competitor, with models such as the RS 255 and RS 275 selling for well under $300, while products such as the RS 195 have established the brand in personalized TV listening and dialogue enhancement.
For viewers who primarily want a cheaper way to hear dialogue more clearly, Sennheiser offers plenty of alternatives. Earis Premium makes more sense for listeners who also care about music, stereo imaging, independent control, and getting closer to a full-range personal home-theater experience without turning on the entire room system.
earis-premium-package
Price & Availability
The Earis Premium is priced at $699, with U.S. shipping beginning August 25, 2026, directly from Essence For Hi Res Audio.
2026 Fosi Audio DAP Neo in pocket
DAPs
The $80 Fosi Audio DAP Neo delivers iPod nostalgia, lossless playback, Bluetooth and expandable storage. Can it win over the streaming generation?
2026 JMGO Iris Ultra Projectors 2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle 2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
Apple TV is adding Dolby Atmos to Formula 1 beginning with the 2026 U.S. Grand Prix, creating a serious 4K Dolby Vision home theater...
Priced from $2,300 to $3,800, Hisense C3 lifestyle 4K projectors offer triple laser imaging, up to 5,000 lumens, Dolby Vision and 240Hz gaming.
Priced from $1,999 to $2,699, Epson's new line of 4K home theater projectors feature 120Hz gaming, laser light source, and brightness from 2500 to...
Is it possible for a $60 Bluetooth speaker to improve your TV's sound? IKEA’s BADKRUKA adds optical input, stereo pairing, 25W output and Spotify...
How big is the U.S. smart home market? CEDIA says $33.8 billion, with networking, distributed audio and lighting leading the business.
Can Sonos 27 make existing speakers more useful with AI control, portable rear surrounds and direct Wi-Fi headphone linking?
