Cambridge Audio Melomania A100 SE Wireless Earbuds Add Dolby Audio and Refined Tuning
2026 Cambridge Audio Melomania A100 SE Wireless Earbuds in hand Blue
Cambridge Audio is updating its true wireless earbud lineup for 2026 with the Melomania A100 SE, a new Special Edition version of its affordable Melomania A100 Wireless Earbuds featuring Dolby Audio, refined sound tuning, and several targeted upgrades rather than an entirely new design.
When the original Melomania A100 arrived in 2025, it caught our attention as a surprisingly affordable alternative to Apple’s AirPods and other premium wireless earbuds. Instead of replacing a model that still has plenty of life left in it, Cambridge Audio has taken the more sensible route for 2026: keep what worked, adjust the tuning, add new features, and keep the price where it was.
cambridge-audio-melomania-a100-se-earbuds-case-black
What’s New with the Melomania A100 SE?
The biggest upgrade to the Melomania A100 SE is the addition of Dolby Audio with Spatial Audio, accessible through the Melomania Connect App (iOS, Android). Cambridge Audio says Dolby Audio is designed to deliver a more immersive listening experience while also improving vocal and dialog clarity.
Pro Tip: Although Dolby Audio is being positioned as one of the key upgrades, Cambridge Audio has confirmed that Dolby Atmos is not supported as part of the feature set.
A second, less obvious and decidedly more low-tech change involves the earbud grilles. Cambridge Audio says the mesh is now less restrictive, allowing for greater treble “airiness.” The company has also revised the overall tuning, promising deeper bass, a richer midrange, and clearer highs compared with the original A100.
Cosmetically, the A100 SE adds a new Blue finish alongside the Black and White options already offered with the A100.
cambridge-audio-melomania-a100-se-earbud-colors
What Has Cambridge Audio Carried Over?
Much of the underlying hardware from the original A100 carries over to the Melomania A100 SE, including the same Class A/B amplification architecture. Cambridge Audio also uses Class A/B amplification in its CX and EX Series components.
The amplifiers are paired with precision-tuned 10mm neodymium drivers, while a dedicated dual-core 240MHz Qualcomm Kalimba DSP handles additional signal processing and is designed to reduce distortion.
Snapdragon Sound also returns, providing support for robust, low-latency wireless connections for music, gaming, and movies. The A100 SE supports 24-bit/96kHz audio, along with aptX Lossless, LDAC, AAC, and SBC.
The six-microphone array, with three microphones in each earbud, has also been carried over from the A100 to support voice calls and background noise isolation.
Like its predecessor, the A100 SE offers up to 39 hours of total battery life, wireless and USB-C charging, Adaptive Hybrid ANC, and IPX5 water resistance.
The A100 SE also retains customizable touch controls on each earbud, allowing users to configure playback and other functions through the Melomania Connect App.
cambridge-audio-melomania-a100-se-earbuds-in-ear-blue
Comparison
Cambridge Audio ModelMelomania A100 SE (2026)Melomania A100 (2025)
Product TypeWireless EarbudsWireless Earbuds
MSRP$149$149
Amplification Class A/B amplification Class A/B amplification
Driver 10mm driver with  recycled neodymium magnets 10mm driver with recycled neodymium magnets
Dolby AudioYes –
DynamEQ YesYes
Adjustable EQ 7-band EQ via Melomania Connect App7-band EQ via Melomania Connect App
Bluetooth Ver 5.4Ver 5.4
Bluetooth MultipointYesYes
Supported profiles A2DP, AVRCP, HFP A2DP, AVRCP, HFP
Supported codecs LDAC, aptX Lossless, aptX Adaptive, AAC, SBC LDAC, aptX Lossless, aptX Adaptive, AAC, SBC
Google Fast Pair Yes Yes
Low latency Under 80ms with Gaming Mode via Melomania Connect App Under 80ms with Gaming Mode via Melomania Connect App
