NUR Headphones Debut at AXPONA 2026: Italian Craft Meets High-End Sound in Mimic Audio Showcase
NUR Audio’s Harmonia, Shanti, and Miah headphones impress at AXPONA 2026, delivering distinct tuning and serious promise from an emerging Italian brand.
Nur Audio Harmonia Headphone at AXPONA 2026
Among the global brands at AXPONA 2026, Mimic Audio did not have the biggest booth or the loudest presence, but it ended up being one of the more worthwhile stops in the EarGear section. The Chicago dealer, owned by TJ Cook, was positioned between Campfire Audio and Austrian Audio and only a few steps from the always swamped ZMF booth, which made it easy to overlook in the rush. That would have been a mistake. Mimic first caught my attention before the show when it supplied the AudioByte components for the Von Schweikert pre-event, paired with NUR Audio’s Harmonia.
My initial listen there was promising, but with the Von Schweikert VR.thrity or Ultra 7 commanding the room and the Harmonia’s open-back design letting all of that noise pour in, it was impossible to draw more than a few early conclusions. That made a return visit at AXPONA essential, where I sat down with all three NUR models on display for a longer listen and a better sense of what this Italian headphone brand is actually bringing to the table.
nur-harmonia-headphones-side
NUR Audio Headphones: Italian Design, Planar Magnetic Ambitions
NUR Audio is not some legacy brand trading on decades of goodwill. It was founded just northeast of Rome by Angelo De Mattia and feels very much like a passion project finding its footing in a crowded category. Right now, the Harmonia open back is the only model you can actually buy, priced at $3,750, while the Shanti open-back reference and Miah closed back are still listed as coming soon with pricing to be determined. That split matters because NUR is already drawing a line between audiences. The Harmonia is built for listening at home, while the Shanti and Miah mark the start of a professional series aimed at engineers who need precision more than romance.
The two open-back designs share a lot of DNA. Similar materials, similar construction, and very similar planar magnetic drivers. The Miah goes a different route with a dynamic driver inside a closed back design, which should make it the more practical option for studio work or less than ideal environments. All three, however, are physically imposing. Think Audeze LCD-4 sized ear cups and the kind of weight that can turn a long session into a short one if the ergonomics are off. Early impressions suggest NUR understands the problem. The suspension system is well padded, the clamp feels reasonable, and the weight distribution does not immediately raise red flags.
nur-harmonia-headphones-angle-headband
The real test, as always, will be whether that comfort holds up after a few hours rather than a few tracks.
Using the AudioByte stack (more on that soon), I was able to spend time with all three NUR models and come away with a clearer sense of how each is voiced. With both the Shanti and Miah still in prototype form, nothing here should be considered final, but the direction is already apparent.
The NUR Harmonia is a large-format open-back planar magnetic headphone built around a 105mm PEEK diaphragm and a double-sided toroidal magnet system using high-grade N52 neodymium magnets. That combination is designed to deliver fast transient response, low distortion, and wide bandwidth, which is reflected in the rated 8Hz to 55kHz frequency response.
nur-harmonia-headband
With a 48 ohm impedance and 107 dB/mW sensitivity, it should be relatively easy to drive for a planar of this size, though it will still benefit from a capable amplifier. The dual 3.5mm cup connections allow for balanced operation out of the box, with either 4.4mm or XLR cables included, along with a 6.35mm adapter for single-ended use. At 630 grams, it is firmly in the heavyweight category, making the suspension system and overall ergonomics critical for longer listening sessions.
The Harmonia leans toward a clean, controlled presentation with a touch of warmth that you don’t always get from planar magnetic designs. Bass has solid presence without sounding pushed, the midrange comes across as slightly lush with very good detail retrieval, and the treble extends well past what my ears are willing to admit at this point. It strikes a balance that feels intentional rather than trying to impress on first listen.
The Shanti prototype shifts gears toward a more analytical presentation. It is crisper, more forward in its detail, and less forgiving overall. The name was a bit of a clue, but the tuning confirms it. This feels like the model aimed squarely at those who want to dissect recordings rather than relax into them.
The Miah, as the closed-back option, moves in a different direction. It is warmer and a bit thicker sounding than the two open-back models, which is not surprising given the design. Detail is still present across most of the range, but the top end has slightly less extension and sparkle. That trade-off is typical for closed-back headphones, especially ones that appear to be targeting studio use rather than chasing an artificially boosted sense of air.
The Bottom Line
I came away impressed enough to spend a good amount of time talking with TJ Cook about getting all three NUR models in for proper review once they hit the market. That says more than any quick show impression. AXPONA has no shortage of big names pulling crowds, and it is easy to fall into the trap of chasing logos instead of sound. The problem is that you end up walking right past booths like Mimic Audio and missing some of the more interesting listens of the weekend.
The NUR lineup, paired with the AudioByte components, proved to be far more than a curiosity. It was one of those setups that rewarded anyone willing to sit down, block out the noise, and actually listen. Not perfect, not finished in two cases, but clearly headed somewhere worth paying attention to.
Expect a deeper dive once review samples land. In the meantime, NUR Audio is a brand to keep on your radar, and if you happen to be in the Chicago area, Mimic Audio is absolutely worth a visit.
Where to buy: $3,750 at Mimic Audio
1 Comment
1 Comment
  1. TJ
    April 22, 2026 at 7:21 pm
    Thanks for the kind words and support! It was a blast meeting you and looking forward to chatting more into the future.
2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle 2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Over-Ear Headphones
The best eCoustics stories from July 2026, including Wharfedale, Hisense, CanJam London, Rhino vinyl, home theater and AI music.
Headphones
Help Capra Audio rebuild after devastating West Virginia floods. Donate or share the GoFundMe, now at about $19,000 of its $30,000 goal.
These 8 new headphones and IEMs have us curious in 2026, from Sony’s 1000X ANC flagship to Final, Meze, HiFiMAN, Audeze and Noble.
Can HIFIMAN’s $1,899 HE6 Remastered revive a planar icon with a lighter headband and the same serious amplifier demands?
Over-Ear Headphones
Can THIEAUDIO's $399 Cypher open-back headphone challenge the HD600 with deeper bass, wider imaging, and more detail without sacrificing natural tone?
Podcasts
Hi-Fi Bear reveals what makes T10 Bespoke's in-ear computers so special with eCoustics Podcast Producer Mitch Anderson who tries them for the first time.