Processor Qualcomm QCC3091Qualcomm QCC3091
Application subsystem Dual-core 32-bit processor, up to 80MHz Dual-core 32-bit processor, up to 80MHz
Audio subsystem Dual-core 240 MHz configurable Qualcomm Kalimba DSPDual-core 240 Mhz configurable Qualcomm Kalimba DSP
AppMelomania Connect Melomania Connect
Firmware Upgradable via Melomania Connect Upgradable via Melomania Connect
Wear detect Yes, capacitive detection Yes, capacitive detection
Noise cancelling Qualcomm Adaptive Active Noise Cancellation Qualcomm Adaptive Active Noise Cancelling
Transparency mode Yes Yes
Wind noise reduction Yes Yes
Microphones 6 microphones, 3 per earbud 6 microphones, 3 per earbud
Voice processing 3-microphone Qualcomm cVc Echo Cancelling and Noise Suppression (ECNS) 3-microphone Qualcomm cVc Echo Cancelling and Noise Suppression (ECNS)
Voice assistant Siri, Google Assistant Siri, Google Assistant
Playtime Up to 39 hours Up to 39 hours
Playtime (ANC on) Up to 21 hours Up to 21 hours
Charging time 1.1 hours 1.1 hours
Fast charge 10 minutes gives 3.2 hours of playback (ANC off) 10 minutes gives 3.2 hours of playback (ANC off)
Charging USB-C, wireless charging (Qi-compatible but not certified) USB-C, wireless charging (Qi-compatible but not certified)
ColorsBlack, White, BlueBlack, White
Dimensions  (Earbuds)33.59 x 23.72 x 21.98 mm
1.32 x 0.933 x 0.86 inches
Dimensions  (Charging Case)60.99 x 24.60 x 44.89mm
2.04 x 0.97 x 1.77 inches
Weight (Earbuds) 4.7g each / 0.1661oz 4.7g each / 0.1661oz
Weight (case) 38.7g / 1.365oz 38.7g / 1.365oz
Weight (total) 48.1g / 1.70oz 48.1g / 1.70oz
What’s In The BoxA100 SE Wireless Earbuds
USB-C to USB-C charging cable
3 x silicone eartips (S, M and L)
Quick Start Guide
Function controls card
Brand booklet
Safety instructions
Quick Start Guide
Brand booklet
Safety instruction
cambridge-audio-melomania-a100-se-case-colors
The Bottom Line
The original Cambridge Audio Melomania A100 already offered an unusually strong feature set for $149, including Class A/B amplification, LDAC and aptX Lossless support, Adaptive Hybrid ANC, Multipoint Bluetooth, wireless charging, customizable EQ, and IPX5 water resistance.
The new Melomania A100 SE does not represent a major generational leap, but it does build on that foundation with revised acoustic tuning, a less restrictive grille design, and a new Blue finish. What remains distinctive at this price is the combination of Class A/B amplification with both LDAC and aptX Lossless, which is still uncommon among true wireless earbuds selling for $149.
cambridge-audio-melomania-a100-se-earbuds-blue-lifestyle
Price & Availability
The Cambridge Audio Melomania A100 SE is available at cambridgeaudio.com and Authorized Retailers for $149.
The Cambridge Audio Melomania A100 – $149 $99 at Amazon
Gaming Headsets
Swappable batteries, dual wireless connectivity, and spatial audio promise plenty. But does this $400 gaming headset deliver?
Dongle DACs
Questyle's QCC Dongle Pro2 brings LDAC, Bluetooth 6.1, and low-latency gaming to more devices. Is the wireless upgrade worth its compromises?
Developers have found a way to restore Dolby Atmos height effects from Blu-ray soundtracks on Apple TV 4K. It's an impressive technical achievement, but...
The tragic death of an Arizona mother raises an important question about ANC headphones, outdoor exercise, and personal safety. Sometimes hearing what's happening around...
Bose acquires Skullcandy after their Sound by Bose partnership. Here's why the deal matters for headphones, McIntosh, Sonus faber, and the audio industry.
Sennheiser's flagship wireless earbuds for 2026 deliver warm sound, capable ANC, and replaceable batteries. At $299, can they compete with Sony's best?
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
